| 1.
Login to RMS2 from RMS1
Login using the admusr account and the private key generated
when the OS Install was completed on RMS2. Sudo to root after logging in.
$ ssh -i /var/occne/rainbow.lab.us.oracle.com/.ssh/occne_id_rsa admusr@172.16.3.5
$ sudo su -
| 2.
Install Necessary RPMs
Install the following files from the ISO USB onto RMS2.
$ yum install qemu-kvm libvirt libvirt-python libguestfs-tools virt-install -y
| 3.
Configure the Kickstart file
The initial setup includes steps to configure the kickstart
file and create the bridge necessary for the VM to network to the system hosts.
- Mount the Utility
USB.
Note: Instructions for
mounting a USB in Linux are at:
OCCNE Installation of Oracle Linux 7.5 on Bootstrap Host : Install Additional
Packages. Only follow steps 1-4 to mount the USB.
- Copy the kickstart
file from the Utility USB to the
/tmp directory as
bastion_host.ks on
RMS2.
Note: The
/tmp location is highly
volatile and may be cleaned out on reboot. It is strongly recommended to put
this somewhere else for safe keeping. It can always be downloaded again.
$ cp /media/usb/bastion_host.ks /tmp/bastion_host.ks
- Update the
kickstart file using the following commands to set the following file
variables:
BASTION_VLAN2_IP
BASTION_VLAN3_IP
BASTION_VLAN4_IP
BASTION_VLAN4_MASK
GATEWAYIP
NODEHOSTNAME
NTPSERVERIPS
NAMESERVERIPS
HTTP_PROXY
PUBLIC_KEY
HTTP_PROXY in the
commands below require only the URL as the
http:// is provided in
the sed command. If a proxy is not needed this variable still must be set to
something as it cannot be left blank. In that case just set it to an unused IP
address.
$ sed -i 's/GATEWAYIP/<gateway_ip>/g' /tmp/bastion_host.ks
$ sed -i 's/BASTION_VLAN2_IP/<bastion_vlan2_ip>/g' /tmp/bastion_host.ks
$ sed -i 's/BASTION_VLAN3_IP/<bastion_vlan3_ip>/g' /tmp/bastion_host.ks
$ sed -i 's/BASTION_VLAN4_IP/<bastion_vlan4_ip>/g' /tmp/bastion_host.ks
$ sed -i 's/BASTION_VLAN4_MASK/<bastion_vlan4_mask>/g' /tmp/bastion_host.ks
$ sed -i 's/NODEHOSTNAME/<node_host_name>/g' /tmp/bastion_host.ks
$ sed -i 's/NAMESERVERIPS/<nameserver_ip>/g' /tmp/bastion_host.ks
$ sed -i 's/NTPSERVERIPS/<ToRswitch_Platform_VIP>/g' /tmp/bastion_host.ks
$ sed -i 's/HTTP_PROXY/http:\/\/<http_proxy>/g' /tmp/bastion_host.ks
$ sed -e '/PUBLIC_KEY/{' -e 'r /home/admusr/.ssh/authorized_keys' -e 'd' -e '}' -i /tmp/bastion_host.ks
| 4.
Configure Networking
The networking required to interface with the Bastion Host is
all handled by executing the following command set:
$ sudo su
$ cd /etc/sysconfig/network-scripts/
$ sed -i '/IPADDR/d' ifcfg-team0
$ sed -i '/PREFIX/d' ifcfg-team0
$ sed -i '/GATEWAY/d' ifcfg-team0
$ sed -i '/DEFROUTE="yes"/d' ifcfg-team0
$ echo "BRIDGE=teambr0" >> ifcfg-team0
$ cp /tmp/ifcfg-bridge ifcfg-teambr0
$ sed -i 's/{BRIDGE_NAME}/teambr0/g' ifcfg-teambr0
$ sed -i 's/{IP_ADDR}/172.16.3.5/g' ifcfg-teambr0
$ sed -i 's/{PREFIX_LEN}/24/g' ifcfg-teambr0
$ sed -i '/NM_CONTROLLED/d' ifcfg-teambr0
$ cp /tmp/ifcfg-vlan ifcfg-team0.2
$ sed -i 's/{BRIDGE_NAME}/vlan2-br/g' ifcfg-team0.2
$ sed -i 's/{PHY_DEV}/team0/g' ifcfg-team0.2
$ sed -i 's/{VLAN_ID}/2/g' ifcfg-team0.2
$ sed -i 's/{IF_NAME}/team0.2/g' ifcfg-team0.2
$ echo "BRIDGE=vlan2-br" >> ifcfg-team0.2
$ cp /tmp/ifcfg-bridge ifcfg-vlan2-br
$ sed -i 's/{BRIDGE_NAME}/vlan2-br/g' ifcfg-vlan2-br
$ sed -i 's/{IP_ADDR}/192.168.20.12/g' ifcfg-vlan2-br
$ sed -i 's/{PREFIX_LEN}/24/g' ifcfg-vlan2-br
$ service network restart
| 5.
Copy and Mount the Oracle Linux ISO
Create the
/var/occne directory on
RMS2 if not already existing.
$ mkdir /var/occne
- Verify the OL7
iso file is available from the previous procedure:
OCCNE Install Host OS onto RMS2 from the Installer Bootstrap Host - RMS1
in the
/var/occne directory.
From RMS2, SCP the Oracle Linux ISO from RMS1 into the
RMS2 and verify the permissions are set to 0644. The file should be in the
RMS1. If the file is not on RMS1 it must be downloaded from the customer
specific site where the OL is maintained onto RMS2.
Note: The example below uses
OracleLinux-7.5-x86_64-disc1.iso.
If the user copies this ISO from their laptop then they must use an application
like WinSCP pointing to the Management Interface IP.
$ scp root@172.16.3.4:/var/occne/<iso_file_name>.iso /var/occne/.
$ chmod 644 /var/occne/<iso_file_name>.iso
| 6.
Update the
qemu.conf File
- Un-comment the
user and group fields in the
/etc/libvirt/qemu.conf
file on RMS2.
$ vim /etc/libvirt/qemu.conf
Update fields:
# Some examples of valid values are:
# user = "qemu" # A user named "qemu"
# user = "+0" # Super user (uid=0)
# user = "100" # A user named "100" or a user with uid=100
user = "root"
# The group for QEMU processes run by the system instance. It can be
# specified in a similar way to user.
group = "root"
- Restart the
libvirtd service RMS2.
Note: After the restart the
service should become enabled. If an error is displayed like the following, it
can be ignored for now. A bug story has been opened to address this in a later
release.
Jun 01 16:13:14
db-2.odyssey.morrisville.us.lab.oracle.com systemd [1]
: Starting Virtualization daemon... Jun 01 16:13:14
: Started Virtualization daemon. Jun 01 16:13:15
db-2.odyssey.morrisville.us.lab.oracle.com dnsmasq
[39538] : read
/etc/hosts - 2
addresses Jun 01 16:13:15
[39538] : failed to load names from
/var/lib/libvirt/dnsmasq/default.addnhosts:
P...enied Jun 01 16:13:15
[39538] : cannot read
/var/lib/libvirt/dnsmasq/default.hostsfile:
Permission denied Hint: Some lines were ellipsized
$ systemctl daemon-reload
$ systemctl restart libvirtd
$ systemctl enable libvirtd
To Verify:
$ systemctl status libvirtd
| 7.
Create the Bastion Host VM
- Execute the
virt-install command on
RMS2.
$ virt-install --name bastion_host --memory 8192 --vcpus 2 --metadata description="Bastion Host" \
--autostart --location /var/occne/OracleLinux-7.5-x86_64-disc1.iso \
--initrd-inject=/tmp/bastion_host.ks --os-variant ol7.5 \
--extra-args "ks=file:/bastion_host.ks console=tty0 console=ttyS0,115200" \
--disk path=/var/lib/libvirt/images/bastion_host.qcow2,size=300 \
--network bridge=teambr0 --network bridge=vlan2-br --network bridge=vlan4-br
--graphics none
- After the VM
creation completes, the login prompt appears which allows the user to login to
the Bastion Host.
- To exit from the
virsh console press CTRL+ '5' keys, after logout from VM.
| 8.
Un-mount the Utility USB
Use the umount command to un-mount the Utility USB and
extract it from the USB port.
$ umount /media/usb
