Adding a Schema Entry
Add Schema is the third tab of the Database Schema Password Manager. This tab is used to add a new schema entry to the FIDELIOBK schema.
To add a new schema entry:
  1. On the Database Schema Password Manager screen, click ... to map to the TNS file on the local machine.
  2. Click the Connection Name drop-down and select the appropriate schema connection.
  3. Select the schema for which you wish to add a new entry.
  4. Click the Add Schema tab, and then enter the following information:
    • System User: Enter the database system user name.
    • System Password: Enter the system user password.
    • Schema Name: Enter the name for the new schema entry.
    • Schema Password: Enter the password for the new schema.
    • Expiry Date: Enter the expiration date.
    The latest encryption key is used for new entries.
  5. Click Add User to complete the addition of a new schema entry.
Figure 8-3 Add Schema tab in the Database Schema Password Manager screen
This figure shows the Add Schema tab on the Database Schema Password Manager screen.
