The Corporate Data Transfer Interface (CDTI) provides a mechanism for transferring data to external systems outside of customer domain to other vendors too. It is based at shore-side location and uses the Fleet Management database. This interface is flexible and dynamic and enables the shore-side user to modify settings to provide formatted/customized solution.
Transmission Control Protocol/Internet Protocol (TCP/IP) Connectivity - This method allow the external system to establishes a direct connection to the Corporate Data Transfer Interface (CDTI), and on the Listener port as and when required and poll data based on pre-agreed messages. The external system would also open a listener port which allow the Corporate Data Transfer Interface (CDTI) to send any triggered messages. This method sends a full record in one message.
Flat File Transfer - Enables you to assign a pre-agreed folder as the location to place the files whenever it is scheduled to do so.
Microsoft Message Queuing - This method is provided on-demand, only if the external system can work with Microsoft Message Queuing (MSMQ). If it is, then messages are transferred over Microsoft Message Queuing (MSMQ) to a pre-defined queue with the structure being exactly similar to that of the Transmission Control Protocol/Internet Protocol (TCP/IP) Connectivity. In this method, one message contains one full record only.
Web Service- This method allows you to call web service methods periodically using the required parameters.
In Exporter, data transfer is done through File transfer and web service. In Importer, data transfer is done through TCP/IP, MSMQ.
Extensible Markup Language (XML) format - This follows the Extensible Markup Language (XML) Schema 1.1 standard. This method is available in all three methods of data transfer.
Delimited Flat File - This method enables the Corporate Data Transfer Interface (CDTI) to throw an output in tab-separated values (TSV), comma-separated values (CSV) or any other user-defined delimiting character. This method is available only in the Flat File data transfer.
Fixed Length Flat File - This enables the Corporate Data Transfer Interface (CDTI) to write output in a pre-defined fixed length for each column in the transfer. This method is available only in the Flat File data transfer.
JSon Format –This format is used for web service integration only.
Triggered Messages - These are messages that the Corporate Data Transfer Interface (CDTI) sends automatically to the external system whenever an event is triggered. This could be when a particular cruise is closed in the cruise table or after a certain time of the cruise closing, to ensure all data from the ship has transferred completely from the ship to shore. This method supports all three data transfers.
On-Demand Messages - These are pre-defined messages that the external system sends to the Corporate Data Transfer Interface (CDTI) and gets an answer in a pre-defined format. This method only supports the Transmission Control Protocol/Internet Protocol (TCP/IP) and Microsoft Message Queuing (MSMQ) transfer methods.
Inward Connection - There are two types of Inward connections you can use - Transmission Control Protocol/Internet Protocol (TCP/IP) and Microsoft Message Queuing (MSMQ). On the Transmission Control Protocol/Internet Protocol (TCP/IP), you can define the port that the Corporate Data Transfer Interface (CDTI) should open and listen. On the Microsoft Message Queuing (MSMQ), you can define the name of the Private Queue on the local machine that the Corporate Data Transfer Interface (CDTI) should poll regularly.
Outward Connection - You can define, as many Outward connections as there are external systems. One External system can also have more than one Outward Connection. The Outward Connections can also include the Flat File Transfer.
Request:
<?xml version=1.0 standalone=yes?>
<request>
<shipid>SHIP_ID</shipid>
<sailingdate>SAILING_DATE</sailingdate>
<guestid>GUEST_ID</guestid>
</request>
Response:
<response>
<type>Passenger Reservations</type>
<cancel>N</cancel>
<booking>
<personalinfo>
<firstname>Name</firstname>
<lastname>LastName</lastname>
<dateofbirth>DATE_OF_BIRTH</dateofbirth>
<gender>PASSENGER_GENDER</gender>
</personalinfo>
<passportinfo>
<nationality>Country</nationality>
<passportno>PASSPORT_NO</passportno>
<passportissuedate>PASSPORT_ISSSUE_DATE</passportissuedate>
<passportissueplace>PlaceofIssue</passportissueplace>
<passportexpirydate>PASSPORT_EXPIRY_DATE</passportexpirydate>
</passportinfo>
<cabininfo>
<cabintype>CABIN_TYPE</cabintype>
</cabininfo>
