KPI/Metrics
The Control Plane Monitor KPI/Metrics page offers similar functionality as the KPI/Metrics page from the Operations Monitor product. The difference is that only Diameter specific KPIs are available, and they are not editable.
Figure 6-1 shows the Control Plane Monitor KPI/Metrics page.
Figure 6-1 Control Plane Monitor KPI/Metrics Page
Description of "Figure 6-1 Control Plane Monitor KPI/Metrics Page"
Currently, the following Platform Wide KPIs are available:
Diameter transactions
Number of new hop-by-hop Diameter transactions per second that pass the filter configured in the Platform Setup Application, regardless of Application ID.
S6 Diameter transactions
Number of new hop-by-hop Diameter transactions per second that have the Application ID 16777251 (3GGP S6a/S6d).
S13 Diameter transactions
Number of new hop-by-hop Diameter transactions per second that have the Application ID 16777252 (3GGPS13/S13').
Successful Update Location transactions
Number of completed hop-by-hop Diameter transactions per second that have the Diameter command 316 (Update Location) and the result code 2001 (Success).
Failed Update Location transactions
Number of completed hop-by-hop Diameter transactions per second that have the Diameter command code 316 (Update Location) and a result code different from 2001 (Success).
Successful Cancel Location transactions
Number of completed hop-by-hop Diameter transactions per second that have the Diameter command 317 (Cancel Location) and the result code 2001 (Success).
Failed Cancel Location transactions
Number of completed hop-by-hop Diameter transactions per second that have the Diameter command code 317 (Cancel Location) and a result code different from 2001 (Success).
The following KPIs are available on a per-device basis:
Incoming S6 Diameter transactions
Number of new Diameter transactions per second that are received by the given device and have the Application ID 16777251 (3GGP S6a/S6d).
Outgoing S6 Diameter transactions
Number of new Diameter transactions per second that are created by the given device and have the Application ID 16777251 (3GGP S6a/S6d).
Successful incoming Update Location transactions
Number of completed Diameter transactions that are received by the given device and have the Diameter command 316 (Up- date Location) and the result code 2001 (Success).
Failed incoming Update Location transactions
Number of completed Diameter transactions that are received by the given device and have the Diameter command 316 (Update Location) and a result code different from 2001 (Success).
Successful incoming Cancel Location transactions
Number of completed Diameter transactions that are received by the given device and have the Diameter command 317 (Cancel Location) and the result code 2001 (Success).
Failed incoming Cancel Location transactions
Number of completed Diameter transactions that are received by the given device and have the Diameter command 317 (Cancel Location) and a result code different from 2001 (Success).
