Examples
List the last 20 calls:
curl -k -X POST -H "X-API-Key: API_Key" -d "limit=20" "https://IP:Port/me/getPagedCalls"
where,
API_Key, is your personal key code. For more information on how to generate this key, see "API Key".
IP, is the IP address of Oracle Communications Session Monitor Mediation Engine.
Port, is the port number of the SSL web interface of Mediation Engine. The :Port section can be omitted if the default HTTPS port (443) is used.
Get the next 20 calls (after executing the previous example):
curl -k -X POST -H "X-API-Key: API_Key" -d "limit=20&older_than=next_value" "https://IP:Port/me/getPagedCalls"
Where next_value is the returned content of the next_value field from the previous example.
List all failed calls starting from last week, from a specific caller:
curl -k -X POST -H "X-API-Key:API_Key" -d 'filters=[{"field":"src_user","data":{"type":"string","value":"src_user"}}, {"field":"setup_start_ts","data":{"type":"datetime","comparison":"gt", "value":"start_date"}}, {"field":"state_msg","data":{"type":"list","value":["Failed"]}}]' "https://IP:Port/me/getPagedCalls"
Where,
src_user, is the ID of the user whose failed calls your retrieving.
start_date, specifies the starting date to retrieve failed calls. The format is YYYY-MM-DD hh:mm:ss, for example 2015-04-13 00:00:00.
