| 1.
Copy the Necessary Files from the Utility
USB to Support the OS Install
This procedure is used to provide the steps
for copying all supporting files from the Utility USB to the appropriate
directories so that the OS Install Container successfully installs OL7 onto
RMS2.
The
cluster_name field is
derived from the
occne_cluster_name field in
the hosts.ini file.
- Create the
directories needed on the Installer Bootstrap Host.
$ mkdir /var/occne
$ mkdir /var/occne/<cluster_name>
$ mkdir /var/occne/<cluster_name>/yum.repos.d
- Mount the Utility
USB.
Note: Instructions for
mounting a USB in Linux are at:
OCCNE Installation of Oracle Linux 7.5 on Bootstrap Host : Install Additional
Packages. Only follow steps 1-4 to mount the USB.
- Copy the hosts.ini
file (created using procedure:
OCCNE Inventory File Preparation) into the
directory. This hosts.ini file defines RMS2 to the OS Installer Container
running the os-install image downloaded from the repo.
$ cp /media/usb/hosts.ini /var/occne/<cluster_name>/hosts.ini
Copy the customer specific
ol7-mirror.repo and the
docker-ce-stable repo on the
Utility USB to the Installer Bootstrap Host.
This is the .repo file created by the customer that
provides access to the onsite (within their network) repositories needed to
complete the full deployment of OCCNE 1.0 and to install docker-ce onto the
$ cp /media/usb/ol7-mirror.repo /var/occne/<cluster_name>/yum.repos.d/ol7-mirror.repo
$ cp /media/usb/ol7-mirror.repo /etc/yum.repos.d/ol7-mirror.repo
$ cp /media/usb/docker-ce-stable.repo /etc/yum.repos.d/docker-ce-stable.repo
If still enabled from procedure:
OCCNE Installation of Oracle Linux 7.5 on Bootstrap Host, the
/etc/yum.repos.d/Media.repo is to be disabled.
$ mv /etc/yum.repos.d/Media.repo /etc/yum.repos.d/Media.repo.disable
- Copy the updated
version of the kickstart configuration file to /var/occne/<cluster_name>
directory.
$ cp /media/usb/occne-ks.cfg.j2.new /var/occne/<cluster_name>/occne-ks.cfg.j2.new
| 2.
Copy the OL7 ISO to the Installer Bootstrap
Host
The iso file should be accessible from a Customer Site
Specific repository. This file should be accessible because the ToR switch
configurations were completed in procedure:
OCCNE Configure Top of Rack 93180YC-EX Switches.
Copy from RMS1, the OL7 ISO file to the /var/occne directory.
The example below uses OracleLinux-7.5-x86_64-disc1.iso.
Note: If
the user copies this ISO from their laptop then they must use an application
like WinSCP pointing to the Management Interface IP.
$ scp <usr>@<site_specific_address>:/<path_to_iso>/OracleLinux-7.5-x86_64-disc1.iso /var/occne/OracleLinux-7.5-x86_64-disc1.iso
| 3.
Install Docker onto the Installer Bootstrap
Host
Use YUM to install docker-ce onto the installer Bootstrap
Host. YUM should use the existing <customer_specific_repo_file>.repo in
the /etc/yum.repos.d directory.
$ yum install docker-ce-18.06.1.ce-3.el7.x86_64
| 4.
Set up access to the Docker Registry on the
- Add an entry to
the
/etc/hosts file on the
Installer Bootstrap Host to provide a name mapping for the docker registry
using the hosts.ini file fields
occne_private_registry
and
occne_private_registry_address
in
OCCNE
Inventory File Preparation.
<occne_private_registry_address>
<occne_private_registry>
Example:10.75.200.217 reg-1
- Create the
/etc/docker/daemon.json file
on the Installer Bootstrap Host. Add an entry for the insecure-registries for
the docker registry.
$ mkdir /etc/docker
$ vi /etc/docker/daemon.json
Enter the following:
"insecure-registries": ["<occne_private_registry>:<occne_private_registry_port>"]
Example:
cat /etc/docker/daemon.json
"insecure-registries": ["reg-1:5000"]
To Verify:
ping <occne_private_registry>
Example:
# ping reg-1
PING reg-1 (10.75.200.217) 56(84) bytes of data.
64 bytes from reg-1 (10.75.200.217): icmp_seq=1 ttl=61 time=0.248 ms
64 bytes from reg-1 (10.75.200.217): icmp_seq=2 ttl=61 time=0.221 ms
64 bytes from reg-1 (10.75.200.217): icmp_seq=3 ttl=61 time=0.239 ms
- Create the docker
service http-proxy.conf file.
$ mkdir -p /etc/systemd/system/docker.service.d/
$ vi /etc/systemd/system/docker.service.d/http-proxy.conf
Add the following:
[Service]
Environment="NO_PROXY=<occne_private_registry_address>,<occne_private_registry>,127.0.0.1,localhost"
Example:
[Service]
Environment="NO_PROXY=10.75.200.217,reg-1,127.0.0.1,localhost"
- Start the docker
daemon
$ systemctl daemon-reload
$ systemctl restart docker
$ systemctl enable docker
Verify docker is running:
$ ps -elf | grep docker
$ systemctl status docker
| 5.
Setup NFS on the Installer Bootstrap Host
Run the following commands (assumes nfs-utils has already been
installed in procedure:
Packages).
Note: The
IP address used in the echo command is the Platform VLAN IP Address (VLAN 3) of
the Bootstrap Host (RMS 1) as given in:
OCCNE 1.0 Installation PreFlight Checklist : Complete Site Survey Host
Table.
$ echo'/var/occne 172.16.3.4/24(ro,no_root_squash)'>> /etc/exports
$ systemctl start nfs-server
$ systemctl enable nfs-server
Verify nfs is running:
$ ps -elf | grep nfs
$ systemctl status nfs-server
| 6.
Set up the Boot Loader on the Installer
Bootstrap Host
Execute the following commands:
$ mkdir -p /var/occne/pxelinux
$ mount -t iso9660 -o loop /var/occne/OracleLinux-7.5-x86_64-disc1.iso /mnt
$ cp /mnt/isolinux/initrd.img /var/occne/pxelinux
$ cp /mnt/isolinux/vmlinuz /var/occne/pxelinux
| 7.
Verify and Set the PXE Configuration File
Permissions on the Installer Bootstrap Host
Each file configured in the step above must be open for read
and write permissions.
$ chmod 777 /var/occne/pxelinux
$ chmod 777 /var/occne/pxelinux/vmlinuz
$ chmod 777 /var/occne/pxelinux/initrd.img
| 8.
Disable DHCP and TFTP on the Installer
Bootstrap Host
The TFTP and DHCP services running on the Installer Bootstrap
Host may still be running. These services must be disabled.
$ systemctl stop dhcpd
$ systemctl disable dhcpd
$ systemctl stop tftp
$ systemctl disable tftp
| 9.
Disable SELINUX
SELINUX must be set to permissive mode. In order to
successfully set the SELINUX mode, a reboot of the system is required. The
getenforce command is used
to determine the status of SELINUX.
$ getenforce
active
If the output of this command displays active, change it to permissive by editing the /etc/selinux/config file.
$ vi /etc/selinux/config
Change the SELINUX variable to passive: SELINUX=permissive
save the file
Reboot the system: reboot
| 10.
Execute the OS Install on RMS2 from the
This step requires executing docker run for four different
Ansible tags.
The initial OS install is performed from the OS install container running
bashbecause the new kickstart configuration file must be copied over the
existing configuration prior to executing the Ansible playbook.
- Run the docker
command below to install the OS onto RMS2. This first command installs the OS
while the subsequent commands (steps) set up the environment for yum repository
support, datastore, and security. These commands must be executed in the order
listed. This command can take up to 30 minutes to complete.
$ docker run -it --rm --network host --cap-add=NET_ADMIN -v /var/occne/rainbow.lab.us.oracle.com/:/host -v /var/occne/:/var/occne:rw <image_name>:<image_tag> bash
Example:
$ docker run -it --rm --network host --cap-add=NET_ADMIN -v /var/occne/rainbow/:/host -v /var/occne/:/var/occne:rw reg-1:5000/os_install:1.0.1 bash
- From the
container, copy the /var/occne/occne-ks.cfg.j2.new file (which is mounted to
the /host directory on the container) over the existing
/install/os-install/roles/pxe_config/templates/ks/occne-ks.cfg.j2 file.
$ cp /host/occne-ks.cfg.j2.new /install/roles/pxe_config/templates/ks/occne-ks.cfg.j2
- Install the OS
onto each host using the ansible command indicated below. This command installs
the OS while the subsequent commands (steps) set up the environment for yum
repository support, datastore, and security. This command can take up to 30
$ ansible-playbook -i /host/hosts.ini --become --become-user=root --private-key /host/.ssh/occne_id_rsa /install/os-install.yaml --limit <RMS2 db node from hosts.ini file>,localhost --skip-tags "ol7_hardening,datastore,yum_update"
Example:
ansible-playbook -i /host/hosts.ini --become --become-user=root --private-key /host/.ssh/occne_id_rsa /install/os-install.yaml --limit db-2.rainbow.lab.us.oracle.com,localhost --skip-tags "ol7_hardening,datastore,yum_update"
Configure db-2 management interface.
The <vlan_4_ip_address> is from
OCCNE 1.0 Installation PreFlight Checklist : Complete Site Survey Host IP
Table.
The <ToRswitch_CNEManagementNet_VIP> is from
OCCNE 1.0 Installation PreFlight Checklist : ToR and Enclosure Switches
Variables Table (Switch Specific).
$ scp /tmp/ifcfg-* root@<db-2 host_net address>:/tmp
$ ssh root@<db-2 host_net address>
$sudo su
$ cd /etc/sysconfig/network-scripts/
$ cp /tmp/ifcfg-vlan ifcfg-team0.4
$ sed -i 's/{BRIDGE_NAME}/vlan4-br/g' ifcfg-team0.4
$ sed -i 's/{PHY_DEV}/team0/g' ifcfg-team0.4
$ sed -i 's/{VLAN_ID}/4/g' ifcfg-team0.4
$ sed -i 's/{IF_NAME}/team0.4/g' ifcfg-team0.4
$ echo "BRIDGE=vlan4-br" >> ifcfg-team0.4
$ cp /tmp/ifcfg-bridge ifcfg-vlan4-br
$ sed -i 's/{BRIDGE_NAME}/vlan4-br/g' ifcfg-vlan4-br
$ sed -i 's/DEFROUTE=no/DEFROUTE=yes/g' ifcfg-vlan4-br
$ sed -i 's/{IP_ADDR}/<vlan_4_ip_address>/g' ifcfg-vlan4-br
$ sed -i 's/{PREFIX_LEN}/29/g' ifcfg-vlan4-br
$ echo "GATEWAY=<ToRswitch_CNEManagementNet_VIP>" >> ifcfg-vlan4-br
$ service network restart
- Execute yum-update
using docker.
This step disables any existing .repo files that are
currently existing in directory /etc/yum.repos.d on RMS after the OS Install.
It then copies any .repo files in the /var/occne/<cluster_name> directory
into the /etc/yum.repos.d and sets up the customer repo access.
$ docker run --rm --network host --cap-add=NET_ADMIN -v /var/occne/<cluster_name>/:/host -v /var/occne/:/var/occne:rw -e "OCCNEARGS=--limit <RMS2 db node from hosts.ini file>,localhost --tags yum_update" <image_name>:<image_tag>
Example:
$ docker run -it --rm --network host --cap-add=NET_ADMIN -v /var/occne/rainbow/:/host -v /var/occne/:/var/occne:rw -e "OCCNEARGS=--limit db-2.rainbow.lab.us.oracle.com,localhost --tags yum_update" reg-1:5000/os_install:1.0.1
- Check the
/etc/yum.repos.d directory on RMS2 for non-disabled repo files. These files
should be disabled. The only file that should be enabled is the customer specif
.repo file that was set in the /var/occne/<cluster_name>/yum.repos.d
directory on RMS1. If any of these files are not disabled then each file must
be renamed as <filename>.repo.disabled.
$ cd /etc/yum.repos.d
$ ls
Check for any files other than the customer specific .repo file that are not listed as disabled. If any exist, disable them using the following command:
$ mv <filename>.repo <filename>.repo.disabled
- Execute datastore
using docker.
$ docker run --rm --network host --cap-add=NET_ADMIN -v /var/occne/<cluster_name>/:/host -v /var/occne/:/var/occne:rw -e "OCCNEARGS=--limit <RMS2 db node from hosts.ini file>.oracle.com,localhost --tags datastore" <image_name>:<image_tag>
Example:
$ docker run -it --rm --network host --cap-add=NET_ADMIN -v /var/occne/rainbow/:/host -v /var/occne/:/var/occne:rw -e "OCCNEARGS=--limit db-2.rainbow.lab.us.oracle.com,localhost --tags datastore" reg-1:5000/os_install:1.0.1
Execute the OL7 hardening using docker.
Note: The two extra-vars
included in the command are not used in the context of this command but need to
be there to set the values to something other than an empty string.
$ docker run --rm --network host --cap-add=NET_ADMIN -v /var/occne/<cluster_name>/:/host -v /var/occne/:/var/occne:rw -e "OCCNEARGS=--limit <RMS2 db node from hosts.ini file>,localhost --tags ol7_hardening --extra-vars ansible_env=172.16.3.4 --extra-vars http_proxy=172.16.3.4" <image_name>:<image_tag>
Example:
$ docker run -it --rm --network host --cap-add=NET_ADMIN -v /var/occne/rainbow/:/host -v /var/occne/:/var/occne:rw -e "OCCNEARGS=--limit db-2.rainbow.lab.us.oracle.com,localhost --tags ol7_hardening --extra-vars ansible_env=172.16.3.4 --extra-vars http_proxy=172.16.3.4" reg-1:5000/os_install:1.0.1
