Go to primary content
Oracle® Communications Diameter Signaling Router Roaming Steering
Release 8.4
F12306
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Configuring SoR Provisioning Tables
Use this task to configure SoR provisioning tables.
The available GUI choices differ between the SO and the NO.
The fields are described in Table 3-3 and Table 3-4.
  1. Select DCA Framework > Roaming of Steering > Application Control.
  2. Select a Version Name choice.
  3. Click the appropriate action button; for example, Config Tables and Data on the NO or Config Data on the SO.
  4. Select a Table Name.
  5. Select Provision Table.
  6. Fill out the fields to define or edit the selected table.
  7. Click OK or Apply to complete the task.
