IMSI Search
The IMSI Search page (see Figure 6-6) displays information about a particular IMSI. To choose the IMSI you can either enter it in the search box from the top of the page or use the right-click menu from the Transactions list.
Figure 6-6 Control Plane Monitor IMSI Search Page
Description of "Figure 6-6 Control Plane Monitor IMSI Search Page"
The Summary section provides high-level information about the selected IMSI number, including the current attachment state and the phone number.
The transactions list from the bottom is similar with the one from the Transactions page, but it is pre-filtered by the selected IMSI.
