If you have access to the Oracle Business Intelligence (OBI) portlet, you can access the analysis reports that you created and saved to your personal folder.
In the OPERA Reporting and Analytics side menu, click the link to go to the Analysis Reports page. If you cannot find the link, contact your system administrator.
Click Modify/Delete Analysis.
In My Folders, navigate to the analysis report.
To edit the analysis report, click Edit. Changes to the report only affect your local instance and do not affect the published instance of the report. If you want to apply changes to a published report, you must unpublish and then republish the report.
To print the analysis report, right-click the report, click Print, and then select a printable format.
To export the analysis report, right-click the report, click Export, and then select a file or data format.
To delete the analysis report, right-click the report, and then click Delete. This does not affect the published instance of a report.
To make a copy of the analysis report, right-click the report, and then click Copy.
To change the filename of the analysis report, right-click the report, and then click Rename. This does not affect the published instance of a report.
