| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to enable and turn on the SEAS over IP feature using the feature’s part number and a feature access key.
The feature access key is based on the feature’s part number and the serial number of the EAGLE, making the feature access key site-specific.
The enable-ctrl-feat command enables the feature by inputting the feature’s access key and the feature’s part number with these parameters:
:fak – The feature access key provided by Oracle.
:partnum – The Oracle-issued part number of the SEAS over IP feature, 893018801.
Once this feature is enabled, it is permanently enabled. This feature cannot be enabled with a temporary feature access key.
The Telnet feature (IP User Interface), part number 893005701, must be enabled and turned on before the SEAS over IP feature can be enabled. Perform the Activating Controlled Features procedure to enable and turn on the Telnet feature.
Once the SEAS over IP feature has been enabled, the SEAS over IP feature must be turned on with the chg-ctrl-feat command. The chg-ctrl-feat command uses these parameters:
:status=on – used to turn the SEAS over IP feature on.
To turn the SEAS over IP feature on in step 5, these items must be provisioned in the database.seasclli value must be provisioned.login and hname values for at least one connection must be provisioned.If you wish to provision the EAGLE for the SEAS over IP feature at this time, perform these procedures.
Once the SEAS over IP feature has been turned on, it be can be turned off. For more information on turning the SEAS over IP feature off, go to the Turning Off the SEAS Over IP Feature procedure.
The status of the SEAS over IP and Telnet features is shown with the rtrv-ctrl-feat command.
Caution:
When the SEAS over IP feature is turned on, and the SEAS terminals and SEAS configuration is provisioned, SEAS traffic is sent to the CCS MR using the SEAS terminals.Figure 5-4 Activating the SEAS over IP Feature
Sheet 1 of 2
Sheet 2 of 2
