| Oracle® Communications Diameter Signaling Router Roaming Steering Release 8.4 F12306 |
![]() Previous |
![]() Next |
Table 3-3 describes the fields on the Config_Params Provision Table page.
Table 3-3 Config_Params Provision Tables elements
| Field (* indicates a required field) | Description | Data Input Notes |
| * MaximumAttempts | The maximum number of consecutive rejections per subscriber. | Format: Numeric Range: 1 - 100 characters Default: 5 |
| * MaxNumOfRejectionsPerMNO | The maximum number of consecutive rejections per MNO per subscriber | Format: Numeric Range: 1 - 100 characters Default: none |
| RejectionCode | The rejection code to use with a ULA. | Format: Numeric Range: 6000 - 9999 characters Default: NA |
| RejectionText | The text to be added in an Error-Message AVP to indicate what caused the error. If the rejection code was indicated, this field must not be empty. | Format: Alpha Range: 1 - 100 characters Default: NA |
| UnknownVPLMN | Select to reject or accept traffic from an unknown VPLMN. | Format: Option Range: Accept/Reject Default: Reject |
