To report a maintenance request for a room and assign it to a staff for resolving, do the following:
From the OPERA Cloud Administration menu, select Inventory, select Accommodation Management, and then select Room Maintenance.
On the Room Maintenance screen, click New. Enter the following information and click Save:
Code: Enter a unique code to identify the room maintenance request code.
Description: Enter an appropriate description for the Room Maintenance request - the description should ideally describe what the Room Maintenance is about.
Sequence: Enter a number to determine the order in which room maintenance codes are displayed when listed. When two or more room maintenance have the same sequence number, they are displayed alphabetically.
Inactive: Select the check box to make the room maintenance request inactive. The inactive room maintenance requests are not available for selection when assigning them to rooms.
