| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to reload the clock LCA (logic cell array) bitfile on the TDMs using the init-card command. To reload the TDM clock LCA bitfile, the E5-MCAP card associated with the TDM being reloaded is initialized by entering the init-card command with the initclk=yes parameter.
It is recommended that the card specified in the init-card command is the GPSM-II or E5-MCAP card in the standby MASP. The rept-stat-db output in 7 shows which TDM is the standby TDM with the indicator ( STDBY) after the TDM’s card location. If the TDM in card location 1114 is the standby TDM, card location 1113 must be specified. If the TDM in card location 1116 is the standby TDM, card location 1115 must be specified.
The TDM clock LCA bitfile can be reloaded only on TDMs with part numbers 870-0774-15 or later. If the EAGLE contains older TDMs, these TDMs must be replaced with TDMs 870-0774-15 or later to perform this procedure.
Contact My Oracle Support (MOS) before replacing the TDMs.The init-card also contains the force=yes parameter. The force=yes parameter can be used only with the initclk=yes parameter. The force=yes parameter must be used if reloading the TDM clock LCA bitfile would cause a system clock outage.
Caution:
A system clock outage can be caused by either the EAGLE having only one TDM (a simplex MASP configuration) or if the status of the high-speed clocks, shown in therept-stat-clk output in 1, on the TDM which is not being reset is Fault. A system clock outage will result in a loss of traffic on some or all signaling links. rept-stat-clk command. This is an example of the possible output.
rlghncxa03w 09-03-01 11:34:04 GMT EAGLE5 40.1.0
COMPOSITE PST SST AST
SYSTEM CLOCK IS-NR Active -----
ALARM STATUS = No Alarms.
Primary Comp Clk 1114 (CLK A) IS-NR Active -----
Primary Comp Clk 1116 (CLK B) IS-NR Active -----
Secondary Comp Clk 1114 (CLK A) IS-NR Idle -----
Secondary Comp Clk 1116 (CLK B) IS-NR Idle -----
Clock Using Bad
CLK A 9 0
CLK B 0 0
CLK I 0 --
HIGH SPEED PST SST AST
SYSTEM CLOCK IS-NR Idle -----
Primary HS Clk 1114 (HS CLK A) IS-NR Active -----
Primary HS Clk 1116 (HS CLK B) IS-NR Active -----
Secondary HS Clk 1114 (HS CLK A) IS-NR Idle -----
Secondary HS Clk 1116 (HS CLK B) IS-NR Idle -----
HS CLK TYPE 1114 = RS422
HS CLK LINELEN 1114 = LONGHAUL
HS CLK TYPE 1116 = RS422
HS CLK LINELEN 1116 = LONGHAUL
Clock Using Bad
HS CLK A 2 0
HS CLK B 0 0
HS CLK I 0 --
Command Completed
If the rept-stat-clk output does not show any high-speed clocks HIGH SPEED SYSTEM CLOCK, Primary HS Clk, Secondary HS Clk, HS CLK TYPE, and HS CLK LINELEN fields), the EAGLE does not contain any cards that are capable of using high-speed master timing.
HS CLK TYPE and HS CLK LINELEN values shown in 1 are set to the system default values (HS CLK TYPE = RS422 and HS CLK LINELEN = LONGHAUL), continue the procedure with 3. HS CLK TYPE and HS CLK LINELEN values shown in 1 are not set to the system default values (HS CLK TYPE = RS422 and HS CLK LINELEN = LONGHAUL), continue the procedure with 2. If the TDM part numbers are 870-0774-15 or later, continue the procedure with 3.
If the TDM part numbers are not 870-0774-15 or later, the TDMs must be replaced with TDM part numbers 870-0774-15 or later. Contact the Customer Care Center before replacing the TDMs. Refer to My Oracle Support (MOS) for the contact information. If the older TDMs are not replaced, this procedure cannot be performed.
rtrv-trm command. If any SEAS terminals are present, they must be taken out of service. The SEAS terminals are shown in the output with the entry SEAS in the TYPE field. If no SEAS terminals are shown in the rtrv-trm command output, continue the procedure with 7.
This is an example of the possible output. In this example, the SEAS terminals are terminals 18 and 27.
rlghncxa03w 10-07-01 16:02:08 GMT EAGLE5 42.0.0 TRM TYPE COMM FC TMOUT MXINV DURAL 1 VT320 9600-7-E-1 SW 30 5 99:59:59 2 KSR 9600-7-E-1 HW 30 5 INDEF 3 PRINTER 4800-7-E-1 HW 30 0 00:00:00 4 VT320 2400-7-E-1 BOTH 30 5 00:30:00 5 VT320 9600-7-O-1 NONE 30 5 00:00:30 6 VT320 9600-7-O-1 NONE 30 5 00:00:30 7 PRINTER 9600-7-N-2 HW 30 5 00:30:00 8 KSR 19200-7-E-2 BOTH 30 5 00:30:00 9 VT320 9600-7-O-1 NONE 30 5 00:00:30 10 VT320 9600-7-E-1 HW 30 5 00:30:00 11 VT320 4800-7-E-1 HW 30 5 00:30:00 12 PRINTER 9600-7-E-1 HW 30 4 00:30:00 13 VT320 9600-7-O-1 NONE 30 5 00:30:00 14 VT320 9600-7-E-2 SW 30 8 00:30:00 15 VT320 9600-7-N-2 HW 30 5 00:30:00 16 VT320 9600-7-E-2 BOTH 30 3 00:30:00 TRM TYPE LOC TMOUT MXINV DURAL SECURE 17 TELNET 1201 60 5 00:30:00 yes 18 SEAS 1201 60 5 00:30:00 yes 19 TELNET 1201 60 5 00:30:00 yes 20 TELNET 1201 60 5 00:30:00 yes 21 TELNET 1201 60 5 00:30:00 yes 22 TELNET 1201 60 5 00:30:00 yes 23 TELNET 1201 60 5 00:30:00 yes 24 TELNET 1201 60 5 00:30:00 yes 25 TELNET 1203 60 5 00:30:00 yes 26 TELNET 1203 60 5 00:30:00 yes 27 SEAS 1203 60 5 00:30:00 yes 28 TELNET 1203 60 5 00:30:00 yes 29 TELNET 1203 60 5 00:30:00 yes 30 TELNET 1203 60 5 00:30:00 yes 31 TELNET 1203 60 5 00:30:00 yes 32 TELNET 1203 60 5 00:30:00 yes 33 TELNET 1205 60 5 00:30:00 yes 34 TELNET 1205 60 5 00:30:00 yes 35 TELNET 1205 60 5 00:30:00 yes 36 TELNET 1205 60 5 00:30:00 yes 37 TELNET 1205 60 5 00:30:00 yes 38 TELNET 1205 60 5 00:30:00 yes 39 TELNET 1205 60 5 00:30:00 yes 40 TELNET 1205 60 5 00:30:00 yes
Thertrv-trm command output contains other fields that are not used by this procedure. If you wish to see all the fields displayed by the rtrv-trm command, see the rtrv-trm command description in Commands User's Guide.rept-stat-trm command. This is an example of the possible output.rlghncxa03w 09-03-01 15:08:45 GMT EAGLE5 40.1.0 TRM PST SST AST 1 IS-NR Active ----- 2 IS-NR Active ----- 3 IS-NR Active ----- 4 IS-NR Active ----- 5 IS-NR Active ----- 6 IS-NR Active ----- 7 IS-NR Active ----- 8 IS-NR Active ----- 9 IS-NR Active ----- 10 IS-NR Active ----- 11 IS-NR Active ----- 12 IS-NR Active ----- 13 IS-NR Active ----- 14 IS-NR Active ----- 15 IS-NR Active ----- 16 IS-NR Active ----- 17 IS-NR Active ----- 18 IS-NR Active ----- 19 IS-NR Active ----- 20 IS-NR Active ----- 21 IS-NR Active ----- 22 IS-NR Active ----- 23 IS-NR Active ----- 24 IS-NR Active ----- 25 IS-NR Active ----- 26 IS-NR Active ----- 27 IS-NR Active ----- 28 IS-NR Active ----- 29 IS-NR Active ----- 30 IS-NR Active ----- 31 IS-NR Active ----- 32 IS-NR Active ----- 33 IS-NR Active ----- 34 IS-NR Active ----- 35 IS-NR Active ----- 36 IS-NR Active ----- 37 IS-NR Active ----- 38 IS-NR Active ----- 39 IS-NR Active ----- 40 IS-NR Active ----- Command Completed.
rmv-trm command with the number of the terminal displayed in 4 whose state is not OOS-MT-DSBLD. The force=yes parameter must be used when placing the last SEAS terminal out of service.
If SEAS terminals are shown in the rtrv-trm output in 3, for this example, enter these commands.
rmv-trm:trm=18
rmv-trm:trm=27:force=yes
Caution:
Placing the SEAS terminals out of service will disable the SEAS feature on the EAGLE.If the status of any of the terminals shown in the PST field in 4 is OOS-MT-DSBLD (out-of-service maintenance disabled), the terminal is already out of service and the rmv-trm command does not need to be executed for that terminal.
This message should appear when each of these commands have successfully completed.
rlghncxa03w 09-03-01 15:08:45 GMT EAGLE5 40.1.0 Inhibit message sent to terminal rlghncxa03w 09-03-01 15:08:45 GMT EAGLE5 40.1.0 Command Completed.
chg-trm command, the type=none parameter, and with the values of the SEAS terminals used in 5.If SEAS terminals are shown in the rtrv-trm output in 3, for this example, enter these commands.
chg-trm:trm=18:type=none
chg-trm:trm=27:type=none
This message should appear when these commands have successfully completed.
rlghncxa03w 09-03-01 11:11:28 GMT EAGLE5 40.1.0 CHG-TRM: MASP B - COMPLTD
rept-stat-db command, to determine which MASP is active, This is an example of the possible output.
rlghncxa03w 09-03-01 16:07:48 GMT EAGLE5 40.1.0
DATABASE STATUS: >> OK <<
TDM 1114 ( ACTV ) TDM 1116 ( STDBY)
C LEVEL TIME LAST BACKUP C LEVEL TIME LAST BACKUP
FD BKUP Y 35 09-02-19 10:19:18 GMT Y 35 09-02-19 10:19:18 GMT
FD CRNT Y 106 Y 106
MDAL 1117
RD BKUP - - - -
If E5-based control cards are installed in the EAGLE, this is an example of the possible output.
FD CRNT Y 106 Y 106
MCAP 1113 MCAP 1115
RD BKUP - - - - - - - -
USB BKP - - - - Y 3 09-02-07 01:11:22 GMT
The output of the rept-stat-db command shows which MASP is active with the indicator ( ACTV ) following the TDM card location. The indicator ( STDBY) following the TDM card location shows which MASP is standby.
For this example, the MASP associated with TDM 1114 is active and the MASP associated with TDM 1116 is standby.
rmv-card command. The rept-stat-db output in 7 shows which TDM is the standby TDM with the entry (Standby ) after the TDMs card location. If the TDM in card location 1114 is the standby TDM, card location 1113 must be specified in this step. If the TDM in card location 1116 is the standby TDM, card location 1115 must be specified in this step.
For this example, enter this command.
rmv-card:loc=1115
When this command has successfully completed, this message should appear.
rlghncxa03w 09-03-01 11:11:28 GMT EAGLE5 40.1.0 Card has been inhibited.
init-card command with the initclk=yes parameter and the card location of the standby E5-MCAP card. Caution:
If reloading the TDM clock LCA bitfile would cause a system clock outage, the force=yes parameter must be used with theinit-card command. A system clock outage can be caused by either the EAGLE having only one TDM (a simplex MASP configuration) or if the status of the high-speed clocks, shown in the rept-stat-clk output in 1, on the TDM which is not being reset is Fault. A system clock outage will result in a loss of traffic on some or all signaling links. For this example, enter this command.
init-card:initclk=yes:loc=1115
When this command has successfully completed, these messages should appear.
rlghncxa03w 09-03-01 13:01:59 GMT EAGLE5 40.1.0
Init Card command issued to card 1115
* 3021.0013 * CARD 1115 EOAM Card is isolated from the system
rlghncxa03w 09-03-01 13:03:10 GMT EAGLE5 40.1.0
3022.0014 CARD 1115 EOAM Card is present
ASSY SN: 1216115
* 3021.0013 * CARD 1115 OAMHC Card is isolated from the system
3022.0014 CARD 1115 OAMHC Card is present
ASSY SN: 1216115
rst-card command with the card location specified in 9. For this example, enter this command. rst-card:loc=1115
rlghncxa03w 09-03-01 11:11:28 GMT EAGLE5 40.1.0 Card has been allowed.
init-card command specifying the location of the E5-MCAP card making up active MASP. Initializing the E5-MCAP card of the active MASP makes the MASPs switch roles. The active MASP becomes the standby MASP, and the standby (text is missing from this point). For this example, enter the init-card:loc=1113 command. This message should appear.
rlghncxa03w 09-03-01 11:11:28 GMT EAGLE5 40.1.0 Init Card command issued to card 1113
After the init-card command has completed, repeat the procedure from 8, specifying the card location used in the init-card command.
Clock Using Bad
CLK A 9 0
CLK B 0 0
CLK I 0 --
Clock Using Bad
HS CLK A 2 0
HS CLK B 0 0
HS CLK I 0 --
Command Completed
chg-trm:trm=18:type=seas
chg-trm:trm=27:type=seas
rst-trm command with the number of the terminals specified in 13. For this example, enter these commands. rst-trm:trm=18
rst-trm:trm=27
rlghncxa03w 09-03-01 15:08:45 GMT EAGLE5 40.1.0 Allow message sent to terminal rlghncxa03w 09-03-01 15:08:45 GMT EAGLE5 40.1.0 Command Completed.
chg-db:action=backup:dest=fixed command. These messages should appear, the active Maintenance and Administration Subsystem Processor (MASP) appears first.BACKUP (FIXED) : MASP A - Backup starts on active MASP. BACKUP (FIXED) : MASP A - Backup on active MASP to fixed disk complete. BACKUP (FIXED) : MASP A - Backup starts on standby MASP. BACKUP (FIXED) : MASP A - Backup on standby MASP to fixed disk complete.
Figure 3-7 Reloading the TDM LCA Clock Bitfile
Sheet 1 of 3
Sheet 2 of 3
Sheet 3 of 3
