Manage Fraud Protection Push Task Updates
Edit a Fraud Protection List Push Task
A push task can only be modified if its status is either PartiallyConfigured or NotScheduled.Commit a Fraud Protection List Push Task Manually
A Fraud Protection List (FPL) push task can be committed manually if the Auto commit checkbox is not checked in the FPL push task configuration pane.
- Expand the Fraud Protection Manager slider and click Fraud protection list.
 - Click the Device association tab and select an FPL push task from the FPL push tasks table and click Commit.
 - In the confirmation dialog box, click Yes.
 - Click Refresh to confirm the FPL push task status changed from Success to Committed.
Update Fraud Protection List Changes Manually When Automatic Updates are Enabled
When the Fraud Protection Manager is configured to automatically push notifications to devices, any user changes made to a Fraud Prevention List (FPL) are delivered to the devices on the next incident reported by the FDP that is registered to the FPL.
- Stop the automation on the current FPL push task.
 - Click the Device association tab, select the Fraud Protection List (FPL) that you want to modify and click Edit.
 - Make the necessary changes to the FPL.
 - In the
		  Edit FPL push
			 task configuration pane, set the
		  Task
			 type drop-down list to
		  On
			 demand.
This pushes your FPL changes to the device.
 - Create a new automatic FPL push task once the manual push task completes. For details on creating an FPL push task, see "Add a Fraud Protection List Push Task".
Stop Fraud Protection List Push Task Updates
Until the FPL push task is committed, you can stop it and perform a rollback to restore the original configuration settings if the push task is in a WaitStarting, Failed, Success or Scheduled state.
 - Click the Device association tab, and select the FPL push task that you want to roll back from the FPL push tasks table and click Abort.
Copy a Fraud Protection List Push Task
When a Fraud Protection List (FPL) push task is executed successfully, it cannot be modified, which includes adding devices. However, you can copy an existing FPL push task and save it as a new FPL push task. The new FPL push task can then be applied to a different set of devices. Copies of an FPL push task can be used to divide large numbers of devices into smaller groups of devices that repeat the same push task.
Resubmit a Device Group Push Task
You can resubmit a push task to start execution for the targeted device group network function (NF) if the status of the push task is in the Failed, ResetToReady, or RollbackFailed state.
You must wait for the running push task to complete before you can resubmit it. A warning appears if you try to resubmit a push task that is currently running.- Expand the Fraud Protection Manager slider and click Fraud protection list.
 - Click the Device association tab to access the Fraud Protection List (FPL) push task information.
 - In the Device group tasks table, select the push task row and click Resubmit.
View Device Group Push Tasks
The Device group tasks table displays a summary of a the best-effort device tasks that are launched or scheduled to be launched in parallel for the selected push task in the Fraud Protection List (FPL) push tasks table.
Oracle Communications Session Delivery Manager (SDM) uses a prefix name plus the name of the applied FPL configuration XML file as the compressed file name that is pushed to the device to replace the FPL file on the device. The syntax of the file is as follows:OCSDM_<globalID>_<FPLFilename>.xml.gz,
			 where the
			 globalID is the unique
			 global identifier that is specified during the SDM installation, and the FPL
			 file name. For example, OCSDM_EastCluster_FPLConfig.xml.gz.
		  Search for a Fraud Protection List Push Task
Refer to the Fraud Protection Manager Search Filters section for more information on filtering when you use a search criteria.
Delete a Fraud Protection List Push Task
A Fraud Protection List (FPL) push task can be manually deleted only if it is in the PartialConfigured, NotScheduled, Aborted, or Committted state.
 - Click the Device association tab, and select the FPL push task from the FPL push tasks table and click Delete.
