System Reboot
You can manually reboot the Oracle Enterprise Communications Broker (OECB) from the Web GUI. If you have a High Availability (HA) deployment, connectivity to the standby OECB stops until the reboot completes.
When the reboot completes, the active and standby systems each display the log on screen and you must manually log on to each system.
When you reboot the system from the Web GUI, the Web GUI is unavailable until the reboot completes.| When you perform a reboot from the Web GUI | The system behaves |
| and no boot is in process and the system is not switching over to the standby system of an HA pair, | the GUI session closes and the system displays the Log On screen. You cannot log on to the Web GUI until the reboot completes on the OECB. |
| and a reboot is already in progress, | the system displays a message stating that a reboot cannot occur. The first reboot must complete before another reboot is initiated. |
| and the active system is currently switching over to the standby system in an HA environment, | the system displays a message stating that a reboot cannot occur because the HA switch over is underway. The standby OECB is updating and getting its configuration from the active OECB. |
