Tracking Records Setting Steps
The batch level tracking of records is a new feature of Sender and Receiver. Batch level tracking is explained in the following steps:
  1. Data transfer of tables occurs through batches.
    Figure 13-4 Direction Group Queue Must Be Active And Schedule Must Be Checked
    This figure shows the Direction Group Queue Must Be Active And Schedule Must Be Checked
  2. In the Sender interface, the direction group queue must be active and schedule must be enabled.
    Figure 13-5 FMS_TRANS_LOG in FIDELIO Schema
    This figure shows the FMS_TRANS_LOG in FIDELIO Schema
  3. The FMS_TRANS_LOG table on the ship side in FIDELIO schema and on the shore side in FCONSOL Schema contains the information for the transferred tables.
    Figure 13-6 FMS_TRANS_LOG in FCONSOL Schema
    This figure shows FMS_TRANS_LOG in FCONSOL Schema
  4. The Status column in FMS_TRANS_LOG table signifies the following:
    1. status=7 signifies the table has been transferred successfully.
    2. status=8 signifies the table transferred has been failed.
  5. The Batch ID of the records with status=7 in FMS_TRANS_AUDIT table are the records which transferred successfully and status=8 are the records with errors in FCONSOL schema.
    Figure 13-7 Transfer Log Grid With Status 8
    This figure shows Transfer Log Grid With Status 8
  6. In the FMS Desktop application you can view batch level transfer error log on Transfer Log Grid With Status 8 screen and Transfer Audit Grid for viewing the record level error.
    Figure 13-8 Transfer Audit Grid
    This figure shows the Transfer Audit Grid
