Go to main content
手册页部分 1:用户命令
退出打印视图
更新时间: 2022年7月27日 星期三
dejagnu-help (1)
名称
dejagnu-help - display manual pages for DejaGnu auxiliary commands
用法概要
dejagnu help [options...] <command>
描述
DEJAGNU-HELP(1)             User's Reference Manual            DEJAGNU-HELP(1)
NAME
     dejagnu help -- display manual pages for DejaGnu auxiliary commands
SYNOPSIS
DESCRIPTION
     The dejagnu help command displays long-form documentation for DejaGnu
     auxiliary commands.
OPTIONS
     -v, --verbose  Emit additional output describing the operation of
                    dejagnu help itself.
     -w, --path     This option is simply passed on to man.
     -W             This option is simply passed on to man.
FILES
     The dejagnu help command checks for man pages in a doc/ directory next to
     the commands/ directory where this script is located.  If the page is
     found there, a full file name is given to man.  Otherwise, only the com-
     mand name is given and the search described in man(1) is performed.
ATTRIBUTES
     See attributes(7) for descriptions of the following attributes:
     |ATTRIBUTE TYPE |    ATTRIBUTE VALUE     |
     |Availability   | developer/test/dejagnu |
     |Stability      | Uncommitted            |
SEE ALSO
     man(1)
AUTHORS
     Jacob Bachmeyer
BUGS
     Currently only supports man pages.
NOTES
     Source code for open source software components in Oracle Solaris can be
     found at https://www.oracle.com/downloads/opensource/solaris-source-code-
     downloads.html.
     This software was built from source available at https://github.com/ora-
     cle/solaris-userland.  The original community source was downloaded from
     https://ftp.gnu.org/gnu/dejagnu/dejagnu-1.6.3.tar.gz.
     Further information about this software can be found on the open source
     community website at https://www.gnu.org/software/dejagnu.
GNU                            December 19, 2018                           GNU
