PreviousNextJavaScript must be enabled to correctly display this content
Changing the Default Administrator Password
To
change the default administrator password:
In the top-right
corner of the Operations Monitor web interface, select admin and then select
My Profile.
The Edit own user information dialog box
opens, as shown in Figure 2-1.
In the
Set password
field, enter a new password.
In the Repeat
password field, re-enter the password used in the
Set password
field, which verifies that the password value was entered correctly.
Click
Finish.
Important:
The default administrator password, which is provided in the
documentation is not secure. Oracle strongly recommends that you change it to a
secure password, especially before creating sub-users.
