23Siebel Upgrade Planning Worksheet
This chapter contains the Upgrade Planning Worksheet. Before you upgrade your Siebel application, photocopy this worksheet, complete it, and give a copy to each member of the upgrade team.
The Upgrade Planning Worksheet contains the following sections:
Team Lead Summary
The following table shows the Team Lead Summary fields to complete on the Upgrade Planning Worksheet.
Field
Description or Value
Deployment Team Lead:
Siebel Administrator:
Privileged User/Siebel Database User:
DB2 Systems Programmer (SYSADM):
DB2 Database Administrator (DBADM):
Security Administrator:
z/OS System Programmer:
Midtier System Administrator:
DB2 Connect Information
The following table shows the DB2 Connect Information fields to complete on the Upgrade Planning Worksheet.
Field
DB2 Host Name/IP Address:
DB2 Port Number:
Siebel Development Environment Information
The following table shows the Development Environment Information fields to complete on the Upgrade Planning Worksheet.
Field
Siebel Gateway Server:
Enterprise Server Name:
Siebel Server Directory:
Siebel Database Configuration Utilities Directory:
Database Alias:
Siebel Administrator User Name:
Siebel Administrator Password:
Siebel Administrator User Group:
Staging Siebel Schema Qualifier ID (Max. 8 chars):
Staging ODBC Data Source Name (Subsystem name):
Staging Database User Name:
Target Siebel Schema Qualifier ID (Max. 8 chars):
Target ODBC Data Source Name (Subsystem name):
Target Database User Name:
Target Security Group ID:
EIM User Group ID (Max. 8 characters):
Siebel User Group ID (Max. 8 characters):
Storage Control Filename:
Storage Group for Temporary Indexes:
Database Name Prefix (Max. 4 characters):
4-KB Bufferpool:
8-KB Bufferpool:
16-KB Bufferpool:
32-KB Bufferpool:
Index Bufferpool:
Note: The Security Group ID is also known as the secondary authorization ID.
Siebel Production Environment Information
The following table shows the Production Environment Information fields to complete on the Upgrade Planning Worksheet.
Field
Database Alias:
ODBC DSN for Development Database:
Database User Name for Development Database:
Database Table Owner for Development Database:
Import Repository Name:
4-KB Bufferpool:
8-KB Bufferpool:
16-KB Bufferpool:
32-KB Bufferpool:
Index Bufferpool:
z/OS Host System Variables Information
The following table shows the z/OS Host System Variables Information fields to complete on the Upgrade Planning Worksheet.
Field
DSN High Level Qualifier Name (DSNHLQ):
Host/LPAR Name:
DB2 WLM Name:
DB2 WLM Load Library Name:
Code Page / CCSID:
DB2 Load Libraries:
Staging Database:
DB2 Load Libraries:
Target Database:
Note: To obtain the correct values for the system variables, talk to your DBA or systems programmer.
