5Quick Reference for Siebel VB Methods
This quick reference section lists Siebel VB methods. It includes the following topics:
Disk and Directory Control Quick Reference
The following table lists methods that you can use to control disks and directories.
| Statement | Purpose | Reference |
ChDir |
Modifies the default directory for a drive. |
ChDrive |
Modifies the default drive. |
CurDir |
Returns the current directory for a drive. |
MkDir |
Creates a directory. |
RmDir |
Removes a directory. |
File Control Quick Reference
The following table lists methods that you can use to control files.
Close |
Closes a file. |
Dir |
Returns a file name that matches a pattern. |
FileAttr |
Returns the file mode or the operating system handle for an open file. |
FileCopy |
Copies a file. |
FileDateTime |
Returns the last modification date and time of a file. |
FileLen |
Returns the length of a file. |
FreeFile |
Returns the next unused file number. |
GetAttr |
Returns attributes of a file, directory, or volume label. |
Kill |
Deletes a file. |
Lock |
Controls access to an open file. |
Lof |
Returns the length of a file in bytes. |
Name |
Renames a file or copies a file from one directory to another directory. |
Open |
Opens a file. |
Reset |
Closes open files and writes to disk any data that currently resides in buffers. |
SetAttr |
Sets attribute information for a file. |
Unlock |
Controls access to some or all of an open file by other processes. |
File Input and Output Quick Reference
The following table lists methods that you can use to manipulate data in a file.
Eof |
Determines if the end of an open file has been reached. |
Get |
Reads the content of a file, and then places this content in a variable. |
Input |
Returns a string of characters from a file. |
Input filenumber, variable |
Reads data from a file, and then saves this data to different variables. |
Line Input |
Reads a line from a sequential file, and then saves it in a string variable. |
Loc |
Returns the current offset of a file. |
Prints data to a file or to the screen. |
Put |
Writes a variable to a file. |
Seek filenumber |
Returns the current position for a file. |
Seek filenumber, position |
Sets the position of the next read or write operation in an open file. |
Spc |
Prints a number of spaces. |
Tab |
Sets the current print position. |
Width |
Sets the output line width for an open file. |
Write |
Writes data to a sequential file. |
Code Setup and Control Quick Reference
The following table lists methods that you can use to perform setup tasks and to control the flow of logic in Siebel VB code.
Shell |
Starts a Microsoft Windows application. |
Call |
Transfers control to a subroutine. |
Sub name |
Creates a subroutine. |
Function |
Creates a function. |
Type userType |
Declares a custom data type. |
Declare Sub Declare Function |
Declares a procedure or a function. |
Const constantName |
Declares a symbolic constant. |
Environ |
Returns a string from the operating system environment |
Nothing |
Sets an object variable to not reference an object. |
AppActivate |
Sends keystrokes to a Microsoft Windows application. |
Clipboard |
Accesses the Microsoft Windows clipboard. |
Code Control Statements Quick Reference
The following table lists statements you can use to control the flow of logic in Siebel VB code.
_ |
Treats the next line as a continuation of the current line. |
Not applicable. |
Command |
Returns the command line specified when the MAIN sub runs. |
Not applicable. |
Do Loop |
Controls repetitive actions. |
Exit |
Causes the current procedure or loop structure to return. |
For Next |
Loops a fixed number of times. |
Go To |
Sends control to a statement. |
Go To Label |
Branches to one of multiple labels depending on value. |
If...Then... Else |
Branches on a conditional value. |
Me |
Gets the current object. |
Rem or ’ |
Treats the remainder of the line as a comment |
Select Case |
Runs one of a series of statement blocks. |
Stop |
Stops code from running. |
While Wend |
Variable Manipulation Quick Reference
The following table lists methods to manipulate variables.
Deftype |
Sets the default data type for one or more variables. |
Dim |
Declares a variable. |
Global |
Declares a global variable. |
Let |
Assigns a value to a variable. |
Null |
Sets a variant variable to a value of Null. |
Option Explicit |
Forces you to explicitly declare every variable in a module. |
Static |
Declares a variable and allocates storage space for this variable. |
VarType |
Returns the type of data stored in a variant. |
With |
Runs a series of statements on a variable. |
Strings Quick Reference
The following table lists methods to manipulate strings.
Chr |
Converts a character code to a string. |
Format |
Returns an expression in a format that you specify. |
InStr |
Returns the position of one string in another string. |
LCase |
Converts a string to lower case. |
Left |
Returns a string copied from the beginning of another string. |
Len |
Returns the length of a string or size of a variable. |
Like |
Compares the contents of two strings. |
Lset |
Copies one string to another string or assigns a custom variable to another variable. |
LTrim |
Removes leading spaces from a string. |
Mid |
Returns a portion of a string. |
Mid = string |
Replaces part or all of one string with another string. |
Option Compare |
Specifies the default method for string comparisons to case-sensitive or not case-sensitive. |
Right |
Returns the right portion of a string. |
Rset |
Right-justifies one string in another string. |
RTrim |
Removes trailing spaces from a string. |
Space |
Returns a string of spaces. |
Str |
Returns the string representation of a number. |
StrComp |
Compares two strings. |
String |
Returns a string that consists of a repeated character. |
Trim |
Removes leading and trailing spaces from a string. |
UCase |
Converts a string to upper case. |
Val |
Returns the numeric value of the first number that it finds in a string. |
Arrays Quick Reference
The following table lists methods for manipulating arrays.
Erase |
Erases the contents of an array. |
LBound |
Gets the lower boundary of an array. |
Option Base |
Specifies the default lower boundary to use for an array. |
ReDim |
Declares an array and reallocates memory. |
UBound |
Gets the upper boundary of an array. |
Math Operations Quick Reference
The following table lists methods to perform mathematical operations.
Abs |
Returns the absolute value of a number. |
Asc |
Returns an integer that corresponds to an ANSI character code. |
Atn |
Returns the arctangent of a number. |
Cos |
Returns the cosine of an angle. |
Exp |
Returns the value of e raised to a power. |
Fix |
Removes the fractional part of a number. |
Hex |
Returns the hexadecimal representation of a number. |
Int |
Returns the integer part of a number. |
Log |
Returns the natural logarithm of a value. |
Oct |
Returns the octal representation of a number. |
Randomize |
Creates a starting value for the random number generator. |
Rnd |
Returns a random number. |
Sgn |
Returns a value that identifies the sign of a number. |
Sin |
Returns the sine of an angle. |
Sqr |
Returns the square root of a number. |
Tan |
Returns the tangent of an angle. |
Date and Time Quick Reference
The following table lists methods for date and time information.
Date |
Converts an expression to the data type variant of type date. |
Date = expression |
Sets the computer date. |
DateSerial |
Converts a number to a date. |
DateValue |
Converts a string to a date. |
Day |
Returns the day component of a date and time value. |
Hour |
Returns the hour of day component of a date and time value. |
Minute |
Returns the minute component of a date and time value. |
Month |
Returns the month component of a date and time value. |
Now |
Returns the current date and time. |
Second |
Returns the second component of a date and time value. |
Time |
Returns the current time. |
Time = expression |
Sets the current time. |
Timer |
Returns the number of seconds since midnight. |
TimeSerial |
Returns the time for a specific hour, minute, and second. |
TimeValue |
Converts a string to time. |
Weekday |
Returns the day of the week for the specified date and time value. |
Year |
Returns the year component of a date and time value. |
ODBC Quick Reference
The following table lists methods that you can use with ODBC.
SQLClose |
Disconnects from an ODBC data source connection. |
SQLError |
Returns a detailed error message for an error that occurs during an ODBC method call. |
SQLExecQuery |
Runs an SQL statement. |
SQLGetSchema |
Gets information about data sources, databases, users, owners, and so on. |
SQLOpen |
Establishes a connection to an ODBC data source. |
SQLRequest |
Makes a connection to a data source, runs an SQL statement, returns the results. |
SQLRetrieve |
Returns the results of a select statement that SQLExecQuery runs. |
SQLRetrieveToFile |
Gets the results of an SQL query and stores them in a file. |
Object Querying Quick Reference
The following table lists methods that you can use to query an object.
If Typeof |
Determines if an object is of a given class. |
IsDate |
Determines if an expression evaluates to a date that Oracle’s Siebel VB allows. |
IsEmpty |
Determines if a variant has been set. |
IsMissing |
Determines if an optional argument for a procedure is missing. |
IsNull |
Determines if a variant contains a NULL value. |
IsNumeric |
Determines if a value is a valid number. |
Financials Quick Reference
The following table lists methods that you can use to calculate financial information.
FV |
Returns future value of a cash flow stream. |
IPmt |
Returns interest payment for a given period. |
IRR |
Returns internal rate of return for a cash flow stream. |
NPV |
Returns net present value of a cash flow stream. |
Pmt |
Returns a constant payment for each period for an annuity. |
PPmt |
Returns principal payment for a given period. |
PV |
Returns present value of a future stream of cash flows. |
Rate |
Returns interest rate for each period. |
Conversions Quick Reference
The following table lists methods that you can use to convert a value.
CCur |
Converts a value to currency. |
CDbl |
Converts a value to a double-precision floating point number. |
CInt |
Converts a value to an integer. |
CLng |
Converts a value to a long number. |
CSng |
Converts a value to single-precision, floating point number. |
CStr |
Converts a value to a string. |
CVar |
Converts a number or string to a variant. |
CVDate |
Converts a value to a date. |
COM Object Quick Reference
The following table lists methods for COM objects.
CreateObject |
Creates a new COM object. |
Dim As Object |
A class that provides access to a COM object. |
GetObject |
Gets a COM object from a file or gets the active COM object for a COM class. |
New |
Allocates and initializes a new COM object. |
Set |
Assigns a COM object to a variable. |
Error Handling Quick Reference
The following table lists methods for error handling.
Erl |
Returns a number that identifies the code line where an error occurred. |
Err |
Returns the error code of the last Visual Basic error handled. |
Err = errornumber |
Sets a run-time error code. |
Error |
Returns the error message that corresponds to an error code. |
Error errornumber |
Simulates the occurrence of an error. |
On Error |
Identifies the location of code that handles an error. |
Resume |
Stops the code that handles an error. |
