Assigning Maintenance Staff to Room Maintenance Orders
Use Room Maintenance to assign a staff member to room maintenance orders. You can search for orders by entering the property name and additional search criteria.
From the OPERA Cloud menu, select Inventory, select Room Management, and then select Room Maintenance.
On the Room Maintenance screen, click New. Enter the following information and click Save.
Room: Search and select the Room(s) for which you want to assign a maintenance request
Assigned To: Search and select the staff member responsible for the maintenance request.
Expected By: Select the date by which the repair or maintenance is expected to be resolved.
Reason: Select the appropriate reason for maintenance.
Remarks: Enter any further information or notes for the maintenance request.
