Hardware Installation Summary
Installing the Oracle Enterprise Communications Broker (OECB) in your rack requires the steps summarized below. This checklist is only an overview. It is not designed to substitute for following the detailed procedures in the hardware installation guides.
If running the OECB as a virtual application, refer to the hardware vendor's installation instructions for hardware to learn how to access the software while it boots. From a console connection, there is little difference to the way successful startup appears as an appliance versus a virtual machine.
