Log On to the System
The Oracle Enterprise Communications Broker (OECB) requires you to set passwords for the Admin and User accounts the first time you power up a new or factory reset system by way of local access. You cannot access the Admin and User accounts until you set the corresponding passwords. Use either an SSH connection or console connection when setting passwords. You can log on to the system after setting passwords.
Before you begin,
plan your passwords to meet the following requirements:
- 8-64 characters
- Include three of the
following:
- Lower case letters
- Uppercase letters
- Numerals
- Punctuation
The system leads you through the process for setting the Admin and User passwords, as follows:
