| Oracle® Communications Service Communication Proxy (SCP) Cloud Native Installation Guide Release 1.0 F12352-01  |
![]() Previous  |
![]() Next  |
SCP deployment can be uninstalled as follows. Below steps needs to be executed from a server which is having access to Kubectl and helm commands.
Table 2-8 SCP Uninstall
| Step # | Procedure | Description |
				   1
				Undeploy SCP |
				   Execute the following command to uninstall SCP: $ helm delete <deployment_name> --purge  |
				   2
				Remove SCP crds |
				   Execute the following command to remove SCP crds: $ kubectl get crds -o name | grep <deployment_name>.oracle.io | xargs kubectl delete Example:
				   3
				Delete namespace |
				   Execute the following command to delete namespace: kubectl delete namespace <deployment_name> Note: Deleting namespace deletes all the other k8s objects in that namespace.  |
