25Upgrade Files for Siebel Business Applications
This chapter lists the files that are used to perform a development or production upgrade to the current release of Siebel CRM, and lists the tables that are amended during PRET processing. This chapter contains the following topics:
Siebel CRM z/OS Upgrade Files
When you run the Siebel Upgrade Wizard on the midtier, it generates files that are used to perform the development and production upgrade. You then transfer these files to the z/OS host, where they are placed in staging data sets. Several upgrade files are also generated on the z/OS host.
The following table lists each of the upgrade files that are generated, the name of the file on the midtier (if applicable) and on the z/OS host, the phase of the upgrade when the file is generated, the upgrade path to which the file applies, and a brief description.
Midtier Filename z/OS Filename Phase Transferred to Host Description Upgrade Paths
job0.txt
JOB0
ftp_stg
Contains REXX code and panels
All
SIEBEL.load.xmit
load.xmit
ftp_stg
Load modules
All
sbllog.txt
SBLLOG.LOADFILE
ftp_stg
Initial log file entries
All
SIEBEL.sp.dbrmlib.xmit
sp.dbrmlib.xmit
ftp_stg
Dbrm modules
All
SIEBEL.sp.spddl.xmit
sp.spddl.xmit
ftp_stg
Stored procedure DDL
All
job1.txt
VSTG0000
VSTG0000 is copied into one of the following VSTG* files on the z/OS host, depending on your upgrade path:
VSTG0002 VSTG0020 VSTG0021 VSTG0022 VSTG0003 VSTG0005 VSTG0006 VSTG0040 VSTG0041 VSTG0042
ftp_stg
Generic install.jcl and help panels
All
siebin01.jcl
VSTG0001
VSTG0001 is copied into one of the following VSTG* files on the z/OS host, depending on your upgrade path:
VSTG0011 VSTG0030 VSTG0031 VSTG0032 VSTG0012 VSTG0014 VSTG0015 VSTG0050 VSTG0051 VSTG0052
ftp_stg
Install.jcl specific to each upgrade path
All
siebproc.jcl
VSTG0070
ftp_stg
JCL PROC members
All
filelist.txt
VSTG0075
Pause #1
List of files All
synctab.jcl
VSTG0085
syncdd
Table Synchronization All
syncidx.sql
VSTG0087
syncdd
Index Synchronization All
schema.staging.db.sql
VSTG0090
ftp_stg
Staging schema databases
All
schema.staging.tbsp.sql
VSTG0091
ftp_stg
Staging schema table spaces All
schema.staging.tbl.sql
VSTG0092
ftp_stg
Staging schema tables All
schema.staging.uind.sql
VSTG0093
ftp_stg
Staging schema unique indexes All
schema.staging.nuind.sql
VSTG0094
ftp_stg
Staging schema NPIs
All
schema.staging.oind.sql
VSTG0095
ftp_stg
Staging schema obsolete indexes All
schema.staging.grt.sql
VSTG0096
ftp_stg
Staging schema grants All
schema.db.sql
VSTG0100
Pause#2
Target schema databases All
schema.tbsp.sql
VSTG0101
Pause#2
Target schema table spaces
All
schema.tbl.sql
VSTG0102
Pause#2
Target schema tables All
schema.grt.sql
VSTG0103
Pause#2
Target schema grants
All
schema.uind.sql
VSTG0104
Pause#2
Target schema unique indexes
All
schema.nuind.sql
VSTG0105
Pause#2
Target schema NPIs
All
schema.oind.sql
VSTG0106
Pause#2
Target schema obsolete indexes
All
Not applicable
VSTG1010
This file is created on the z/OS host. It contains CREATE INDEX statements extracted from VSTG0104 and VSTG0105.
Not applicable
Generates index REBUILD control statements for the target environment. All
Not applicable
VSTG1111
This file is dynamically built on the z/OS host.
Not applicable
Maintains a list of the additive changes that are applied to the staging database. This list is updated dynamically as changes are applied. All
Not applicable
VSTG1112
Not applicable
Contains the additive changes applied to the staging database during the preupgrade phase. All
scindx.sql
VSTG0110
Pause#3
DDL for secondary indexes All
tmptable.sql
VSTG0119
Pause#2
Staging. Common TMPTABLES (tmptable.ctl)
All
tmptable.sql
VSTG0120
Pause#2
Target. Common TMPTABLES (tmptable.ctl)
All
tmptable1.sql
VSTG0121
ftp_stg
Staging.
Logging for Unload jobs and TMPTBL_ADDR table (no storage.ctl file)
All
tmptable2.sql
VSTG0122
ftp_stg
Target.
All
drop_view.sql
VSTG0130
ftp_stg
Apply drop view before Nonadditive All
ddlview_sql
VSTG0131
ftp_stg
Apply create view after Nonadditive All
siebel.translate.iconv
VSTG0150
Pause #1
Program to convert code pages for each language
All
pregen.txt
VSTG0200
ftp_stg
JCL (genclobf, gentrgd, geneimd)
All
pret.jcl
VSTG0210
Pause #1
PRET SQL All
pret_prod.jcl
VSTG0211
Pause #1
PRET JCL All
pret_sia.jcl
VSTG0220
Pause #1
PRETFINS SQL
SIA753, SIA77, SIA78, SIA80
pret_sia_prod.jcl
VSTG0221
Pause #1
PRETFINS JCL
unload.ldc
VSTG0300
Pause #2
Unload control cards All
load.ldc
VSTG0310
Pause #2
Load control cards All
preschm.jcl
VSTG0400
Pause #1
PRESCHM SQL All
preschm_prod.jcl
VSTG0401
Pause #1
PRESCHM JCL All
preschm_sia.jcl
VSTG0410
Pause #1
PRESCHMF SQL
preschm_sia_prod.jcl
VSTG0411
Pause #1
PRESCHMF JCL
upg_iss.jcl
VSTG0600
Pause #1
UPGISS JCL
All
upg_iss_prod.jcl
VSTG0601
Pause #1
UPGISS SQL
All
gen_primary1.jcl
VSTG0700
Pause #1
Gen Primary part 1 - SQL
All
gen_primary1_prod.jcl
VSTG0701
Pause #1
Gen Primary part 1 - JCL
All
gen_primary2.jcl
VSTG0702
Pause #1
Gen Primary part 2 - SQL
All
gen_primary2_prod.jcl
VSTG0703
Pause #1
Gen Primary part 2 - JCL
All
gen_primary3.jcl
VSTG0704
Pause #1
Gen Primary part 3 - SQL
All
gen_primary3_prod.jcl
VSTG0705
Pause #1
Gen Primary part 3 - JCL
All
gen_primary4.jcl
VSTG0706
Pause #1
Gen Primary part 4 - SQL
All
gen_primary4_prod.jcl
VSTG0707
Pause #1
Gen Primary part 4 - JCL
All
hhmignot.sql
VSTG0850
Pause #1
Household
hhmigpop.sql
VSTG0851
Pause #1
Household
household_mig_Fins.jcl
VSTG0852
Pause #1
Household
household_mig_Fins_prod.jcl
VSTG0853
Pause #1
Household
rpt_dup_addr_rowids.sql
VSTG0861
ftp_stg
Gen Dup Addr Report SQL
All
rpt_dup_addr_names.sql
VSTG0860
ftp_stg
All
schema.additive.sql
VSTG1000
Pause #1
Staging additive changes
All
Not applicable
VSTG1001
This file is a copy of VSTG1000; it is created on the z/OS host.
Not applicable
Target additive changes
All
Tables Amended During PRET Unload Processing
The unload job control cards for specific tables have been modified so that during PRET (pre-table) processing, the data in the tables is modified during the table unload process instead of being modified after the data has been loaded into the target table.
The following table lists the tables containing the data that is modified during unload processing, the macro that performs the modifications, and the relevant upgrade paths.
PRET Tables Modified During the Table Unload Process Macro Siebel Business Applications Paths Siebel Industry Applications Paths
S_APPL_WEB_TMPL
PTH0062
Not applicable
SIA753
S_APPL_WTMPL_IT
PTH0064
Not applicable
SIA753
S_CONTROL
PTH0222
All Paths
All Paths
S_PCONTROL
PTS0223
HOR753, HOR77
SIA753
S_FN_CRDT_RPT
PTS0224
HOR753, HOR77
SIA753
S_ASGN_RULE_GRP
PTS0225
HOR753, HOR77
SIA753
S_REGION
PTS0227
Not applicable
SIA753
S_REGION
PTS0228
Not applicable
SIA753
S_QTA_OBJCRT_D
PTH0833
All Paths
All Paths
S_ETL_TIME_DAY
PTS0313
Not applicable
SIA753
S_ETL_TIME_DAY
PTS0314
Not applicable
SIA753
S_EXTDATA_TBL
PTS0500
Not applicable
SIA753
S_PAPL_WEB_TMPL
PTS0505
Not applicable
SIA753
S_NOTE_CON
PTM0520
Not applicable
SIA77
S_NOTE_PROD_INT
PTM0520
Not applicable
SIA77
S_NOTE_ACCNT
PTM0520
Not applicable
SIA77
S_DOCK_TXN_LOG
PTM0010
All Paths
All Paths
S_ESCL_REQ
PTM0010
All Paths
All Paths
Note: Unload and load jobs on tables that contain CLOB data are processed by the PTMCLOBx macros. These macros adjust the unload and load job control cards to handle any CLOB data in a table. The PTMCLOBx macros can be found in the DSNHLQ.SIEBEL.EXEC or in the VSTG0300 and the VSTG0310 staging data sets.
PRET Members Generated By Pretedit.txt
The Pretedit.txt file creates the partitioned data set (PDS) on the z/OS host that is used for PRET processing. The members in this PDS perform a number of tasks, for example, listing the tables that contain CLOB columns, gathering information required for key processing, and deleting rows in specific tables. Data sets are generated for each upgrade path.
The following table shows the data set members created by the Pretedit.txt file, the objects amended by these members (the SQL statement that is run is contained in the member) and the upgrade path for which these members are generated.
PDS Member Name PRET Object Affected SIA Upgrade Paths
PRETLDIN
S_DOCK_TXN_LOG
All
PRETLDIN
S_ESCL_REQ
All
PRETCLBF
SQL/CLOB list, used by SBLCLOBU
All
PRETKEYS
SQL/Clustering Index Key structures
All
Target Tables Amended During PRET Processing
The PRET upgrade jobs perform operations on the target database tables listed in the following table. You might want to back up these tables before you start the upgrade.
The following table shows the target tables amended by PRET upgrade processing, the type of amendment made, and the upgrade path affected.
Tables Amended During PRET Processing Type of Change Made SIA Paths
S_FN_CRDT_RPT
Alter
SIA753
S_REGION
Alter
SIA753
