For records level tracking, the columns in FIDELIO and FCONSOL Schema are as follows:
SUCCESS_ROWS >> FMS_TRAN_LOG
STATUS >> FMS_TRANS_AUDIT
ERROR>>FMS_TRANS_AUDIT
REMARKS>>FMS_TRANS_AUDIT
Status column is marked as required, initially status is 0. Then receiving side status become 7 or 8 (depending upon success or error) and the same is applied to the sending side. Sending side, retain records whose status is <> 7 for resending.
The record level tracking process is describe as the following steps:
Some errors may require help from a support team or from a Database Administrator (DBA) consultant.For example:
When you are trying to add data for a mandatory column but the column is missing from the database table.
The FMS Transfer entries are incorrect.
