Configure a Fraud Protection List Backup Schedule
You can schedule the automatic backup of Fraud Protection List (FPL) on a device to be run once, daily, weekly, or monthly.
Add a Fraud Protection List Backup Schedule
- Expand the Fraud Protection Manager slider and click Archive.
 - Click the Schedule tab, click Add Schedule.
In the
			 FPL Archive
				Schedules pane, complete the following fields:
Schedule drop-down list Select from the following options to set the type configuration backups for devices: - Schedule—Select to schedule a date and time and make the configuration backup available on an on-demand basis.
 - On Demand—Select to
The parameters described below are unavailable if you choose this option.
Frequency drop-down list Select from the following options to set the frequency of configuration backups for devices: - None—Select to not repeat a scheduled backup.
 - Daily—Select to perform daily backups.
 - Weekly—Select to perform weekly backups.
 - Monthly—Select to perform monthly backups.
Schedule drop-down list Select a start date using the calendar icon. Start time drop-down list Select a start time in a 24-hour cycle.  - Click Add.
 - In the Select Device dialog box, choose the device or device group in the Managed devices pane for which you want to schedule a backup, and click Add to move it to the Targeted devices pane.
Click
			 OK.
The targeted device for scheduled configuration backups appears in the Devices table.
 - Click Apply to complete the backup schedule for the device.
