| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to make a backup of the database to FTP server using the chg-db command with these parameters.
:action=backup :dest=server The database in the active partition of the active MASP (FD CRNT) must be coherent. The status of the database is shown in the rept-stat-db command. For more information on verifying the database, refer to Verifying the Database.
As of Release 46.5, the E5-IPSM card and its functionality is replaced by the E5-ENET-B (p/n 870-2971-01) or SLIC (p/n 7094646) card. Any references to E5-IPSM and the 870-2877-01 part number should be replaced by the 46.5 and greater card and part number.The EAGLE must contain at least one E5-IPSM and an FTP server for the DB application. The rept-stat-gpl command with the appl=ips parameter displays the E5-IPSMs and IPSMs that are in the database. E5-IPSMs are shown by the entry IPSHC in the GPL column of the rept-stat-gpl output. IPSMs are shown by the entry IPS in the GPL column of the rept-stat-gpl output. The rtrv-ftp-serv command shows the FTP servers that are configured. E5-IPSMs can be added by performing the procedure Adding an E5-IPSM. FTP servers can be added by performing the procedure Adding an FTP Server.
When a backup of the database to the FTP server is performed, A file containing the database is created with the following naming convention is created:
“CLLI string”-“Release number string”-“yymmddhh”.tar.gz
The CLLI string is the CLLI value shown in the output header. The release number string is the release number shown in the output header. If the archbldid option, shown in the rtrv-stpopts output, is set to yes, the release number string contains the build number instead of the release number. If you wish to change the archbldid option, perform the procedure Configuring the Archive Build ID Option. The string yymmddhh is the year (yy - 2 digits), the month (mm), the day (dd), and the hour (hh) that the backup was performed. For example, the file name for a backup performed on September 26, 2008 at 12 noon would be: rlghncxa03w-39.2.0-08092612.tar.gz. This file name will be needed to restore the database from the FTP server. The file name for the backup can contain a maximum of 39 alphanumeric characters.
Figure D-3 Making a Backup of the Database to the FTP Server
Sheet 1 of 2
Sheet 2 of 2
