| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
The BLIXP GPL is a tar image of all the flash GPLs that are necessary to operate the cards shown in Table 3-5. When the BLIXP GPL is downloaded to the card, the tar image is un-archived and the flash GPLs are loaded onto the card.
Table 3-5 High-Capacity Cards
| HC MIM | E5-E1T1 | E5-ENET |
| E5-STC | E5-SLAN | E5-SM4G |
| E5-ATM | E5-TSM |
This procedure updates the BLIXP GPL using the init-flash and act-flash commands.
Caution:
Theinit-flash command cannot be entered if the IMT Rate Change sequence or the Extended Bit Error Rate Test (BERT) is being performed. The act-flash command cannot be entered if the Extended Bit Error Rate Test (BERT) is being performed.The applications and entities supported by the high-capacity cards are shown in Table 3-6.
Table 3-6 High-Capacity Card Applications
| High-Capacity Card | Card Name (as shown on the card label) | Application | Application GPL Running on the Card | Supported Entities |
| HC MIM | HC MIM | SS7ANSI, CCS71TU | SS7HC | E1 or T1 signaling links |
| E5-E1T1 | E5-E1T1 | SS7ANSI, CCS71TU | SS7HC | E1 or T1 signaling links |
| E5-ENET | E5-ENET | SS7IPGW, IPLIM, IPLIMI, IPGWI, IPSG | IPLHC, IPGHC, IPSG | IP signaling links |
| E5-STC | E5-ENET | EROUTE | ERTHC | EAGLE 5 Integrated Monitoring Support |
| E5-SM4G | E5-SM4G | VSCCP | SCCPHC | GTT-related features |
| E5-SLAN | E5-ENET | STPLAN | SLANHC | TCP/IP data links for the STPLAN feature |
| E5-ENET-B/SLIC | E5-ENET-B SLIC |
IPS | IPSHC | Telnet sessions for remote connections to the EAGLE and SEAS terminals for the SEAS over IP feature |
| E5-ATM | E5-ATM | ATMANSI, ATMITU | ATMHC | ANSI and ITU ATM high-speed signaling links |
| E5-TSM | E5-TSM | GLS | GLSHC | Gateway Screening related features |
A removable cartridge or removable media containing the BLIXP GPL that is being updated is required.
Caution:
Before any high-capacity card can be updated with the BLIXP GPL, all the traffic hosted by the high-capacity card must be stopped, and the high-capacity card must be taken out of service.Canceling the REPT-STAT-SLK and RTRV-SLK Commands
Because the rept-stat-slk and rtrv-slk commands used in this procedure can output information for a long period of time, the rept-stat-slk and rtrv-slk commands can be canceled and the output to the terminal stopped. There are three ways that the rept-stat-slk and rtrv-slk commands can be canceled.
F9 function key on the keyboard at the terminal where the rept-stat-slk or rtrv-slk commands command were entered. canc-cmd without the trm parameter at the terminal where the rept-stat-slk or rtrv-slk commands were entered. canc-cmd:trm=<xx>, where <xx> is the terminal where the rept-stat-slk or rtrv-slk commands were entered, from another terminal other that the terminal where the rept-stat-slk or rtrv-slk commands were entered. To enter the canc-cmd:trm=<xx> command, the terminal must allow Security Administration commands to be entered from it and the user must be allowed to enter Security Administration commands. The terminal’s permissions can be verified with the rtrv-secu-trm command. The user’s permissions can be verified with the rtrv-user or rtrv-secu-user commands. For more information about the canc-cmd command, go to Commands User's Guide.
Refer to Maintenance and Administration Subsystem for information about the control cards.
If E5-based control cards are installed in the EAGLE, continue the procedure with 2.
rept-stat-db command. This is an example of the possible output.
rlghncxa03w 10-12-01 15:25:40 GMT EAGLE5 43.0.0
DATABASE STATUS: >> OK <<
TDM 1114 ( STDBY) TDM 1116 ( ACTV )
C LEVEL TIME LAST BACKUP C LEVEL TIME LAST BACKUP
FD BKUP Y 36 10-11-19 09:38:25 GMT Y 36 10-11-19 09:38:25 GMT
FD CRNT Y 39 Y 39
MCAP 1113 MCAP 1115
RD BKUP - - - - Y 36 10-11-19 09:27:17 GMT
USB BKP - - - - Y 3 10-11-07 01:11:22 GMT
If removable media is installed in the active MASP, continue the procedure with 4.
If removable media is not installed in the active MASP, insert the removable media in the removable media drive in the active MASP. For more information about inserting removable media in the removable media drive, refer to Removable USB Drive. After the removable media has been inserted in the removable media drive in the active MASP, continue the procedure with 4.
rtrv-gpl:gpl=blixp
rlghncxa03w 10-12-01 11:34:04 GMT EAGLE5 43.0.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL BLIXP 1114 133-002-000 133-002-000 133-001-000 133-003-000 BLIXP 1116 133-002-000 133-002-000 133-001-000 133-003-000 BLIXP 1115 ----------- ----------- ----------- -----------
If the version of the BLIXP GPL shown in the REMOVE TRIAL column of the rtrv-gpl output is not the version that is to be loaded onto the cards, remove the removable media from the active MASP. Insert the removable media that contains the BLIXP GPL that is being updated into the removable media drive in the active MASP and repeat this step. For more information about inserting removable media in the removable media drive, or removing removable media from the removable media drive, refer to Removable USB Drive.
If the version of the BLIXP GPL shown in the REMOVE TRIAL column of the rtrv-gpl output is the version that is to be loaded onto the cards, continue the procedure with 133-.
chg-gpl command with the gpl=blixp parameter and the version of the BLIXP GPL shown in the REMOVE TRIAL column in the output of the rtrv-gpl command used in 4. For this example, enter this command.
chg-gpl:gpl=blixp:ver=133-003-000
These messages should appear.
rlghncxa03w 10-12-01 11:43:04 GMT EAGLE5 43.0.0 GPL Auditing ON BLIXP upload on 1114 completed BLIXP upload on 1116 completed System Release ID table upload 1114 completed System Release ID table upload 1116 completed
act-gpl command with the gpl=blixp parameter and the version of the trial GPL specified in 133-. For this example, enter this command.
act-gpl:gpl=blixp:ver=133-003-000
rlghncxa03w 10-12-01 06:54:39 GMT EAGLE5 43.0.0 BLIXP activate on 1114 completed BLIXP activate on 1116 completed
rtrv-gpl:gpl=blixp
rlghncxa03w 10-12-01 11:34:04 GMT EAGLE5 43.0.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL BLIXP 1114 133-003-000 133-003-000 133-002-000 133-003-000 BLIXP 1116 133-003-000 133-003-000 133-002-000 -----------
If E5-based control cards are installed in the EAGLE, this is an example of the possible output.
rlghncxa03w 10-12-01 11:34:04 GMT EAGLE5 43.0.0 GPL Auditing ON GPL CARD RELEASE APPROVED TRIAL REMOVE TRIAL BLIXP 1114 133-003-000 133-003-000 133-002-000 133-003-000 BLIXP 1116 133-003-000 133-003-000 133-002-000 133-003-000 BLIXP 1115 ----------- ----------- ----------- -----------
rept-stat-gpl:gpl=blixp
rlghncxa03w 10-12-01 11:40:26 GMT EAGLE5 43.0.0 GPL CARD RUNNING APPROVED TRIAL BLIXP 1303 133-002-000 ALM 133-003-000 133-002-000 BLIXP 2101 133-002-000 ALM 133-003-000 133-002-000 BLIXP 2103 133-002-000 ALM 133-003-000 133-002-000 BLIXP 2205 133-002-000 ALM 133-003-000 133-002-000 BLIXP 2207 133-002-000 ALM 133-003-000 133-002-000 BLIXP 2211 133-002-000 ALM 133-003-000 133-002-000 Command Completed
rept-stat-gpl output in 8, that the GPL will be loaded onto using the rept-stat-card command and specifying the location of the card. For this example, enter this command.
rept-stat-card:loc=1303
For an HC MIM or E5-E1T1 card, this is an example of the possible output.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0
CARD VERSION TYPE GPL PST SST AST
1303 134-003-000 LIME1 SS7HC IS-NR Active -----
ALARM STATUS = No Alarms.
BLIXP GPL version = 133-002-000
IMT BUS A = Conn
IMT BUS B = Conn
SIGNALING LINK STATUS
SLK PST LS CLLI
A IS-NR e11303a -----------
B IS-NR e11303b -----------
A1 IS-NR e11303a -----------
B3 IS-NR e11303b -----------
Command Completed.
BLBIOS GPL version = 133-002-000
PLDPMC1 GPL version = 133-002-000
BLROM1 GPL version = 133-002-000
IMT BUS A = Conn
IMT BUS B = Conn
SLK PST LS CLLI
Command Completed.
For an E5-E1T1 card, this is an example of the possible output.
1303 134-003-000 LIME1 SS7EPM IS-NR Active -----
IMT BUS A = Conn
IMT BUS B = Conn
CURRENT TEMPERATURE = 32C ( 90F) [ALARM TEMP: 60C (140F)]
PEAK TEMPERATURE: = 39C (103F) [06-05-02 13:40]
SLK PST LS CLLI
Command Completed.
IMT BUS A = Conn
IMT BUS B = Conn
SLK PST LS CLLI
Command Completed.
For an E5-ENET card, this is an example of the possible output.
1303 134-003-000 DCM IPLHC IS-NR Active -----
IMT BUS A = Conn
IMT BUS B = Conn
SLK PST LS CLLI
Command Completed.
IMT BUS A = Conn
IMT BUS B = Conn
SLK PST LS CLLI
Command Completed.
For an E5-STC card, this is an example of the possible output.
1303 134-003-000 STC ERTHC IS-NR Active -----
IMT BUS A = Conn
IMT BUS B = Conn
CURRENT TEMPERATURE = 61C (142F)
PEAK TEMPERATURE: = 61C (142F) [06-05-02 13:40]
NTP broadcast = VALID
STC IP PORT A: OOS-MT Unavail -----
ALARM STATUS = ** 0084 IP Connection Unavailable
ERROR STATUS = DHCP Lease. Physical Link.
STC IP PORT B: OOS-MT Unavail -----
Command Completed.
For an E5-SLAN card, this is an example of the possible output.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1303 134-003-000 DCM SLANHC IS-NR Active ----- ALARM STATUS = No Alarms. BLIXP GPL version = 133-002-000 IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 60C (140F) PEAK TEMPERATURE: = 63C (146F) [00-02-12 21:58] DLK A PST = IS-NR SST = Avail AST = ----- SLAN % EAGLE CAPACITY = 57% SLAN % HOST CAPACITY = 49% Command Completed.
For an E5-SM4G card, this is an example of the possible output.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1303 134-003-000 DSM SCCPHC IS-NR Active ----- ALARM STATUS = No Alarms. BLIXP GPL version = 133-002-000 IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 31C ( 88F) PEAK TEMPERATURE: = 32C ( 90F) [07-05-12 15:55] SCCP % OCCUP = 1% Command Completed.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1303 134-003-000 DSM SCCPHC IS-NR Active ----- ALARM STATUS = No Alarms. BLIXP GPL version = 133-002-000 BLBSMG GPL version = 133-002-000 IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 31C ( 88F) PEAK TEMPERATURE: = 32C ( 90F) [07-05-12 15:55] SCCP % OCCUP = 1% Command Completed.
For an E5-ENET-B/SLIC card, this is an example of the possible output.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1303 134-003-000 IPSM IPSHC IS-NR Active ----- ALARM STATUS = No Alarms. BLIXP GPL version = 133-002-000 IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 32C ( 90F) PEAK TEMPERATURE: = 39C (103F) [06-05-02 13:40] Command Completed.
For an E5-ATM card, this is an example of the possible output.
1303 134-003-000 LIMATM ATMHC IS-NR Active -----
IMT BUS A = Conn
IMT BUS B = Conn
CURRENT TEMPERATURE = 38C (101F)
PEAK TEMPERATURE: = 38C (101F) [07-11-23 06:10]
SLK PST LS CLLI
A IS-NR ls1 -----------
Command Completed.
For an E5-TSM card, this is an example of the possible output.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1303 134-003-000 TSM GLSHC IS-NR Active ----- ALARM STATUS = No Alarms. BLIXP GPL version = 133-002-000 IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 38C (101F) PEAK TEMPERATURE: = 38C (101F) [07-11-23 06:10] Command Completed.
Continue the procedure by performing one of these actions:
GPL column in the rept-stat-card output in 9), continue the procedure with 12. GPL column in the rept-stat-card output in 9), continue the procedure with 19. GPL column in the rept-stat-card output in 9), continue the procedure with 14. GPL column in the rept-stat-card output in 9), continue the procedure with 16. GPL column in the rept-stat-card output in 9), continue the procedure with 10. GPL column in the rept-stat-card output in 9), continue the procedure with 11. rept-stat-card:appl=gls
The output from this command will display the TSMs that are running the GLS GPL and the E5-TSMs that are running the GLSHC GPL.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1207 133-003-000 TSM GLSHC IS-NR Active ----- 1211 133-003-000 TSM GLSHC IS-NR Active ----- 1303 133-003-000 TSM GLSHC IS-NR Active ----- Command Completed.
Continue the procedure with 19.
rept-stat-sccp command.The output from this command will display the DSMs that are running the VSCCP GPL and the E5-SM4G cards that are running the SCCPHC GPL.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION PST SST AST MSU USAGE CPU USAGE ----------------------------------------------------------------------------- 1303 133-003-000 IS-NR Active ----- 47% 81% 2103 133-003-000 IS-NR Active ----- 34% 50% 2111 133-003-000 IS-NR Active ----- 21% 29% 2115 133-003-000 IS-NR Active ----- 35% 52% 2117 133-003-000 IS-NR Active ----- 40% 71% ----------------------------------------------------------------------------- SCCP Service Average MSU Capacity = 36% Average CPU Capacity = 56% Command Completed.
Therept-stat-sccp command output contains other fields that are not used by this procedure. If you wish to see all the fields displayed by the rept-stat-sccp command, refer to the rept-stat-sccp command description in Commands User's Guide.Continue the procedure with 19.
Enter the rtrv-slk command with the card location specified in 9. For this example, enter this command.
rtrv-slk:loc=1303
This is an example of the possible output for an HC MIM or E5-E1T1 card.
L2T PCR PCR E1 E1
LOC LINK LSN SLC TYPE SET BPS ECM N1 N2 LOC PORT TS
1303 A e11303a 0 LIME1 1 64000 PCR 76 3800 1303 2 12
1303 B e11303b 0 LIME1 1 56000 BASIC --- ----- 1303 1 2
1303 A1 e11303a 1 LIME1 1 56000 BASIC --- ----- 1303 1 3
1303 B3 e11303b 1 LIME1 1 56000 BASIC --- ----- 1303 1 7
This is an example of the possible output for an E5-ENET card.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 LOC LINK LSN SLC TYPE IPLIML2 1303 A e11303a 0 IPLIM M2PA 1303 B e11303b 0 IPLIM M2PA 1303 A1 e11303a 1 IPLIM M2PA 1303 B3 e11303b 1 IPLIM M2PA
This is an example of the possible output for an E5-ATM card.
LP ATM
LOC LINK LSN SLC TYPE SET BPS TSEL VCI VPI LL
1303 A ls2 2 LIMATM 1 1544000 LINE 5 0 0
1303 B ls1 3 LIMATM 1 1544000 LINE 5 0 0
dact-slk command. For this example, enter these commands.
dact-slk:loc=1303:link=a
dact-slk:loc=1303:link=b
dact-slk:loc=1303:link=a1
dact-slk:loc=1303:link=b3
Caution:
These command examples place the signaling links on card 1303 out of service. This will interrupt service on the signaling links on card 1303 and allow the BLIXP GPL to be loaded on to card 1303.Caution:
Do not deactivate all the signaling links assigned to these cards: HC MIMs, E5-E1T1, E5-ENET, E5-ATM, at the same time. Doing so will take all the E1, T1, IP, and ATM signaling links out of service, and the traffic on these signaling links could be lost.Caution:
If the EAGLE contains only signaling links assigned to the card that is specified in this step, deactivating all of the signaling links that are assigned to the card will take all of these signaling links out of service and will isolate the EAGLE from the network.When each of these commands have successfully completed, this message should appear.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 Deactivate SLK message sent to card
rept-stat-dlk command with the card location specified in 9. For this example, enter this command.
rept-stat-dlk:loc=1303This is an example of the possible output.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 DLK PST SST AST 1303 IS-NR Active ---- Alarm Status = No Alarms. Command Completed.
canc-dlk command. For this example, enter this command. canc-dlk:loc=1303
Caution:
This command example places the TCP/IP data link on card 1303 out of service. This will interrupt service on the TCP//IP data link on card 1303 and allow the flash GPL to be loaded onto card 1303.Caution:
If there is only one TCP/IP data link in the EAGLE, placing the card out of service will cause the STPLAN feature to be disabled.When this command has successfully completed, these messages should appear.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 Deactivate Link message sent to card. Command Completed.
rtrv-trm command. The Telnet terminals associated with the card shown in 9 must be taken out of service. The Telnet terminals are shown in the output with the entry TELNET in the TYPE field. This is an example of the possible output. In this example, the Telnet terminals that must be taken out of service are terminals 17 to 24.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 TRM TYPE COMM FC TMOUT MXINV DURAL 1 VT320 9600-7-E-1 SW 30 5 99:59:59 2 KSR 9600-7-E-1 HW 30 5 INDEF 3 PRINTER 4800-7-E-1 HW 30 0 00:00:00 4 VT320 2400-7-E-1 BOTH 30 5 00:30:00 5 VT320 9600-7-O-1 NONE 30 5 00:00:30 6 VT320 9600-7-O-1 NONE 30 5 00:00:30 7 PRINTER 9600-7-E–2 HW 30 5 00:30:00 8 KSR 19200-7-E-2 BOTH 30 5 00:30:00 9 VT320 9600-7-O-1 NONE 30 5 00:00:30 10 VT320 9600-7-E-1 HW 30 5 00:30:00 11 VT320 4800-7-E-1 HW 30 5 00:30:00 12 PRINTER 9600-7-E-1 HW 30 4 00:30:00 13 VT320 9600-7-O-1 NONE 30 5 00:30:00 14 VT320 9600-7-E-2 SW 30 8 00:30:00 15 VT320 9600-7-E–2 HW 30 5 00:30:00 16 VT320 9600-7-E-2 BOTH 30 3 00:30:00 TRM TYPE LOC TMOUT MXINV DURAL 17 TELNET 1303 60 5 00:30:00 18 TELNET 1303 60 5 00:30:00 19 TELNET 1303 60 5 00:30:00 20 TELNET 1303 60 5 00:30:00 21 TELNET 1303 60 5 00:30:00 22 TELNET 1303 60 5 00:30:00 23 TELNET 1303 60 5 00:30:00 24 TELNET 1303 60 5 00:30:00 25 TELNET 1203 60 5 00:30:00 26 TELNET 1203 60 5 00:30:00 27 TELNET 1203 60 5 00:30:00 28 TELNET 1203 60 5 00:30:00 39 TELNET 1203 60 5 00:30:00 30 TELNET 1203 60 5 00:30:00 31 TELNET 1203 60 5 00:30:00 32 TELNET 1203 60 5 00:30:00 33 TELNET 1208 60 5 00:30:00 34 TELNET 1208 60 5 00:30:00 35 TELNET 1208 60 5 00:30:00 36 TELNET 1208 60 5 00:30:00 37 TELNET 1208 60 5 00:30:00 38 TELNET 1208 60 5 00:30:00 39 TELNET 1208 60 5 00:30:00 40 TELNET 1208 60 5 00:30:00
Thertrv-trm command output contains other fields that are not used by this procedure. If you wish to see all the fields displayed by the rtrv-trm command, see the rtrv-trm command description in Commands User's Guide. rept-stat-trm command. This is an example of the possible output. rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 TRM PST SST AST 1 IS-NR Active ----- 2 IS-NR Active ----- 3 IS-NR Active ----- 4 IS-NR Active ----- 5 IS-NR Active ----- 6 IS-NR Active ----- 7 IS-NR Active ----- 8 IS-NR Active ----- 9 IS-NR Active ----- 10 IS-NR Active ----- 11 IS-NR Active ----- 12 IS-NR Active ----- 13 IS-NR Active ----- 14 IS-NR Active ----- 15 IS-NR Active ----- 16 IS-NR Active ----- 17 IS-NR Active ----- 18 IS-NR Active ----- 19 IS-NR Active ----- 20 IS-NR Active ----- 21 IS-NR Active ----- 22 IS-NR Active ----- 23 IS-NR Active ----- 24 IS-NR Active ----- 25 IS-NR Active ----- 26 IS-NR Active ----- 27 IS-NR Active ----- 28 IS-NR Active ----- 29 IS-NR Active ----- 30 IS-NR Active ----- 31 IS-NR Active ----- 32 IS-NR Active ----- 33 IS-NR Active ----- 34 IS-NR Active ----- 35 IS-NR Active ----- 36 IS-NR Active ----- 37 IS-NR Active ----- 38 IS-NR Active ----- 39 IS-NR Active ----- 40 IS-NR Active ----- Command Completed.
rmv-trm or inh-trm command. The function of the rmv-trm and the inh-trm commands are the same. For this example, enter these commands. rmv-trm:trm=17
rmv-trm:trm=18
rmv-trm:trm=19
rmv-trm:trm=20
rmv-trm:trm=21
rmv-trm:trm=22
rmv-trm:trm=23
rmv-trm:trm=24
If the terminal that is being taken out of service is the last in service SEAS terminal, theforce=yes parameter must be specified with thermv-trm command for that terminal. Caution:
Placing the Telnet terminals out of service will disable any Telnet sessions running on these terminals.If the status of any of the terminals shown in the PST field in 17 is OOS-MT-DSBLD (out-of-service maintenance disabled), the terminal is already out of service and the rmv-trm command does not need to be executed for that terminal.
This message should appear when each of these commands have successfully completed.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 Inhibit message sent to terminal rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 Command Completed.
rmv-card or inh-card command. The function of the rmv-card and the inh-card commands are the same. Caution:
Multiple cards running the BLIXP GPL can be updated at the same time with theinit-flash command (20). This requires that the cards in the locations specified with the init-flash command in 20 are out of service. All the high-capacity cards running the BLIXP GPL being updated can be placed out of service. However it is recommended that only some of these high-capacity cards are placed out of service. Placing all these high-capacity cards out of service will case all traffic hosted by high-capacity cards to be lost. Caution:
If there is only one high-capacity card running the BLIXP GPL being updated, placing this card out of service will cause all the traffic hosted by this high-capacity card to be lost.For this example, enter this command.
rmv-card:loc=1303
If more than one card running the same flash GPL is to be updated in 20, repeat this step for those cards.
When this command has successfully completed, this message should appear.
rlghncxa03w 10-12-01 11:11:28 GMT EAGLE5 43.0.0 Card has been inhibited.
force=yes parameter must be specified in this step if any of these conditions exist.init-flash command with the code=appr parameter. Caution:
Theflash-card command cannot be entered if the IMT Rate Change sequence or the Extended Bit Error Rate Test (BERT) is being performed. For this example, enter this command.
init-flash:code=appr:loc=1303:gpl=blixp
FLASH Memory Downloading for card 1303 Started.
BLIXP Downloading for card 1303 Complete.
Command Completed.
Updating more than One Card at the Same Time
If more than one card running the BLIXP GPL is being updated, enter the init-flash command with these parameters along with the code=appr parameter:
sloc - the first card location in the range of card locations
eloc - the last card location in the range of card locations
gpl - blixp
Thesloc, eloc, and gpl parameters cannot be specified with the loc parameter. When the sloc, eloc, and gpl parameters are specified, only the cards running the BLIXP GPL and within the range specified by the sloc and eloc parameters are updated. All other cards in the range specified by the sloc and eloc parameters are skipped. Entering the example command will update the cards in the locations 1303 to 2103 running the BLIXP GPL with the approved version of the BLIXP GPL.
init-flash:code=appr:sloc=1303:eloc=2103:gpl=blixp
FLASH Memory Download for cards 1303 - 2103 Started.
FLASH Memory Download for cards 1303 - 2103 Completed.
LOC 1303 : PASSED
LOC 2101 : PASSED
LOC 2103 : PASSED
ALL CARD RESULTS PASSED
Command Completed.
rst-card or alw-card command. The function of the rst-card and the alw-card commands are the same.The rst-card command also loads the approved version of the GPL onto the card.
rst-card:code=appr:loc=1303
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 Card has been allowed.
rept-stat-card command. For this example, enter this command.
BLIXP GPL version = 133-003-000 +
IMT BUS A = Conn
IMT BUS B = Conn
SLK PST LS CLLI
A OOS-MT-DSBLD e11303a -----------
B OOS-MT-DSBLD e11303b -----------
A1 OOS-MT-DSBLD e11303a -----------
B3 OOS-MT-DSBLD e11303b -----------
Command Completed.
IMT BUS A = Conn
IMT BUS B = Conn
SLK PST LS CLLI
Command Completed.
1303 134-003-000 IPLIM SS7EPM IS-NR Active -----
IMT BUS A = Conn
IMT BUS B = Conn
SLK PST LS CLLI
Command Completed.
IMT BUS A = Conn
IMT BUS B = Conn
SLK PST LS CLLI
Command Completed.
IMT BUS A = Conn
IMT BUS B = Conn
SLK PST LS CLLI
Command Completed.
IMT BUS A = Conn
IMT BUS B = Conn
SLK PST LS CLLI
Command Completed.
IMT BUS A = Conn
IMT BUS B = Conn
Command Completed.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1303 134-003-000 DCM SLANHC IS-NR Active ----- ALARM STATUS = No Alarms. BLIXP GPL version = 133-003-000 + IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 60C (140F) PEAK TEMPERATURE: = 63C (146F) [00-02-12 21:58] DLK A PST = IS-NR SST = Avail AST = ----- SLAN % EAGLE CAPACITY = 57% SLAN % HOST CAPACITY = 49% Command Completed.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1303 134-003-000 DSM SCCPHC IS-NR Active ----- ALARM STATUS = No Alarms. BLIXP GPL version = 133-003-000 + IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 31C ( 88F) PEAK TEMPERATURE: = 32C ( 90F) [07-05-12 15:55] SCCP % OCCUP = 1% Command Completed.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1303 134-003-000 DSM SCCPHC IS-NR Active ----- ALARM STATUS = No Alarms. BLIXP GPL version = 133-003-000 + BLBSMG GPL version = 133-002-000 IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 31C ( 88F) PEAK TEMPERATURE: = 32C ( 90F) [07-05-12 15:55] SCCP % OCCUP = 1% Command Completed.
For an E5-ENET-B or SLIC card, this is an example of the possible output.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1303 134-003-000 IPSM IPSHC IS-NR Active ----- ALARM STATUS = No Alarms. BLIXP GPL version = 133-003-000 + IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 32C ( 90F) PEAK TEMPERATURE: = 39C (103F) [06-05-02 13:40] Command Completed.
IMT BUS A = Conn
IMT BUS B = Conn
SLK PST LS CLLI
Command Completed.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 CARD VERSION TYPE GPL PST SST AST 1303 134-003-000 TSM GLSHC IS-NR Active ----- ALARM STATUS = No Alarms. BLIXP GPL version = 133-003-000 + IMT BUS A = Conn IMT BUS B = Conn CURRENT TEMPERATURE = 38C (101F) PEAK TEMPERATURE: = 38C (101F) [07-11-23 06:10] Command Completed.
The ’+’ symbol indicates that the BLIXP GPL has not been activated.
If the version number of the BLIXP GPL that is shown in this step is not the version specified in 1, contact the Customer Care Center. Refer to the My Oracle Support (MOS) section for the contact information.act-flash command with the card location and the gpl=blixp parameter. Caution:
Theact-flash command cannot be entered if the Extended Bit Error Rate Test (BERT) is being performed. For this example, enter this command.
act-flash:loc=1303:gpl=blixp
FLASH Memory Activation for card 1303 Completed.
Command Completed.
Activating more than One Card at the Same Time
If more than one card running the BLIXP GPL was updated in 20, enter the act-flash command with these parameters:
sloc – the first card location in the range of card locations
eloc – the last card location in the range of card locations
gpl – blixp
Thesloc, eloc, and gpl parameters cannot be specified with the loc parameter. When the sloc, eloc, and gpl parameters are specified, only the cards running the BLIXP GPL and within the range specified by thesloc and eloc parameters are updated. All other cards in the range specified by the sloc and eloc parameters are skipped. Entering this example command will activate the BLIXP GPL on the cards in the locations 1303 to 2103.
act-flash:sloc=1303:eloc=2103:gpl=blixp
FLASH Memory Activation for cards 1303 - 2103 Started.
FLASH Memory Activation for cards 1303 - 2103 Completed.
LOC 1303 : PASSED
LOC 2101 : PASSED
LOC 2103 : PASSED
Command Completed.
If any card is not running the release version of the BLIXP GPL, shown in the RELEASE column of the rtrv-gpl output in 7, the indicator ALM is displayed next to the BLIXP GPL version in the RUNNING column of the rept-stat-gpl output. For this example, enter this command.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 GPL CARD RUNNING APPROVED TRIAL BLIXP 1303 133-003-000 133-003-000 133-002-000 BLIXP 2101 133-002-000 133-003-000 133-002-000 BLIXP 2103 133-002-000 133-003-000 133-002-000 BLIXP 2205 133-002-000 ALM 133-003-000 133-002-000 BLIXP 2207 133-002-000 ALM 133-003-000 133-002-000 BLIXP 2211 133-002-000 ALM 133-003-000 133-002-000 Command Completed
Continue the procedure by performing one of these actions.
GPL column in the rept-stat-card output in 22), continue the procedure with 25. GPL column in the rept-stat-card output in 22), continue the procedure with 31. GPL column in the rept-stat-card output in 22), continue the procedure with 27. GPL column in the rept-stat-card output in 22), continue the procedure with 29. act-slk command. For this example, enter these commands.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 Activate SLK message sent to card
rept-stat-slk command with the card location and signaling link. For this example, enter these commands.
rept-stat-slk:loc=1303:link=a
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 SLK LSN CLLI PST SST AST 1303,A e11303a ----------- IS-NR Avail ---- ALARM STATUS = No Alarms. UNAVAIL REASON = --
rept-stat-slk:loc=1303:link=b
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 SLK LSN CLLI PST SST AST 1303,B e11303b ----------- IS-NR Avail ---- ALARM STATUS = No Alarms. UNAVAIL REASON = --
rept-stat-slk:loc=1303:link=a1
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 SLK LSN CLLI PST SST AST 1303,A1 e11303a ----------- IS-NR Avail ---- ALARM STATUS = No Alarms. UNAVAIL REASON = --
rept-stat-slk:loc=1303:link=b3
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 SLK LSN CLLI PST SST AST 1303,B3 e11303b ----------- IS-NR Avail ---- ALARM STATUS = No Alarms. UNAVAIL REASON = -- Command Completed.
Continue the procedure with 31.
act-dlk command. For this example, enter this command. act-dlk:loc=1303 rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 Activate Link message sent to card.
rept-stat-dlk command. For this example, enter this command. rept-stat-dlk:loc=1303This is an example of the possible output.
rst-trm or alw-trm command. The function of the rst-trm and the alw-trm commands are the same. For this example, enter these commands. rst-trm:trm=17 rst-trm:trm=18 rst-trm:trm=19 rst-trm:trm=20 rst-trm:trm=21 rst-trm:trm=22 rst-trm:trm=23 rst-trm:trm=24 This message should appear when each of these commands have successfully completed.
rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 Allow message sent to terminal rlghncxa03w 10-12-01 09:12:36 GMT EAGLE5 43.0.0 Command Completed.
Figure 3-8 Updating the BLIXP GPL
Sheet 1 of 7
Sheet 2 of 7
Sheet 3 of 7
Sheet 4 of 7
Sheet 5 of 7
Sheet 6 of 7
Sheet 7 of 7
