Go to main content
手册页部分 1:用户命令
退出打印视图
更新时间: 2022年7月27日 星期三
npm-help (1)
名称
npm-help - Get help on npm Synopsis npm help <term> [<terms..>] alias: hlep Note: This command is unaware of workspaces. Description If supplied a topic, then show the appropriate documentation page. If the topic does not exist, or if multiple terms are provided, then npm will run the help-search command to find a match. Note that, if help-search finds a single subject, then it will run help on that topic, so unique matches are equivalent to specifying a topic name. Configuration viewer o Default: "man" on Posix, "browser" on Windows o Type: String The program to use to view help content. Set to "browser" to view html help content in the default web browser. See Also o npm help npm o npm help folders o npm help config o npm help npmrc o npm help package.json o npm help help-search
用法概要
Please see following description for synopsis
描述
NPM-HELP(1)                                                        NPM-HELP(1)
NAME
   Synopsis
         alias: hlep
   Description
   Configuration
   viewer
       o Type: String
   See Also
       o npm help npm
       o npm help folders
       o npm help config
       o npm help npmrc
ATTRIBUTES
       See attributes(7) for descriptions of the following attributes:
       |ATTRIBUTE TYPE |     ATTRIBUTE VALUE      |
       |Availability   | runtime/nodejs/nodejs-18 |
       |Stability      | Pass-thru volatile       |
NOTES
       Source code for open source software components in Oracle  Solaris  can
       be found at https://www.oracle.com/downloads/opensource/solaris-source-
       code-downloads.html.
       This    software    was    built    from    source     available     at
       https://github.com/oracle/solaris-userland.    The  original  community
       source   was   downloaded   from     https://github.com/nodejs/node/ar-
       chive/v18.1.0.zip.
       Further information about this software can be found on the open source
       community website at https://github.com/nodejs/node.
                                  April 2022                       NPM-HELP(1)
