Manage Fraud Protection Lists
Edit a Fraud Protection List
- Expand the Fraud Protection Manager slider, and click Fraud protection list.
 - In the FPL management tab, select an existing FPL from the FPL table and click Edit.
In the
			 Edit
				FPL dialog box, modify the following applicable fields:
Name (Read-only) The unique FPL name that is used by SDM to identify the FPL. There must be no space before, within, or after the name you enter. The first character must be alphabetic. A dash (-) and an underscore (_) are supported. A space cannot precede or trail the name. Description The FPL description. Device file name The FPL file name that exists on the southbound device. Realm originated from This field cannot be edited unless the referenced device is no longer available. If the device is no longer available, click the ellipses (...) button. In the Select managed device dialog box, navigate the folder hierarchy to the southbound device from which the realm originates.
 - Click OK.
Manage a Fraud Protection List Entry
 - In the FPL management tab, select the FPL to which you want to make changes from the FPL table and click Manage.
In the
			 Modify
				FPL pane, select from the following FPL entry tabs, and click
			 Add to add an entry:
- Black list
 - White list
 - Rate limit
 - Call redirect
In the dialog box
			 for the above FPL entry, the following parameters are retrieved dynamically
			 from the ingress realm of the southbound device associated with the FPL:
Data Type The data type of the Session Initiation Protocol (SIP) to or from header, or SIP user-agent header. See the Fraud Protection List Data Types section for more information about valid data type parameters. Match value The exact match value that corresponds to the data type. For example, the match value could be a type of data such as a phone number prefix, source or destination IP address. See the Fraud Protection List Data Type Formats section for more information on the formats required for this parameter. Ingress realm Select to change the ingress realm instance, which is specified on the southbound device, from the drop-down list. Realm instances are obtained from the southbound device. The southbound device uses this parameter to route traffic. Refer to your device documentation for more information about ingress realms. Calls per second (Rate limit only) The number of call attempts per second from 0 to 65535. Enter zero for unlimited call attempts. Max active calls (Rate limit only) The maximum number of simultaneous active calls from 0 to 65535. Enter zero for unlimited active calls. Redirect target (Call redirect only) The SIP redirect server which can be identified by using any one of the following values: session agent, session agent group name, hostname, or IP address.  - Click OK to finish adding the entry to the FPL entry.
Edit a Fraud Protection List Entry
In the
			 Edit FPL
				entries pane, select from the following FPL entry tabs, select an
			 entry, and click
			 Edit.
Refer to the Fraud Protection List Type Entries section for more information about the following FPL types:
- Black list
 - White list
 - Rate limit
 - Call redirect
In the edit list
			 dialog box, edit the following fields.
Data type drop-down list The data type of the Session Initiation Protocol (SIP) to or from header, or SIP user-agent header. See the Fraud Protection List Data Types section for more information about data type parameters. Match value field The exact match value that corresponds to the data type. For example, the match value could be a type of data such as a phone number prefix, source or destination IP address. See the Fraud Protection List Data Type Formats section for more information on the formats required for this parameter. Realm drop-down list You must first click the drop down-list arrow first to select the name of the SIP realm that is configured on the device. The SIP realm is associated with the match value. If the realm for which you are looking does not appear in the drop-down list, you can then type this realm name in the field. Calls per second field (Rate limit only) The number of call attempts per second from 0 to 65535. Enter zero for unlimited call attempts.
Max active calls field (Rate limit only) The maximum number of simultaneous active calls from 0 to 65535. Enter zero for unlimited active calls.
Redirect target field (Call redirect only) The SIP redirect server which can be identified by using any one of the following values: session agent, session agent group name, hostname, or IP address.
 - Click OK.
Copy a Fraud Protection List Entry
You can copy values from one Fraud Protection List (FPL) entry to build a new entry.
In the
			 Modify
				FPL pane, choose from the following FPL entry tabs, select an
			 entry, and click
			 Copy:
- Black list
 - White list
 - Rate limit
 - Call redirect
In the copy list
			 dialog box, edit any of the following fields that you are copying.
Data type drop-down list The data type of the Session Initiation Protocol (SIP) to or from header, or SIP user-agent header. See the Fraud Protection List Data Types section for more information about data type parameters. Match value field The exact match value that corresponds to the data type. For example, the match value could be a type of data such as a phone number prefix, source or destination IP address. See the Fraud Protection List Data Type Formats section for more information on the formats required for this parameter. Realm drop-down list The name of the SIP realm that is configured on the device. The SIP realm is associated with the match value. Calls per second field (Rate limit only) The number of call attempts per second from 0 to 65535. Enter zero for unlimited call attempts.
 - Click OK.
View Fraud Protection List Entry Information
 - In the FPL management tab, select the FPL for which you want to view entries from the FPL table and click Manage.
In the
			 Modify
				FPL pane, you can view the following table columns for each FPL
			 Black
				list,
			 White
				list,
			 Rate
				limit, and
			 Call
				redirect entry tab:
Data type The data type of the Session Initiation Protocol (SIP) to or from header, or SIP user-agent header. See the Fraud Protection List Data Types section for more information about data type parameters. Match value The exact match value that corresponds to the data type. For example, the match value could be a type of data such as a phone number prefix, source or destination IP address. See the Fraud Protection List Data Type Formats section for more information on the formats required for this parameter. Realm The name of the SIP realm that is configured on the device. The SIP realm is associated with the match value. Calls per second field (Rate limit only) The number of call attempts per second from 0 to 65535. Enter zero for unlimited call attempts.
 - (Optional) Click Refresh to refresh the Fraudulent list table contents in each FPL Black list, White list, Rate limit, and Call redirect entry tab.
Search Fraud Protection List Entry Information
Refer to the Fraud Protection Manager Search Filters section for more information on filtering when you use a search criteria.
 - In the Modify FPL pane, select Search in the Black list, White list, Rate limit, or Call redirect entry tab.
 - (Optional) In the Fraudulent list table, click Search to search the contents in each FPL Black list, White list, Rate limit, and Call redirect entry tab.
 In the
			 Search
				criteria dialog box, complete the following fields.
Data type drop-down list The data type of the Session Initiation Protocol (SIP) to or from header, or SIP user-agent header. See the Fraud Protection List Data Types section for more information about data type parameters. Match value field The exact match value that corresponds to the data type. For example, the match value could be a type of data such as a phone number prefix, source or destination IP address. See the Fraud Protection List Data Type Formats section for more information on the formats required for this parameter. Realm field The name of the SIP realm that is configured on the device. The SIP realm is associated with the match value. Calls per second field (Rate limit only) The number of call attempts per second from 0 to 65535. Enter zero for unlimited call attempts.
 - Click OK.
Delete a Fraud Protection List Entry
In the
			 Modify
			 entry, and click
			 Delete:
- Black list
 - White list
 - Rate limit
 - Call redirect
 - In the confirmation dialog box, click Yes.
Unassign a Fraud Detection and Prevention Device from a Fraud Protection List
 - In the FPL management tab, select an FPL from the FPL table and click Un-assign.
 - In the confirmation dialog box, click OK.
View Fraud Protection List Information
In the
			 FPL
				management tab, you can view the following Fraud Protection List
			 (FPL) column information:
Name The unique FPL name. Description (Hidden) The user-specified description of the FPL. Device file name (Hidden) The name of the xml file which is defined and used by SDM when the FPL is pushed to the device. Ingress realm originated from (Hidden) The southbound device target name whose realm configuration instances are the choices for the ingress realm of any entry in a blacklist, white list, rate limit, and call redirect. Creation date The last date and time that the FPL was added. Modified date The last date and time that the FPL was modified. Status The FPL status, which is either in the Updated successfully or Failed reconciliation state. Assigned The name of the registered fraud detection device (FDP) that is assigned to the FPL.  - (Optional) Click Refresh to refresh the FPL management tab table contents.
(Optional) Click
			 FPL
				managementtab table contents. In the
			 Search
				criteria dialog box, you can search using the criteria:
Name The FPL name. Device file name The FPL file name of the southbound device. Creation date field Click the calendar icon to select the date and time for when the FPL was created. Modified date field Click the calendar icon to select the date and time for when the FPL was modified. Status drop-down list Select the status of the FPL on which you are searching: Success, Updated successfully, or Failed reconciliation. Assigned The name of the registered fraud detection device (FDP) that is assigned to the FPL.
Search for a Fraud Protection List
 - In the FPL management tab, click Search.
In the
			 Search
				criteria dialog box, complete any of the following fields to create
			 a search criteria:
Name field The unique FPL name that is used by SDM to identify the FPL. There must be no space before, within, or after the name you enter. The first character must be alphabetic. A dash (-) and an underscore (_) are supported. A space cannot precede or trail the name. Device File name field The FPL file name. Creation date field Click the calendar icon to select the date and time for when the FPL was created. Modified date field Click the calendar icon to select the date and time for when the FPL was modified. Status field Select from the following FPL status search options: - Success
 - Updated successfully
 - Failed reconciliation
 - In Progress
 - Copy in Progress
 - FDP Update in Progress
 - FDP Update Failed
 - Export in Progess
 - Export Failed
 - Import in Progress
 - Import Failed
 - Upload in Progress
 - Upload Failed
 - Failed
Assigned field The name of the registered fraud detection device (FDP) that is assigned to the FPL.  - Click OK.
 - In the FPL management tab, select the FPL and click Delete.
In the confirmation
			 dialog box, click
			 OK.
An FPL cannot be deleted if it is currently associated with a Fraud Detection and Prevention (FDP) device or with a push task.
