previous
Running and Maintaining the OXI_HUB Interface
Example:  The OXI_HUB main menu bar.
OXI_HUB Message Status
From main menu select Interface Status>Message Status. This screen is the vital part for a running interface and will be reviewed often to identify failed messages or other transmission problems. You will use it to view the status of transmitted messages and to review details of the XML messages. All errors and warnings that occurred during message processing are visible and traceable here. A message can also be reprocessed after configuration errors have been corrected.
Example: Message Status screen after entering. Auto Refresh and Auto display XML parameters have been activated for this sample screen shot.
Message Flow from ORS to external system
  1. The OXI_HUB monitor process calls an ORS API to get the next available business event for a particular interface ID
  2. The monitor process calls an OXI API to process the business event.
  3. The OXI_HUB API calls the necessary OXI/OPERA APIs to process the business event, generates XML message, and writes the processed information into the OXI out queue.
  4. External System Interfaces listen on this queue and retrieves messages as and when they are available.
Statistics
This screen displays all messages that have been generated from the ORS or OPERA PMS systems and their current status of being processed. The Statistics screen is broken into four areas for the users ability to see how the ORS or OPERA PMS’s business events are being processed. Also what the status is of those transmitted messages. (Sample screen shot above.)
Process flow of messages from ORS to external systems:
Action is done in ORS or OPERA PMS, which is sent to OPERA Business Events In Queue then moves to OPERA Business Events Out Queue>OXI_HUB In Queue>OXI_HUB Out Queue then messages go to external systems.
OXI_HUB XML Out Queue
This out queue shows the current amount of messages per delivery type. The types of delivery visible will depend on what the properties are working with. You can have HTTP, MSMQ, FAX, EMAIL and PRINT. The Message Statuses will go through the process of Ready, Wait and Processed. If the queue stays filled with messages, without a change or an increase in the number of messages, then check that External Systems services/processors are running.
OXI_HUB XML In Queue
This in queue shows the current messages that are coming from the OPERA Business Events Out Queue that will be grabbed and transmitted to properties via the OXI_HUB. This section should frequently be empty, or at least show messages for a minimal amount of time.
This in queue will show entries for every action that has been done in the OPERA application if the Business Event processor is OFF. When the Business Event processor is ON, then this queue should frequently be empty, or at least show messages for a minimal amount of time until they make their way into the OPERA Business Events Out Queue.
Shows the current amount of messages queued for each type of external system that is to be delivered. If the OPERA Business Events Out Queue stays filled with messages then check that Central Systems QUEUE service is running. This service is located on the Central IFC machine; which is accessed through the IFC Monitor.
Business Events Outqueue
This screen shows all business events and their detailed data elements that have been created in ORS. If the OXI_HUB service is running for a particular interface, the business event will never be visible here, as it will be processed immediately. If business events are created for interfaces that are not running, these will be visible with all their details in this screen.
This tab is used as an indicator whether the OXI_HUB Queue service is running.
See, Business Events Outqueue, for more information.
ORS To Ext. System Log
This screen shows messages and their status from ORS to an external system. It is the second stage after the Business Event Outqueue tab and shows the result of the message processing including errors and warnings.
See, the following list of topics for more information on ORS to External System Log.
Aqueue Out
This screen displays the next level in the live cycle of a message from ORS to the external system. The additional information in this screen is minimal. If a reservation message goes into failover in OXI_HUB, only the next delivery attempt will be visible on the Aqueue Out status screen.
Refer to, Aqueue Out, for more details.
Message Flow from External systems to ORS
Ext. System to ORS Log
This screen displays all messages that have been received in ORS from the external system. It also shows when errors and warnings have occurred during message processing.
Refer to the following list of topics for more information.
Export/Import Utility
Go into Utilities > Export/Import. The purpose of this utility is to export and import a full set of configuration data from one interface to another.
See, Export Import Utility, for more information.
Copy Conversions
Under Utilities > Copy Conversions. This tool is used for first time installations to copy OPERA data into the Inteface's Conversion Code tables. It is also used for validation of existing information that may no longer be setup in OPERA. Allows you to clean up the Conversion Code tables without going into each Conversion individually.
See, Utilities, for more information.
Resync
Under Utilities > Resync. This tool is used to balance information between two systems.
See, Resynchronization of data, for more information.
Purge Data
Under Utilities > Purge Data. This is a quick reference for how long the interface will hold transmitted messages.
Help
Formerly known as Version. Under Help > About MICROS OPERA. This shows you what exact ORS and OXI_HUB version you are running.
See, About MICROS OPERA, for more information.
Switch Interfaces
Go into Switch Interfaces and you see all of your configured interface records. Switch Interfaces is used to switch between various global interfaces or into a property-specific interface without exiting the interface.
See, Switch Interfaces, for more information.
Membership Stay Point Lookup
This message allows the membership award points that would be available to the guest at the time of check out to be displayed on the guest folio. This feature is available to guests with membership associations as well as to guests not yet enrolled in order to show what they could have accrued if they were members.
For the membership award points projection to work, there must be a membership type in PMS designated as “primary” with points "centrally" managed. This configuration is done in ORS/OCIS on the Membership Types - Main tab by selecting the External System option under the Points Calculation Method area. In this area of the Membership Types - Main screen, the database against which the points lookup should be performed must also be selected.
OXI
The outgoing Membership Stay Point Lookup request and response message logs can be found in the OXI Message Status screen under the “Messages To External System” tab. The Module for this message is "STAY" and the action type is "POINTS REQUEST."
The XML request message contains the STAY message generated by PMS to request the membership points from ORS/OCIS. The response message generated by the ORS/OCIS contains the membership stay points. In case of request failure in the external system (ORS/OCIS), the response message will contain the error message received from the external system.
Message Statuses
The possible statuses for the Membership Stay Point Lookup message are listed below.
Status
Description
NEW
STAY XML has been built, but the point lookup operation has not yet been completed.
FAILED
Stay point lookup failed; review the error messages for details.
SUCCESS
Stay point lookup succeeded.
OXIHUB
In OXIHUB, the incoming stay point lookup request and outgoing response messages are logged in OXIHUB’s Message Status screen under the “Ext system to ORS Log” and “ORS to Ext System Log” tabs.
