| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to configure IP communications links between the EAGLE and the customer’s network and enable the Integrated Measurements feature on the EAGLE using these commands.
ent-ip-host –
Configuring the
IP host of the
E5-MCAP.
chg-ip-card –
Configuring the IP address of the E5-MCAP.
chg-ip-lnk –
Configuring the IP link assigned to the E5-MCAP.
chg-measopts –
Enabling the measurement collection option for the E5-MCAP card option.
enable-ctrl-feat –
Enabling the Integrated Measurements feature.
chg-ctrl-feat –
Turning the Integrated Measurements feature on.
Some of these commands contain parameters that are not used in this procedure. Commands User's Guide contains a full description of these commands.
The Integrated Measurements feature requires measurements FTP servers. A maximum of three measurements FTP servers can be configured with one of these procedures.
This procedure can be performed only on EAGLEs that contain E5-based control cards. Refer to Maintenance and Administration Subsystem for more information about the control cards.
The Integrated Measurements feature is enabled using the
enable-ctrl-feat command with these
parameters.
:fak – The feature
access key provided by Oracle.
:partnum – The
Oracle-issued part number of the Integrated Measurements feature, 893037301.
Once this feature is enabled, it is permanently enabled. This feature cannot be enabled with a temporary feature access key.
The
enable-ctrl-feat command requires that
the database contain a valid serial number for the EAGLE, and that this serial
number is locked. This can be verified with the
rtrv-serial-num command. The EAGLE is
shipped with a serial number in the database, but the serial number is not
locked. The serial number can be changed, if necessary, and locked once the
EAGLE is on-site, with the
ent-serial-num command. The
ent-serial-num command uses these
parameters.
:serial – The serial
number assigned to the EAGLE. The serial number is not case sensitive.
:lock – Specifies
whether or not the serial number is locked. This parameter has only one value,
yes, which locks the serial number.
Once the serial number is locked, it cannot be changed.
To enter and lock the EAGLE serial number, theent-serial-num command must be entered
twice, once to add the correct serial number to the database with the
serial parameter, then again with the
serial and the
lock=yes parameters to lock the serial
number. Verify that the serial number in the database is correct before locking
the serial number. The serial number can be found on a label affixed to the
control shelf (shelf 1100).
Once the Integrated Measurements feature has been
enabled, the Integrated Measurements feature must be turned on with the
chg-ctrl-feat command. The
chg-ctrl-feat command uses these
parameters:
:partnum – The
:status=on – used to
turn the Integrated Measurements feature on.
Once the Integrated Measurements feature has been turned on, it be cannot be turned off.
The status of the Integrated Measurements feature is
shown with the
rtrv-ctrl-feat command.
If a Class B IP address is specified for the
ipaddr parameter of the
chg-ip-lnk command, the subnet address
that results from the
ipaddr and
submask parameter values cannot be the
same as the subnet address that results from the
pvn and
pvnmask,
fcna and
fcnamask, or
fcnb and
fcnbmask parameter values of the
chg-netopts command. The
pvn and
pvnmask,
fcna and
fcnamask, or
fcnb and
fcnbmask parameter values can be
verified by entering the
rtrv-netopts command. Choose
ipaddr and
submask parameter values for the IP
address assigned to the E5-MCAP card whose resulting subnet address is not be
the same as the subnet address that resulting from the
pvn and
pvnmask,
fcna and
fcnamask, or
fcnb and
The Integrated Measurements feature supports the collection and reporting of all measurement entities for EAGLEs configured with a maximum of 2400 signaling links (or 1200 links if the 15-minute measurements feature is turned on) using the E5-MCAP cards instead of the MCPM. The enhanced reporting capabilities provided by the Integrated Measurements feature support the generation of text file measurements reports in the CSV format. The reports can be sent to a customer-provided FTP server on-demand or on a scheduled basis. EAGLEs with more than 2400/1200 signaling links require the Measurements Platform for full measurements support.
Figure 4-34 Configuring the Integrated Measurements Feature
Sheet 1 of 4
Sheet 2 of 4
Sheet 3 of 4
Sheet 4 of 4
