Analysis Reports enforce file permissions by restricting access to the My Folder
for each user account and to the Shared Folder
for each organization:
Only the specific user can view and access the contents of their My Folder
All users can view the content of the Shared Folder
but cannot enact changes.
When you create an analysis report, the system creates and saves the report in your My Folder
. This prevents all other users from being able to run and perform modifications on your report.
When you publish the report, the system creates a copy of your saved report in the Shared Folder
, and allows users without access to the OBIEE Analysis portlet to run the report.
Deleting a report in your My Folder
does not impact the published copy of the report. You must unpublish the report to remove the published copy.
Shared Folder
or to change the users and roles for which the report is published:
Shared Folder
for all users and roles, use the filters to find and select the report for which you want to configure permissions, and then click Unpublish.
