PreviousNextJavaScript must be enabled to correctly display this content
Start the Cluster Installation
You can install a high-availability (HA) cluster of
OCSDM servers to ensure
reliable, continuous data and operations by masking both planned and unplanned
downtime and preventing single points of failure without compromising
availability.
Login to your
server as root user.
Navigate to the
Oracle Communications Session
Delivery Manager installation bin directory.
For example:
cd /<sdm-install-directory>/AcmePacket/NNC<version>/bin
Run the setup.sh
script.
./setup.sh
A
warning message appears if you have less than the recommended minimum physical
memory. Proceeding without the recommended minimum physical memory may result
in performance degradation.
WARNING:
This process may take several
minutes to complete. Interrupting the setup.sh process risks corrupting the
system.
Repeat the previous
steps on each server node in the cluster.
After the each
cluster node is complete, refer to the
Configure the
Installed Session Delivery Manager Cluster chapter for more information
on associating the cluster nodes that you installed with each other so that
they can function together as a cluster.
