26REST API References for Migration Services
This chapter provides examples for using REST API to discover migration services. It includes the following topics:
Using REST API with the Migration Data Service with Transformation Service
Using REST API with the Migration Incremental Runtime Repository Data Service
Using REST API with the Migration Runtime Repository Data Service
Using REST API with the Migration Incremental Application Workspace Data Service
Using REST API with Migration Application Workspace Data Service
Using REST API with the Migration File Prepare and Deploy Service
Using REST API with the Migration Schema Service
The Migration Schema Service migrates the physical Siebel schema from the source environment to the target environment. The following table includes the methods supported for the Migration Schema Service.
| Method | Definition |
Export |
Method used to export a schema for a migration. For more information, see Exporting with the Migration Schema Service. |
Import |
Method used to import a schema for a migration. For more information, see Importing with the Migration Schema Service. |
GetWatermark |
Method used to get a watermark for a migration. For more information, see Getting a Watermark with the Migration Schema Service. |
IsSchemaChanged |
Method used to check if a schema has changed for a migration. For more information, see Verifying If a Schema Changed with the Migration Schema Service. |
GetStatus |
Method used to get the status of a migration. For more information, see Getting Status with the Migration Schema Service. |
You can export a Migration Schema resource by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to export a resource:
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Schema Service/ExportHTTP Method: POST
Content-Type: application/json
Authorization: Basic
Request parameter:
migrationid: Use the migrationid parameter to include the migration identification value in the REST API request.
Request body:
{ "body":{ "migrationid": "<Migration Id value> } }
The following are the details for the response to a successful request:
HTTP Code: 200
Response parameters:
trackingid: String that contains the tracking identification value.
Response body:
{ "trackingid": "<tracking ID value>" }
You can get status for a Migration Schema resource by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to get status for a resource:
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Schema Service/GetStatusHTTP Method: POST
Request parameters:
trackingid: Contains the tracking identification value.
getlog: If the value of this parameter is true, the log content of the resource along with the status is returned in the response. If the value is false, only the status is returned in the response.
Request body:
{"body":{ "trackingid": "<tracking Id value>", "getlog": "true" "migrationid": "<Migration Id value> } }
HTTP Code: 200
status: Returns a value for the status of the request:
running: Indicates that the resource is running.
success: Indicates that the request was completed successfully.
error: Indicates that the request failed and the error parameter is populated with an error message.
error: Returns an error message if an error is encountered.
Response body:
{ "status": "success", "error": "" }
You can import a Migration Schema resource by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to import a resource:
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Schema Service/ImportHTTP Method: POST
Request parameters:
filename: Use the filename parameter to enter the name of the file to be imported.
username: Use the user name parameter to enter your database user name.
password: Use the password parameter to enter your database password.
Request body:
{"body":{ "filename": "<file name value>", "username":"<db username>", "password":"<db password>" "migrationid": "<Migration Id value> } }
HTTP Code: 200
trackingid: Returns the tracking identification value.
Response body:
{ "trackingid": "<tracking id value>" }
You can check if a schema for a Migration Schema resource has changed by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to check if a schema has changed for a resource:
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Schema Service/IsSchemaChangedHTTP Method: POST
Request parameter:
watermark: Use the watermark parameter to enter the watermark value.
Request body:
{ "body": { "watermark": "<watermark value>" } }
HTTP Code: 200
isschemachanged: Returns the value Y or N. Y indicated that the schema has changed. N indicates that the schema has not changed.
Response body:
{ "isschemachanged": "Y" }
You can get a watermark for a Migration Schema resource by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to get a watermark for a resource:
URI:
http:/<host>:<port>/siebel/v1.0/service/Migration Schema Service/GetWatermarkHTTP Method: POST
Request body:
{ "body":{} }
HTTP Code: 200
watermark: Returns the watermark value.
Response body:
{ "watermark": "watermark value>" }
Using REST API with the Migration Application Data Service
The Migration Application Data Service migrates the data from the source environment to the target environment based on the tables listed in the datamig.inp file on the source environment. The following table includes the methods supported for the Migration Application Data Service.
Export |
Method used to export the application data for a migration. For more information, see Exporting with the Migration Application Data Service. |
Import |
Method used to import the application data for a migration. For more information, see Importing with the Migration Application Data Service. |
GetStatus |
Method used to get the status of a migration. For more information, see Getting Status with the Migration Application Data Service. |
You can export a Migration Application Data Service resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Application Data Service/ExportHTTP Method: POST
Request parameters:
Request body:
HTTP Code: 200
Response body:
You can get status for a Migration Application Data Service resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Application Data Service/GetStatusHTTP Method: POST
Request parameters:
Request body:
{ "body": { "trackingid": "tracking id value>", "migrationid": "Migration Id value> "getlog": "true" } }
HTTP Code: 200
Response body:
You can import a Migration Application Data Service resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Application Data Service/ImportHTTP Method: POST
Request parameters:
Request body:
{ "body": { "filename": "file name value>" "migrationid": "Migration Id value> } }
HTTP Code: 200
Response body:
{ "trackingid": "tracking id value>" }
The Migration Data Service with Transformation service migrates the data from the source environment to the target environment based on the tables listed in the datamig.inp file on the source environment.
While exporting the data, this service uses the rule defined in the datamig.rul file and performs the transformation. The transformed data will be migrated to the target environment.
The following table includes the methods supported for the Migration Data Service with Transformation Service.
Export |
Method used to export the application data for a migration. For more information, see Exporting with the Migration Application Data Service With Transformation. |
Import |
Method used to import the application data for a migration. For more information, see Importing with the Migration Application Data Service With Transformation. |
GetStatus |
Method used to get the status of a migration. For more information, see Getting Status with the Migration Application Data Service With Transformation. |
You can export a Migration Application Data Service With Transformation resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Application Data Service With Transformation/ExportHTTP Method: POST
Request parameter:
Request body:
HTTP Code: 200
Response body:
You can get status for a Migration Application Data Service With Transformation resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Application Data Service With Transformation/GetStatusHTTP Method: POST
Request parameters:
Request body:
HTTP Code: 200
Response body:
You can import a Migration Application Data Service With Transformation resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Application Data Service With Transformation/ImportHTTP Method: POST
Request parameters:
filename: Use the filename parameter to include the name of the file to be imported.
Request body:
{ "body": { "filename": "filename value>" "migrationid": "Migration Id> } }
HTTP Code: 200
Response body:
The Migration Incremental Runtime Repository Data Service identifies the version of the repository data that was previously migrated. If you select the latest migration version, then this service takes the changes from the previous migration version and latest version and migrates the data to the target environment. If you do not make any selections, the service only considers the latest migration version and migrates the data to the target environment.
The following table includes the methods supported for the Migration Incremental Runtime Repository Data Service. For information on how to activate task-based UI tasks after importing the incremental runtime repository, see Activating Tasks with the Migration Incremental Runtime Repository Data Service.
Export |
Method used to export the incremental Runtime Repository changes for a migration. For more information, see Exporting with the Migration Incremental Runtime Repository Data Service. |
Import |
Method used to import the incremental Runtime Repository for a migration. For more information, see Importing with the Migration Incremental Runtime Repository Data Service. |
GetWatermark |
Method used to get a watermark for a migration. For more information, see Getting a Watermark with the Migration Incremental Runtime Repository Data Service. |
DBCheck |
Method used to check a database has a migration. For more information, see Checking a Database with the Migration Incremental Runtime Repository Data Service. |
GetStatus |
Method used to get the status of a migration. For more information, see Getting Status with the Migration Incremental Runtime Repository Data Service. |
You can get a watermark for a Migration Incremental Runtime Repository Data Service resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Incremental Runtime Repository Data Service/GetWatermarkHTTP Method: POST
Request body:
{ "body":{} }
HTTP Code: 200
Response body:
You can export a Migration Incremental Runtime Repository Data Service resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Incremental Runtime Repository Data Service/ExportHTTP Method: POST
Request parameters:
watermark: Use the watermark parameter to include the watermark value.
Request body:
{ "body": "migrationid": "<Migration Id value> { "watermark": "<watermark value>" } }
HTTP Code: 200
Response body:
You can get status for a Migration Incremental Runtime Repository Data Service resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/ Migration Incremental Runtime Repository Data Service/GetStatusHTTP Method: POST
Request parameters:
Request body:
{ "body": { "trackingid": "<tracking id value>", "migrationid", "<Migration Id value>" "getlog": "true" } }
HTTP Code: 200
Response body:
You can import a Migration Incremental Runtime Repository Data Service resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/ Migration Incremental Runtime Repository Data Service/ImportHTTP Method: POST
Request parameter:
Request body:
{ "body": { "filename":"file name value>", "migrationid", "Migration Id value>" } }
HTTP Code: 200
Response body:
You can check a database for a Migration Incremental Runtime Repository Data Service resource by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to check a database for a resource:
URI:
http://<host>:<port>/siebel/v1.0/service/ Migration Incremental Runtime Repository Data Service/DBCheckHTTP Method: POST
Request body:
{ "body":{} }
HTTP Code: 200
Response body:
You can activate task-based UI tasks after importing the incremental runtime repository by sending an HTTP POST request to the repository resource's URL.
The following details are for a request to activate the task-based UI tasks for a resource:
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Runtime Repository Data Service/ActivateTasksHTTP Method: POST
Request body:
{ "body":{} }
HTTP Code: 200
status: Returns a value for the status of the request.
running (status): Indicates that the resource is running.
success (status): Indicates that the request was completed successfully.
error (status): Indicates that the request failed and the error parameter is populated with an error message.
Response body:
{ “status:success }
The Migration Runtime Repository Data Service migrates only the runtime repository from the source environment to the target environment. The following table includes the methods supported for the Migration Runtime Repository Data Service.
Export |
Method used to export the Runtime Repository for a migration. For more information, see Exporting with the Migration Runtime Repository Data Service. |
Import |
Method used to import the Runtime Repository for a migration. For more information, see Importing with the Migration Runtime Repository Data Service. |
GetWatermark |
Method used to get a watermark for a migration. For more information, see Getting a Watermark with the Migration Runtime Repository Data Service. |
DBCheck |
Method used to check a database for a migration. For more information, see Checking a Database with the Migration Runtime Repository Data Service. |
GetStatus |
Method used to get the status of a migration. For more information, see Getting Status with the Migration Runtime Repository Data Service. |
GetRRInfo |
Method used to get Runtime Repository information. For more information, see Getting Runtime Repository Information with the Migration Runtime Repository Data Service. |
You can get runtime repository information for a Migration Runtime Repository Data Service resource by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to get runtime repository information for a resource:
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Runtime Repository Data Service/GetRRInfoHTTP Method: POST
Request body:
{ "body":{} }
HTTP Code: 200
workspace: Returns the name of the workspace branch, the latest version of the workspace branch, and workspace languages. If there are multiple workspace branches in the Siebel environment, then the branch name and its latest version will be separated by a comma in the response. The response lists all the Siebel environment languages. If there is only one language, then only one language is listed in the response.
Response body:
{ "workspace": { "Branch Name": "Last Version Number of the Branch" }, "languages": {... } }
You can get a water mark for a Migration Runtime Repository Data Service resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Runtime Repository Data Service/GetWaterMarkHTTP Method: POST
Request parameters:
workspace: Use the workspace parameter to enter the name of the workspace branch in the REST API request.
version: Use the version parameter to enter the version number of the workspace branch. The value is 0 to the latest version of the specified workspace branch.
Request body:
{ "body": { "workspace":"workspace branch name>", "version":"version>", } }
HTTP Code: 200
Response body:
{ "watermark": "Watermark value>" }
You can export a Migration Runtime Repository Data Service resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Runtime Repository Data Service/ExportHTTP Method: POST
Request parameters:
watermark: Use the watermark parameter to include the name of the watermark in the REST API request.
Request body:
{ "body": { "watermark": "Watermark value>" "migrationid", "Migration Id value>" } }
HTTP Code: 200
Response body:
You can get status for a Migration Runtime Repository Data Service resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Runtime Repository Data Service/GetStatusHTTP Method: POST
Request parameters:
Request body:
{ "body": { "trackingid":"tracking id value>", "migrationid", "Migration Id value>" "getlog":"TRUE" } }
HTTP Code: 200
log: Returns log file content if the getlog parameter value is set to TRUE.
Response body:
{ "status": "success", "error": "", "log":log file content> }
You can import a Migration Runtime Repository Data Service resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Runtime Repository Data Service/ImportHTTP Method: POST
Request parameters:
Request body:
HTTP Code: 200
Response body:
You can check a database for a Migration Runtime Repository Data Service resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Runtime Repository Data Service/DBCheckHTTP Method: POST
Request body:
{ "body":{} }
HTTP Code: 200
Response body:
The Migration Incremental Application Workspace Data Service identifies the version that was previously migrated. This service takes all the changes from the previously migrated version to the latest version and migrates them to the target environment. The following table includes the methods supported for the Migration Incremental Application Workplace Data Service. For information on how to invalidate seed caches, see Invalidating Seed Caches with the Migration Incremental Application Workspace Data service.
Export |
Method used to export the Workspace data for a migration. For more information, see Exporting with the Migration Incremental Application Workspace Data Service. |
Import |
Method used to import the Workspace data for a migration. For more information, see Importing with the Migration Incremental Application Workspace Data Service. |
GetWatermark |
Method used to get a watermark for a migration. For more information, see Getting a Watermark with the Migration Incremental Application Workspace Data Service. |
GetStatus |
Method used to get the status of a migration. For more information, see Getting Status with the Migration Incremental Application Workspace Data Service. |
You can get status for a Migration Incremental Application Workspace Data Service resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Incremental Application Workspace Data Service/GetStatusHTTP Method: POST
Request parameters:
Request body:
HTTP Code: 200
log: Return log file content if the getlog parameter is set to TRUE.
Response body:
{ "status": "success", "error": "", "log": log file content }
You can get a watermark for a Migration Incremental Application Workspace Data Service resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Incremental Application Workspace Data Service/GetWaterMarkHTTP Method: POST
Request body:
{ "body":{} }
HTTP Code: 200
Response body:
{ "watermark": "watermark value" }
You can export a Migration Incremental Application Workspace Data Service resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Incremental Application Workspace Data Service/ExportHTTP Method: POST
Request parameters:
watermark: Use the watermark parameter to include the watermark value in the REST API request.
Request body:
{ "body": "migrationid", "Migration Id value>" { "watermark": "watermark value>" } }
HTTP Code: 200
Response body:
You can import a Migration Incremental Application Workspace Data Service resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Incremental Application Workspace Data Service/ImportHTTP Method: POST
Request parameters:
Request body:
{ "body": { "filename": "file name value>" "migrationid", "Migration Id value>" } }
HTTP Code: 200
Response body:
You can invalidate seed caches for a Migration Incremental Application Workspace Data service resource by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to invalidate seed caches for a resource:
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Incremental Application Workspace Data service/InvalidateSeedCachesHTTP Method: POST
Request body:
{ "body":{} }
HTTP Code: 200
Response body:
{ "status": "success" }
The Migration Application Workspace Data Service migrates the seed records from the source environment to the target environment. The following table includes the methods supported for the Migration Application Workspace Data Service. For information on how to invalidate seed caches, see Invalidating the Seed Caches with the Migration Application Workspace Data Service.
GetSeedCopyWatermark |
Method used to get the watermark that is needed for the SeedCopyExport method for a migration. For more information, see Getting a Seed Copy Watermark with the Migration Application Workspace Data Service. |
GetFullSeedWatermark |
Method used to get the watermark that is needed for the FullSeedExport method for a migration. For more information, see Getting the Full Seed Watermark with the Migration Application Workspace Data Service. |
SeedCopyExport |
Method used to export the Workspace data (LOV) from the Siebel Repository in the target environment. For more information, see Getting a Seed Copy Export with the Migration Application Workspace Data Service. |
SeedCopyImport |
Method used to import the Workspace data (LOV), that was exported using the SeedCopyExport method, into the Migrated Repository in the target environment. This helps move the additional LOVs that are present in the Siebel Repository to the Migrated Repository. For more information, see Getting a Seed Copy Import with the Migration Application Workspace Data Service. |
FullSeedExport |
Method used to export the Workspace data (LOV) from a chosen Integration Workspace in the source environment. For more information, see Getting the Full Seed Export with the Migration Application Workspace Data Service. |
FullSeedImport |
Method used to import the Workspace data (LOV), that was exported using the FullSeedExport method, into the Migrated Repository in the target environment. For more information, see Getting the Full Seed Import with the Migration Application Workspace Data Service. |
GetStatus |
Method used to get the status of a migration. For more in formation, see Getting Status with the Migration Application Workspace Data Service. |
You can get a seed copy watermark for a Migration Application Workspace Data Service resource by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to get a seed copy watermark for a resource:
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Application Workspace Data Service/GetSeedCopyWatermarkHTTP Method: POST
Request body:
{ "body":{} }
HTTP Code: 200
Response body:
{ "watermark": "<Watermark value>" }
You can get the full seed watermark for a Migration Application Workspace Data Service resource by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to get the full seed watermark for a resource:
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Application Workspace Data Service/GetFullSeedWatermarkHTTP Method: POST
Request body:
{ "body":{} }
HTTP Code: 200
Response body:
You can get status for a Migration Application Workspace Data Service resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Application Workspace Data Service/GetStatusHTTP Method: POST
Request parameters:
Request body:
{ body": { "trackingid":"<tracking id value>" "migrationid", "<Migration Id value>" "getlog":"TRUE" } }
HTTP Code: 200
Response body:
{ "status": "success", "error": "", "log": "log file content }
You can get a seed copy export for a Migration Application Workspace Data Service resource by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to get a seed copy export for a resource:
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Application Workspace Data Service/SeedCopyExportHTTP Method: POST
Request parameters:
Request body:
{ "body": "migrationid", "<Migration Id value>" { "watermark": "<Watermark value>" } }
HTTP Code: 200
Response body:
You can get a seed copy import for a Migration Application Workspace Data Service resource by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to get a seed copy import for a resource:
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Application Workspace Data Service/SeedCopyImportHTTP Method: POST
Request parameters:
Request body:
{ "body": { "filename":"<file name value>" "migrationid", "<Migration Id value>" } }
HTTP Code: 200
Response body:
You can get a full seed export for a Migration Application Workspace Data Service resource by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to get a full seed export for a resource:
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Application Workspace Data Service/FullSeedExportHTTP Method: POST
Request parameters:
Request body:
{ "body": "migrationid", "<Migration Id value>" { "watermark": "<watermark value>" } }
HTTP Code: 200
Response body:
You can get full seed import for a Migration Application Workspace Data Service resource by sending an HTTP POST request to the repository resource's URI.
The following details are for a request to get full seed import for a resource:
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Application Workspace Data Service/FullSeedImportHTTP Method: POST
Request parameters:
Request body:
HTTP Code: 200
Response body:
You can invalidate seed caches for a Migration Application Workspace Data Service resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/service/Migration Application Workspace Data Service/InvalidateSeedCachesHTTP Method: POST
Request body:
{ "body":{} }
HTTP Code: 200
Response body:
The Migration File Prepare and Deploy Service identifies all the new and modified files and migrates those files from the source environment to the target environment. The following table shows the methods supported by the Migration File Prepare and Deploy Service.
Export |
Method used to export modified files. For more information, see Exporting with the Migration File Prepare and Deploy Service. |
Import |
Method used to import modified files. For more information, see Importing with the Migration File Prepare and Deploy Service. |
generateWatermark |
Method used to generate a watermark for modified files. For more information, see Generating a Watermark with the Migration File Prepare and Deploy Service. |
readwatermarkfile |
Method used to read the watermark for modified files. For more information, see Reading the Watermark with the Migration File Prepare and Deploy Service. |
writewatermarkfile |
Method used to write the watermark for modified files. For more information, see Writing the Watermark with the Migration File Prepare and Deploy Service. |
GetStatus |
Method used to get the status of modified files. For more information, see Getting Status with the Migration File Prepare and Deploy Service. |
You can export a File Prepare and Deploy resource by sending an HTTP POST request to the (source) repository resource’s URI.
The following details are for a request to export a resource (that is, the source files for a File Prepare and Deploy resource):
URI:
http://<host>:<port>/siebel/v1.0/MigrationFilePrepareAndDeploy/ExportHTTP Method: POST
Request parameters:
Request body:
{ "body":{ "migrationid": "<Migration Id Value>", "watermarkFile": "<Watermark File Name>" } }
HTTP Code: 200
Response body:
You can get (the API Export or Import) status for a Migration File Prepare and Deploy resource by sending an HTTP POST request to the repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/MigrationFilePrepareAndDeploy/getstatusHTTP Method: POST
Request parameters:
Request body:
{"body":{ "trackingid": "<Tracking Id value>", "migrationid": "<Migration Id value>", "getlog": "true" } }
HTTP Code: 200
#status: Returns a value for the status of the request:
Response body:
You can import a Migration File Prepare and Deploy resource by sending an HTTP POST request to the (target) repository resource's URI.
URI:
http://<host>:<port>/siebel/v1.0/MigrationFilePrepareAndDeploy/ImportHTTP Method: POST
Request parameters:
Request body:
{"body":{ "migrationid": "<Migration Id value> } }
HTTP Code: 200
Response body:
You can generate a watermark for a Migration File Prepare and Deploy resource by sending an HTTP POST request to the (target) repository resource's URI.
The following details are for a request to generate a watermark for a resource:
URI:
http://<host>:<port>/siebel/v1.0/MigrationFilePrepareAndDeploy/generateWatermarkHTTP Method: POST
Request parameters:
filename: File name for the watermark.
Request body:
{"body":{ "migrationid": "<Migration Id value>", "Filename": "<File Name>" } }
HTTP Code: 200
Response body:
{ "tracking id": "<tracking id value>" }
You can read the watermark for a Migration File Prepare and Deploy resource by sending an HTTP POST request to the (target) repository resource's URI.
The following details are for a request to read the watermark for a resource:
URI:
http://<host>:<port>/siebel/v1.0/MigrationFilePrepareAndDeploy/readwatermarkfileHTTP Method: POST
Request parameters:
filename: Name of the watermark file.
Request body:
HTTP Code: 200
watermarkContents: Returns the watermark.
Response body:
{ "tracking id": "<tracking id value>" "watermarkContents": "<Watermark contents>" }
You can write the watermark received from the target by sending an HTTP POST request to the (source) repository resource's URI.
The following details are for a request to write the watermark (received from the target) for a resource:
URI:
http://<host>:<port>/siebel/v1.0/MigrationFilePrepareAndDeploy/writewatermarkfileHTTP Method: POST
Request parameters:
watermarkContents: Watermark contents received from the target.
Request body:
{"body":{ "migrationid": "<Migration Id value>", "Filename": "<File Name>", "watermarkContents": "<Watermark contents>" } }
HTTP Code: 200
Response body:
Using REST API with Siebel Migration Application
You can use REST APIs both before and after the repository upgrade is done. Use the asynchronous migration feature only if both source (development) and target (production) environments are in a Repository Upgraded state. If either (source or target) environment is not in a Repository Upgraded state, then the migration execution will be performed in synchronous mode.
Work with connections. You can use REST APIs to create connections, update your existing connection, get information about connections, generate a watermark for your connection, and delete your connection.
Work with migration plans. You can use REST APIs to create migration plans, update migration plans, get information about migration plans, and delete migration plans.
Execute migration plans. You can use REST APIs to execute migration plans and get status about your running migration plans by plan name, resource name, and operation. You can also get the log file based on an operation for a running migration plan.
Get history information about migration plans. You can use REST APIs to get history information about your migration plans by ID, resource name, plan name, and operation. You can also get the log file based on an operation for a particular history record.
Using REST API to Configure Siebel Migration Application Connections
You can use the Siebel Migration REST API to configure connections for your migration plan. For more information, see the following subtopics:
Getting All Connections
You can get all connections for your migration by sending an HTTP GET request to the Siebel Migration Application.
The following details are for a request to get all connections for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/connectionHTTP Method: GET
HTTP Code: 200
Response body:
[ { "id":"88-1V5WJZ", "name":"Dev", "restEndpoint":"https://{hostname}:{port}/siebel/v1.0", "isFavourite":"false", "schemaUser": "", "tableSpaceData": "", "tableSpaceIndex": "", "tableSpacePage16K": "", "tableSpacePage32K": "", "isUnicodeDatabase": "true", "resources":[ { "id":"88-1V5WK0", "name":"Migration Schema Service", "displayName":"Schema Service", "type":"DB Util" }, { "id":"88-1V5WK2", "name":"Migration Runtime Repository Data Service", "displayName":"Runtime Repository Data Service", "type":"DB Util" }, { "id":"88-1V5WK3", "name":"Migration Application Workspace Data Service", "displayName":"Application Workspace Data Service", "type":"DB Util" }, { "id":"88-1V5WK4", "name":"Migration Incremental Runtime Repository Data Service", "displayName":"Incremental Runtime Repository Data Service", "type":"DB Util" }, { "id":"88-1V5WK5", "name":"Migration Incremental Application Workspace Data Service", "displayName":"Incremental Application Workspace Data Service", "type":"DB Util" }, { "id":"88-1V5WK6", "name":"Migration Application Data Service", "displayName":"Application Data Service", "type":"DB Util" }, { "id":"88-1V5WK7", "name":"Migration Application Data Service With Transformation", "displayName":"Application Data Service With Transformation", "type":"DB Util" }, { "id":"88-1V5WK8", "name":"MigrationFilePrepareAndDeploy", "displayName":"File Prepare And Deploy", "type":"DB Util" }, { "id":"88-1V5WK9", "name":"FINS BIB", "displayName":"FINS BIB", "type":"ADM" } ] }, { "id":"88-1V5WLD", "name":"Prod", "restEndpoint":"https://slc07fnj.us.oracle.com:16690/siebel/v1.0", "isFavourite":"false", "schemaUser": "", "tableSpaceData": "", "tableSpaceIndex": "", "tableSpacePage16K": "", "tableSpacePage32K": "", "isUnicodeDatabase": "true", "resources":[ { "id":"88-1V5WLE", "name":"Migration Schema Service", "displayName":"Schema Service", "type":"DB Util" }, { "id":"88-1V5WLG", "name":"Migration Runtime Repository Data Service", "displayName":"Runtime Repository Data Service", "type":"DB Util" }, { "id":"88-1V5WLH", "name":"Migration Application Workspace Data Service", "displayName":"Application Workspace Data Service", "type":"DB Util" }, { "id":"88-1V5WLI", "name":"Migration Incremental Runtime Repository Data Service", "displayName":"Incremental Runtime Repository Data Service", "type":"DB Util" }, { "id":"88-1V5WLJ", "name":"Migration Incremental Application Workspace Data Service", "displayName":"Incremental Application Workspace Data Service", "type":"DB Util" }, { "id":"88-1V5WLK", "name":"Migration Application Data Service", "displayName":"Application Data Service", "type":"DB Util" }, { "id":"88-1V5WLL", "name":"Migration Application Data Service With Transformation", "displayName":"Application Data Service With Transformation", "type":"DB Util" }, { "id":"88-1V5WLM", "name":"MigrationFilePrepareAndDeploy", "displayName":"File Prepare And Deploy", "type":"DB Util" }, { "id":"88-1V5WLN", "name":"FINS BIB", "displayName":"FINS BIB", "type":"ADM" } ] } ]
Getting a Connection by Name
You can get a connection for your migration by sending an HTTP GET request to the Siebel Migration Application.
The following details are for a request to get a connection by name for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/connection/{connectionName}HTTP Method: GET
HTTP Code: 200
Response body:
Creating a New Connection
You can create a new connection for your migration by sending an HTTP POST request to the Siebel Migration Application.
The following details are for a request to create a new connection for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/connectionHTTP Method: POST
Request Body:
{ "name":"Demo Source", "restEndpoint":"https://{hostname}:{port}/siebel/v1.0", "isFavourite":"true" "schemaUser": "", "tableSpaceData": "", "tableSpaceIndex": "", "tableSpacePage16K": "", "tableSpacePage32K": "", "isUnicodeDatabase": "true" }
HTTP Code: 200
Response Body:
{ "id":"88-1V5ZL2", "name":"Demo Source", "restEndpoint":"https://{hostname}:{port}/siebel/v1.0", "isFavourite":"true", "schemaUser": "", "tableSpaceData": "", "tableSpaceIndex": "", "tableSpacePage16K": "", "tableSpacePage32K": "", "isUnicodeDatabase": "true", "resources":[ { "id":"88-1V5ZL3", "name":"Migration Schema Service", "displayName":"Schema Service", "type":"DB Util" }, { "id":"88-1V5ZL5", "name":"Migration Runtime Repository Data Service", "displayName":"Runtime Repository Data Service", "type":"DB Util" }, { "id":"88-1V5ZL6", "name":"Migration Application Workspace Data Service", "displayName":"Application Workspace Data Service", "type":"DB Util" }, { "id":"88-1V5ZL7", "name":"Migration Incremental Runtime Repository Data Service", "displayName":"Incremental Runtime Repository Data Service", "type":"DB Util" }, { "id":"88-1V5ZL8", "name":"Migration Incremental Application Workspace Data Service", "displayName":"Incremental Application Workspace Data Service", "type":"DB Util" }, { "id":"88-1V5ZL9", "name":"Migration Application Data Service", "displayName":"Application Data Service", "type":"DB Util" }, { "id":"88-1V5ZLA", "name":"Migration Application Data Service With Transformation", "displayName":"Application Data Service With Transformation", "type":"DB Util" }, { "id":"88-1V5ZLB", "name":"MigrationFilePrepareAndDeploy", "displayName":"File Prepare And Deploy", "type":"DB Util" }, { "id":"88-1V5ZLC", "name":"FINS BIB", "displayName":"FINS BIB", "type":"ADM" } ] }
Creating a Watermark for a Connection
You can create a watermark for your migration connection by sending an HTTP POST request to the Siebel Migration Application.
The following details are for a request to create a watermark for a migration connection:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/connection/{connectionName}/watermarkHTTP Method: POST
Request Body:
{ "fileName":"demo.txt" }
HTTP Code: 200
Response Body:
{ "watermarkFile":"c:\\fs\\migration\\demo.txt" }
Updating the Connection
You can update a connection for your migration by sending an HTTP PUT request to the Siebel Migration Application.
The following details are for a request to update a connection for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/connection/{connectionName}HTTP Method: PUT
Request Body:
{ "name":"Demo Dev", "restEndpoint":"https://{hostname}:{port}/siebel/v1.0", "isFavourite":"true" "schemaUser": "", "tableSpaceData": "", "tableSpaceIndex": "", "tableSpacePage16K": "", "tableSpacePage32K": "", "isUnicodeDatabase": "true" }
HTTP Code: 200
Response Body:
{ "id":"88-1V5ZL2", "name":"Demo Dev", "restEndpoint":"https://slc04ovj.us.oracle.com:5021/siebel/v1.0", "isFavourite":"false", "schemaUser": "", "tableSpaceData": "", "tableSpaceIndex": "", "tableSpacePage16K": "", "tableSpacePage32K": "", "isUnicodeDatabase": "true", "resources":[ { "id":"88-1V5ZL3", "name":"Migration Schema Service", "displayName":"Schema Service", "type":"DB Util" }, { "id":"88-1V5ZL5", "name":"Migration Runtime Repository Data Service", "displayName":"Runtime Repository Data Service", "type":"DB Util" }, { "id":"88-1V5ZL6", "name":"Migration Application Workspace Data Service", "displayName":"Application Workspace Data Service", "type":"DB Util" }, { "id":"88-1V5ZL7", "name":"Migration Incremental Runtime Repository Data Service", "displayName":"Incremental Runtime Repository Data Service", "type":"DB Util" }, { "id":"88-1V5ZL8", "name":"Migration Incremental Application Workspace Data Service", "displayName":"Incremental Application Workspace Data Service", "type":"DB Util" }, { "id":"88-1V5ZL9", "name":"Migration Application Data Service", "displayName":"Application Data Service", "type":"DB Util" }, { "id":"88-1V5ZLA", "name":"Migration Application Data Service With Transformation", "displayName":"Application Data Service With Transformation", "type":"DB Util" }, { "id":"88-1V5ZLB", "name":"MigrationFilePrepareAndDeploy", "displayName":"File Prepare And Deploy", "type":"DB Util" }, { "id":"88-1V5ZLC", "name":"FINS BIB", "displayName":"FINS BIB", "type":"ADM" } ] }
Deleting a Connection
You can delete a migration connection by sending an HTTP DELETE request to the Siebel Migration Application.
The following details are for a request to delete a migration connection:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/connection/{connectionName}HTTP Method: DELETE
Using REST API to Configure Siebel Migration Application Migration Plans
You can use the Siebel Migration REST API to configure your migration plan. For more information, see the following subtopics:
Getting All Migration Plans
You can get all migration plans for your migration by sending an HTTP GET request to the Siebel Migration Application.
The following details are for a request to get all migration plans for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/planHTTP Method: GET
HTTP Code: 200
Response Body:
[ { "id":"88-1V5WMR", "name":"IRRMigration", "description":"IRRMigration", "source":"Dev", "target":"Prod", "resources":[ { "id":"88-1V5WMS", "name":"Migration Schema Service", "displayName":"Schema Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5WMU", "name":"Migration Runtime Repository Data Service", "displayName":"Runtime Repository Data Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5WMV", "name":"Migration Application Workspace Data Service", "displayName":"Application Workspace Data Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5WMW", "name":"Migration Incremental Runtime Repository Data Service", "displayName":"Incremental Runtime Repository Data Service", "isSelected":"true", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5WMX", "name":"Migration Incremental Application Workspace Data Service", "displayName":"Incremental Application Workspace Data Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5WMY", "name":"Migration Application Data Service", "displayName":"Application Data Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5WMZ", "name":"Migration Application Data Service With Transformation", "displayName":"Application Data Service With Transformation", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5WN0", "name":"MigrationFilePrepareAndDeploy", "displayName":"File Prepare And Deploy", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5WN1", "name":"FINS BIB", "displayName":"FINS BIB", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" } ] }, { "id":"88-1V5Y2U", "name":"Data Mig", "description":"Data Mig", "source":"Dev", "target":"Prod", "resources":[ { "id":"88-1V5Y2V", "name":"Migration Schema Service", "displayName":"Schema Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5Y2X", "name":"Migration Runtime Repository Data Service", "displayName":"Runtime Repository Data Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5Y2Y", "name":"Migration Application Workspace Data Service", "displayName":"Application Workspace Data Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5Y2Z", "name":"Migration Incremental Runtime Repository Data Service", "displayName":"Incremental Runtime Repository Data Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5Y30", "name":"Migration Incremental Application Workspace Data Service", "displayName":"Incremental Application Workspace Data Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5Y31", "name":"Migration Application Data Service", "displayName":"Application Data Service", "isSelected":"true", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5Y32", "name":"Migration Application Data Service With Transformation", "displayName":"Application Data Service With Transformation", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5Y33", "name":"MigrationFilePrepareAndDeploy", "displayName":"File Prepare And Deploy", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5Y34", "name":"FINS BIB", "displayName":"FINS BIB", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" } ] } ]
Getting a Migration Plan by Name
You can get a migration plan by name for your migration by sending an HTTP GET request to the Siebel Migration Application.
URI:
https://{hostname}:{port}/siebel/v1.0/migration/plan/{planName}HTTP Method: GET
HTTP Code: 200
Response Body:
Creating a New Migration Plan
You can create a new migration plan for your migration by sending an HTTP POST request to the Siebel Migration Application.
The following details are for a request to create a new migration plan for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/planHTTP Method: POST
Request Body:
{ "name":"Demo Data Mig", "description":"Demo Data Migration", "source":"Dev", "target":"Prod", "resources":[ { "id":"88-1V5WLP", "name":"Migration Schema Service", "displayName":"Schema Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5WLR", "name":"Migration Runtime Repository Data Service", "displayName":"Runtime Repository Data Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5WLS", "name":"Migration Application Workspace Data Service", "displayName":"Application Workspace Data Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5WLT", "name":"Migration Incremental Runtime Repository Data Service", "displayName":"Incremental Runtime Repository Data Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5WLU", "name":"Migration Incremental Application Workspace Data Service", "displayName":"Incremental Application Workspace Data Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5WLV", "name":"Migration Application Data Service", "displayName":"Application Data Service", "isSelected":"true", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5WLW", "name":"Migration Application Data Service With Transformation", "displayName":"Application Data Service With Transformation", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5WLX", "name":"MigrationFilePrepareAndDeploy", "displayName":"File Prepare And Deploy", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "id":"88-1V5WLY", "name":"FINS BIB", "displayName":"FINS BIB", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" } ] }
HTTP Code: 200
Response Body:
Updating a Migration Plan
You can update a migration plan for your migration by sending an HTTP PUT request to the Siebel Migration Application.
The following details are for a request to update a migration plan for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/plan/{planName}HTTP Method: PUT
Request Body:
{ "name":"Demo Data Migration Plan", "description":"Demo Data Migration for Winter", "source":"Dev", "target":"Prod", "resources":[ { "name":"Migration Schema Service", "displayName":"Schema Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "name":"Migration Runtime Repository Data Service", "displayName":"Runtime Repository Data Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "name":"Migration Application Workspace Data Service", "displayName":"Application Workspace Data Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "name":"Migration Incremental Runtime Repository Data Service", "displayName":"Incremental Runtime Repository Data Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "name":"Migration Incremental Application Workspace Data Service", "displayName":"Incremental Application Workspace Data Service", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "name":"Migration Application Data Service", "displayName":"Application Data Service", "isSelected":"true", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "name":"Migration Application Data Service With Transformation", "displayName":"Application Data Service With Transformation", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "name":"MigrationFilePrepareAndDeploy", "displayName":"File Prepare And Deploy", "isSelected":"true", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" }, { "name":"FINS BIB", "displayName":"FINS BIB", "isSelected":"false", "integrationBranchName":"", "versionNumber":"0", "language":"", "sequenceNumber":"0" } ] }
HTTP Code: 200
Response Body: None
Deleting a Migration Plan
You can delete for your migration by sending an HTTP DELETE request to the Siebel Migration Application.
The following details are for a request to delete a migration plan for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/plan/{planName}HTTP Method: DELETE
Request Body:
None
HTTP Code: 200
Response Body: None
Using REST API to Execute Siebel Migration Plans
You can use the Siebel Migration REST API to execute migration plans. For more information, see the following subtopics:
Executing a Migration Plan
You can execute a migration plan for your migration by sending an HTTP POST request to the Siebel Migration Application.
If you selected a Schema Service with Export & Import or Import only for your migration plan, then you must provide the following parameter and value in your REST API request:
schemaPassword. The password for the schema user. The schemaPassword must be encrypted by using base64 in the REST API request.
If you selected the Incremental Runtime Repository or the Incremental Application Workspace Data Service or the File Prepare and Deploy Service with Export only for your migration plan, then you must provide the watermarkFilename parameter and value in your REST API request.
If you want to only migrate a specific version when run the Incremental Runtime Repository (Export & Import or Export only) migration, then you must provide the irrEndVersion parameter and value in the REST API request. If you do not provide the irrEndVersion parameter and value, then, the migration migrates up to the latest version.
For all Export only or Import only migration plans, you must provide the packageFilename parameter and value in the REST API request.
URI:
https://{hostname}:{port}/siebel/v1.0/migration/execution/{planName}HTTP Method: POST
Request Body:
{ "schemaPassword":"", "watermarkFilename":"", "irrEndVersion":"", "packageFilename":"", }
HTTP Code: 200
Response Body:
{ "id":"88-1V5YFC", "planName":"Data Mig", "description":"Data Mig", "status":"Running", "startDate":"2018-07-24 09:50:20", "endDate":"", "source":"Dev", "target":"Prod", "packageName":"", "resources":[ { "id":"88-1V5YFD", "name":"", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Not Started", "startTime":"", "endTime":"", "resourceType":"" }, { "id":"88-1V5YFE", "name":"", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Not Started", "startTime":"", "endTime":"", "resourceType":"" } ] }
Getting Status for a Running Migration Plan by Name
You can get status for a running migration plan by name for your migration by sending an HTTP GET request to the Siebel Migration Application.
The following details are for a request to get status for a migration plan by name for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/execution/{planName}HTTP Method: GET
Request Body: None
HTTP Code: 200
Response Body:
{ "id":"88-1V5WPF", "planName":"IRRMigration", "description":"IRR Migration", "status":"Running", "startDate":"2018-07-17 04:33:54", "endDate":"", "source":"Dev", "target":"Prod", "packageName":"", "resources":[ { "id":"88-1V5WPG", "name":"", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Not Applicable", "startTime":"", "endTime":"", "resourceType":"" }, { "id":"88-1V5WPH", "name":"", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Not Applicable", "startTime":"", "endTime":"", "resourceType":"" }, { "id":"88-1V5WPI", "name":"", "operation":"Export", "sequenceNumber":"3", "mode":"Asynchronous", "status":"Running", "startTime":"2018-07-17 04:33:55", "endTime":"", "resourceType":"" }, { "id":"88-1V5WPJ", "name":"", "operation":"Import", "sequenceNumber":"4", "mode":"Asynchronous", "status":"Not Started", "startTime":"", "endTime":"", "resourceType":"" }, { "id":"88-1V5WPK", "name":"", "operation":"ActivateTasks", "sequenceNumber":"5", "mode":"Asynchronous", "status":"Not Started", "startTime":"", "endTime":"", "resourceType":"" }, { "id":"88-1V5WPL", "name":"", "operation":"DBCheck", "sequenceNumber":"6", "mode":"Asynchronous", "status":"Not Started", "startTime":"", "endTime":"", "resourceType":"" } ] }
Getting Status for a Running Migration Plan by Plan Name and Resource Name
You can get status for a running migration plan by plan name and resource name for your migration by sending an HTTP GET request to the Siebel Migration Application.
The following details are for a request to get status for a running migration plan by plan name and resource name for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/execution/{planName}/{resourceName}HTTP Method: GET
Request Body: None
HTTP Code: 200
Response Body:
{ "id":"88-1V60OJ", "planName":"Repo Export", "description":"Repo Export", "status":"Running", "startDate":"2018-08-17 06:02:39", "endDate":"", "source":"Dev", "target":"", "packageName":"irr_export.zip", "resources":[ { "id":"88-1V61H2", "name":"Incremental Runtime Repository Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Running", "startTime":"2018-08-17 06:02:39", "endTime":"", "resourceType":"DB Util" } ] }
Getting Execution Status by Migration Plan Name, Resource Name, and Operation
You can get execution status by migration plan name, resource name, and operation for your migration by sending an HTTP GET request to the Siebel Migration Application.
The following details are for a request to get execution status by migration plan name, resource name, and operation for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/execution/{planName}/{resourceName}/{operation}HTTP Method: GET
Request Body: None
HTTP Code: 200
Response Body:
{ "id":"88-1V5WPF", "planName":"Test REST Execution", "description":"Test REST Execution", "status":"Running", "startDate":"2018-07-17 04:33:54", "endDate":"", "source":"Dev", "target":"Prod", "packageName":"", "resources":[ { "id":"88-1V5WPI", "name":"Incremental Runtime Repository Data Service", "operation":"Export", "sequenceNumber":"3", "mode":"Asynchronous", "status":"Running", "startTime":"2018-07-17 04:33:55", "endTime":"", "resourceType":"" } ] }
Getting the Migration Execution Operation Log
You can get the migration execution operation log for your migration by sending an HTTP GET request to the Siebel Migration Application.
The following details are for a request to get the migration execution operation log for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/execution/{planName}/{resourceName}/{operation}/logHTTP Method: GET
Request Body: None
The response returns the migration execution operation log for your migration. The following are the details for the response to a successful request:
HTTP Code: 200
Using REST API to Get Siebel Migration Plan History
You can use the Siebel Migration REST API to get migration plan history.
Getting All Migration History
You can get all the history for your migration by sending an HTTP GET request to the Siebel Migration Application.
The following details are for a request to get all the history for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/historyHTTP Method: GET
Request Body: None
HTTP Code: 200
Response Body:
[ { "id":"88-1V5YFC", "planName":"Data Mig", "description":"Data Mig", "status":"Success", "startDate":"2018-07-24 09:50:20", "endDate":"2018-07-24 09:51:07", "source":"Dev", "target":"Prod", "packageName":"", "resources":[ { "id":"88-1V5YFD", "name":"Application Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-24 09:50:20", "endTime":"2018-07-24 09:50:36", "resourceType":"DB Util" }, { "id":"88-1V5YFE", "name":"Application Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-24 09:50:52", "endTime":"2018-07-24 09:51:07", "resourceType":"DB Util" } ] }, { "id":"88-1V5Y4X", "planName":"Data Mig", "description":"Data Mig", "status":"Success", "startDate":"2018-07-23 02:47:14", "endDate":"2018-07-23 02:48:00", "source":"Dev", "target":"Prod", "packageName":"", "resources":[ { "id":"88-1V5Y4Y", "name":"Application Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 02:47:14", "endTime":"2018-07-23 02:47:29", "resourceType":"DB Util" }, { "id":"88-1V5Y4Z", "name":"Application Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 02:47:44", "endTime":"2018-07-23 02:47:59", "resourceType":"DB Util" } ] }, { "id":"88-1V5WOX", "planName":"IRRMigration", "description":"IRRMigration", "status":"Error", "startDate":"2018-07-17 04:29:06", "endDate":"2018-07-17 04:29:22", "source":"Dev", "target":"Prod1", "packageName":"", "resources":[ { "id":"88-1V5WP0", "name":"Incremental Runtime Repository Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Error", "startTime":"2018-07-17 04:29:07", "endTime":"2018-07-17 04:29:22", "resourceType":"DB Util" }, { "id":"88-1V5WP1", "name":"Incremental Runtime Repository Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Not Started", "startTime":"", "endTime":"", "resourceType":"DB Util" }, { "id":"88-1V5WP2", "name":"Incremental Runtime Repository Data Service", "operation":"ActivateTasks", "sequenceNumber":"3", "mode":"Asynchronous", "status":"Not Started", "startTime":"", "endTime":"", "resourceType":"DB Util" }, { "id":"88-1V5WP3", "name":"Incremental Runtime Repository Data Service", "operation":"DBCheck", "sequenceNumber":"4", "mode":"Asynchronous", "status":"Not Started", "startTime":"", "endTime":"", "resourceType":"DB Util" } ] }, { "id":"88-1V5WOU", "planName":"Rest Testing", "description":"Rest Testing", "status":"Error", "startDate":"2018-07-17 04:28:35", "endDate":"2018-07-17 04:28:51", "source":"Dev", "target":"Prod1", "packageName":"", "resources":[ { "id":"88-1V5WOV", "name":"Application Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Error", "startTime":"2018-07-17 04:28:35", "endTime":"2018-07-17 04:28:51", "resourceType":"DB Util" }, { "id":"88-1V5WOW", "name":"Application Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Not Started", "startTime":"", "endTime":"", "resourceType":"DB Util" } ] }, { "id":"88-1V5WON", "planName":"IRRMigration", "description":"IRRMigration", "status":"Error", "startDate":"2018-07-17 04:28:06", "endDate":"2018-07-17 04:28:22", "source":"Dev", "target":"Prod1", "packageName":"", "resources":[ { "id":"88-1V5WOQ", "name":"Incremental Runtime Repository Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Error", "startTime":"2018-07-17 04:28:07", "endTime":"2018-07-17 04:28:22", "resourceType":"DB Util" }, { "id":"88-1V5WOR", "name":"Incremental Runtime Repository Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Not Started", "startTime":"", "endTime":"", "resourceType":"DB Util" }, { "id":"88-1V5WOS", "name":"Incremental Runtime Repository Data Service", "operation":"ActivateTasks", "sequenceNumber":"3", "mode":"Asynchronous", "status":"Not Started", "startTime":"", "endTime":"", "resourceType":"DB Util" }, { "id":"88-1V5WOT", "name":"Incremental Runtime Repository Data Service", "operation":"DBCheck", "sequenceNumber":"4", "mode":"Asynchronous", "status":"Not Started", "startTime":"", "endTime":"", "resourceType":"DB Util" } ] } ]
Getting Migration History by Migration Plan Name
You can get the migration history by migration plan name for your migration by sending an HTTP GET request to the Siebel Migration Application.
The following details are for a request to get the migration history by migration plan name for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/history?plan=<planName>HTTP Method: GET
Content-Type: application/json
Authorization: Basic
Request Body: None
HTTP Code: 200
Response Body:
[ { "id":"88-1V5YFF", "planName":"Data Mig", "description":"Data Mig", "status":"Success", "startDate":"2018-07-24 08:44:42", "endDate":"2018-07-24 08:45:27", "source":"Dev", "target":"Prod", "packageName":"", "resources":[ { "id":"88-1V5YFG", "name":"Application Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-24 08:44:42", "endTime":"2018-07-24 08:44:57", "resourceType":"DB Util" }, { "id":"88-1V5YFH", "name":"Application Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-24 08:45:12", "endTime":"2018-07-24 08:45:27", "resourceType":"DB Util" } ] }, { "id":"88-1V5YFC", "planName":"Data Mig", "description":"Data Mig", "status":"Success", "startDate":"2018-07-24 09:50:20", "endDate":"2018-07-24 09:51:07", "source":"Dev", "target":"Prod", "packageName":null, "resources":[ { "id":"88-1V5YFD", "name":"Application Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-24 09:50:20", "endTime":"2018-07-24 09:50:36", "resourceType":"DB Util" }, { "id":"88-1V5YFE", "name":"Application Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-24 09:50:52", "endTime":"2018-07-24 09:51:07", "resourceType":"DB Util" } ] }, { "id":"88-1V5YB6", "planName":"Data Mig", "description":"Data Mig", "status":"Success", "startDate":"2018-07-23 09:37:39", "endDate":"2018-07-23 09:38:24", "source":"Dev", "target":"Prod", "packageName":null, "resources":[ { "id":"88-1V5YB7", "name":"Application Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 09:37:39", "endTime":"2018-07-23 09:37:54", "resourceType":"DB Util" }, { "id":"88-1V5YB8", "name":"Application Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 09:38:09", "endTime":"2018-07-23 09:38:24", "resourceType":"DB Util" } ] }, { "id":"88-1V5YAK", "planName":"Data Mig", "description":"Data Mig", "status":"Success", "startDate":"2018-07-23 09:09:48", "endDate":"2018-07-23 09:10:34", "source":"Dev", "target":"Prod", "packageName":"", "resources":[ { "id":"88-1V5YAL", "name":"Application Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 09:09:48", "endTime":"2018-07-23 09:10:03", "resourceType":"DB Util" }, { "id":"88-1V5YAM", "name":"Application Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 09:10:19", "endTime":"2018-07-23 09:10:34", "resourceType":"DB Util" } ] }, { "id":"88-1V5YAH", "planName":"Data Mig", "description":"Data Mig", "status":"Success", "startDate":"2018-07-23 07:19:46", "endDate":"2018-07-23 07:20:32", "source":"Dev", "target":"Prod", "packageName":null, "resources":[ { "id":"88-1V5YAI", "name":"Application Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 07:19:46", "endTime":"2018-07-23 07:20:01", "resourceType":"DB Util" }, { "id":"88-1V5YAJ", "name":"Application Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 07:20:16", "endTime":"2018-07-23 07:20:32", "resourceType":"DB Util" } ] }, { "id":"88-1V5Y6J", "planName":"Data Mig", "description":"Data Mig", "status":"Success", "startDate":"2018-07-23 06:20:12", "endDate":"2018-07-23 06:20:58", "source":"Dev", "target":"Prod", "packageName":null, "resources":[ { "id":"88-1V5Y6K", "name":"Application Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 06:20:12", "endTime":"2018-07-23 06:20:27", "resourceType":"DB Util" }, { "id":"88-1V5Y6L", "name":"Application Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 06:20:43", "endTime":"2018-07-23 06:20:58", "resourceType":"DB Util" } ] }, { "id":"88-1V5Y5Y", "planName":"Data Mig", "description":"Data Mig", "status":"Success", "startDate":"2018-07-23 06:11:24", "endDate":"2018-07-23 06:12:37", "source":"Dev", "target":"Prod", "packageName":null, "resources":[ { "id":"88-1V5Y5Z", "name":"Application Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 06:11:24", "endTime":"2018-07-23 06:11:39", "resourceType":"DB Util" }, { "id":"88-1V5Y60", "name":"Application Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 06:11:54", "endTime":"2018-07-23 06:12:37", "resourceType":"DB Util" } ] }, { "id":"88-1V5Y5S", "planName":"Data Mig", "description":"Data Mig", "status":"Success", "startDate":"2018-07-23 06:11:13", "endDate":"2018-07-23 06:12:17", "source":"Dev", "target":"Prod", "packageName":null, "resources":[ { "id":"88-1V5Y5T", "name":"Application Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 06:11:13", "endTime":"2018-07-23 06:11:28", "resourceType":"DB Util" }, { "id":"88-1V5Y5U", "name":"Application Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 06:11:43", "endTime":"2018-07-23 06:12:17", "resourceType":"DB Util" } ] }, { "id":"88-1V5Y5M", "planName":"Data Mig", "description":"Data Mig", "status":"Success", "startDate":"2018-07-23 06:11:07", "endDate":"2018-07-23 06:11:53", "source":"Dev", "target":"Prod", "packageName":null, "resources":[ { "id":"88-1V5Y5N", "name":"Application Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 06:11:07", "endTime":"2018-07-23 06:11:22", "resourceType":"DB Util" }, { "id":"88-1V5Y5O", "name":"Application Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 06:11:38", "endTime":"2018-07-23 06:11:53", "resourceType":"DB Util" } ] }, { "id":"88-1V5Y5P", "planName":"Data Mig", "description":"Data Mig", "status":"Error", "startDate":"2018-07-23 06:11:09", "endDate":"2018-07-23 06:11:39", "source":"Dev", "target":"Prod", "packageName":null, "resources":[ { "id":"88-1V5Y5Q", "name":"Application Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 06:11:09", "endTime":"2018-07-23 06:11:24", "resourceType":"DB Util" }, { "id":"88-1V5Y5R", "name":"Application Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Not Started", "startTime":"", "endTime":"", "resourceType":"DB Util" } ] }, { "id":"88-1V5Y4X", "planName":"Data Mig", "description":"Data Mig", "status":"Success", "startDate":"2018-07-23 02:47:14", "endDate":"2018-07-23 02:48:00", "source":"Dev", "target":"Prod", "packageName":null, "resources":[ { "id":"88-1V5Y4Y", "name":"Application Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 02:47:14", "endTime":"2018-07-23 02:47:29", "resourceType":"DB Util" }, { "id":"88-1V5Y4Z", "name":"Application Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 02:47:44", "endTime":"2018-07-23 02:47:59", "resourceType":"DB Util" } ] }, { "id":"88-1V5Y4B", "planName":"Data Mig", "description":"Data Mig", "status":"Success", "startDate":"2018-07-23 02:36:26", "endDate":"2018-07-23 02:38:36", "source":"Dev", "target":"Prod", "packageName":null, "resources":[ { "id":"88-1V5Y4C", "name":"Application Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 02:37:50", "endTime":"2018-07-23 02:38:06", "resourceType":"DB Util" }, { "id":"88-1V5Y4D", "name":"Application Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 02:38:21", "endTime":"2018-07-23 02:38:36", "resourceType":"DB Util" } ] }, { "id":"88-1V5Y48", "planName":"Data Mig", "description":"Data Mig", "status":"Success", "startDate":"2018-07-23 02:30:33", "endDate":"2018-07-23 02:31:19", "source":"Dev", "target":"Prod", "packageName":null, "resources":[ { "id":"88-1V5Y49", "name":"Application Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 02:30:33", "endTime":"2018-07-23 02:30:48", "resourceType":"DB Util" }, { "id":"88-1V5Y4A", "name":"Application Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-23 02:31:03", "endTime":"2018-07-23 02:31:18", "resourceType":"DB Util" } ] }, { "id":"88-1V5Y3J", "planName":"Data Mig", "description":"Data Mig", "status":"Success", "startDate":"2018-07-22 11:26:29", "endDate":"2018-07-22 11:27:15", "source":"Dev", "target":"Prod", "packageName":"", "resources":[ { "id":"88-1V5Y3K", "name":"Application Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-22 11:26:29", "endTime":"2018-07-22 11:26:44", "resourceType":"DB Util" }, { "id":"88-1V5Y3L", "name":"Application Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-22 11:27:00", "endTime":"2018-07-22 11:27:15", "resourceType":"DB Util" } ] }, { "id":"88-1V5Y35", "planName":"Data Mig", "description":"Data Mig", "status":"Success", "startDate":"2018-07-22 11:17:16", "endDate":"2018-07-22 11:18:03", "source":"Dev", "target":"Prod", "packageName":"", "resources":[ { "id":"88-1V5Y36", "name":"Application Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-22 11:17:16", "endTime":"2018-07-22 11:17:31", "resourceType":"DB Util" }, { "id":"88-1V5Y37", "name":"Application Data Service", "operation":"Import", "sequenceNumber":"2", "mode":"Asynchronous", "status":"Success", "startTime":"2018-07-22 11:17:48", "endTime":"2018-07-22 11:18:03", "resourceType":"DB Util" } ] } ]
Getting Migration History by ID Number
You can get a migration history by ID number for your migration by sending an HTTP GET request to the Siebel Migration Application.
The following details are for a request to get a migration history by ID number for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/history/{id}HTTP Method: GET
Request Body: None
HTTP Code: 200
Response Body:
Getting Migration History by ID and Resource Name
You can get the migration history by ID and resource name for your migration by sending an HTTP Get request to the Siebel Migration Application.
The following details are for a request to get the migration history by ID and resource name for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/history/{id}/{resourceName}HTTP Method: GET
Request Body: None
HTTP Code: 200
Response Body:
Getting Migration History by ID, Resource Name, and Operation
You can get migration history by ID, resource name, and operation for your migration by sending an HTTP GET request to the Siebel Migration Application.
The following details are for a request to get migration history by ID, resource name, and operation for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/history/{id}/{resourceName}/{operation}HTTP Method: GET
Request Body: None
HTTP Code: 200
Response Body:
{ "id":"88-1V5WON", "planName":"IRRMigration", "description":"IRRMigration", "status":"Error", "startDate":"2018-07-17 04:28:06", "endDate":"2018-07-17 04:28:22", "source":"Dev", "target":"Prod1", "packageName":"", "resources":[ { "id":"88-1V5WOQ", "name":"Incremental Runtime Repository Data Service", "operation":"Export", "sequenceNumber":"1", "mode":"Asynchronous", "status":"Error", "startTime":"2018-07-17 04:28:07", "endTime":"2018-07-17 04:28:22", "resourceType":"DB Util" } ] }
Getting the Migration History Operation Log
You can get the migration history operation log for your migration by sending an HTTP GET request to the Siebel Migration Application.
The following details are for a request to get the migration history operation log for a migration:
URI:
https://{hostname}:{port}/siebel/v1.0/migration/history/{id}/{resourceName}/{operation}/logHTTP Method: GET
Request Body: None
The response returns the migration history operation log for your migration The following are the details for the response to a successful request:
HTTP Code: 200
