Go to primary content
Oracle® Communications Diameter Signaling Router Roaming Steering
Release 8.4
F12306
Contents
Previous
Next
Adding a new SoR_Profile entry
Use this task to add SoR provisioning entries.
Navigate to
DCA Framework
DCA Roaming Steering
Application Control
Select
DCA_SOR
Select a
Version Name
Select a
Config Tables and Data
Select a
Table Name
Select a
Provision Table
Fill out the fields to define the table. The field values you provide define either Config_Params or SoR_Profile configuration parameters (this depends on which provision option that you selected).
See
Config_Params Provision Tables elements
and
SoR_Profile Provision Tables elements
