Manage the Fraud Protection List Archive
Use the following tasks to specify a Fraud Protection List (FPL) backup schedule for one or more devices and use FPL archive file to restore or seed a new FPL.
Refer to Security Manager Applications tab if you need to change your user group privileges to allow you to manage the telephony fraud archive.
Backup a Fraud Protection List Now
You can backup a Fraud Protection List (FPL) when ever you want, on-demand.
- Expand the Fraud Protection Manager slider and click Archive.
- Click the Schedule tab, select a backup schedule and click Back Up Now.
Restore a Fraud Protection List Backup
The Archive tab displays all of the FPL files that have been archived, whether manually, or as a result of a scheduled backup.
The purge policy or existing Fraud Protection List (FPL) backups are not affected when a backup is restored for a device.- Expand the Fraud Protection Manager slider and click Archive.
- Click the Archive tab, select a backed up FPL file from the FPL Archive File table, and click Restore.
- In the confirmation dialog, click Yes to restore the backed-up configuration.
Search the Fraud Protection List Archive
Use this task to search the FPL archive for a list of existing Fraud Protection List (FPL) archive (backup) files.
Refer to the Fraud Protection Manager Search Filters section for more information on filtering when you use a search criteria.
