| Oracle® Communications Service Communication Proxy (SCP) Cloud Native Installation Guide Release 1.0 F12352-01 |
![]() Previous |
![]() Next |
This procedure describes the steps to deploy SCP on CNE. Below steps needs to be executed from a server which is having access to Kubectl and helm commands.
Table 2-6 SCP Deployment
| Step # | Procedure | Description |
1
Search helm chart | Execute the following command to check the
version of the helm chart installation.
2
Prepare custom_values.yaml file |
Prepare a custom_values.yaml file with the required parameter information. Refer to SCP Configuration Parameters for more information on parameters. Refer to OCSCP Yaml File for sample YAML file. You can also download sample ocscp_values.yaml file from OHC, refer to Table 2-5 for more information. Note:
3
Deploy SCP using HELM repository | Execute the following command:
Where: helm-repo: repository name where the helm images, charts are stored custom_values: helm configuration file which needs to be updated based on the doctor registry deployment_name and namespace_name: depends on customer configuration For example:
helm install ocspf-helm-repo/ocscp -f <custom values.yaml> --name ocscp --namespace scpsvc --version <helm version> |
4
Deploy SCP using HELM tgz | Execute the following command:
5
Check repo status | Execute
helm
status <deployment_name> to check the deployment status.
6
Check svc status | Check if all the services are deployed and
running:
7
Check pod status | Check if all the pods are up and running:
Note: Worker and pilot status must be Running and Ready must be n/n. spfc-soothsayer status must be Running and Ready must be n/n, where n is number of containers in the pod. |
