| Oracle® Communications Service Communication Proxy (SCP) Cloud Native Installation Guide Release 1.0 F12352-01 |
![]() Previous |
![]() Next |
Table A-1 provides list of configuration parameters in Helm file. Refer to OCSCP Yaml File for sample file.
Table A-1 SCP Configuration Parameters
| Attribute Name | DataType | Range | Default Value | Mandatory(M)/Optional(O)/Conditional(C) | User can change? | Description |
| Global: Configuration used by all the micro services | ||||||
| domain | <string> | Labels can be letter a-z, number 0-9, hyphen(-). Hyphen cannot be first character. Label combined with dot(.) forms domain | svc.cluster.local | M | Y | Option to configure the Service Domain of the K8 cluster. |
| clusterDomain | <string> | Labels can be letter a-z, number 0-9, hyphen(-). Hyphen cannot be first character. Label combined with dot(.) forms domain | cluster.local | M | Y | Option to configure the Domain of the K8 cluster. Ideally it is domain attribute value by removing "svc." |
| publicSignalingIPSpecified | <boolean> | true/false | false | O | Y | Option to enable/disable Loadbalancer IP configuration statically for Signalling interface. |
| publicSignalingIP | <IPv4 Address> | Valid IPV4 address as per RFC 791 | N/A | C | Y | Option to configure static Signalling Loadbalancer IP. Configured value will be used only if signalingloadbalanceripenabled is configured as "true" |
| publicSignalingPort | <integer> | Min- 0 , Max-65535 | 8000 | M | Y | Option to configure Signalling Port |
| adminport | <integer> | Min- 0 , Max-65535 | 8001 | M | Y | Option to configure Admin Port (used for debugging purpose) |
| scpInfo | SCP Profile that will be used while Registering current SCP instance with NRF | |||||
| fqdn: <string> | Labels can be letter a-z, number 0-9, hyphen(-). Hyphen cannot be first character. Label combined with dot(.) forms domain | N/A | M | Y | Fully Qualified Domain Name of SCP | |
| nfType: <string> | NA | CUSTOM_ORACLE_SCP | M | N | ||
| nfStatus: <string> | NA | REGISTERED | M | N | Status of current SCP Instance | |
| locality: <string> | As per 3GPP TS 29.510 spec | N/A | M | Y | Locality of the current SCP Instance (e.g. geographic location, data center) | |
| customInfo: mateScpInfo: capacity: <integer> priority: <integer> mateSCPLocalities: - <string> servingLocalities: - <string> remainingLocalities: - <string> | capacity: Min = 0, Max = 65535, Priority: Min = 0, Max = 65535. Localities: As per 3GPP TS 29.510 spec | N/A | M | Y | capacity: Static capacity information in the range of 0-65535, expressed as a weight relative to other SCP instances of the same type. priority: Priority (relative to other SCPs) in the range of 0-65535, to be used for NF selection; lower values indicate a higher priority. mateSCPLocalities: List of serving localities of the Mate SCP(s)servingLocalities: List of serving localities of the current SCP (apart from the locality in present in "locality" attribute)remainingLocalities: List of localities which will be served by current SCP but are not part of mateSCPLocalities and servingLocalities | |
| nfInstanceId: string | String uniquely identifying a NF instance. The format of the NF Instance ID shall be a Universally Unique Identifier (UUID) version 4, as described in IETF RFC 4122 [15]. | N/A | M | Y | String uniquely identifying current SCP instance. The format of the Instance ID shall be a Universally Unique Identifier (UUID) version 4, as described in IETF RFC 4122. | |
| nrfDetails | List of NRFs to which the current SCP instance will subscribe for notifications | |||||
| - nfType: [<string>,<string>] | Valid 5g NF Type as per 3GPP TS 29.510. | [] i.e. Blank, which means subscribe for all supported NF Types. | M | Y | List of NF Types for which the current SCP instance will subscribe for notifications | |
nrfManagement:
fqdn: <string>
port: '<integer>'
scheme: HTTP2
priority: <integer>
capacity: <integer>
ipEndPoints:
- ipv4Address: <IPv4 Address>
transport: TCP
port: <integer>
fqdn: Labels can be letter a-z, number 0-9, hyphen(-).
Hyphen cannot be first character. Label combined with dot(.) forms domain.
port: 0 to 65535 priority: 0 to 65535 capacity: 0 to 65535 |
N/A | M | Y | fqdn: Fully Qualified Domain Name of NRF
port: NRF Management Service Port scheme: Always HTTP2 priority: Priority of the NRF among the NRF List. It will be used for load balancing between the NRFs. capacity: Capacity of the NRF among the NRF List. It will be used for load balancing between the NRFs. ipEndPoints: List of IPv4 Address, transport and port combination of the given NRF |
nrfDiscovery:
fqdn: <string>
port: '<integer>'
scheme: HTTP2
priority: <integer>
capacity: <integer>
ipEndPoints:
transport: TCP
port: <integer>
| scpc-soothsayer: Configuration specific to Soothsayer Micro Service | ||||||
| configuration | docker Image details for Configuration container of scpc-soothsayer | |||||
| image:repository: <docker repository>/soothsayer-configurationtag: <string>pullPolicy: Always | Repository: Name components may contain lowercase letters, digits and separators. A separator is defined as a period, one or two underscores, or one or more dashes. A name component may not start or end with a separator Tag: valid ASCII and may contain lowercase and uppercase letters, digits, underscores, periods and dashes. A tag name may not start with a period or a dash and may contain a maximum of 128 characters | N/A | M | Y | repository: docker repository that contains Configuration
container
imagetag: Image Tag to be used for Configuration container pullPolicy: Image pull policy. |
| subscription | docker Image details for Subscription container of scpc-soothsayer | |||||
| image:repository: <docker repository>/soothsayer-subscription tag: <string>pullPolicy: Always | Repository: Name components may contain lowercase letters, digits and separators. A separator is defined as a period, one or two underscores, or one or more dashes. A name component may not start or end with a separator Tag: valid ASCII and may contain lowercase and uppercase letters, digits, underscores, periods and dashes. A tag name may not start with a period or a dash and may contain a maximum of 128 characters | N/A | M | Y | repository: docker repository that contains Subscription
container
image tag: Image Tag to be used for Subscription container pullPolicy: Image pull policy. |
| notification | docker Image details for Notification container of scpc-soothsayer | |||||
| image:repository: <docker repository>/soothsayer-notification tag: <string> pullPolicy: Always | Repository: Name components may contain lowercase letters, digits and separators. A separator is defined as a period, one or two underscores, or one or more dashes. A name component may not start or end with a separator Tag: valid ASCII and may contain lowercase and uppercase letters, digits, underscores, periods and dashes. A tag name may not start with a period or a dash and may contain a maximum of 128 characters | N/A | M | Y | repository: docker repository that contains Notification
container image tag: Image Tag to be used for Notification container
| init | docker Image details for Initialization container of scpc-soothsayer | |||||
| repository: <docker repository>/soothsayer-init tag: <string> pullPolicy: Always | Repository: Name components may contain lowercase letters, digits and separators. A separator is defined as a period, one or two underscores, or one or more dashes. A name component may not start or end with a separator Tag: valid ASCII and may contain lowercase and uppercase letters, digits, underscores, periods and dashes. A tag name may not start with a period or a dash and may contain a maximum of 128 characters | N/A | M | Y | repository: docker repository that contains Initialization
container image tag: Image Tag to be used for Initialization container
| audit | docker Image details for Audit container of scpc-soothsayer | |||||
| image:repository: <docker repository>/soothsayer-audit tag: <string> pullPolicy: Always | Repository: Name components may contain lowercase letters, digits and separators. A separator is defined as a period, one or two underscores, or one or more dashes. A name component may not start or end with a separator Tag: valid ASCII and may contain lowercase and uppercase letters, digits, underscores, periods and dashes. A tag name may not start with a period or a dash and may contain a maximum of 128 characters | N/A | M | Y | repository: docker repository that contains Audit container image tag: Image Tag to be used for Audit containerpullPolicy: Image pull policy. | |
| reconfiguration | docker Image details for Re-configuration container of scpc-soothsayer | |||||
| image:repository: <docker repository>/soothsayer-reconfiguration tag: <string> pullPolicy: Always | Repository: Name components may contain lowercase letters, digits and separators. A separator is defined as a period, one or two underscores, or one or more dashes. A name component may not start or end with a separator Tag: valid ASCII and may contain lowercase and uppercase letters, digits, underscores, periods and dashes. A tag name may not start with a period or a dash and may contain a maximum of 128 characters | N/A | M | Y | repository: docker repository that contains Re-configuration container image tag: Image Tag to be used for Re-configuration containerpullPolicy: Image pull policy. | |
| defaultLocalityToScp | <boolean> | true/false | true | O | Y | TBD |
| configService | Configuration related to Configuration container | |||||
| publicConfigIPSpecified: <boolean> | true/false | false | O | Y | Option to enable/disable Loadbalancer IP configuration statically for OAM interface. | |
| publicConfigIP: <IPv4 Address> | Valid IPV4 address as per RFC 791 | N/A | C | Y | Option to configure static Loadbalancer IP. Configured value will be used only if oamloadbalanceripenabled is configured as "true" | |
| staticnodeportenabled: <boolean> | true/false | false | O | Y | Option to enable/disable configuring static Node Port for OAM interface | |
| nodeport: <integer> | As per kubernetes cluster , by default is 30000 to 32767 | 30002 | C | Y | Option to configure static Node Port for OAM interface. Configured value will be used only if staticnodeportenabledis configured as "true" | |
| configServiceNetworkNameEnabled: <boolean> | true/false | false | O | Y | Option to enable/disable metalLB IP allocation dynamically from the pool for OAM interface. | |
| configServiceNetworkName: metallb.universe.tf/address-pool:<string> | alpha-numeric | oam | C | Y | Annotation to notify metalLB to allocate a IP for OAM interface of SCP. The annotation will be added only if configServiceNetworkName is configured as "true". <TODO> Need few more updates after testing. | |
| scp-worker: Configuration specific to Worker Micro Service | ||||||
| image | docker image details for scp-worker micro service | |||||
| repository: <docker repository>/scp-worker | Repository: Name components may contain lowercase letters, digits and separators. A separator is defined as a period, one or two underscores, or one or more dashes. A name component may not start or end with a separator | N/A | M | Y | docker repository that contains scp-worker micro service image | |
| tag: <string> | Tag: valid ASCII and may contain lowercase and uppercase letters, digits, underscores, periods and dashes. A tag name may not start with a period or a dash and may contain a maximum of 128 characters | N/A | M | Y | Image Tag to be used for scp-worker micro service | |
| pullPolicy: Always | Always | O | Y | Image pull policy. | ||
| replicaCount | <integer> | NA | 2 | O | N | Minimum number of Worker Pod. |
| jaeger | Jaeger service configuration | |||||
| address: <fqdn> | Labels can be letter a-z, number 0-9, hyphen(-). Hyphen cannot be first character. Label combined with dot(.) forms domain | N/A | M | Y | Option to Configure Jaeger Collector FQDN | |
| port_value: <integer> | Min: 0 Max: 65535 | N/A | M | Y | Option to Configure Jaeger Collector Port | |
| tracingenable | <boolean> | true/false | true | O | Y | Option to enable/disable Jaeger tracing. |
| admin | ||||||
| enablejaegerbody: <boolean> | true/false | false | O | Y | Option to enable/disable tracing for full body of all Request/Response messages. The configuration will be added only if tracingenable is configured as "true". | |
| retrytimeoutvalue: <integer> | min: 1 max: 3600 | 5 | O | Y | Option to configure time to wait (in seconds) before making new requests to the a upstream cluster after receiving 503 or 429 response code. This value will only be used if 'retry-after' header is not present in response. | |
| service | ||||||
| port: staticnodeportenabled: <boolean> | true/false | false | O | Y | Option to enable/disable configuring static Node Port for Signaling interface | |
| nodeport: <integer> | As per kubernetes cluster , by default is 30000 to 32767 | 30001 | C | Y | Option to configure static Node Port for Signaling interface . Configured value will be used only if staticnodeportenabled configured as "true" | |
| networkNameEnabled: <boolean> | true/false | false | O | Y | Option to enable/disable metalLB IP allocation dynamically from the pool for Signaling interface. | |
| networkName: metallb.universe.tf/address-pool:<string> | alpha-numeric | signaling | C | Y | Annotation to notify metalLB to allocate a IP for Signaling interface of SCP. The annotation will be added only if networkNameEnabled is configured as "true". <TODO> Need few more updates after testing. | |
| loglevel | <string> | trace/debug/info/warning | warning | O | Y | Option to increase/decrease Logging level of scp-worker micro-service. |
| prometheus | scrape: <boolean> | true/false | true | O | Y | Option to enable/disable Prometheus metrics scraping |
| request | Initial requested Resource quota for scp-worker micro-service | |||||
| memory: 4096Mi | NA | 4096Mi | M | N | Requested memory (RAM) for scp-worker micro-service in Mega Bytes | |
| cpu: 4000m | NA | 4000m | M | N | Requested CPU for scp-worker micro-service in milliCPU | |
| limits | Max allocated Resource quota for scp-worker micro-service | |||||
| memory: 4096Mi | NA | 4096Mi | M | N | Max allocated memory (RAM) for scp-worker micro-service in Mega Bytes | |
| cpu: 4000m | NA | 4000m | M | N | Max allocated CPU for scp-worker micro-service in milliCPU | |
| minreplicas | <integer> | NA | 2 | M | N | Minimum replica count of scp-worker micro-service |
| maxreplicas | <integer> | Min: 2 Max: 32 | 32 | M | Y | Maximum replica count of scp-worker micro-service |
| heapoverloadcontrol: | SCP memory overload control configuration | |||||
| refresh_interval: seconds: 0 nanos: 250000000 | NA | N/A | O | N | Refresh Interval (250 milliseconds) to check memory Overload condition | |
| resource_monitors: max_heap_size_bytes: 4294967296 | NA | N/A | O | N | Max Configured Heap Size for scp-worker micro-service (4GB) | |
| actions: stop_accepting_requests: <%age in decimal value> | Min: 0 Max: 1 | 0.70 | O | Y | Option to configure threshold %age at which SCP will stop accepting new requests. | |
| stop_accepting_connections: <%age in decimal value> | Min: 0 Max: 1 | 0.75 | O | Y | Option to configure threshold %age at which SCP will stop accepting new connections. This %age should be always greater than the %age configured for stop_accepting_requests | |
| shrink_heap:<%age in decimal value> | Min: 0 Max: 1 | 0.70 | O | Y | Option to configure threshold %age at which SCP will start freeing unused memory blocks. This %age should be always minimum of threshold configured for stop_accepting_requests and stop_accepting_connections | |
| scpc-pilot: Configuration specific to Pilot Micro Service | ||||||
| image | docker image details for scpc-pilot micro service | |||||
| repository: <docker repository>/scpc-pilot | Repository: Name components may contain lowercase letters, digits and separators. A separator is defined as a period, one or two underscores, or one or more dashes. A name component may not start or end with a separator | N/A | M | Y | docker repository that contains scpc-pilot micro service image | |
| tag: <string> | Tag: valid ASCII and may contain lowercase and uppercase letters, digits, underscores, periods and dashes. A tag name may not start with a period or a dash and may contain a maximum of 128 characters | N/A | M | Y | Image Tag to be used for scpc-pilot micro service | |
| pullPolicy: Always | Always | M | Y | Image pull policy. | ||
| enableTracing | <Boolean> | true/false | True | O | Y | Option to enable/disable request .tracing |
| logOutputLevel | "<Module:level>,<Module:level>,...." | Supported Modules: ads, default, mcp, model, rbacSupported Level: debug, info, warn, error, fatal, none | "default:info" | O | Y | Option to increase/decrease scpc-pilot log level |
| logStacktraceLevel | "<Module:level>,<Module:level>,...." | Supported Modules: ads, default, mcp, model, rbacSupported Level: debug, info, warn, error, fatal, none | "default:none" | O | Y | Option to increase/decrease scpc-pilot Stack Trace level |
