| Oracle® Communications Service Communication Proxy (SCP) Cloud Native Installation Guide Release 1.0 F12352-01 |
![]() Previous |
![]() Next |
Customer NFs are required to set
http_proxy/HTTP_PROXY
to scp-worker's
<FQDN or IPV4 address>:<PORT of
SCP-Worker> for customer NFs to route messages towards SCP.
Also all NFs are required to register with NRF so that SCP can create rules based on the notifications from NRF.
Execute this command from where SCP worker and FQDN can be accessed.Table 2-7 Configure SCP as HTTP Proxy
| Step # | Procedure | Description |
1
Test successful deploy of SCP | To test SCP deployed successfully and is able
to receive message as an proxy and route it to the appropriate producer, use
the below curl command:
$ curl -v -X GET --url 'http://<FQDN:PORT of SCP-Worker>/nnrf-nfm/v1/subscriptions/' --header 'Host:<FQDN:PORT of NRF>' |
2
Fetch the current subscription list |
The curl command is to fetch the current subscription list (as a client) from NRF by sending the request to NRF via SCP. Example: $ curl -v -X GET --url 'http://scp-worker.scpsvc:8000/nnrf-nfm/v1/subscriptions/' --header 'Host:ocnrf-ambassador.nrfsvc:80' |
