Display Log Files The Oracle Enterprise Communications Broker (OECB) allows you to view log files without needing to download them. Access the File Management page. Click System, File Management. On the File Management page, select a Log file from list. Expand a log file category and select a log file by selecting the check box by the file name. The OECB enables the View control. Click View. The OECB displays the Viewing log:[filename] dialog with the log file's contents.
