22Data Migration Using Siebel Migration
This chapter provides guidelines for performing a migration with Siebel Migration. This chapter includes the following topics:
Incremental Migration from Development to Production Environment Without Using Siebel Migration
Full Runtime Repository Migration Without Using Siebel Migration
Migrating Repository Changes from Development to Production Environment (Siebel CRM 18.8 or Later)
Activating Tasks in the Production Environment After Full Migration
Before You Begin Migrating with Siebel Migration
Before you begin using Siebel Migration:
Review and follow the tasks listed in Roadmap for Planning a Migration with Siebel Migration
Start Siebel Migration with the following URL format:
https://<hostname>:<port>/siebel/migration
Back up your target database before starting to migrate repository or data using Siebel Migration
Process of Using Siebel Migration to Migrate Data
This procedure describes how use Siebel Migration for migration tasks. Siebel Migration tasks include:
Creating Connections. For information, see Creating a Connection.
Generating Watermarks. For more information, see Generating a Watermark.
Creating Migration Plans. For more information, see Creating a Migration Plan.
Executing Migration Plans. For more information, see Executing a Siebel Migration Plan.
Reviewing Migration History. For more information, see Viewing Migration History and Log Files.
This procedure describes how to use Siebel Migration to create a connection for a migration. Creating a connection registers a Siebel environment to the Siebel Migration. Each connection represents either a Source (development) or Target (production) environment to be used for migration. Numerous connections can be created for a migration
This task is a step in Process of Using Siebel Migration to Migrate Data.
To create a connection
In the Siebel Migration application, click Connections in the navigation menu in the side panel to go to the Connections screen. You define the Source or Target of a migration plan in this screen.
Click New Connection, and in the New Connection window that appears:
Note: The Name field and REST Endpoint field are mandatory fields; all other fields in the New Connection window are to be completed as required.Enter a name for the new connection in the Name field.
Enter a valid endpoint for the connection in the REST Endpoint field.
The format for a valid REST Endpoint is as follows:
https://<hostname>:<port>/siebel/v1.0Where
siebelcan be replaced with any customized URL.If this connection will ever be used as the target of a migration plan, then in the Database Information Applicable for Target Environments only section of the New Connection window, enter the information described in the following table.
Field
Description
DB Schema Owner User ID
Enter the Database Table Owner user name.
Tablespace for Data
Enter the name of the tablespace where you want to import the tables. This field applies to Oracle and DB2 LUW. For any other database, this value will be ignored.
Tablespace for Index
Enter the name of the tablespace where you want to import the indexes. This field applies to Oracle and DB2 LUW. For any other database, this value will be ignored.
Tablespace for 16k Page
Enter the name of the 16k tablespace where you want to import the tables. This field applies to DB2 LUW only. For any other database, this value will be ignored.
Tablespace for 32k Page
Enter the name of the 32k tablespace where you want to import the tables. This field applies to DB2 LUW only. For any other database, this value will be ignored.
Database Encoding
Select one of the following options:
UNICODE Database
Non-UNICODE Database
To modify an existing connection:
Click Edit (the pencil icon) next to the connection that you want to edit.
In the Edit Connection window that appears, modify the fields as required—see the previous table for more information.
Use Siebel Migration to create a watermark. A watermark is useful to see the data that was previously migrated to your database environment. Based on the previously migrated data, you can determine the correct incremental version that you need to migrate.
Siebel Migration obtains the current repository watermark from the Siebel Server. Siebel Migration generates the watermark for the Web artifacts file from the Siebel Application Interface folder and then writes the watermark file into the filename provided by the user in the migration folder under the file system or Shared Package Location if provided. The connection that points to the Siebel Server must be a Runtime Repository environment. If the connection points to a development environment, then Siebel Migration throws an error.
To generate a watermark
In Siebel Migration, navigate to the Connection Tab.
Click the Watermark icon.
Enter the Watermark file name.
Click OK.
After creating the watermark file, a window displays a success message with the path and filename for the watermark file.
This procedure describes how to use Siebel Migration to create a migration plan for a migration. The procedure involves selecting connections, including Source and Target environments, and resources that you want to migrate as part of the migration plan. In Siebel Migration, you can select Database Utilities, ADM Projects or File Prepare and Deploy services. When you run a migration plan, Siebel Migration exports the migration data from the Source environment and imports it into the Target environment.
To create a migration plan
In the Siebel Migration application, click Migration Plans in the navigation menu in the side panel to go to the Migrations Plans screen.
Click New Migration.
Enter the Name of the Migration Plan and a Description.
Select and move the Source Connection & Target Connection onto the Flow Chart.
An intersection of Migration Resources (between Source & Target) for Database Utilities and only from Source for ADM Projects will be displayed.
Select the Migration Resource that will be executed as part of the migration plan.
Siebel Migration Plan Dependencies
The Siebel Migration Discovery services that appear in Siebel Migration depend on the selections that you make. The following table outlines the Siebel Migration plan dependencies.
| If You Select this Resource... | Read Only Resources | Auto Selected Resources |
Application Workspace Data Service |
Incremental Application Workspace Data Service |
Runtime Repository Data Service |
Incremental Runtime Repository Data Service |
This procedure describes how to use Siebel Migration to execute a migration plan for a migration.
To execute a migration plan
In the Siebel Migration application, click Execution in the navigation menu in the side panel to go to the Execution screen.
Identify and select the migration plan (for example, Sync Execution or Import Plan) that you want to execute.
Click the Play icon next to the migration plan that you want to execute.
Click OK when the following message (or similar) appears:
Are you sure you want to execute <Name_of_Plan> migration plan?In the Execution Details window that appears, complete the fields as required.
Depending on the configuration of the migration plan that you are executing (that is, the action and resources or services selected in the migration plan), the Execution Details window will prompt you to enter different information, as follows:
Package Filename. Enter the name of the package file (.zip) to export or import from. This field applies only to Export Only and Import Only migration plans.
Watermark. Enter the name of the watermark file (.txt). This field applies to Export Only migration plans that contain either Incremental Runtime Repository Data Service (IRR) or File Prepare & Deploy.
Workspace Branch Name and Workspace Version. These fields apply only to the Incremental Runtime Repository Data Service, and are automatically populated for Export and Import (Sync) migration plans.
Note: In the case of Export Only migration plans, you must click Get Workspace Details to populate the fields. The value in the Workspace Version Number field defaults to the very latest version, but you can select a different version if required. The Workspace Version Number is the range between the next version of the Target and the latest available version on the Source.Database Information for Target Environment. The fields in this section apply to the following migration plans that contain a Schema Service: Import Only, Export and Import (Sync). Complete the fields in this section as follows:
If you have already defined the database parameters for your target connection, then enter the password of the target connection’s Database Table Owner in the DB Schema Owner Password field — all other database information in this section will be read-only.
If you have not already defined the database parameters for your target connection, then enter the information described in the following table.
Note: If you have to specify the database parameters during execution of a migration plan, then the database information will be saved for the target connection as well, and you will not have to specify the database parameters for any subsequent executions of the migration plan.Field
Description
(Required) Enter the database schema owner user ID for the target connection.
(Required) Enter the database schema owner password for the target connection.
Tablespace for Data
Enter the name of the tablespace on the target where you want to import the tables. This field applies to Oracle and DB2 LUW. For any other database, this value will be ignored.
Enter the name of the tablespace on the target where you want to import the indexes. This field applies to Oracle and DB2 LUW. For any other database, this value will be ignored.
Enter the name of the 16k tablespace on the target where you want to import the tables. This field applies to DB2 LUW only. For any other database, this value will be ignored.
Enter the name of the 32k tablespace on the target where you want to import the tables. This field applies to DB2 LUW only. For any other database, this value will be ignored.
Database Encoding
(Required) Select one of the following options:
UNICODE Database
Click Refresh, while the migration plan is running, to refresh the migration plan or get status for a migration task.
Click Log, while the migration plan is running, to view log details for a migration task.
After Execution of Runtime Repository Data Service Completes
After execution of the Runtime Repository Data Service completes, you must perform the following steps in the target environment:
Rename the Migrated Repository to Siebel Repository, and then restart the Siebel Server - for more information, see Step 10 in Full Runtime Repository Migration Without Using Siebel Migration.
Activate task-based UI tasks by running ActivateTasks - for more information, see Step 11 in Full Runtime Repository Migration Without Using Siebel Migration.
Preprocessing and Postprocessing for Migration Execution
The operations involved during the preprocessing and postprocessing of any migration plan execution include for example, Package, Unpackage, Transfer the File (for Sync migration), Create Manifest, GetConnectString, and so on. A number of preprocessing and postprocessing methods are invoked during the execution of a migration plan. The following table describes these methods, which are in the orchestration.json file.
Resource |
Operation |
Purpose |
Applies to Resource |
Mode |
PreProcessing_Export |
GetWatermarks |
Gets the watermark details from the watermark file specified during migration execution. |
Migration Schema Service. Migration Incremental Application Workspace Data Service. Migration Incremental Runtime Repository Data Service. |
Asynchronous |
GetWaterMark |
Gets the watermark details by invoking the REST request to the Target. |
Synchronous |
PostProcessing_Export |
CreateManifest |
Creates the manifest file, which includes all the details of the resource being exported. The manifest file is used to validate credentials during the asynchronous migration import. |
All services. |
Synchronous Asynchronous |
preparePackage |
Creates a compressed package file that contains all the exported resources. |
All services. |
GetConnectString |
Gets the SynchMgr Object Manager Connect String from Source. This will be used by ImportFile to transfer the file from Source to Target. This operation applies only if the Migration Package Location in the migration profile in Siebel Management Console is not specified. |
All services except ADM. |
Synchronous |
ImportFile |
Transfers the package from Source to Target. This operation applies only if the Migration Package Location in the migration profile in Siebel Mobile Console is not specified. |
Synchronous |
PreProcessing_Import |
unPackage |
Decompresses the exported package. |
All services. |
Synchronous |
This procedure describes how to use Siebel Migration to view the history and log files for a migration task. The History screen in Siebel Migration keeps an ongoing log of the success or failure of each attempted migration task, along with the details of what happened. The following information is available for each migration task: Name, Desccription, Status, Source, Target, Archive ID, Start Date, End Date, Package Filename.
To view migration history and log files
In Siebel Migration, navigate to the History or Execution tab.
Select or click the plus (+) icon next to the migration task to show the log generated for the operation.
For example, if you select the Incremental Runtime Repository Migration task, the task expands to show the Resource and Operation.
Click Log next to an operation to view the log details for that migration operation.
From Siebel CRM 19.7 Update onwards, you can review logs for the following Siebel Migration resource operations:
Runtime Repository Data Service: GetWatermark operation.
Application Workspace Data Service: GetFullSeedWatermark and GetSeedCopyWatermark operations.
Incremental Runtime Repository Data Service: ActivateTasks operation.
Incremental Application Workspace Data Service: InvalidateSeedCaches operation.
File Prepare and Deploy: generateWatermark, readwatermarkfile, writewatermarkfile operations.
Reviewing Execution Log Messages
Log messages typically record the Archive Id, Resource name, and the Operation name in the log file along with the log message. After an Archive Id is generated, all corresponding log messages will contain the Archive Id.
Log files are generated by the Siebel Migration application but they are not visible in the migration UI. If errors are encountered during migration execution, then you can review the migration.log file located in the migration server’s Application Interface application container’s \logs folder to determine why the migration failed and to decide how to resolve the issue.
To find and review the logs generated for a particular migration execution, then search for the appropriate Archive Id in the migration.log file.
To find and review the logs generated by a specific Resource under an Archive Id, then search for the Resource name in the migration.log file.
To find and review the logs generated by a specific Operation under a Resource Name, then search for the Operation in the migration.log file.
<AI_ROOT>\applicationcontainer\logs.
Once Siebel Migration starts executing operations that are part of a resource in the migration plan, all resulting log messages will contain the appropriate Archive Id, Resource name, and Operation name as shown in the following examples.
Example Log 1: Archive Id is in Brackets
[DEBUG] 2018-10-25 04:41:24.203 [Thread-33] Migration - com.siebel.migration.server.Transaction:callExecutor [88-1VBW0R] Exporting resource {"name":"Migration Schema Service","URI":["https:\/\/slc04ovj.us.oracle.com:9001\/siebel\/v1.0"],"Source":"https:\/\/slc04ovj.us.oracle.com:9001\/siebel\/v1.0","Target":"https:\/\/slc07fnj.us.oracle.com:9001\/siebel\/v1.0","Steps":[{"StepName":"Export","Business Service":"Migration Schema Service","Method":"Export","InArg":["migrationid"],"OutArg":["trackingid"],"Location":"Source","Async":{"Async Business Service":"Migration Schema Service","Async Method":"GetStatus","Async InArg":["migrationid","trackingid"],"Async OutArg":["error","getlog","log","status"]}}],"TransId":"88-1VBW0R","rowId":["88-1VBW0S"],"Watermark":"","ActivationDate":""}
[DEBUG] 2018-10-25 04:41:24.212 [Thread-33] Migration - com.siebel.migration.server.ProcessFlow:<init>[88-1VBW0R] Entered process flow for resource : Migration Schema Service
Example Log 2: Archive Id and Resource Name are in Brackets
[DEBUG] 2018-10-25 04:41:24.214 [pool-4-thread-2] Migration - com.siebel.migration.server.ProcessFlow:getResources [88-1VBW0R] [Migration Runtime Repository Data Service] Entered get resources for resource : Migration Runtime Repository Data Service [DEBUG] 2018-10-25 04:41:24.216 [pool-4-thread-1] Migration - com.siebel.migration.server.ProcessFlow:getResources [88-1VBW0R] [Migration Schema Service] Entered get resources for resource : Migration Schema Service [DEBUG] 2018-10-25 04:41:24.216 [pool-4-thread-3] Migration - com.siebel.migration.server.ProcessFlow:getResources [88-1VBW0R] [Migration Application Workspace Data Service] Entered get resources for resource : Migration Application Workspace Data Service
Example Log 3: Archive Id, Resource Name and Operation are in Brackets
[DEBUG] 2018-10-25 04:41:24.234 [pool-4-thread-2] Migration - com.siebel.migration.server.Transaction:invokeRestCall [88-1VBW0R] [Migration Runtime Repository Data Service] [GetWatermark] Input PostData : {"body":{"workspace":"MAIN","language":"ENU","version":"0"}}
[DEBUG] 2018-10-25 04:41:24.251 [pool-4-thread-3] Migration - com.siebel.migration.server.ProcessFlow:getResources [88-1VBW0R] [Migration Application Workspace Data Service] [GetFullSeedWatermark] Argument Map constructed : {migrationid=88-1VBW0R, password=, workspace=MAIN, fileName=Migration_88-1VBW0R.txt, filename=, watermark=, isUnicodeDatabase=Y, sharedPath=, language=ENU, ActivationDate=, version=0, username=}
Asynchronous Migration Using Siebel Migration
You can use Siebel Migration to plan and carry out an asynchronous migration. An asynchronous migration essentially involves creating an asynchronous migration plan for the source environment and another (separate) asynchronous migration plan for the target environment. Migration activities that must be completed on the source environment can then be carried out independently of the migration activities that must be completed on the target environment. For asynchronous migration to work, both source and target environments must be in a Repository Upgraded state; otherwise migration execution will be performed in synchronous mode.
According to the source and target environment state, the following table outlines the supported migration scenarios. These migration scenarios are supported. using either the Siebel Migration application or REST API, in Siebel CRM 18.11 Update and later releases.
| Source and Target State | Export Only Migration | Import Only Migration | Export and Import Migration |
Source is Repository Upgraded, Target is not. |
Supported |
Not Supported |
Supported |
Both Source and Target are Repository Upgraded. |
Supported |
Supported |
Supported |
Source is not Repository Upgraded, Target is Upgraded |
Not Supported |
Not Applicable |
Supported |
Generating a watermark if required.
Creating and executing an export only migration plan to export resources from the source environment.
Creating and executing an import only migration plan to import (exported) resources to the target environment.
To perform an asynchronous migration using Siebel Migration
Generate a watermark if required. To export an Incremental Runtime Repository, you must get the Watermark file from the target environment where you are planning to import the exported data.
Note: You must ensure that the watermark you use is the latest watermark. If you export the repository using an old watermark, then the import will fail with an error message similar to the following: Watermark does not match the exported resources watermark.Navigate to the Connections tab in Siebel Migration.
Click the Watermark icon next to the target connection (that is, the target environment where you want to import the exported data).
In the dialog that appears, enter the Watermark file name and click OK.
If the Migration Package Location is configured on the Migration Profile in Siebel Management Console, then the Watermark file is generated in the Migration Package Location path. Otherwise the Watermark file is generated in the
<File System>\migrationfolder on the selected connection.
Create an export only migration plan on the source environment.
Navigate to the Migration Plan tab in Siebel Migration.
Click New Migration and then enter the Name of the migration plan and a Description.
Select and move the connection, where you want to export data from, to the Source field.
Select the resources that you want to export.
Save the source migration plan.
Create an import only migration plan on the target environment.
Select and move the connection, where you want to import data to, to the Destination field.
Select the resources you want to import.
Save the target migration plan.
Execute the export only migration plan on the source environment.
Navigate to the Execute tab in Siebel Migration.
Go to and select the migration plan that you created in Step 2 and want to export, and then click the Play icon in the Action column.
Complete the fields in the Execution Details Window that appears as required, and then click OK. For information on how to complete the fields in the Execution Details Window, see Executing a Siebel Migration Plan.
Siebel Migration starts to export all the resource data simultaneously. After all data has been exported, it is then packaged into a package file. If the Migration Package Location is configured on the Migration Profile in Siebel Management Console, then the package file will be created in the Migration Package Location path. Otherwise, the package file will be created in the
<File System>\migrationfolder on the source machine.The package file contains a list of all the resources that were exported. It also contains the Watermark information if you have chosen the Incremental Runtime Repository or Incremental Workspace Data resource in the migration plan.
Execute the import only migration plan on the target environment:
Go to and select the migration plan that you created in Step 3 and want to import, and then click the Play icon in the Action column.
Complete the fields in the Execution Details Window that appears as required, and then click OK. For information about how to complete the fields in the Execution Details Window, see Executing a Siebel Migration Plan.
Before executing the import only migration plan, you must ensure and do the following:
Ensure that the package file (created in Step 4) is accessible to the target connection where you want to import the exported data. If the Migration Package Location is configured on the Migration Profile in Siebel Management Console, then the package file must be in the Migration Package Location path.
If the Migration Package Location is not configured, then you must copy the package file (created in Step 4) from the source to the target environment’s
<File System>\migrationfolder.
Note: Before the import starts, Siebel Migration ensures that the resources selected in the import only migration plan match the resources selected in the export only migration plan. If the resources do not match, then an error message appears and the import will not start. Similarly, if the Incremental Runtime Repository or Incremental Workspace Data is part of the migration plan, then the watermark used during the export must match the watermark in the target environment. Otherwise , an error message appears and the import will not start.Note: The File System path must be accessible by all Siebel Servers and application interface machines.
Typically if either source (development) or target (production) environment is not in a Repository Upgraded state, then migration execution is performed in synchronous mode. You can migrate asynchronously only if both environments are in a Repository Upgraded state. However, if you want to avoid synchronous migration altogether, you can manually apply any repository and schema changes to target environments that are not in a Repository Upgraded state by completing the steps in this procedure.
To migrate incrementally from a development (source) to a production (target) environment without using the Siebel Migration application
Generate a watermark for the target environment:
Start the target application. For example, Siebel Call Center or any other employee facing application.
Navigate to the Administration - Business Service screen, then the Simulator view.
Click New (the plus (+) icon) to create a new Business Service record with the following values:
Service Name Method Name Migration Incremental Runtime Repository Data Service
GetWatermark
Click Run.
In the Output Arguments applet, copy the value in the Property Value field for the watermark Property Name.
Save the value in a text file because you will need it in Step 3.
Export the schema from the source environment:
Start the source application. For example, Siebel Call Center or any other employee facing application.
Service Name Method Name Migration Schema Service
Export
Create a new record in the Inputs Arguments list applet:
Click the multiple select button in the Property Name field, and then click the plus (+) icon on the Property Set Properties applet that appears.
Enter the following values in the Property Name and Value fields, and then click Save.
Property Name Value migrationid
schema_export
Click OK to close the Property Set Properties applet.
Click Run.
trackingidProperty Name.Save the value in a text file because you will need it in Step 5.
Make sure that the ddldict process is running.
To do this, use Task Manager on Windows or the ps command on UNIX.
Export the Incremental Runtime Repository from the source environment:
Export
Enter the following values in the Property Name and Value fields, and then click Save:
repo_export
Click the plus (+) icon in Property Set Properties applet again, enter the following values in the Property Name and Value fields, and then click Save.
Property Name Value watermark
Paste the value that you saved from the Property Value field in the Output Arguments applet in Step 1 into this field.
Click Run.
trackingidProperty Name.Save the value in a text file because you will need it in Step 6.
Make sure that the repimexp process is running.
Ensure that the Schema Export and Incremental Runtime Repository Export from the source environment is complete:
At regular intervals, check that the ddldict and repimexp processes are running, until they complete.
Verify the logs for ddldict and repimexp. The logs for these utilities are stored in the following locations:
<FS_PATH>\migration\schema_export\logfor Schema Export<FS_PATH>\migration\repo_export\logfor Incremental RRYou must wait until these two processes (ddldict and repimexp) are complete.
Import the (source) Schema to the target environment:
Copy the
schema_exportfolder from<FS_PATH>\migration\on the source machine.Paste the
schema_exportfolder into the<FS_PATH>\migrationpath on the target machine.Start the target application. For example: Siebel Call Center or any other employee facing application.
Import
schema_export
Property Name Value filename
Paste the value that you saved from the Property Value field in the Output Arguments applet in Step 2 into this field.
Property Name Value username
<Target Database Schema User Name>Note: The database schema user name is in plain text format. Contact your Siebel administrator if you do not know what the database schema user name is for the target environment.Click the plus (+) icon in Property Set Properties applet again, enter the following values in the Property Name and Value fields, and then click Save.
Property Name Value password
<Target Database Schema Password>Note: The database schema password must be in Base 64 encoded format. Contact your Siebel administrator if you do not know what the database schema password is for the target environment.Click OK to close the Property Set Properties applet.
Click Run.
Make sure that the ddlimp process is running in the target environment.
Wait until the ddlimp process completes successfully.
Verify the log located in the
<FS_PATH>\migration\schema_export\logfolder on the Target machine.
Import the (source) Incremental Runtime Repository to the target environment:
Note: Perform this task only if the previous step completes successfully.Copy the
repo_exportfolder from<FS_PATH>\migration\on the source machine.Paste the
repo_exportfolder into the<FS_PATH>\migrationpath on the target machine.Start the target application.
Import
repo_export
Paste the value that you saved from the Property Value field in Output Arguments applet in Step 3 into this field.
Click Run.
Make sure that the process repimexp is running in the target environment.
Wait until the repimexp process completes successfully.
<FS_PATH>\migration\repo_export\logfolder on the Target machine.
After you complete the steps in this procedure, the environment is ready for asynchronous migration.
Use the following procedure to complete a synchronous full Runtime Repository (RR) migration without using the Siebel Migration application.
To perform a full RR migration without using the Siebel Migration application
Generate a watermark for the Full RR source environment:
Service Name Method Name Migration Runtime Repository Data Service
GetWatermark
Property Name Value workspace
Enter the
<Integration_Workspace_Name>of the repository that you want to migrateClick the plus (+) icon in Property Set Properties applet again, enter the following values in the Property Name and Value fields, and then click Save.
Property Name Value version
Enter the
<Version_Number>of the repository (<Integration_Workspace_Name>) that you want to migrate.Click the plus (+) icon in Property Set Properties applet again, enter the following values in the Property Name and Value fields, and then click Save.
Property Name Value language
Enter the
<language>or<language1, language2, language3, etc>that you have enabled on the database.Click OK to close the Property Set Properties applet.
Click Run.
Save the value in a text file because you will need it in the next step.
Export the Full RR from the source environment:
Export
repo_export
Paste the value that you saved from the Property Value field in the Output Arguments applet in the previous step into this field.
Click Run.
Generate a watermark for the Full Seed source environment:
Service Name Method Name Migration Application Workspace Data Service
Property Name Value Workspace Name
Enter the
<Integration_Workspace_Name>of the full seed that you want to migrateClick OK to close the Property Set Properties applet.
Click Run.
Export the Full Seed from the source environment:
FullSeedExport
seed_export
Click Run.
trackingidProperty Name.Save the value in a text file because you will need it in Step 9.
Make sure that the dataexp process is running.
Ensure that the Full RR and Full Seed export from the source environment is complete:
At regular intervals, check that the ddldict, repimexp, and dataexp processes are running, until they complete.
Verify the logs for ddldict, repimexp, and dataexp. The logs for these utilities are stored in the following locations:
<FS_PATH>\migration\repo_export\logfor Full RR<FS_PATH>\migration\seed_export\logfor Workspace DataYou must wait until these three processes (ddldict, repimexp, and dataexp) are complete.
Import the Full RR to the target environment:
Import
repo_export
Click Run.
Make sure that the repimexp process is running in the target environment.
Export a SeedCopyExport from the target environment:
Note: Perform this task only if the previous step completes successfully.Start the target application.
SeedCopyExport
seed_copy
Mode=SegCopyFullMigrationClick OK to close the Property Set Properties applet.
Click Run.
trackingidProperty Name.Save the value in a text file because you will need it in the next step.
Make sure that the dataexp.exe process is running in the target environment.
To do this, use Task Manager on Windows or the ps command on UNIX and wait until the process completes.
Wait until the dataexp.exe process completes successfully.
<FS_PATH>\migration\seed_copy\logfolder on the Target machine.
Import the SeedCopyImport to the target environment:
SeedCopyImport
seed_copy
Click Run.
Make sure that the dataimp.exe process is running in the target environment.
Wait until the dataimp.exe process completes successfully.
Import the FullSeedImport to the target environment:
seed_exportfolder from<FS_PATH>\migration\on the source machine.Paste the
seed_exportfolder into the<FS_PATH>\migrationpath on the target machine.Start the target application.
FullSeedImport
seed_export
Paste the value that you saved from the Property Value field in the Output Arguments applet in Step 4 into this field.
Click Run.
<FS_PATH>\migration\seed_export\logfolder on the Target machine.
Rename the Migrated Repository in the target environment:
Log in to the target database.
Rename Siebel Repository to Original Siebel Repository, for example, as follows:
UPDATE S_REPOSITORY SET NAME='Original Siebel Repository' WHERE NAME='Siebel Repository';
Rename the
Migrated RepositorytoSiebel Repository,for example, as follows:.UPDATE S_REPOSITORY SET NAME='Siebel Repository' WHERE NAME='Migrated Repository';
Restart Siebel Server for the changes to take effect.
Activate task-based UI tasks in the target environment:
Note: This task must be performed after completing the previous step (that is, after restarting Siebel Server).Start the target application.
Service Name Method Name Siebel Runtime Metadata Publisher Service
ActivateTasks
Property Name Value FullMigration
True
Click Run.
It will take some time to activate all tasks. Until this process completes, the UI will remain in a frozen state.
Invalidate Seed Caches in the target environment:
Click Run.
It will take some time for the task to complete. Until this process completes, the UI will remain in a frozen state.
Once the development environment (source Design Time Repository/DR) is upgraded to the Siebel 18.8 Update or later release binary and repository, you must perform the steps in the following procedure to migrate the changes to the production (target Runtime Repository/RR) environment. You can use the asynchronous migration feature to do this only if both source (development) and target (production) environments are in a Repository Upgraded state. If either (source or target) environment is not in a Repository Upgraded state, then the migration execution will be performed in synchronous mode.
To migrate Siebel 18.8 Update or later release repository changes from a development (source) to a production (target) environment
Create a connection to the target environment.
For more information about creating a connection, see Creating a Connection.
Create a migration plan with Incremental Runtime Repository Service where source is the Development (DR) environment and target is the Target (RR or production) environment. (You can use the Runtime Repository Service instead of Incremental Runtime Repository Service.)
For more information about migration planning, see Creating a Migration Plan.
Run the migration plan that you created in Step 2.
After you complete Steps 1 to 3, you must add the seed data to the target (RR or production) environment.
For more information, see Adding Seed Data to the Target Environment.
After you complete the steps described in Migrating Repository Changes from Development to Production Environment (Siebel CRM 18.8 or Later), you must complete the following procedure to add the seed data to the target environment.
To add seed data to the target environment
In Siebel CRM, open the Call Center application from the development environment that is upgraded to the Siebel 18.8 Update or later release binary and repository.
Navigate to the Site Map and then Administration Application - Business Service Access.
In the Business Service applet, query for the Application Migration Utility Service in the Name field.
In the Business Service Method applet, verify that it contains the following methods:
CreateManifest
GenerateWatermark
GetWatermarkForIncrementalImport
GetWatermarks
ReadManifest
ValidateManifest
GetWatermarkFrmFile
In Siebel CRM on the target environment that you plan to upgrade to the 18.8 Update or later Siebel Runtime Repository, open the Call Center application. This step assumes that the binary is already upgraded to 18.8 Update or later. If not, upgrade the binary.
Create a new record in the Business Service applet.
Enter Application Migration Utility Service for the value in the Name field.
In the Access By Responsibility applet, add the appropriate responsibility. The default responsibility is Siebel Administrator.
In the Business Service Access Method applet, add all the methods listed in Step 4.
Save your changes.
Restart the EAI Object Manager component (
EAIObjMgr_<lang>) to read the newly added data.
All tasks for task-based UIs must be activated. It is recommended that you activate all task-based UI tasks immediately after a full migration.
The following procedure shows you how to activate task-based UI tasks in the production (target RR) environment after a full migration. This procedure applies for Siebel 17.x, Siebel 18.x and later releases.
To activate task-based UI tasks in the production environment after a full migration
Rename the migrated repository to Siebel Repository.
To do this, for example, use an SQL statement on the target environment.
Restart the Siebel Server (siebsrvr).
Start the Siebel business application, for example, Siebel Call Center.
Run the following business service to activate all tasks in the target environment:
Business Service Name Invocation Method Input Arguments Siebel Runtime Metadata Publisher Service
ActivateTasks
Property Name = “Full Migration” Value = True
Migrating Configuration Data and Incremental Changes
When migrating configuration data (such as LOVs, runtime events, and data mapper) and incremental changes, note the following:
LOVs are versioned and may change from one incremental migration to the next.
Performing a full migration creates a single instance of all repository objects and LOVs with version 0.
During incremental migrations, new and/or modified LOVs from the DR are created in the RR with new version numbers.
To seed a new Target environment with all the LOVs and repository objects, the first migration that you perform must always be a full migration.
Note: After a flatten workspace operation, the next migration must always be a full migration. For more information about flattening workspaces, see Using Siebel Tools.Since LOV is workspace enabled, use the Application Workspace Data Service and Incremental Application Workspace Data Service to migrate LOV data including incremental changes.
For all other configuration data (bar incremental changes), use the Application Data Service, Application Data Service with Transformation, or Application Deployment Manager Projects to migrate data. Migrating incremental changes is not supported here.
For example, to perform a full migration of LOVs using Siebel Migration application, select the following resource options:
For example, to perform an incremental migration of LOVs using Siebel Migration application, select the following resource options:
Migrating User Preferences
As of Siebel CRM 8.1.x/8.2.x (including all Siebel Innovation Packs), the migration of user preferences is typically supported between releases provided that existing SPF files are placed in the Siebel File System on the upgraded system. For example, if you set your Default Greeting Template to My Template, then this preference will be preserved across releases.
However, note that if something changes between releases, then old preferences may be ignored. For example, if significant changes are made to Siebel Calendar (like they were in Siebel Innovation Pack 2016), then many of the preferences related to Calendar will change as a result, making the old preferences obsolete. Any addition of new preferences is backward compatible.
