4Methods Reference for Siebel VB
This chapter describes reference information for Siebel VB methods. It includes the following topics:
Overview of Siebel VB Language Reference
A Siebel VB method can access a component of the Siebel software architecture, such as applets and business components. You must preface a Siebel VB method with the name of the architecture component that it references. For example:
BusComp.GetFieldValue(fieldName)
where:
BusComp is the name of the architecture component
GetFieldValue is the name of the Siebel VB method
A Microsoft VB command does not reference a specific component of the Siebel software architecture. All the statements and methods that this chapter describes are Microsoft VB constructs except for the ODBC methods. For more information, see ODBC Methods.
For more information, see About Functions and Methods.
Usage of the Dollar Sign
Some methods include the dollar sign ($) in the method name. This dollar sign is optional:
If you include it, then the return type is string.
If you do not include it, then the return type is string variant.
This situation is true unless noted differently in the description for each method in this chapter.
For more information, see Variants.
Methods, Functions, and Statements Described in Siebel Object Interfaces Reference
Siebel Object Interfaces Reference describes a number of methods, functions, and statements that you can use with Siebel VB that this chapter does not describe. For more information about each of these methods, see the Siebel VB Quick Reference chapter in Siebel Object Interfaces Reference.
Disk and Directory Control Methods
This topic describes methods that you can use to control the disk and directories. It includes the following topics:
Change Directory Method
The Change Directory method changes the default directory of a drive. It does not return a value. It does the following depending on how you use the arguments:
Include the drive argument. It changes the default directory on the current drive.
Include the first backslash in [\]directory\. It uses the path from the root directory.
Do not include the first backslash in [\]directory\. It changes to a directory that resides in the current directory.
The Change Directory method does not change the default drive. You can use the Change Drive method to change the default drive.
Format
ChDir [drive][[\]directory\]directory
The following table describes the arguments that you can use with this method.
| Argument | Description |
drive |
The name of the drive that contains the desired default directory. You can use one of the following values:
A colon is not required. |
[\]directory\ |
The path. You can use one of the following values:
You can use this argument in the following situations:
directory |
The name of the directory that this method sets for the default directory, or a string expression that identifies this name. |
Example
The following example changes the current directory to C:\Windows:
Sub Button_Click
Dim newdir as String
newdir = "c:\Windows"
If CurDir <> newdir then
ChDir newdir
End If
End Sub
Change Drive Method
The Change Drive method changes the default drive. It does not return a value. The drive that it changes to the default drive must exist, and this drive must reside in the range that the LASTDRIVE statement in the config.sys file specifies.
You can use a colon as part of the name of the drive but it is not required.
You can use the Change Directory method to change the current directory on a drive.
Format
ChDrive drive
drive |
A string expression that identifies the drive that this method makes the default drive. This method changes the drive according to one of the following values that you provide in the drive argument:
Example
The following example changes the default drive to A:
Sub Button_Click
Dim newdrive as String
newdrive = "A"
If Left(CurDir,2) <> newdrive then
ChDrive newdrive
End If
End Sub
Create Directory Method
The Create Directory method creates a new directory. It does not return a value.
Format
MkDir[drive:][\directory\]directory
drive |
Optional. The name of the drive where this method creates the directory. You can use a letter or a string expression that identifies the drive name. If you do not include the drive argument, then this method creates the new directory on the current drive. If you include the drive argument, then you must include the colon (:). |
\directory\ |
The path to the directory where this method creates the new directory, or a string expression that identifies this path. You can use this argument only if the Create Directory method must not create the directory in the following locations:
directory |
The name of the directory that this method creates, or a string expression that identifies this directory name. |
Example
The following example creates a new temporary directory in the C:\ directory, and then deletes it:
Sub Button_Click
Dim path as String
On Error Resume Next
path = CurDir(C)
If path <> "C:\" then
ChDir "C:\"
End If
MkDir "C:\TEMP01"
If Err = 75 then
Else
RmDir "C:\TEMP01"
End If
End Sub
Get Current Directory Method
The Get Current Directory method returns the default directory of a drive. If you specify a null ("") drive argument, or if you do not include the drive argument, then it returns the path for the default drive.
The drive that this method examines must exist, and it must reside in the range that the LASTDRIVE statement in the config.sys file specifies.
You can use the Change Drive method to change the current drive. You can use the Change Directory method to change the current directory.
Format
CurDir[$][(drive)]
For information about the dollar sign, see Usage of the Dollar Sign.
drive |
The letter of the drive to search. |
Example
Sub Button_Click Dim newdir as String newdir = "c:\Windows" If CurDir <> newdir then ChDir newdir End If End Sub
Remove Directory Method
The Remove Directory method removes a directory. It does not return a value. Note the following:
The directory that it removes must be empty, except for the working directory or parent directory.
It cannot remove the default directory. To remove the default directory, you must first make another directory current on the drive.
Format
RmDir[drive:][\directory\]directory
drive |
Optional. The name of the drive that contains the directory that this method removes. You can use a letter or a string expression that identifies the drive name. |
\directory\ |
The path to the directory that this method removes. You can use this argument only if the Remove Directory method must not remove the directory from the following locations:
directory |
The name of the directory that this method removes. |
Example
The following example makes a new temporary directory in the C:\ directory, and then deletes it:
Sub Button_Click
Dim path as String
path = CurDir(C)
ChDir "C:\"
End If
MkDir "C:\TEMP01"
If Err = 75 then
Else
RmDir "C:\TEMP01"
End If
End Sub
File Control Methods
This topic describes methods that you can use to control files. It includes the following topics:
Close All Files Method
The Close All Files method closes every open file and writes to disk any data that currently resides in the operating system buffers. It does not return a value.
Format
Reset
This method does not include any arguments.
Example
The following example creates a file, puts the numbers 1 through 10 in this file, and then attempts to get past the end of the file. The On Error statement handles the error and Siebel VB continues to the Debugger code. This code uses the Reset statement to close the file before it exits:
Sub Button_Click ' Put the numbers 1-10 into a file Dim x as Integer Dim y as Integer On Error Goto Debugger Open "c:\temp001" as #1 Len = 2 For x = 1 to 10 Put #1,x, x Next x Close #1 msgtext = "The contents of the file is:" & Chr(10) Open "C:\TEMP001" as #1 Len = 2 For x = 1 to 10 Get #1,x, y msgtext = msgtext & Chr(10) & y Next x done: Close #1 Kill "c:\temp001" Exit Sub
Debugger:
TheApplication.RaiseErrorText "Error " & Err & " occurred. Closing open file."
Reset
Resume done
End Sub
Close File Method
The Close File method closes a file and stops any input or output operations to this file. It does not return a value. When it runs, Siebel VB writes the final output buffer to the operating system buffer for this file. It frees the buffer space that is associated with the closed file. You can use the Close All Files method to cause the operating system to move the data in the buffers to disk. For more information, see Close All Files Method.
Format
Close [[#]filenumber [, [#]filenumber ... ]]
filenumber |
The file number that the Open statement uses to open the file. It identifies the file to close. The value in the filenumber argument is the number that the Open statement assigns to the file. A pound sign (#) can precede this argument. If you do not include this argument, then the Close statement closes every open file. When a Close statement runs, the association of a file with filenumber is ended, and Siebel VB can reopen this file with the same or a different file number. |
Example
The following example opens a file for random access, gets the contents of one variable, and then closes the file. The CreateFile subroutine creates the c:\temp001 file that the main subroutine uses:
(general) (declarations) Option Explicit Declare Sub CreateFile
Sub CreateFile
Rem Put the numbers 1-10 into a file
Dim x as Integer
Open "c:\temp001" for Output as #1
For x = 1 to 10
Write #1, x
Next x
Close #1
Reset
End Sub
Sub Button1_Click
Dim acctno as String * 3
Dim recno as Long
Dim msgtext as String
Call CreateFile
recno = 1
newline = Chr(10)
Open "c:\temp001" For Random As #1 Len = 3
msgtext = "The account numbers are:" & newline & newline
Do Until recno = 11
Get #1,recno,acctno
msgtext = msgtext & acctno
recno = recno + 1
Loop
Close #1
Reset
Kill "c:\temp001"
End Sub
Copy File Method
The Copy File method copies a file. It does not return a value. You cannot use the following wildcards in any of the arguments:
* (asterisk)
? (question mark)
The Copy File method cannot copy the file that the source argument identifies in the following situations:
If Siebel VB opens this file for anything other than read access
If other code has already opened and is using the file
Format
FileCopy [path1]source, [path2]target
path1 |
The path of the file to copy. If the value in the source argument does not reside in the current directory, then this argument is optional. |
source |
The name and, if necessary, the path of the file to copy. |
path2 |
The path to a directory. This method copies the file to this directory. If you require that this method not copy the file to the current directory, then the path2 argument is optional. |
target |
A name. This method copies the file to this name. |
Example
The following example copies one file to another file:
Sub Button_Click
Dim oldfile, newfile
oldfile = "c:\temp\trace.txt"
newfile = "c:\temp\newtrace.txt"
FileCopy oldfile,newfile
If Err <> 0 then
msgtext = "Error during copy. Rerun program."
Else
msgtext = "Copy successful."
End If
End Sub
Delete File Method
The Delete File method deletes a file. It does not return a value. It only deletes files. It does not delete directories. You can use the Delete Directory method to delete a directory.
Format
Kill pathname
pathname |
A string expression that identifies a valid DOS file specification. It can include paths and the following wildcards:
Example
The following example does the following work:
Prompts a user for an account number.
Opens a file.
Searches the file for the account number.
Displays the matching letter for that number.
The CreateFile subroutine creates the c:\temp001 file that the main subroutine uses. The first subroutine uses the Kill statement to delete the file after Siebel CRM finishes processing:
(general) (declarations) Option Explicit Declare Sub CreateFile Global x as Integer Global y(100) as String
Sub CreateFile
' Put the numbers 1-10 and letters A-J into a file
Dim startletter
startletter = 65
For x = 1 to 10
y(x) = Chr(startletter)
startletter = startletter + 1
Next x
For x = 1 to 10
Write #1, x,y(x)
Next x
Close #1
End Sub
Sub Button_Click
Dim acctno as Integer
Dim msgtext
Call CreateFile
i: acctno = 6
If acctno<1 Or acctno>10 then
Goto i:
End if
x = 1
Open "c:\temp001" for Input as #1
Do Until x = acctno
Input #1, x,y(x)
Loop
msgtext = "The letter for account number " & x & " is: _
" & y(x)
Close #1
kill "c:\temp001"
End Sub
Get File Attributes Method
The Get File Attributes method returns the attributes of a file, directory, or a volume label.
Format
GetAttr(pathname)
pathname |
A string or string expression that evaluates to the name of the file, directory, or volume label to query. It cannot include the following wildcards:
Returns
The following table describes the values that the Get File Attributes method returns.
| Value | Description |
0 |
Normal file. |
1 |
Read-only file. |
2 |
Hidden file. |
4 |
System file. |
8 |
Volume label. |
16 |
Directory. |
32 |
Archive. The file has changed since the last backup occurred. |
If it returns any other value, then the return value represents the sum of the return values of the attributes that are set. For example, a return value of 6 represents a hidden system file, where 6 is 2 + 4. |
Related Topics
Get File Date Method
The Get File Date method returns the last modification date and time of a file.
Format
FileDateTime(pathname)
pathname |
A string or string expression that evaluates to the name of the file to query. It can contain path and disk information. It cannot include the following wildcards:
Get File Length Method
The Get File Length method returns the length in bytes of an open file. The file must already be open to use this method.
Format
Lof(filenumber)
filenumber |
The file number that the Open statement uses to open the file. |
Example
The following example opens a file and prints the contents of this file to the screen:
Sub Button_Click
Dim fname As String,fchar() As String
Dim x As Integer, msgtext As String, newline As String
newline = Chr(10)
fname = "d:\temp\trace.txt"
Open fname for Input as #1
If Err <> 0 then
Exit Sub
End If
msgtext = "The contents of " & fname & " is: " _
& newline & newline
Redim fchar(Lof(1))
For x = 1 to Lof(1)
fchar(x) = Input(1,#1)
msgtext = msgtext & fchar(x)
Next x
Close #1
End Sub
Get File Length 2 Method
The Get File Length 2 method returns the length of a file. If the file is open, then it returns the length of the file before it was opened. The file can be closed or open to use this method.
Format
FileLen(pathname)
pathname |
A string or string expression that evaluates to the name of the file to query. It cannot include the following wildcards:
Example
The following example returns the length of a file:
Sub Button_Click
Dim length as Long
Dim userfile as String
Dim msgtext
msgtext = "Enter a file name:"
userfile = "trace.txt"
length = FileLen(userfile)
If Err <> 0 then
msgtext = "Error occurred. Rerun program."
Else
msgtext = "The length of " & userfile & " is: " & length
End If
End Sub
Get File Mode Method
The Get File Mode method returns the file mode or the operating system handle for an open file. The following table describes this return value.
| Value of Returntype Argument | Description of the Return Value |
1 |
The file mode of the open file:
2 |
The operating system handle of the open file. |
Format
FileAttr(filenumber, returntype)
filenumber |
returntype |
An integer that identifies the type of information to return. |
Example
The following example does one of the following:
If the open file is in input mode or output mode, then it closes this open file.
If the open file is in append mode, then it writes a range of numbers to this file.
The CreateFile subroutine creates the file and leaves it open:
Sub CreateFile
Dim x as Integer
For x = 1 to 10
Write #1, x
Next x
End Sub
Sub Button_Click
Dim filemode as Integer
Dim attrib as Integer
Call CreateFile
attrib = 1
filemode = FileAttr(1,attrib)
If filemode = 1 or 2 then
Close #1
Else
For x = 11 to 15
Write #1, x
Next x
Close #1
End If
Kill "c:\temp001"
End Sub
Get File Names Method
The Get File Names method is a standard Visual Basic method that returns the first file name it finds that matches the value in the pathname argument and that possesses the attributes that you specify in the attributes argument. If it does not find a file, then it returns a null string ("").
Format
Dir[$] [(pathname[, attributes])]
pathname |
A string or string expression that evaluates to a path or file name. |
attributes |
An integer expression that specifies the file attributes to choose. |
Usage for the Attributes Argument
You can use the integer values for the attributes argument described in the following table to return a specific type of file.
| Value in Attributes Argument | File Type |
0 (default) |
Normal files with no attributes set. |
2 |
Normal and hidden files. |
4 |
Normal and system files. |
8 |
Volume label only. |
16 |
Normal files and directories. |
You can add values to choose multiple attributes. For example, to return normal files, hidden files, and system files, you set the attributes argument to 6, where 6 equals 0 plus 2 plus 4.
If you set the attributes argument to 8, then this method returns one of the following values:
The volume label of the drive that you specify in the pathname argument.
The current drive if you do not specify a drive in the pathname argument.
Usage for the Pathname Argument
The pathname argument can include a drive specification and the following wildcard characters:
? (question mark)
* (asterisk)
Siebel VB interprets a null string ("") in the pathname argument as the current directory. This value is equivalent to a period (.). You can use the Get File Names method again to get more matching file names, but this time do not include the pathname argument or the attributes argument.
Example
The following example lists all the files that reside on drive A:
Sub Button_Click Dim msgReturn Dim directory, count Dim x, msgtext Dim A() count = 1
ReDim A(100)
directory = Dir ("A:\*.*")
Do While directory <> ""
A(count) = directory
Count = count + 1
directory = Dir
loop
msgtext = "Contents of drive A:\ is:" & Chr(10) & Chr(10)
For x = 1 to count
msgtext = msgtext & A(x) & Chr(10)
Next x
End Sub
Get Free File Number Method
The Get Free File Number method returns the lowest unused file number. It does not include arguments. You can use it if you must supply a file number and must make sure that this file number is not already in use. You can use the return value in a subsequent Open statement.
Format
FreeFile
The following example opens a file and assigns to it the next file number that is available:
Sub Button_Click Dim filenumber As Integer Dim filename As String filenumber = FreeFile filename = "d:\temp\trace.txt" On Error Resume Next Open filename For Input As filenumber If Err <> 0 then Exit Sub End If Close #filenumber End Sub
Lock File Method
The Lock File method controls access to an open file. It does not return a value.
Format
Lock [#]filenumber[, [start] [To end]]
filenumber |
start |
A long integer that identifies the number of the first record or byte offset to lock or unlock. |
end |
A long integer that identifies the number of the last record or byte offset to lock or unlock. |
Specifying the Start Argument and End Argument
The Lock File method locks the file according to the following modes:
Binary mode. The start argument and the end argument identify byte offsets.
Random mode. The start argument and the end argument identify record numbers:
If you include the start but not the end, then it locks only the record or byte that the start argument identifies.
If you include the end but not the start, then it locks records or bytes from the record number or offset 1 to the end.
Input mode, output mode, or append mode. It locks the entire file. It ignores the start argument and the end argument.
Removing Locks
You must use the Lock File method and the Unlock File method in pairs to remove a lock, and the arguments that you use with these methods must be identical. For more information, see Unlock File Method.
You must configure Siebel VB to remove a lock on an open file before it closes the file. If you do not do this, then unpredictable results might occur.
Example
In the following example, if the file is already in use, then this code locks the file that other users on a network share. The CreateFile subroutine creates the file that the main subroutine uses:
Sub CreateFile
' Put the letters A-J into the file
Dim x as Integer
For x = 1 to 10
Write #1, Chr(x + 64)
Next x
Close #1
End Sub
Sub Button_Click
Dim btngrp, icongrp
Dim defgrp
Dim answer
Dim noaccess as Integer
Dim msgabort
Dim msgstop as Integer
Dim acctname as String
noaccess = 70
msgstop = 16
Call CreateFile
btngrp = 1
icongrp = 64
defgrp = 0
answer = 1
If answer = 1 then
If Err = noaccess then
‘File Locked -Aborted
Else
Lock #1
Line Input #1, acctname
Unlock #1
End If
Close #1
End If
Kill "C:\TEMP001"
End Sub
Open File Method
The Open File method opens a file for input or output. It does not return a value. Siebel CRM opens the file in the default character encoding that the local operating system uses. This method does not support Unicode.
Format
Open filename [For mode] [Access access] [lock] As [#]filenumber [Len = reclen]
filename |
A string or string expression that identifies the name of the file to open. If this file does not exist, then this method creates it if opened in one of the following modes:
This file must be open before Siebel VB can perform any input or output operation on it. |
mode |
A keyword that identifies the purpose for which this method opens the file. If you do not include the mode argument, then this method defaults the mode to random. |
access |
A keyword that identifies the method to access the file. If you do not include the access argument for random or binary modes, then the Open File method attempts to access the file in the following order:
lock |
A keyword that designates the access method that other processes can use to open this file. If you do not include the lock argument, then other processes can open the file that the filename argument identifies. Other processes cannot perform any file operation on the file while the original process still has the file open. |
filenumber |
An integer that identifies the file while it is open. You can use the Get Free File Number method to find the next available value that you can use in the filenumber argument. For more information, see Get Free File Number Method. |
reclen |
In a random or binary file, the length of the records. This method ignores the reclen argument for the following modes:
Usage
The following table describes the keywords that you can use with this method.
| Type of Keyword | Keyword | Description |
Mode |
Input |
Reads data from the file sequentially. |
Output |
Puts data into the file sequentially. |
Append |
Adds data to the file sequentially. |
Random |
Gets data from the file by random access. |
Binary |
Gets binary data from the file. |
Access |
Read |
Reads data only from the file. |
Write |
Writes data only to the file. |
Read Write |
Reads or writes data to the file. |
Lock |
Shared |
Read or write is available on the file. |
Lock Read |
Only read is available. |
Lock Write |
Only write is available. |
Lock Read Write |
No read or write is available. |
Example
The following example opens a file for random access, gets the contents of the file, and then closes the file. The CreateFile subroutine creates the c:\temp001 file that the main subroutine uses:
Sub CreateFile
Dim x as Integer
For x = 1 to 10
Write #1, x
Next x
Close #1
End Sub
Sub Button_Click
Dim recno as Long
Call CreateFile
recno = 1
newline = Chr(10)
Do Until recno = 11
Get #1,recno,acctno
recno = recno + 1
Loop
Close #1
Kill "c:\temp001"
End Sub
Rename File Method
The Rename File method renames a file or copies a file from one directory to another directory. It does not return a value. The file that this method renames must be closed. Siebel VB creates an error message in the following situations:
The file that the oldfilename argument identifies is open.
The file that the newfilename argument identifies already exists.
If you use the Rename File method with a Siebel application, and if you do not include the path2 argument, then it places a copy of the original file in the following directory under the new name:
c:\siebel\bin
Format
Name [path1\]oldfilename As [path2\]newfilename
path1 |
A string expression that contains the path to the current file location. If the file is not in the current directory of the current drive, then you must include this argument. |
oldfilename |
A string expression that contains the name of the file that this method renames. |
path2 |
A string expression that contains the path to the location where the renamed file must reside. If you do not include this argument, then this method saves the file in the current directory of the current drive. |
newfilename |
A string expression that contains the new name for the file. |
Example
The following example creates the c:\temp001 file, renames this file to c:\temp002, and then deletes these files. It calls the CreateFile subroutine to create the c:\temp001 file:
Sub CreateFile
Dim x as Integer
Dim y()
Dim startletter
Open "C:\TEMP001" for Output as #1
For x = 1 to 10
Write #1, x
Next x
Close #1
End Sub
Sub Button_Click
Call CreateFile
Name "C:\TEMP001" As "C:\TEMP002"
Kill "TEMP001"
Kill "TEMP002"
End Sub
Set File Attributes Method
The Set File Attributes method sets the file attributes for a specified file. It does not return a value.
You cannot use a wildcard in the pathname argument. If the file is open, you can modify the file attributes, but only if it is opened for Read access.
Format
SetAttr pathname, attributes
pathname |
A string or string expression that evaluates to the name of the file. |
attributes |
An integer expression that contains the new attributes of the file. |
Usage
The following table describes the attributes you can modify.
0 |
Normal file. |
1 |
Read-only file. |
2 |
Hidden file. |
4 |
System file. |
32 |
Archive. File has changed since the last backup. |
Example
For an example, see Select Case Statement.
Unlock File Method
The Unlock File method controls access to an open file. It does not return a value.
You must use the Lock File method and the Unlock File method in pairs to unlock a file, and the arguments that you use with these methods must be identical. For more information, see Lock File Method.
You must remove a lock before you close the file. For more information, see Lock File Method.
Format
Unlock [#]filenumber[, {record | [start] To end} ]
filenumber |
The file number that the Open statement uses to open the file. For more information, see Open File Method. |
record |
An integer that identifies the first record to unlock. |
start |
A long integer that identifies the first record or byte offset to unlock. |
end |
A long integer that identifies the last record or byte offset to unlock. |
Example
For an example of the Unlock statement, see Lock File Method.
File Input and Output Methods
This topic describes methods that you can use to manipulate file data. It includes the following topics:
End of File Method
The End of File method determines if the end of an open file has been reached. It returns one of the following values:
-1. The end of the file has been reached.
0. The end of the file has not been reached.
Format
Eof(filenumber)
filenumber |
The file number you use in the Open statement to open the file. For information about assigning a number to a file when it is opened, see Open File Method. |
Example
The following example uses the End of File method to read records from a random file. It keeps the Get statement from attempting to read beyond the end of the file. The CreateFile subroutine creates the C:\TEMP001 file that the main subroutine uses:
Sub CreateFile
Dim x as Integer
For x = 1 to 10
Write #1, x
Next x
Close #1
End Sub
Sub Button_Click
Dim acctno
newline = Chr(10)
Call CreateFile
Open "C:\temp001" For Input As #1
Do While Not Eof(1)
Input #1,acctno
msgtext = msgtext & newline & acctno & newline
Loop
Close #1
Kill "C:\TEMP001"
End Sub
For another example, see Get Free File Number Method:
Get Characters From File Method
The Get Characters From File method returns a string that contains the characters that it reads from a file. It advances the file pointer according to the number of characters it reads. Unlike the Parse File Contents method, the Get Characters From File method returns every character it reads, including carriage returns, line feeds, and leading spaces.
The input buffer can hold a maximum of 32K characters. If the Get Characters From File method must get an amount of data that exceeds this maximum, then you must call it multiple times, processing 32K characters each time you call it.
Format
Input[$](number, [#]filenumber)
number |
An integer that identifies the number of bytes to read from the file. |
filenumber |
A number that identifies the open file to use. |
Get File Contents Method
The Get File Contents method reads the content of a file opened in random or binary mode, and then places this content in a variable. It does not return a value.
Format
Get [#]filenumber, [recnumber], varName
filenumber |
The file number that the Open statement uses to open the file. For information about how Siebel VB numbers a file when it opens a file, see Open File Method. |
recnumber |
An expression of type long. It contains a value that depends on one of the following modes:
The recnumber argument is in the range of 1 through 2,147,483,647. If you do not include this argument, then this method uses the next record or byte. You must include the commas before and after the recnumber argument even if you do not include the recnumber argument. |
varName |
The name of a variable. This method reads file data into this variable. It can be any variable type except for the following:
Usage with Random Mode
For Random mode, the Get File Contents method reads content from the file in chunks whose size is equal to the size specified in the Len clause of the Open statement. It does one of the following, depending on the size of the variable that the varName argument identifies:
The variable is smaller than the record length. It discards the additional content.
The variable is larger than the record length. It creates an error.
The Get File Contents method handles content differently depending on the following type of variable:
Variable length string variable. it reads two bytes of content that identifies the length of the string, and then copies the contents into the variable that the varName argument identifies.
Variant variable. It reads two bytes of content that identifies the type of the variant, and then it copies the body of the variant into the varName argument. A variant that includes a string includes the following information:
Two bytes of data type information.
Two bytes of length data.
The body of the string.
Custom variable. It reads the content as if each member were read separately. No padding occurs between elements.
Usage with Binary Mode
Usage with a file opened in Binary mode is the same as usage with a file opened in Random mode except for the following differences:
The Get File Contents method reads variables from the disk without record padding.
For a variable length string that is not part of a custom type, the Get File Contents method does not precede this variable with a two-byte string length. Instead, it reads the number of bytes as equal to the length of the variable that the varName identifies.
Example
The following example opens a file for random access, gets the contents of this file, and then closes the file. The createfile subroutine creates the c:\temp001 file that the main subroutine uses:
Sub CreateFile
Dim x as Integer
For x = 1 to 10
Write #1, x
Next x
Close #1
End Sub
Sub Button1_Click
Dim recno as Long
Call CreateFile
recno = 1
newline = Chr(10)
Do Until recno = 11
Get #1,recno,acctno
recno = recno + 1
Loop
Close #1
Kill "c:\temp001"
End Sub
Related Topics
Get File Offset Method
The Get File Offset method determines the current offset of a file. It returns a value depending on the following mode that it uses to open the file:
Random file. It returns the number of the last record read or written.
File opened in append, input, or output mode. It returns the current byte offset divided by 128.
File opened in binary mode. It returns the offset of the last byte read or written.
The offset starts at 0 in a random file or binary file. A position starts at 1. For more information, see Get File Position Method.
Format
Loc(filenumber)
filenumber |
Example
The following example creates a file of account numbers that the user enters. When the user finishes, it displays the offset of the file of the last entry that the user made:
Sub Button_Click
Dim filepos as Integer
Dim acctno() as Integer
Dim x as Integer
x = 0
Open "c:\TEMP001" for Random as #1
Do
x = x + 1
Redim Preserve acctno(x)
acctno(x) = 234
If acctno(x) = 0 then
Exit Do
End If
Put #1,, acctno(x)
Loop
filepos = Loc(1)
Close #1
Kill "C:\TEMP001"
End Sub
The Get File Position method returns the current position of an open file depending on the following mode that it uses to open the file:
Random mode. It returns the number of the next record to be read or written.
Other modes It returns the file offset of the next operation.
The first byte in the file is at offset 1, the second byte is at offset 2, and so on. The return value is a long number.
Format
Seek(filenumber)
filenumber |
Example
The following example reads the contents of a sequential file line by line to a carriage return, and then displays the results. The CreateFile subroutine creates the c:\temp001 file that the main subroutine uses:
Sub CreateFile
Rem Put the numbers 10-100 into a file
Dim x as Integer
For x = 10 to 100 step 10
Write #1, x
Next x
Close #1
End Sub
Sub Button_Click
Dim testscore as String
Dim x
Dim y
Dim newline
Call CreateFile
x = 1
newline = Chr(10)
msgtext = "The test scores are: " & newline
Do Until x = Lof(1)
Line Input #1, testscore
x = x + 1
y = Seek(1)
If y>Lof(1) then
x = Lof(1)
Else
Seek 1,y
End If
msgtext = msgtext & newline & testscore
Loop
Close #1
Kill "c:\temp001"
End Sub
Get Line From File Method
The Get Line From File method reads a line from a sequential file, and then saves it in a string variable. It does not return a value. You can use it to read lines of text from a text file where a carriage return separates each data element. You can use a read method to read data from a file that includes values and commas that separate each of these values.
Format A
Line Input [#] filenumber, varName
Line Input [prompt,] varName
filenumber |
This method does the following depending on if you include the filenumber argument:
varName |
A string variable. This method saves a line of data or user input into this variable. |
prompt |
A string literal that prompts the user for keyboard input. If you do not include the prompt argument, then this method displays a question mark (?) as the prompt. |
Example
The following example reads the contents of a sequential file line by line up to a carriage return, and then displays the result. The CreateFile subroutine creates the C:\temp001 file that the main subroutine uses:
Sub CreateFile
Dim x as Integer
For x = 1 to 10
Write #1, x
Next x
Close #1
End Sub
Sub Button_Click
Dim x
Dim y
Dim newline
Call CreateFile
x = 1
newline = Chr(10)
msgtext = "The contents of c:\temp001 is: " & newline
Do Until x = Lof(1)
x = x + 1
y = Seek(1)
If y>Lof(1) then
x = Lof(1)
Else
Seek 1,y
End If
msgtext = msgtext & testscore & newline
Loop
Close #1
Kill "c:\temp001"
End Sub
Parse File Contents Method
The Parse File Contents method reads data from a sequential file, and then saves this data to different variables. It does not return a value.
Format
Input [#]filenumber, variable[, variable]...
filenumber |
variable |
One or more variables to contain the values that this method reads from the file. A comma separates each variable. |
Example
Opens a file.
This example uses the Input statement to increase the value of x and at the same time to get the letter associated with each value. The CreateFile subroutine creates the c:\temp001 file that the main subroutine uses:
Sub CreateFile
Dim startletter
startletter = 65
For x = 1 to 10
Next x
For x = 1 to 10
Write #1, x,y(x)
Next x
Close #1
End Sub
Sub Button2_Click
Dim msgtext
Call CreateFile
start: acctno = 2
Goto start:
End if
x = 1
Do Until x = acctno
Input #1, x,y(x)
Loop
msgtext = "The letter for account number " & x & " is: " _
& y(x)
Close #1
Kill "C:\TEMP001"
End Sub
Print Spaces Method
The Print Spaces method prints a number of spaces. It returns a string of spaces in the target of a Print statement. You can use it only in a Print statement. To determine the number of spaces to print, it uses different rules according to the following values:
The value in the number argument is less than the total line width. It prints the number spaces according to the value of the number argument.
The value in the number argument is greater than the total line width. It prints the number of spaces according to the modulus of the following calculation:
Value in the argument that the Print Spaces method receives divided by the length of the string to print.
The modulus in this context is the remainder of a calculation rounded to an integer.
X is less is than the value of the number argument or number Mod width, where x is the difference between the current print position and the output line width. It skips to the next line and prints the value of the number argument minus x spaces.
You can use the Set File Width statement to set the width of a print line. For more information, see Set File Width Method.
Format
Spc(number)
number |
An integer or integer expression that specifies the number of spaces to print. |
Example
The following example prints five spaces and the following string to a file:
ABCD
This example divides 15 by 10 with a remainder of 5 to determine the five spaces:
Sub Button_Click Dim str1 as String Dim x as String * 10 str1 = "ABCD" Open "C:\temp001" For Output As #1 Width #1, 10 Print #1, Spc(15); str1 Close #1 Open "C:\TEMP001" as #1 Len = 12 Get #1, 1,x Close #1 Kill "C:\temp001" End Sub
Print Data to File Method
The Print Data to File method prints data to an open file. It does not return a value. You can use the following methods in a Print statement:
Print Spaces method. Inserts a given number of spaces. For more information, see Print Spaces Method.
Set Print Position method. Moves the print position to a desired column. For more information, see Set Print Position Method.
The Print statement supports only elementary Visual Basic data types. For more information on parsing this statement, see Get Characters From File Method.
Format
Print [#][filenumber,] expressionList [{;|, }]
filenumber |
The file number that the Open statement uses to open the file. The Print Data to File method prints data to this file. For more information, see Open File Method. |
expressionList |
A list of values that this method prints. It prints these values in the form of literals or expressions. It determines where output for the next Print statement to the same output file must begin. If you do not include the expressionList argument, then this method writes a blank line to the file. |
Usage for the Expression List
You can use one of the following characters to separate each value in the expressionList argument:
Semicolon (;). The next value must occur immediately after the preceding value without intervening white space.
Comma (,). The next value must occur at the next print zone. A new print zone begins every 14 spaces.
If you do not specify a semicolon or a comma, then the Print Data to File method creates a CR-LF (carriage return - line feed) pair and the next Print statement prints on the next line.
Set File Position Method
The Set File Position method sets the position of the next read or write operation in an open file. It does not return a value. If you write to a file after reading beyond the end of the file, then this method increases the file length. If a read operation attempts to specify a negative or zero position, then Visual Basic returns an error message.
Format
Seek [#]filenumber, position
filenumber |
position |
An expression of type long that identifies the position depending on the following mode that this method uses to open the file:
The position is in the range of 1 through 2,147,483,647. The first byte or record in the file is at position 1, the second is at position 2, and so on. |
Example
Sub CreateFile
Dim x as Integer
Write #1, x
Next x
Close #1
End Sub
Sub Button_Click
Dim x
Dim y
Dim newline
Call CreateFile
x = 1
newline = Chr(10)
Do Until x = Lof(1)
x = x + 1
y = Seek(1)
If y>Lof(1) then
x = Lof(1)
Else
Seek 1,y
End If
Loop
Close #1
Kill "c:\temp001"
End Sub
The Set File Width method sets the output line width for an open file. It does not return a value.
Format
Width [#]filenumber, width
filenumber |
width |
An integer expression that specifies the width of the output line. A value of zero (0) specifies that no line length limit exists. The default value is zero (0). |
Example
For an example, see Print Spaces Method
The Set Print Position method sets the current print position. It does not return a value. You can use it only in a Print statement. Position number 1 is the left most print position. This method sets the new print position according to one of the following values of the position:
The value in the position argument is less than the total line width. It sets the new print position to the value in the position argument.
The value in the position argument is greater than the total line width. It sets the new print position according to the following calculation:
The remainder of the input position argument divided by the length of the string
The current print position is greater than the position or the position Mod width. It skips to the next line and sets the print position to the value in the position argument or to the value in the position Mod width.
Format
Tab(position)
position |
The position at which Siebel VB begins to print. |
Example
The following example prints the octal values for the numbers from 1 through 25. It uses the Set Print Position method to insert five character spaces between the values:
Sub Button_Click
Dim x As Integer
Dim y As String
For x = 1 to 25
y = Oct$(x)
Print x Tab(10) y
Next x
End Sub
Write Data to File Method
The Write Data to File method writes data to an open sequential file. It does not return a value. You must open the file in output mode or in append mode. If you do not include the expressionList argument, then it writes a blank line to the file. For more information, see Lock File Method.
The Write statement places quotes around the string that it writes to the file.
Format
Write [#]filenumber[, expressionList]
filenumber |
expressionList |
One or more values to write to the file. |
Example
The following example writes a variable to a file according to a comparison of the last saved time of the file and the current time:
Sub Button_Click
Dim tempfile
Dim filetime, curtime
Dim msgtext
Dim acctno(100) as Single
Dim x, I
tempfile = "C:\TEMP001"
Open tempfile For Output As #1
filetime = FileDateTime(tempfile)
x = 1
I = 1
acctno(x) = 0
Do
curtime = Time
acctno(x) = 88
If acctno(x) = 99 then
If x = 1 then Exit Sub
For I = 1 to x-1
Write #1, acctno(I)
Next I
Exit Do
ElseIf (Minute(filetime) + 2)< = Minute(curtime) then
For I = I to x-1
Write #1, acctno(I)
Next I
End If
x = x + 1
Loop
Close #1
x = 1
msgtext = "Contents of C:\TEMP001 is:" & Chr(10)
Open tempfile for Input as #1
Do While Eof(1) <> -1
Input #1, acctno(x)
msgtext = msgtext & Chr(10) & acctno(x)
x = x + 1
Loop
Close #1
Kill "C:\TEMP001"
End Sub
Related Topics
Write Variable to File Method
The Write Variable to File method writes a variable to a file opened in random mode or binary mode. It does not return a value. Usage for this method with random mode and binary mode is the same usage for these modes with the Get File Contents method. For more information, see Get File Contents Method and Get File Contents Method.
The Put statement uses the default character encoding of the local operating system. It does not write to the file in Unicode format.
Format
Put [#]filenumber, [recnumber], varName
filenumber |
recnumber |
varName |
The name of the variable that contains the data to write. It can be any variable type except for the following types:
Example
The following example opens a file for random access, puts the values 1 through 10 in this file, prints the contents of the file, and then closes it:
Sub Button_Click
Dim x As Integer, y As Integer
For x = 1 to 10
Put #1,x, x
Next x
For x = 1 to 10
Get #1,x, y
msgtext = msgtext & y & Chr(10)
Next x
Close #1
Kill "C:\TEMP001"
End Sub
Code Setup and Control Methods
This topic describes items that you can use to setup and control Siebel VB code. It includes the following topics:
Call Application Method
The Call Application method starts a Microsoft Windows application. It returns the task ID of this application, which is a unique number that identifies the running code.
The pathname argument can contain the name of any valid BAT, COM, EXE, or PIF file. You can include arguments and command line switches. If the pathname argument does not contain a valid executable file name, or if the Shell statement cannot start the code, then this method creates an error message.
Format
Shell(pathname, [windowStyle])
pathname |
A string or string expression that evaluates to the name of the code to run. |
windowStyle |
One of the following integers that specifies how to display the window:
If you do not include the windowStyle argument, then Siebel VB uses the default value of 1. |
Example
The following example opens Microsoft Excel when the user clicks a button:
Sub Button1_Click
Dim i as long
i = Shell("C:\Program Files\Microsoft
Office\Office\EXCEL.EXE",1)
End Sub
For other examples, see Get Right String Method and Send Keystrokes Method.
For more information, see Send Keystrokes Method.
Call Subroutine Method
The Call Subroutine method is a control structure that directs flow to a subroutine or function. It returns one of the following values:
If it calls a function, then it returns the output of the function.
if it calls a subroutine, then it returns nothing.
You can use this method to call a subroutine or function that is written in Visual Basic or to call C code in a DLL. A Declare Procedure method must describe this C code and it must be implicit in the application. You must make sure the DLL is present on every Siebel Server. For more information, see Declare Procedure Method.
If you use the Call Subroutine method, then it is recommended that you use the following guidelines:
Format A
Call subroutine_name [(argument_list)]
subroutine_name argument_list
where:
subroutine_name is the name of the subroutine or function. Siebel VB passes control to this subroutine or function.
Arguments
argument_list |
The arguments that Siebel VB passes to the subroutine or function. |
Example
The following example does the following:
Calls a subroutine named CreateFile to open a file.
Writes the numbers 1 through 10 in this file.
The calling code examines the file mode, and then closes the file if the mode is 1 or 2:
Sub CreateFile
Dim x as Integer
For x = 1 to 10
Write #1, x
Next x
End Sub
Sub Button1_Click
Call CreateFile
attrib = 1
If filemode = 1 or filemode = 2 then
Close #1
End If
Kill "c:\temp001"
End Sub
Create Subroutine Method
The Create Subroutine method is a control structure that defines a subroutine. It does not return a value. It returns flow to the caller when Siebel VB encounters the End Sub statement or an Exit Sub statement.
Format
[Static] [Private] Sub name [([Optional] argument [As type], ...)] End Sub
name |
The name of the subroutine. |
argument |
A list of argument names that includes commas that separate each name. For more information, see the following. |
type |
The data type of the argument. |
Usage
Note the following:
For important caution information, see Create Function Method.
A call to a subroutine stands alone as a separate statement. For more information, see Call Subroutine Method).
Siebel VB supports recursion.
A Visual Basic procedure passes values through reference. This means that if a procedure assigns a value to an argument, then it modifies the variable that the caller passes. You must use this feature with caution. For more information, see Pass Values Through Reference.
You must use the Create Function method rather than the Create Subroutine method to define a procedure that includes a return value. For more information, see Create Function Method.
Usage for the Static Keyword and Private Keyword
The Static keyword specifies that any variable you declare in this method retains a value as long as the code runs. This situation applies regardless of how you declare variables in this method.
The Private keyword specifies that other functions and subroutines in other modules cannot access the subroutine that you define with this method. Only procedures defined in the same module can access a private function.
Specifying Arguments
Note the following:
To specify multiple arguments, you can use a list of variable names where a comma separates each name.
To specify the data type of an argument, you can use a type character or the As clause.
To declare a record argument, you use the As clause and a value in the type argument. You must have already used the Type statement to define this value in the type argument.
To declare an array argument, you can use empty parentheses after the argument. You do not specify array dimensions in the Create Subroutine method. You must use a consistent number of dimensions for every reference to an array argument that occurs in the body of the Create Subroutine code.
Declaring Optional Arguments
If you declare an optional argument, then you can omit the value for this argument when Siebel VB calls the method that contains this argument. Note the following:
You can only declare a variant argument as optional.
Any optional arguments must occur after the required arguments in the Create Subroutine method.
You can use the IsMissing method to determine if an optional argument is omitted. For more information, see Is Optional Argument Missing Method. For more information on using named arguments, see Comments and Call Subroutine Method.
Example
The following example is a subroutine that uses the Create Subroutine method:
Sub Button1_Click End Sub
The Create Function method creates a function. It returns to the caller when it encounters an End Function statement or an Exit Function statement. It returns the value that the expression argument calculates.
Format
[Static] [Private] Function name([[Optional ]argument [As type]][, ... ]) [As funcType] name = expression End Function
name |
The name of the function. |
argument |
The argument to pass to the function when Siebel VB calls it. For more information, see Create Subroutine Method. |
type |
funcType |
The data type of the value that the function returns. |
Usage
For information about the static and private keywords, see Create Subroutine Method.
For information about declaring optional arguments, see Create Subroutine Method.
Specifying the Type
Specifying the type character when you use the Create Function method is optional. A function can create and return a single value of a type that you specify. The data type of the value in the name argument determines the type of the return value. You can do one of the following to specify the data type:
Use a type character as part of the name.
Use the As funcType clause.
If you do not use one of these formats, then Siebel VB uses the default data type, which is variant.
Specifying the Return Value
You use the following format to specify the return value for the function name:
name = expression
where:
name is the name of the function
expression evaluates to a return value
If you do not include this code, then Siebel VB returns one of the following values:
0 for a numeric function
null string ("") for a string function
An Empty variable type for a return type of variant. For more information, see Variants.
You can use the Sub statement to define a procedure that does not include a return value.
Caution About Writing a Custom Function or Subroutine
If you create more than one function or subroutine in the general declarations section, then you must make sure that any other custom function or subroutine that you create that calls this function or subroutine occurs before the procedure that calls it. Otherwise, you cannot compile your procedures.
You cannot create a custom function or custom subroutine in a method or event that displays in Siebel Tools. You can create a custom function or custom subroutine in the general declarations section in the script of a method. If your function or subroutine must be available throughout the code, then you can use a PreInvokeMethod method or an external DLL file to store them in a central location. For more information, see doc ID 476501.1 on My Oracle Support.
Example
The following example declares a function that the subroutine calls. The function performs a calculation on the value sent to it. This calculation modifies the value of the variable:
(general) (declarations) Option Explicit Declare Function Calculate(i as Single) As Single
Function Calculate(i As Single) i = i * 3 + 2 Calculate = i End Function
Sub Button_Click Dim x as String Dim y As Single x = 34 y = val(x) Call Calculate(y) End Sub
For other examples, see Declare Procedure Method, and Go To Statement.
Related Topics
Declare Custom Data Type Method
The Declare Custom Data Type method declares a custom data type. It does not return a value. For more information, see About Data Types.
Format
Type userType field1 As type1 field2 As type2 ... End Type
userType |
The name of the custom data type. |
field1, field2 |
Each argument specifies the name of a field in the custom type. |
type1, type2 |
Each argument specifies the data type of the field. |
Usage
You can use the following format to access the fields of a record:
recordName.fieldName
You can use the following format to access the fields of an array of records:
arrayName(index).fieldName
You cannot specify an array in the field argument. Arrays of records are allowed.
You cannot use the Type statement in a procedure definition. You must use it in the general declarations section. For example, see Set Array Lower Boundary Method.
Siebel VB cannot pass a custom type to a COM function or subroutine.
To declare a record variable, you can use the Declare Custom Data Type method in a Declare Variable method. Siebel VB does not allocate memory when you define a custom type. It only allocates memory if you use a Declare Variable method to declare a custom type. If you declare a variable of a custom type, then you are instantiating the type. For more information, see Declare Variable Statement.
Example
The following example includes a Type statement and a Dim statement. You must define a record type before you can declare a record variable. The subroutine references a field in the record:
Type Testrecord Custno As Integer Custname As String End Type
Sub Button_Click
Dim myrecord As Testrecord
Dim msgText As String
i:
myrecord.custncustomame = "Chris Smith"
If myrecord.custname = "" then
Exit Sub
End If
End Sub
The Declare Procedure method declares a procedure in a module or in a dynamic link library (DLL). The value it returns depends on one of the following formats that you use:
Format A. It does not return a value.
Format B. A value of the funcType type. You can use this value in an expression.
For more information about the format and arguments that you can use with this method, see Declaring a Procedure.
Format A
Declare Sub name [(argument [As type])]
Declare Function name [(argument [As type])] [As funcType]
name |
The name of the subroutine or function that this method declares. |
argument |
The argument that this method passes. A comma separates each argument. |
type |
The data type of the arguments. |
funcType |
The data type of the return value. |
Example
The following example declares a function that the main subroutine subsequently calls. This function only sets the return value to 1:
(general) (declarations) Option Explicit Declare Function SVB_exfunction()
Function SVB_exfunction() SVB_exfunction = 1 End Function
Sub Button_Click Dim y as Integer Call SVB_exfunction y = SVB_exfunction End Sub
For other examples of functions, see Create Function Method and Go To Statement.
Related Topics
Declare Symbolic Constant Method
The Declare Symbolic Constant method declares a symbolic constant. It does not return a value.
Format
[Global] Const constantName [As type] = expression [, constantName [As type] = expression] …
constantName |
The variable name to contain a constant value. |
type |
The data type of the constant. This type is Number or String. |
expression |
Any expression that evaluates to a constant number. |
Usage
To specify the type of the constant, you can use one of the following characters as a suffix of the constantName argument:
# (pound sign). Specifies a number.
$ (dollar sign). Specifies a string.
You can use this technique instead of using the As clause.
If you do not specify a type character, then the Declare Symbolic Constant method derives the type of the value that you specify in the constantName argument from the type of the expression.
To specify a global constant, you must declare it in the general declarations section of the module where you must access this global variable.
Example
For an example, see Convert Expression to Long Method.
Get Environment Setting Method
The Get Environment Setting method returns the string setting that is assigned to an environment variable for a keyword in the environment table of the operating system. If it cannot find the value that you specify, then it returns a null string.
Format A
Environ[$](environment-string)
The return value for format A is the string that is associated with the keyword.
Format B
Environ[$](numeric_expression)
The return value for format B is a string that uses the following format:
KEYWORD=value
environment-string |
The name of a keyword in the operating system. You must enter the value for this argument in uppercase. If you do not, then this method returns a null string (""). |
numeric_expression |
An integer for the position of the string in the environment table. For example, 1st, 2nd, 3rd, and so on. This method rounds the numeric expression to a whole number, if necessary. |
Example
The following example lists the strings from the operating system environment table:
Sub Button_Click
Dim str1(100)
Dim msgtext
Dim count, x
Dim newline
newline = Chr(10)
x = 1
str1(x) = Environ(x)
Do While Environ(x) <> ""
x = x + 1
Loop
msgtext = "The Environment Strings are:" & newline & newline
count = x
For x = 1 to count
msgtext = msgtext & str1(x) & newline
Next x
End Sub
Remove Object Method
You can use the Remove Object method to remove from memory an object that Siebel VB instantiates in memory. If an object variable does not reference an object, then it contains a value of Nothing. The Remove Object method does not return a value.
Format
Set objectName = Nothing
objectName |
The name of the object variable to set to Nothing. |
For example:
If Not objectVar Is Nothing then objectVar.Close Set objectVar = Nothing End If
The following example adds an activity record when the user adds a contact record in a Siebel application. It presumes that the Contact business component is the parent business component. It instantiates the Action business component, and then uses the Remove Object method to remove this instance from memory after it finishes processing the business component data:
Sub BusComp_WriteRecord
Dim oBCact as BusComp
Set oBCact = theApplication.ActiveBusObject.GetBusComp("Action")
With oBCact
.NewRecord NewAfter
.SetFieldValue "Type", "Event"
.SetFieldValue "Description", "ADDED THRU SVB"
.SetFieldValue "Done", Format(Now(),"mm/dd/yyyy hh:mm:ss")
.SetFieldValue "Status", "Done"
.WriteRecord
End With
set oBCact = Nothing
End Sub
For other examples that use the Remove Object method, see Date and Time Methods and Get COM Object Method.
The Send Keystrokes method sends keystrokes to an active Microsoft Windows application. It does not return a value. It can send a keystroke only to the currently active application. You can use the AppActivate statement to activate an application. You cannot use this method to send keys to an application that does not run in Microsoft Windows.
Format
SendKeys string[, wait]
| string |
A string or string expression that contains the characters to send. Each character in the string argument represents a keystroke. |
| wait |
Specifies to wait until Siebel VB processes every key before it continues to the next code line. It can include one of the following values:
Specifying Alphanumeric Characters
To specify an alphanumeric character, you enter it in the string argument. For example, to send the character a, you use a as the value in the string argument. You can combine multiple characters in one string. For example, if the string argument contains abc, then Siebel VB sends the following values to the application:
a, b, and c
Specifying Control Keys
To specify that the user must press the SHIFT, ALT, or CTRL key simultaneously with a character, you prefix the character with one of the following values:
+. Specifies SHIFT.
%. Specifies ALT.
^ . Specifies CTRL.
You can use parentheses to specify that the user must press the SHIFT, ALT, or CTRL key with a group of characters. For example, %(abc) is equivalent to %a%b%c.
Control Keys That the Send Keystrokes Method Interprets
The following table describes some keys that the Send Keystrokes method interprets. To specify one of these characters as a literal value, you must enclose the character in curly brackets ({}).
| Key | Description |
SHIFT key. |
ALT key. |
CTRL key. |
Apply a shift state to the characters that the parentheses enclose. |
Newline. Note the following:
Makes the enclosed characters literals. |
Square brackets do not possess a special meaning for the Send Keystrokes method, but they might possess a special meaning for other applications. |
For example, if the string argument contains {%}, then the Send Keystrokes method sends the literal value of the percentage symbol (%).
You can use the following format to send a bracket:
Left bracket. You use {{}.
Right bracket. You use {}}.
Repeating the Same Key
To send the same key multiple times, you can enclose the character in curly brackets ({}), add a space, and then specify the number of keys to send. For example, the following code sends 20 X characters:
{X 20}
Sending Nonprintable Keys
The following table describes how you can to send a nonprintable key. You can use a special keyword and enclose it in curly brackets ({}).
| Nonprintable Key | Format |
BACKSPACE |
{BACKSPACE} or {BKSP} or {BS} |
BREAK |
{BREAK} |
CAPS LOCK |
{CAPSLOCK} |
CLEAR |
{CLEAR} |
DELETE |
{DELETE} or {DEL} |
DOWN ARROW |
{DOWN} |
END |
{END} |
ENTER (on numeric keypad) |
{ENTER} |
ESC |
{ESCAPE} or {ESC} |
HELP |
{HELP} |
HOME |
{HOME} |
INSERT |
{INSERT} |
LEFT ARROW |
{LEFT} |
NUM LOCK |
{NUMLOCK} |
PAGE DOWN |
{PGDN} |
PAGE UP |
{PGUP} |
RIGHT ARROW |
{RIGHT} |
SCROLL LOCK |
{SCROLLLOCK} |
TAB |
{TAB} |
UP ARROW |
{UP} |
| Function key (F1 through F15) |
You enclose the name of the function key in curly brackets ({}). For example, to send F5, you use the following format: {F5} |
Combining Keywords
You can use the following characters to combine some keywords:
Plus sign (+)
Percentage symbol (%)
Caret (^)
For example, %{TAB} is ALT+TAB.
You can send multiple keywords. For example, the following code sends 25 up arrows:
{UP 25}
Example
The following example starts the Microsoft Windows Phone Dialer application and dials a phone number that the user enters:
Sub Button_Click
Dim phonenumber, msgtext
Dim x
phonenumber = 650-555-1212
x = Shell ("Terminal.exe",-1)
SendKeys "%N" & phonenumber & "{Enter}", -1
End Sub
Related Topics
Use Clipboard Methods
The Use Clipboard methods are standard Visual Basic methods that allow you to use the Microsoft Windows clipboard as an object. They do not return a value. You can use the Microsoft Windows Clipboard to transfer text to and from other applications that support this clipboard.
Format
Clipboard.Clear Clipboard.GetText() Clipboard.SetText string Clipboard.GetFormat()
The following table describes the arguments that you can use with these methods.
| Argument | Description |
string |
A string or string expression that contains the text to send to the clipboard. |
The following table describes the statements that you can use the clipboard.
| Statement | Description |
Clear |
Clears the contents of the clipboard. |
GetText |
Returns a text string from the clipboard. |
SetText |
Puts a text string in the clipboard. |
GetFormat |
Returns one of the following values:
If code or if a cut or copy operation places data that is of the same format as the data that currently resides in the clipboard, then the current data on the clipboard is lost.
Example
The following example places the following text string on the clipboard:
Hello, world:
Sub Button_Click Dim mytext as String mytext = "Hello, world." Clipboard.Settext mytext End Sub
Code Control Statements
This topic describes statements that you can use to control the flow of Siebel VB code. It includes the following topics:
Do Loop Statement
The Do Loop statement is a control structure that repeats a series of code lines as long as an expression is TRUE. It does not return a value.
If an Exit Do statement runs, then control flows to the statement that resides immediately after the Loop statement. If you use an Exit Do statement in a nested loop, then it moves control out of the immediate loop.
Format A
Do [{ While|Until } condition]
statement_block
[Exit Do]
statement_block
Loop
Do
statement_block
[Exit Do]
statement_block
Loop [{ While|Until } condition]
The following table describes the arguments that you can use with this method.
condition |
Any expression that evaluates to TRUE (not zero) or FALSE (0). |
statement_block |
Code lines to repeat while or until the value you specify in the condition argument is TRUE (not zero). |
Example
For examples, see Get File Names Method, Erase Array Method, and Get Error Code Method.
Exit Statement
The Exit statement is a control structure that stops statements that reside in a loop or transfers control to a calling procedure. It does not return a value.
You can include an Exit Do statement in a Do Loop statement. You can use an Exit For statement in a For Next statement. When the Exit statement runs, control transfers to the statement that occurs after the Loop statement or the Next statement. When used in a nested loop, an Exit statement moves control out of the immediately enclosing loop.
Note the following:
You can use the Exit statement in the Create Function method. For more information, see Create Function Method.
You can use the Exit Sub statement in the Create Subroutine method. For more information, see Create Subroutine Method.
Format
Exit {Do | For | Function | Sub}
The following example uses the On Error statement to handle run-time errors. If an error exists, then the code continues at the Debugger label. This example uses the Exit statement to skip the debugging code when no error exists:
Sub Button_Click
Dim msgtext, userfile
On Error GoTo Debugger
msgtext = "Enter the filename to use:"
userfile = "c:\temp\trace.txt"
Open userfile For Input As #1
' ....etc....
Close #1
done:
Exit Sub
Debugger:
msgtext = "Error " & Err & ": " & Error$
Resume done
End Sub
For Next Statement
The For Next statement is a control structure that repeats a series of code lines a fixed number of times. It does not return a value.
Format
For counter = start To end [Step increment]
statement_block
[Exit For]
statement_block
Next [counter]
counter |
A numeric variable for the loop counter. |
start |
The initial value of the counter. |
end |
The ending value of the counter. |
increment |
The amount by which Siebel VB modifies the counter each time the loop runs. The default value is 1. |
statement_block |
The Visual Basic functions, statements, or methods to run. |
How Siebel VB Handles a For Next Statement
Siebel VB compares the sign of start and the sign of end to the sign of increment, and then does one of the following:
If the signs are the same, and if end does not equal start, then it starts the For Next loop.
If the signs are not the same, then it skips the loop entirely.
Siebel VB does the following when it runs a For Next loop:
Runs the code lines that occur after the For statement until it encounters the Next statement.
Adds the Step amount to the counter.
Compares the value in the counter argument to the value in the end argument.
Does one of the following:
If the beginning and ending values are the same. It runs the loop one time, regardless of the Step value.
If the beginning and ending values are not same. It uses the Step value to control the loop as follows:
| Step Value | Description |
Positive |
Siebel VB does one of the following, depending on the value of the counter:
Negative |
Siebel VB repeats the loop until the counter is less than the value in the end argument. |
Zero |
Siebel VB repeats the loop indefinitely. |
Usage
The values in the start argument and the end argument must be consistent with the value in the increment argument:
If end is greater than start, then increment must be positive.
If end is less than start, then increment must be negative.
You must not modify the value of the counter while the loop runs. Changing this value makes the code more difficult to maintain and debug.
You can use the Exit For statement as an alternative exit from a For Next loop.
Nesting a For Next Loop
You can nest a For Next loop in another For Next loop:
You must specify a unique variable name for the counter in each nested loop.
You must make sure the Next statement of the inner loop occurs before the Next statement of the outer loop.
To merge Next statements that are multiple and consecutive, you must make sure the innermost counter occurs first and the outermost counter occurs last. For example:
For i = 1 To 10
statement_block
For j = 1 To 5
statement_block
Next j, i
If you do not include the variable in a Next statement, then this Next statement matches the most recent For statement. If a Next statement occurs prior to the corresponding For statement for this Next statement, then Siebel VB returns an error message.
Example
For an example, see Convert Expression to Single-Precision Method.
Go To Statement
The Go To statement is a control structure that directs flow to a label. It does not return a value. The value of the label argument uses the same format as any other Visual Basic name. A reserved word is not a valid label. You cannot use a Go To statement to transfer control out of the current function or subroutine. It is recommended that you avoid using a Go To statement. For more information, see the following.
Format
GoTo label
label |
A name that begins in the first column of a line of code and ends in a colon (:). |
Example 1
The following example displays the date for one week from the date that the user enters. If the date is not valid, then the Go To statement directs flow to the beginning of the start statement:
Sub Button_Click
Dim str1 as String
Dim nextweek
Dim msgtext
start:
str1 = "5/20/2001"
answer = IsDate(str1)
If answer = -1 then
str1 = CVDate(str1)
nextweek = DateValue(str1) + 7
msgtext = "One week from the date entered is "
msgtext = msgtext & Format(nextweek,"dddddd")
Else
GoTo start
End If
End Sub
It is recommended that you avoid using a Go To statement. When possible, you must use another technique. For example, Go To Statement could use an If statement that occurs in a separate function that the main code calls. If the test fails, then Siebel VB can call the initial code again. For example:
(general) (declarations) Option Explicit ' Variables must be declared in this section so that they ' can be used by both procedures. Dim str1 As String, nextweek, MsgText As String Declare Function CheckResponse(Answer) As String
str1 = CVDate(str1)
CheckResponse = "One week from the date entered is " & _
Format(nextweek, "dddddd")
End Function
Sub Button1_Click
Dim Answer as String
str1 = "2/5/2001"
Answer = IsDate(str1)
If Answer <> -1 Then
‘Invalid date or format. Try again.
Button1_Click
Else
Answer = CheckResponse(Answer)
End If
End Sub
If Then Else Statement
The If Then Else statement is a control structure that runs a block of code according to one or more expressions. It does not return a value.
Format A
If condition Then then_statement [Else else_statement]
If condition Then statement_block [ElseIf expression Then statement_block ]... [Else statement_block ] End If
If you require multiple statements in the Then clause or in the Else clause, then you must use Format B.
Arguments
condition |
Any expression that evaluates to TRUE (not zero) or FALSE (zero). |
then_statement |
Any valid single expression. |
else_statement |
expression |
statement_block |
Zero or valid expressions where a colon (:) or a different code line separates each expression. |
Example
The following example examines the time and the day of the week and returns a message:
Sub Button_Click
Dim h, m, m2, w
h = hour(now)
If h > 18 then
m = "Good evening, "
Elseif h >12 then
m = "Good afternoon, "
Else
m = "Good morning, "
End If
w = weekday(now)
If w = 1 or w = 7
Then m2 = "the office is closed."
Else m2 = "please hold for company operator."
End If
End Sub
Go To Label Statement
The Go To Label statement is a control structure that directs flow to a label in the current procedure according to the value of a numeric expression. It does not return a value.
If the value in the number argument evaluates to:
Zero or to a number that is greater than the number of labels that occur after the Go To Label statement, then Siebel VB runs the code at the next statement.
Less than 0 or greater than 255, then Siebel VB creates the following error:
Illegal function call
Format
On number GoTo label1[, label2, ... ]
number |
Any numeric expression that evaluates to a positive number. |
label1, label2, ... |
A label in the current procedure. Siebel VB directs flow to this procedure. |
Me Statement
The Me statement is standard Visual Basic shorthand that refers to the currently used object. It does not return a value. A Siebel VB module can be attached to an application object. If this application object encounters a some events, then Siebel VB might call a subroutine. For example, if the user clicks a button, then the Me statement runs Visual Basic code or a statement calls a method on an application object.
A subroutine in this situation can use the Me variable to reference the object that starts the event. For example, the button click. You can use the Me statement the same way that you use any other object variable except that you can use the Assign COM Object statement to set Me.
Format A
With Me .methodname() statement End With
Me.methodname() statement
methodname |
The name of the method that Siebel VB uses with the object. |
statement |
The statement argument includes one of the following items:
Example
For an example, see Modify Variable Statement.
Related Topics
Rem Statement
The Rem statement identifies a line of code as a comment in Visual Basic code. It does not return a value. A code line that begins with a single quote (') also identifies a comment.
Format
Rem comment
The following example code is attached to a button on the Account Form applet that counts the number of corresponding child contact records:
Sub Button1_Click
Dim i as Integer
Dim icount as Integer
Dim oBC as BusComp
Rem Test this from the Account Contacts View
Rem This code presumes that Account is the parent BusComp
Rem BusObject returns the business object
Rem associated with a control or applet.
Rem GetBusComp here returns a reference
Rem to the BC that is in the UI context.
set oBC = me.BusObject.GetBusComp("Contact")
Rem FirstRecord positions you at the
Rem first record in the business component.
Rem FirstRecord, NextRecord, and so forth, do not return Booleans.
Rem Siebel VB does not have a Boolean data type.
i = oBC.FirstRecord Rem Returns 0 if fails, 1 if succeeds
if i <> 1 then
else
icount = 0
Rem This is a sample of using a while statement to loop.
Rem NextRecord returns 1 if it succesfully
Rem moved to the next record in the BC
While i = 1
icount = icount + 1
i = oBC.NextRecord Rem Returns 1 if successful
wend
oBC.FirstRecord
end if
End Sub
The Select Case statement is a control structure that runs one or more statements, depending on the value of an expression. It does not return a value.
Format
Select Case testexpression
Case expressionList
[statement_block]
[Case expressionList
[statement_block] ]
[Case Else
[statement_block]
End Select
testexpression |
Any expression that contains a variable. |
expressionList |
One or more expressions that contain a possible value for the testexpression argument. |
statement_block |
One or more lines of code to run if the value in the testexpression argument equals a value in the expressionList argument. |
Usage
If the value in the testexpression argument is equal to the value in the expressionList argument, then Siebel VB runs the statement_block that occurs immediately after the Case clause. When Siebel VB encounters the next Case clause, the code flows to the statement that occurs immediately after the End Select statement.
The expressionList can include a list of expressions. A comma separates each expression in this list. It can include one of the following forms:
expression
expression To expression
Is comparison_operator expression
The type of each expression must be compatible with the type of the testexpression.
Each statement_block can contain any number of statements on any number of lines.
Using the Is Keyword
If you use the To keyword to specify a range of values, then the smaller value must occur first. The comparison_operator that you use with the Is keyword must contain one of the following:
< (less than)
> (greater than)
= (equal)
<= (less than or equal)
>= (greater than or equal)
<> (not equal)
If the Case is one end of a range, then you must use the Is operator. For example:
Case Is < 100
Stop Statement
The Stop statement is a control structure that stops code from running. It does not return a value. It does not include arguments. You can include a Stop statement anywhere in Siebel VB code. A Stop statement does not close files or clear variables.
Format
Stop
Example
The following example stops code from running when the user clicks a button:
Sub Button_Click Dim str1 str1 = Y If str1 = "Y" or str1 = "y" then Stop End If End Sub
While Wend Statement
The While Wend statement is a control structure that controls a repetitive action. It does not return a value. Siebel VB includes the While statement so that it is compatible with older versions of Visual Basic. If possible, it is recommended that you use the Do Loop statement instead. For more information, see Do Loop Statement.
Format
While condition statement_block Wend
condition |
A condition where Siebel VB runs the statements in a statement_block. |
statement_block |
A series of statements that Siebel VB runs while the value in the condition argument is TRUE. |
Example
The following example opens a series of files and looks for the following string in each file:
*Overdue*
This example uses the While Wend statement to loop through the c:\temP00? files. The CreateFiles subroutine creates these files:
Option Explicit
Declare Sub CreateFiles
Sub CreateFiles
Dim odue as String
Dim ontime as String
Dim x
Open "c:\temp001" for OUTPUT as #1
odue = "*Overdue*"
ontime = "*On-Time*"
For x = 1 to 3
Write #1, odue
Next x
For x = 4 to 6
Write #1, ontime
Next x
Close #1
Open "c:\temp002" for Output as #1
Write #1, odue
Close #1
End Sub
Sub Button_Click
Dim custfile as String
Dim aline as String
Dim pattern as String
Dim count as Integer
Call CreateFiles
Chdir "c:\"
custfile = Dir$("temP00?")
pattern = "*" + "Overdue" + "*"
While custfile <> ""
Open custfile for input as #1
On Error goto atEOF
Do
Line Input #1, aline
If aline Like pattern Then
count = count + 1
End If
Loop
nxtfile:
On Error GoTo 0
Close #1
custfile = Dir$
Wend
Kill "c:\temp001"
Kill "c:\temp002"
Exit Sub
atEOF:
Resume nxtfile
End Sub
Variable Manipulation Methods
This topic describes statements and methods that setup and control variables. It includes the following topics:
Assign Expression to Variable Statement
The Assign Expression to Variable statement is a predefined VB statement that assigns an expression to a Visual Basic variable. It does not return a value. You can use it to assign a value or expression to a variable that is of one of the following data types:
Numeric
String
Variant
Record
If you use this statement to assign a value to a numeric variable or to a string variable, then Siebel VB applies the standard conversion rules.
You can use this statement to assign a value to a field in a record or to assign a value to an element in an array.
The Let keyword is optional. Let is different from Set because Set assigns a variable to a COM object. For example:
Set o1 = o2. Sets the object reference.
Let o1 = o2. Sets the value of the default member.
Format
[Let] variable = expression
variable |
The variable where Siebel VB assigns a value. |
expression |
The expression that contains the value that Siebel VB assigns. |
Example
The following example uses the Assign Expression to Variable statement for the sum variable. It calculates an average of 10 golf scores:
Sub Button_Click
Dim score As Integer
Dim x, sum
Dim msgtext
Let sum = 34
For x = 1 to 10
score = 76
sum = sum + score
Next x
msgtext = "Your average is: " & CInt(sum/(x-1))
End Sub
The Declare Variable statement declares a variable. It does not return a value. For more information about the format and arguments you can use this statement, see Declaring Variables.
Dim is an abbreviation for Declare in Memory. You must begin the value in the VariableName argument with a letter. It must contain only letters, numbers, and underscores. You can use square brackets to separate a name. You can use any character between the square brackets except for more square brackets. For example:
Dim my_1st_variable As String Dim [one long and strange! variable name] As String
Format
Dim [Shared] variableName [As[ New] type] [, variableName [As[ New] type]] ...
variableName |
The name of the variable to declare. |
type |
The data type of the variable. |
Example
The following example includes a Dim statement for each of the possible data types:
' Must define a record type before you can declare a record
' variable
Type Testrecord
Custno As Integer
Custname As String
End Type
Sub Button_Click Dim counter As Integer Dim fixedstring As String * 25 Dim varstring As String Dim myrecord As Testrecord Dim ole2var As Object Dim F(1 to 10), A() '...(code here)... End Sub
Declare Global Variable Statement
The Declare Global Variable statement declares a global variable. It does not return a value. You must declare a global variable in every module from which Siebel VB must access that variable. You declare a global variable in the general declarations section of the module.
Format
Global variableName [As type] [,variableName [As type]] ...
variableName |
The variable name. |
type |
Usage
If you do not include the As clause, then you can add a type character as a suffix to the variableName argument. You can simultaneously use the two different type specification methods in a single Global statement, but you cannot use these methods simultaneously on the same variable.
Regardless of how you declare a global variable, you can choose to include or not include the type character when you reference the variable from another section of code. Siebel VB does not consider the type suffix as part of the variable name.
Formats That You Can Use to Specify the Type of a Global Variable
Visual Basic is a strongly typed language. You must assign a data type to a variable or Siebel VB assigns a type of variant.
The following table describes the data types you can use to specify the type of a global variable. Declaring a global variable is the same as declaring a variable, except where noted in the Format column in the table. The Reference column includes a link to the description for declaring a variable.
| Type | Format | Reference |
Array |
You use the following format to declare a global record: Global variable([ subscriptRange, ... ]) [As typeName] where:
[startSubscript To] endSubscript |
Number |
Not applicable. |
Record |
You use the following format to declare a global record: Global variableName As typeName You cannot use the Declare Global Variable statement to declare a dialog record. |
String |
You use the following format to declare a global string: Global variableName As String * length You use one of the following formats to declare a dynamic string: Global variableName$ Global variableName As String |
Variant |
You use one of the following formats to declare a global variant: Global variableName GlobalvariableName As Variant |
Example
The following example includes two subroutines that share the total and acctno variables, and the grecord record:
(general)(declarations) Option Explicit Type acctrecord acctno As Integer End Type
Global acctno as Integer Global total as Integer Global grecord as acctrecord Declare Sub CreateFile
Sub CreateFile
Dim x
x = 1
grecord.acctno = 2345
Open "c:\temp001" For Output as #1
Do While grecord.acctno <> 0
grecord.acctno = 0
If grecord.acctno <> 0 then
Print #1, grecord.acctno
x = x + 1
End If
Loop
total = x-1
Close #1
End Sub
Sub Button_Click
Dim msgtext
Dim newline as String
newline = Chr$(10)
Call CreateFile
Open "c:\temp001" For Input as #1
msgtext = "The new account numbers are: " & newline
For x = 1 to total
Input #1, grecord.acctno
msgtext = msgtext & newline & grecord.acctno
Next x
Close #1
Kill "c:\temp001"
End Sub
Declare Static Variable Statement
The Declare Static Variable statement declares a variable and allocates storage space for this variable. It does not return a value.
A variable that you declare with the Static statement retains a value as long as the code runs. The format you use is exactly the same as the format you use with the Declare Variable statement. For more information, see Declare Variable Statement.
To make a procedure variable static, you can use the Static keyword in the definition of this procedure. For more information, see Create Function Method and Create Subroutine Method.
Format
Static variableName [As type] [,variableName [As type]] …
variableName |
The name of the variable to declare as static. |
type |
The data type of the variable. If you do not include the type argument, then Siebel VB uses the variant type. |
Related Topics
The Modify Variable statement runs a series of statements on a variable. It does not return a value. The value you specify in the variable argument can be an object or a custom type. You can nest With statements.
Format
With variable statement_block End With
variable |
The variable that Siebel VB modifies in the statement_block. |
statement_block |
The statements that Siebel VB runs on the variable. |
Example
The following example uses a Siebel VB method to modify the values that an object contains if Siebel CRM modifies a field value. The Modify Variable statement references this object:
Sub BusComp_SetFieldValue(FieldName As String)
Select Case FieldName
Case "Account Status"
If Me.GetFieldValue(FieldName) = "Inactive" Then
Dim sMessage as String
Set oBCact = me.BusObject.GetBusComp("Action")
sMessage = “ADDED THRU SVB: Account Status made Inactive"
With oBCact
.NewRecord NewAfter
.SetFieldValue "Description", sMessage
.SetFieldValue "Done", _
.WriteRecord
End With
End If
End Select
End Sub
For another example, see Remove Object Method.
Force Explicit Declaration Statement
The Force Explicit Declaration statement forces you to explicitly declare every variable in a module. It does not return a value.
Format
Option Explicit
Visual Basic declares any variables that does not occur in one of the following statements, by default:
Dim
Global
ReDim
Static
If you include the Force Explicit Declaration statement in your code, then Siebel VB creates the following error every time it encounters a variable that is not declared:
Variable Not Declared
Using the Force Explicit Declaration statement makes debugging code easier because it forces you to declare each variable before you use it. It is recommended that you declare variables at the beginning of the project, module, or procedure where these variables possess scope. Declaring variables in this way simplifies locating their definitions when reading through code.
You must include the Force Explicit Declaration statement in the general declarations section. For more information, see Set Array Lower Boundary Method.
Example
The following example specifies that variables must be explicitly declared. This technique prevents mistyped variable names:
Option Explicit
Sub Button_Click
'...(code here)...
End Sub
Get Variant Type Method
The Get Variant Type method returns a number that represents the type of data stored in a variant variable. For more information, see Variants.
Format
VarType(varName)
varName |
The name of a variant variable. |
Example
The following example returns the variant type of the myarray variant variable:
Sub Button_Click
Dim x
Dim myarray(8)
Dim retval
Dim retstr
myarray(1) = Null
myarray(2) = 0
myarray(3) = 39000
myarray(4) = CSng(10^20)
myarray(5) = 10^300
myarray(6) = CCur(10.25)
myarray(7) = Now
myarray(8) = "Five"
For x = 0 to 8
retval = Vartype(myarray(x))
Select Case retval
Case 0
retstr = " (Empty)"
Case 1
retstr = " (Null)"
Case 2
retstr = " (Integer)"
Case 3
retstr = " (Long)"
Case 4
retstr = " (Single)"
Case 5
retstr = " (Double)"
Case 6
retstr = " (Currency)"
Case 7
retstr = " (Date)"
Case 8
retstr = " (String)"
End Select
If retval = 1 then
myarray(x) = "[null]"
ElseIf retval = 0 then
myarray(x) = "[empty]"
End If
Next x
End Sub
Set Variable Data Type Statement
The Set Variable Data Type statement sets the default data type for one or more variables.
Format
DefCur varTypeLetters DefInt varTypeLetters DefLng varTypeLetters DefSng varTypeLetters DefDbl varTypeLetters DefStr varTypeLetters DefVar varTypeLetters
varTypeLetter |
The first letter of a variable name. |
Usage
The VarTypeLetters argument can be one of the following:
Single letter
List of letters that includes a comma to separate each letter
Range of letters
For example, if you specify a-d, then Siebel VB uses letters a, b, c, and d.
The case of the letters is not important, even in a letter range. Siebel VB considers the a-z letter range as all alpha characters, including international characters.
The Deftype statement affects only the code where you specify it. It must precede any variable definition in the code.
To override the Deftype statement, you can use the Global statement or the Declare Variable statement to declare a variable, and then use an As clause or a type character.
Example
The following example determines the average of bowling scores that the user enters. Because the average variable begins with A, this example defines it as a single-precision, floating point number. It defines the other variables as integers:
DefInt c,s,t
DefSng a
Sub Button_Click
Dim count
Dim total
Dim score
Dim average
Dim msgtext
For count = 0 to 4
score = 180
total = total + score
Next count
average = total/count
msgtext = "Your average is: " &average
End Sub
Set Variant Variable to Null Method
The Set Variant Variable to Null method sets a variant variable to a value of Null. It returns a variant that is set to NULL. Note that Visual Basic sets a variant to the empty value, which is different from the Null value.
Format
variableName = Null
The Set Variant Variable to Null method does not include arguments.
Example
The following example calculates the average of ten test score values. If any score is negative, then it sets this value to Null. Before this example calculates the average, the IsNull statement reduces the total count of scores to only those scores that are positive values:
Sub Button_Click
Dim arrayvar(10)
Dim total as Integer
Dim x as Integer
Dim tscore as Single
count = 10
total = 0
For x = 1 to count
tscore = 88
If tscore < 0 then
arrayvar(x) = Null
Else
arrayvar(x) = tscore
total = total + arrayvar(x)
End If
Next x
Do While x <> 0
x = x - 1
If IsNull(arrayvar(x)) = -1 then
count = count - 1
End If
Loop
msgtext = " The average (excluding negative values) is: "
msgtext = msgtext & Chr(10) & Format (total/count, "##.##")
End Sub
Related Topics
String Methods
This topic describes string methods. It includes the following topics:
Compare Strings Method
The Compare Strings method compares two strings. It returns one of the following integers. This integer describes the result of the comparison:
-1 (negative one). string1 is less than string2.
0 (zero). string1 equals string2.
>1 (greater than one). string1 is greater than string2.
Null . string1 equals Null or string2 equals Null.
This method passes the values in the string1 argument and string2 argument as a variant. It supports any type of expression. It automatically converts a number to a string.
Format
StrComp(string1, string2[, compare])
string1 |
An expression that contains the first string to compare. |
string2 |
An expression that contains the second string to compare. |
compare |
An integer that specifies if the comparison is case-sensitive. You use one of the following values: 0. Case-sensitive. It performs a case-sensitive comparison according to the ANSI character set sequence. 1. Not case-sensitive. It performs a comparison that is not case-sensitive according to the relative order of characters. The country code setting for your computer determines this order. If you do not include the compare argument, then this method uses the module-level default. The Set String Comparison method sets this default. For more information, see Set String Comparison Method. |
Example
The following example compares a custom string to the Smith string:
Option Compare Text
Sub Button_Click
Dim lastname as String
Dim smith as String
Dim x as Integer
smith = "Smith"
lastname = "smith"
x = StrComp(lastname,smith,1)
If x = 0 then
‘You typed Smith or smith
End If
End Sub
Compare Strings Operator
The Compare Strings operator is a standard Visual Basic operator that compares the contents of two strings. It returns one of the following values:
-1 (TRUE). The string does match the pattern.
0 (FALSE). The string does not match the pattern.
If the string argument or if the pattern argument is NULL, then it returns NULL.
The Compare Strings operator performs a comparison according to the current configuration of the Set String Comparison method. For more information, see Set String Comparison Method.
For more information about operators, see About Expressions.
Format
string LIKE pattern
string |
Any string or string expression. |
pattern |
Any string expression to compare to the value of the string argument. |
Usage
The following table describes characters that you can use in the pattern argument.
| Character | Character That the Compare Strings Operator Compares |
A single character. |
A set of zero or more characters. |
A single digit character in the range of 0 through 9. |
[chars] |
A single character in chars. |
[!chars] |
A single character not in chars. |
[startchar–endchar] |
A single character in the range startchar through endchar. |
[!startchar–endchar] |
A single character not in the range startchar through endchar. |
A range or list can occur in a single set of square brackets. The Compare Strings operator matches ranges according to their ANSI values. In a range, the value in startchar must be less than the value in endchar.
Example
The following example determines if a letter is lowercase:
Sub Button_Click
Dim userstr as String
Dim revalue as Integer
Dim msgtext as String
Dim pattern
pattern = "[a-z]"
userstr = "E"
retvalue = userstr LIKE pattern
If retvalue = -1 then
msgtext = "The letter " & userstr & " is lowercase."
Else
msgtext = "Not a lowercase letter."
End If
End Sub
Convert Number to String Method
The Convert Number to String method converts a number to a string. It returns a string representation of this number. It uses the following precision in the returned string:
Single-precision for an integer or for a single-precision numeric expression.
Double-precision for a long number or for a double-precision numeric expression.
Currency precision for currency.
A variant returns the precision of the underlying variable type. For more information, see Variants.
Format
Str[$](number)
For information about the dollar sign, see Usage of the Dollar Sign.
number |
The number that this method converts to a string. |
Example
The following example prompts the user to enter two numbers. It adds these numbers, and then displays them as a concatenated string:
Sub Button_Click Dim x as Integer Dim y as Integer Dim str1 as String Dim value1 as Integer x = 1 y = 2 str1 = "The sum of these numbers is: " & x+y str1 = Str(x) & Str(y) End Sub
Convert String to Lowercase Method
The Convert String to Lowercase method converts the contents of a string to lowercase, and then returns a lowercase copy of that string. It substitutes characters according to the country specified in the Microsoft Windows Control Panel. It accepts expressions of type string. It accepts any type of argument and converts the input value to a string.
If you must configure Siebel VB to compare text values but not case, then you can use the Convert String to Lowercase method and the Convert String to Uppercase method. For more information, see Convert String to Uppercase Method.
Format
LCase[$](string)
string |
A string or an expression that contains a string. If this value is NULL, then this method returns a Null variant. For more information, see Variants. |
Example
The following example converts to lowercase a string that the user enters:
Sub Button_Click
userstr = "This Is A Test"
userstr = LCase$(userstr)
End Sub
The Convert String to Uppercase method converts lowercase letters to uppercase letters. It returns a copy of this string. Note the following:
The conversion occurs according to the country specified in the Microsoft Windows Control Panel.
If the value that the string argument contains is NULL, then this method returns a Null variant. For more information, see Variants.
Format
UCase[$](string)
string |
A string or string expression. |
Example
The following example converts a file name that the user enters to uppercase letters:
Option Base 1 Sub Button_Click Dim filename as String filename = "c:\temp\trace.txt" filename = UCase(filename) End Sub
Copy String Method
The Copy String method copies one string to another string or assigns a custom variable to another variable. It does not return a value. It copies values differently depending on the following:
The value in the string argument is shorter than the value in the string-expression argument. It copies the leftmost characters that the string-expression contains to the string that the string argument identifies. The number of characters it copies is equal to the length of the string argument.
The value in the string argument is longer than the value in the string-expression argument. It copies every character in the string-expression argument to the string that the string argument identifies, filling it from left to right. It replaces any leftover characters in the string argument with spaces.
You cannot use the Copy String method to assign variables of different custom types if one of these variables contains a variant or a variable-length string.
Format A
Lset string = string-expression
Lset variable1 = variable2
If you use format B, then the number of characters that this method copies is equal to the length of the shorter of variable1 and variable2.
Arguments
string |
A string variable or string expression to contain the copied characters. |
string-expression |
A string variable or string expression that contains the string that this method copies. |
variable1 |
A variable in a custom type to contain the copied variable. |
variable2 |
A variable that contains a custom type to be copied. |
Example
The following example places a user last name into a variable. If the name is longer than the size of lastname, then it truncates the user name:
Sub Button_Click Dim lastname as String Dim strlast as String * 8 lastname = "Smith" Lset strlast = lastname msgtext = "Your last name is: " & strlast End Sub
Get a String of Spaces Method
The Get a String of Spaces method returns a string of spaces.
Format
Space[$](number)
number |
A numeric expression that specifies the number of spaces to return. This number can be any numeric data type, but this method rounds the number to an integer. This number must reside in the range of 0 through 32,767. |
Example
For an example, see Get Octal Method.
Get ANSI String Method
The Get ANSI String method returns the character string that corresponds to the ANSI code of the character that the charCode argument contains.
Format
Chr[$](charCode)
charCode |
An integer in the rage of 0 through 255 that identifies the ANSI code for a character. |
Example
The following example displays the character equivalent for an ASCII code in the range of 65 through 122:
Sub Button_Click
Dim numb as Integer
Dim out as Integer
out = 0
Do Until out
numb = 75
If Chr$(numb)> = "A" AND Chr$(numb)< = "Z" _
OR Chr$(numb)> = "a" AND Chr$(numb)< = "z" then
msgtext = "The letter for the number " & numb _
" is: " & Chr$(numb)
out = 1
ElseIf numb = 0 then
Exit Sub=
Else
msgtext = "Does not convert to a character; try again."
End If
Loop
End Sub
Get First Number From String Method
The Get First Number From String method returns the numeric value of the first number that it finds in a string. If it finds no number, then it returns 0 (zero). It ignores any spaces that exist in the string.
Format
Val(string)
string |
A string or string expression that contains a number. |
Example
The following example examines the value of the profit variable. If profit contains a negative number, then it displays 0 (zero). The Sgn statement determines if profit is positive, negative, or zero:
Sub Button_Click
Dim profit as Single
Dim expenses
Dim sales
expenses = 100000
sales = 20000
profit = Val(sales)-Val(expenses)
If Sgn(profit) = 1 then
‘Yeah! We turned a profit!
ElseIf Sgn(profit) = 0 then
‘Okay. We broke even.
Else
‘Uh, oh. We lost money.
End If
End Sub
Get Left String Method
The Get Left String method returns a string copied from the beginning of another string. If the value in the length argument is greater than the length of the string that the string argument specifies, then it returns the entire string.
Format
Left[$](string, length)
string |
A string or an expression that contains a string. This method returns a substring of the string that you specify. The substring begins at the first character of this string. If this argument contains a NULL value, then this method returns a Null variant. For more information, see Variants. This method accepts any type of string, including numeric values, and converts the input value to a string. |
length |
An integer that specifies the number of characters to copy. |
Example
The following example gets a user first name from the entire name:
Sub Button_Click
Dim username as String
Dim firstname as String
Dim charspace
charspace = Chr(32)
username = "Chris Smith"
count = InStr(username,charspace)
firstname = Left(username,count)
End Sub
Get Repeated Character String Method
The Get Repeated Character String method creates a string that consists of a repeated character. It returns this string.
Format A
String[$](number, character)
String[$] (number, stringExpression)
Arguments
number |
The length of the string that this method returns. This number must reside in the range of 0 through 32,767. |
character |
An integer or integer expression that contains the ANSI code of the character that this method uses. This argument must evaluate to an integer in the range of 0 through 255. |
stringExpression |
A string argument. This method uses the first character of this argument as the repeated character. |
Example
The following example places asterisks (*) in front of a string that it prints as a payment amount:
Sub Button_Click
Dim str1 as String
Dim size as Integer
i: str1 = 666655.23
If Instr(str1,".") = 0 then
str1 = str1 + ".00"
End If
If Len(str1)>10 then
Goto i
End If
size = 10-Len(str1)
'Print amount in a space on a check allotted for 10 characters
str1 = String(size,Asc("*")) & str1
End Sub
The Get Right String method returns a portion of a string beginning at the end of the string. Note the following:
It accepts any type of string, including numeric values, and converts the input value to a string.
If the value that the string argument contains is NULL, then it returns a Null variant. For more information, see Variants.
If the value in the length argument is greater than the length of the string, then it returns the entire string.
Format
Right[$](string, length)
string |
A string or string expression that contains the characters to copy. |
length |
The number of characters to copy, beginning at the right-most position of the string and counting toward the left. |
Example
The following example searches for the BMP extension in a file name that the user enters. If it does not find the file, then it activates the Paintbrush application. It uses the Option Compare Text statement to accept uppercase or lowercase letters for the file name extension. For more information, see Set String Comparison Method:
Option Compare Text
Sub Button_Click
Dim x
filename ="d:\temp\picture.BMP"
extension = Right(filename,3)
If extension = "BMP" then
x = Shell("PBRUSH.EXE",1)
Sendkeys "%FO" & filename & "{Enter}", 1
Else
End If
End Sub
Get String Length Method
The Get String Length method gets the length of one of the following:
The string that the string argument contains
The string in the variable that the varName argument identifies
Format A
Len(string)
Len(varName)
string |
Includes a string or an expression that evaluates to a string. If you use the string argument, then this method returns the number of characters that the string contains. |
varName |
Identifies a variable that contains a string. If the varName argument:
Example
The following example returns the length of a name that the user enters, including spaces:
Sub Button_Click
count = Len(username)
End Sub
Get Substring Method
The Get Substring method returns a portion of a string, starting at a location in the string that you specify. It allows you to get a substring from a string. It accepts any type of string, including numeric values, and converts the input value to a string. To modify a portion of a string, see Replace String Method.
Format
Mid[$](string, start[, length])
string |
A string or string expression that contains the string that this method copies. If this value is NULL, then this method returns a Null variant. Mid$ requires the string argument to be of type string or variant. For more information, see Variants. |
start |
An integer that identifies the starting position in the string argument to begin copying characters. The position of the first character in a string is 1. If the number in the start argument is larger than the number of positions that the string contains, then this method returns a null string (""). |
length |
Example
The following example returns the last name in a string that the user enters:
Sub Button_Click
Dim position as Integer
Do
position = InStr(username," ")
If position = 0 then
Exit Do
End If
position = position + 1
username = Mid(username,position)
Loop
End Sub
Get Substring Position Method
The Get Substring Position method returns the position of the first occurrence of a substring that resides in another string. It can also return the following values:
Returns a zero in the following situations:
The value in the start argument is greater than the length of the value in the string2 argument.
The string1 argument contains a null string.
The string2 argument is not found.
If the string1 argument or the string2 argument contains a null variant, then it returns a null variant.
If the string2 argument contains a null string (""), then it returns the value of the start argument.
Format A
InStr([start,] string1, string2)
InStr(start, string1, string2[, compare])
Arguments can be of any type. This method converts them to strings.
start |
An integer that identifies a position in the string that the string1 argument identifies. This position is the starting position, with the first character in the string as 1. If you do not specify a value for the start argument, then this method starts at the beginning of the string. |
string1 |
The string that includes the substring. |
string2 |
The substring. |
compare |
You can use one of the following values:
If you do not include the compare argument, then this method uses the module level default that the Set String Comparison method sets. For more information, see Set String Comparison Method. |
Example
The following example creates a random string of characters, and then uses the Get Substring Position method to find the position of a single character in that string:
Sub Button_Click
Dim x as Integer
Dim y
Dim str1 as String
Dim str2 as String
Dim letter as String
Dim randomvalue
Dim upper, lower
Dim msgtext, newline
upper = Asc("z")
lower = Asc("a")
newline = Chr(10)
Randomize
For x = 1 to 26
randomvalue = Int(((upper - (lower + 1)) * Rnd) + lower)
letter = Chr(randomvalue)
str1 = str1 & letter
'Need to waste time here for fast processors
For y = 1 to 1000
Next y
Next x
str2 = "i"
position = InStr(str1,str2)
If position then
msgtext = "The position of " & str2 & " is: " _
& position & newline & "in string: " & str1
Else
msgtext = "The letter: " & str2 & " was not found in: " _
& newline
End If
End Sub
Remove Spaces From String Method
The Remove Spaces From String method removes leading spaces from a string. It returns a copy of this string with the leading spaces removed. It accepts any type of string, including numeric values, and converts the input value to a string.
Format
LTrim[$](string)
string |
A string or string expression that contains the string that this method trims. |
Example
The following example removes the leading spaces from a string:
Sub Button_Click Dim userinput as String Dim numsize Dim str1 as String * 50 Dim strsize strsize = 50 userinput = "abdcGFTRes" numsize = Len(userinput) str1 = Space(strsize-numsize) & userinput ' Str1 has a variable number of leading spaces. str1 = LTrim$(str1) ' Str1 now has no leading spaces. End Sub
The Replace String method replaces part or all of one string with another string. It returns the string that the stringVar argument contains.
Format
Mid (stringVar, start[, length]) = string
stringVar |
The string that this method modifies. |
start |
An integer that identifies the position in stringVar at which to begin replacing characters. The position of the first character in a string is 1. |
length |
An integer that identifies the number of characters to replace. |
string |
The string that this method places into stringVar. |
Usage
This method replaces characters starting at the start position to the end of the string in the following situations:
You do not include the length argument.
The string that the string argument contains is shorter than the value that the length argument contains.
This method does the following:
If the start value is larger than the number of characters in stringVar, then it appends the string that the string argument contains to stringVar.
If length plus start is greater than the length of stringVar, then it replaces characters only up to the end of stringVar.
If the value in the start argument is greater than the number of characters that exist in stringVar, then it creates an error at runtime.
The Replace String method never modifies the number of characters in the string Var argument.
Example
The following example replaces the last name in a custom string with asterisks (*):
Sub Button_Click
Dim uname as String
Dim replacement as String
uname = username
replacement = "*"
Do
Exit Do
End If
username = Mid(username,position + 1)
count = count + position
Loop
For x = 1 to Len(username)
count = count + 1
Mid(uname,count) = replacement
Next x
End Sub
Right-Justify String Method
The Right-Justify String method right-justifies one string in another string. It does not return a value. It justifies a string in the following ways:
Value in the string argument is longer than string-expression. It replaces the leftmost characters of the string with spaces.
Value in the string argument is shorter than string-expression. It copies only the leftmost characters of string-expression.
You cannot use it to assign variables of different custom types.
Format
Rset string = string-expression
string |
The string that receives the right-aligned characters. |
string-expression |
The string that this method puts into the string that the string argument contains. |
Example
The following example right-justifies an amount that the user enters in a field that is 15 characters long. It then pads the extra spaces with asterisks (*) and adds a dollar sign ($) and decimal places, if necessary:
Sub Button_Click
Dim amount as String * 15 Dim x as Integer Dim msgtext as String Dim replacement as String Dim position as Integer
replacement = "*"
amount = 234.56
position = InStr(amount,".")
amount = Rtrim(amount) & ".00"
End If
Rset amount = "$" & Rtrim(amount)
length = 15-Len(Ltrim(amount))
For x = 1 to length
Mid(amount,x) = replacement
Next x
End Sub
The Set String Comparison method specifies the default method for string comparisons to case-sensitive or not case-sensitive. It does not return a value. You must include this method in the general declarations section. Note the following:
A binary comparison is case-sensitive. It compares strings according to the ANSI character set. A lowercase letter is different from an uppercase letter.
A text comparison is not case-sensitive. It compares strings according to the relative order of characters. The country code setting for your computer determines this order.
Format
Option Compare {Binary | Text}
This statement does not include arguments.
Example
The following example compares the following strings:
Jane Smith
jane smith
If Set String Comparison is Text, then these strings are the same. If Set String Comparison is Binary, then these strings are not the same. Binary is the default value. To examine this difference, you can run the example, comment out the Set String Comparison method, and then run it again:
Option Compare Text
Sub Button_Click
Dim strg1 as String
Dim strg2 as String
Dim retvalue as Integer
strg1 = "JANE SMITH"
strg2 = "jane smith"
i:
retvalue = StrComp(strg1,strg2)
If retvalue = 0 then
‘The strings are identical
Else
‘The strings are not identical
Exit Sub
End If
End Sub
Set String Format Method
The Set String Format method returns an expression in a format that you specify. For details about how to use this method, see About Formatting Strings.
Format
Format[$](expression[, format])
expression |
The value that this method formats. This argument can contain one of the following items:
This method formats the value you enter as a number, date, time, or string depending on the format argument. To format a string, it transfers one character at a time from the value you enter in the expression argument to the output string. |
format |
A string expression that identifies the format that this method uses. You must use quotation marks ("") to enclose the value in the format argument. |
Usage
The Set String Format method formats a numeric value as a number or date and time. If you specify a numeric expression, and if you do not include the format argument, or if the format argument is null, then this method converts the number to a string without any special formatting.
It can format a numeric value or a variant as a date. If it formats a numeric value as a date, then it interprets the value according to standard Visual Basic date encoding. The starting date is December 30, 1899. It represents this date as zero. It represents subsequent dates as the number of days from the starting date.
If the format string does not match the Regional Settings, or if the Date in the Microsoft Windows setting is not set to the U.S. format, then the Set String Format method does not return the correct format.
Example 1
The following example includes tokens:
Sub Button1_Click
Dim msgtext As String
msgtext = Format("Section #AB-234", "<\[&&&&&&&&&&&&&&&\]") _
& Chr$(13) & Chr$(13) & Format("incoming", ">@@@@@@@@\!\!") _
& Chr$(13) & Chr$(13) _
& Format("Profits are expected to rise.", _
End Sub
The following example calculates the square root of 2 as a double-precision, floating point value, and then displays it in scientific notation:
Sub Button1_Click Dim value As Double Dim msgtext As String value = CDbl(Sqr(2)) msgtext = "The square root of 2 is " & Format(value, "Scientific") End Sub
Example 3
The following example uses multiple tokens to format the result of the Now method, which returns the current date and time on the computer clock:
Sub ClickMe_Click dim msgtext As String msgtext = Now & Chr$(13) & Chr$(13) _ & "Today is " & Format(Now, "dddd") & ", " _ & Format(Now, "mmmm") & " " & Format(Now, "dd") & ", " _ & Format(Now, "yyyy") & "." _ & Chr$(13) & "The time is " & Format(Now, "h:nn am/pm") _ & " and " & Format(Now, "s") & " seconds." End Sub
For other examples, see the following topics:
Trim Spaces From String Method
The Trim Spaces From String method removes leading and trailing spaces from a string. It returns a copy of this string with the leading and trailing spaces removed. Note the following:
Format
Trim[$](string)
string |
A literal or expression from which this method removes leading and trailing spaces. |
Example
For an example, see Get Substring Method.
Trim Trailing Spaces From String Method
The Trim Trailing Spaces From String method copies a string, and then removes any trailing spaces that exist in that copy. It returns a string with all trailing spaces removed. Note the following:
Format
RTrim[$](string)
string |
Example
For an example, see Right-Justify String Method.
Array Methods
This topic describes array methods. It includes the following topics:
For more information, see Arrays.
Declare Array Method
The Declare Array method allocates memory for a dynamic array to the dimensions that you specify. It does not return a value. You typically use the Dim statement to declare a dynamic array without specifying a size for it.
Format
ReDim [Preserve] arrayName (lower To upper) [As [New] type], …
arrayName |
The name of the array to redimension. |
lower |
The lower boundary of the array. If you do not specify this argument, then Siebel VB uses 0 as the default value of the lower boundary. You can use the Set Array Lower Boundary method to modify this default value. |
upper |
The upper boundary of the array. |
type |
The data type of the array elements. |
Usage
Note the following:
You can use the ReDim statement to declare an array in a procedure that has not previously been declared using the Dim statement or the Global statement. In this situation, you can declare no more than 60 dimensions.
As an option, you can use the Declare Array method to reset array elements.
You cannot use the Declare Array method at the module level. You must use it in a procedure.
The Preserve option modifies the last dimension in the array while maintaining the contents of the array. If you do not specify the Preserve option, then Siebel VB resets the contents of the array. It sets numbers to zero (0). It sets strings and variants to null ("").
If you do not include the As clause, then to specify the variable type, you can use a type character as a name suffix. You can use this clause and suffix in a single Declare Array method. YOu cannot use this clause and suffix on the same variable.
You must not redimension an array in a procedure that has received a reference to an element in the array in an argument. The result of this configuration is not predictable.
A dynamic array that you create with the Dim statement can include no more than eight dimensions. If you require more than eight dimensions, then you must use the Declare Array method. For information about declaring a dynamic array, see Dynamic Arrays.
Example
The following example determines the net present value for a series of cash flows. The array variable that holds the cash flow amounts is initially a dynamic array that this example redimensions after the user enters the number of cash flow periods:
Sub Button_Click
Dim aprate as Single
Dim varray() as Double
Dim cflowper as Integer
Dim x as Integer
Dim netpv as Double
Dim msgtext as string
cflowper = 2
ReDim varray(cflowper)
For x = 1 to cflowper
varray(x) = 4583
Next x
msgtext = "Enter discount rate:"
aprate = 3.25
If aprate > 1 then
aprate = aprate / 100
End If
netpv = NPV(aprate,varray())
msgtext = "The Net Present Value is: " (netpv, "Currency")
End Sub
Erase Array Method
The Erase Array method erases the contents of a fixed array or frees the storage associated with a dynamic array. It does not return a value. The following table describes how it erases the contents of different element types.
| Element Type | Description |
Numeric |
Sets each element to zero. |
Variable-length string |
Sets each element to a zero-length string (""). |
Fixed-length string |
Fills the string of each element with zeros. |
Variant |
Sets each element to Empty. |
Custom type |
Clears each member of each element as if each member is an array element. For example, it sets numeric members to zero, strings to "", and so on. |
Object |
Sets each element to the following value: Nothing |
Format
Erase Array[, Array]
Array |
The name of the array to erase. |
Example
The following example prompts the user for a list of item numbers to put into an array. If the user must start over, then it clears the array. For information about the Dim statement, see Declare Variable Statement:
Sub Button_Click
Dim msgtext
Dim inum(100) as Integer
Dim x, count
Dim newline
newline = Chr(10)
x = 1
count = x
inum(x) = 0
Do
inum(x) = x + 1
If inum(x) = 99 then
Erase inum()
x = 0
ElseIf inum(x) = 0 then
Exit Do
End If
x = x + 1
Loop
count = x-1
msgtext = "You entered the following numbers:" & newline
For x = 1 to count
TheApplication.TraceOn "c:\temp\trace.txt", "Allocation", "All"
TheApplication.Trace msgtext & inum(x) & newline
Next x
End Sub
Get Array Lower Boundary Method
The Get Array Lower Boundary method returns the lowest index number of the dimension that the dimension argument identifies. The numbering for each dimension of an array starts at 1. If you do not include the dimension argument, then it uses 1 is the default.
You can use the Get Array Lower Boundary method with the Get Array Upper Boundary method to determine the length of an array.
Format
LBound(arrayname [, dimension] )
arrayname |
The name of the array to query. |
dimension |
The dimension to query. |
Example
The following example resizes an array if the user enters more data than this array can hold. It uses the LBound statement and the UBound statement to determine the existing size of the array. It uses the ReDim statement to resize the array. The Option Base statement sets the default lower boundary of the array to 1:
Option Base 1
Sub Button_Click
Dim arrayvar() as Integer
Dim answer as String
Dim x, y as Integer
Dim total
total = 0
x = 1
count = 4
ReDim arrayvar(count)
start:
Do until x = count + 1
arrayvar(x) = 98
x = x + 1
Loop
x = LBound(arrayvar,1)
count = UBound(arrayvar,1)
For y = x to count
total = total + arrayvar(y)
Next y
End Sub
Get Array Upper Boundary Method
The Get Array Upper Boundary method returns the upper boundary an array. You can use the Get Array Lower Boundary method with the Get Array Upper Boundary method to determine the length of an array.
The minimum value for the lower boundary of an array is 0. The maximum value for the upper boundary of an array is 65,536.
Format
UBound(arrayName[,dimension])
| Argument | Description |
arrayName |
dimension |
The array dimension whose upper boundary this method returns. If you do not include this argument, then Siebel VB uses 1 as the default value. |
Example
For an example, see Get Array Lower Boundary Method.
The Set Array Lower Boundary method specifies the default lower boundary to use for an array. It does not return a value. Note the following:
You can use this method to set the lower boundary before you use any array in your code. If you do not use this method, then Siebel VB uses 0 as the default value for the lower boundary.
You can use this method only one time for each module.
You cannot use this method in a procedure.
You must include this method in the general declarations section. For example:
Option Explicit Option Base 1 Option Compare Text
Format
Option Base lowerBound
lowerBound |
The value 0 or 1 or an expression that evaluates to one of these values. |
Example
Mathematical Methods
This topic describes mathematical methods. It includes the following topics:
Overview of Mathematical Methods
This topic describes an overview of mathematical methods.
How Some Math Methods Handle the Data Type
Some math methods provide a different return value depending on the following data types of the variable that contains the return value:
Integer or currency. The return value is a single-precision number.
A single-precision value. The return value is a single-precision number.
Long or variant. The return value is a double-precision value.
A double-precision value. The return value is a double-precision value.
These methods are noted in this chapter, where appropriate.
Trigonometric Methods
The following information lists the trigonometric methods that are available in Siebel VB.
| Method | Computation |
ArcCoSecant |
ArcCoSec(x) = Atn(x/Sqr(x*x-1))+(Sgn(x)-1)*1.5708 |
ArcCosine |
ArcCos(x) = Atn(-x/Sqr(-x*x+1))+1.5708 |
ArcCoTangent |
ArcTan(x) = Atn(x)+1.5708 |
ArcSecant |
ArcSec(x) = Atn(x/Sqr(x*x-1))+Sgn(x-1)*1.5708 |
ArcSine |
ArcSin(x) = Atn(x/Sqr(-x*x+1)) |
CoSecant |
CoSec(x) = 1/Sin(x) |
CoTangent |
CoTan(x) = 1/Tan(x) |
Hyperbolic ArcCoSecant |
HArcCoSec(x) = Log((Sgn(x)*Sqr(x*x+1)+1)/x) |
Hyperbolic ArcCosine |
HArcCos(x) = Log(x+Sqr(x*x-1)) |
Hyperbolic ArcCoTangent |
HArcCoTan(x) = Log((x+1)/(x-1))/2 |
Hyperbolic ArcSecant |
HArcSec(x) = Log((Sqr(-x*x+1)+1)/x) |
Hyperbolic ArcSine |
HArcSin(x) = Log(x+Sqr(x*x+1)) |
Hyperbolic ArcTangent |
HArcTan(x) = Log((1+x)/(1-x))/2 |
Hyperbolic CoSecant |
HCoSec(x) = 2/(Exp(x)-Exp(-x)) |
Hyperbolic Cosine |
HCos(x) = (Exp(x)+Exp(-x))/2 |
Hyperbolic Cotangent |
HCotan(x) = (Exp(x)+Exp(-x))/ (Exp(x)-Exp(-x)) |
Hyperbolic Secant |
HSec(x) = 2/(Exp(x)+Exp(-x)) |
Hyperbolic Sine |
HSin(x) = (Exp(x)-Exp(-x))/2 |
Hyperbolic Tangent |
HTan(x) = (Exp(x)-Exp(-x))/(Exp(x)+Exp(-x)) |
Secant |
Sec(x) = 1/Cos(x) |
Exponential Method
The Exponential method returns the value e raised to the power of the value that you specify in the number argument. The value e is the base of natural logarithms. The constant e is approximately 2.718282. For information about how this method handles the data type, see How Some Math Methods Handle the Data Type.
Format
Exp(number)
The following table describes the arguments that you can use with this method.
number |
The exponent value of e. |
Example
The following example estimates the value of a factorial of a number that the user enters:
Sub Button_Click
Dim x as Single
Dim msgtext, PI
Dim factorial as Double
PI = 3.14159
i: x = 55
If x< = 0 then
Exit Sub
ElseIf x>88 then
Goto i
End If
factorial = Sqr(2 * PI * x) * (x^x/Exp(x))
msgtext = "The estimated factorial is: " & Format _
(factorial, "Scientific")
End Sub
A factorial is the product of a number and each integer between it and the number 1. For example, 5 factorial, or 5!, is the product of 5*4*3*2*1, or the value 120. An exclamation point (!) can specify a factorial.
Get Absolute Value Method
The Get Absolute Value method returns the absolute value of the value that the number argument contains. The data type of the return value matches the data type of the value in the number argument. This method does the following:
If the value is a string variant type, then it converts the return value to a double variant type.
If the value is an empty variant type, then it converts the return value to a long variant type.
Format
Abs(number)
number |
Any valid numeric expression. |
Example
The following example determines the difference between the oldacct variable and the newacct variable:
Sub Button_Click Dim oldacct, newacct, count oldacct = 1234566 newacct = 33345 count = Abs(oldacct - newacct) End Sub
Get ANSI Integer Method
The Get ANSI Integer method returns an integer that corresponds to the ANSI code of the first character in the string that you specify. You can use the Get ANSI String method to modify an ANSI code to string characters. For more information, see Get ANSI String Method.
Format
Asc(string)
string |
A string expression that contains one or more characters. |
Example
The following example asks the user for a letter and returns the ANSI value for this letter:
Sub Button_Click Dim userchar As String Dim ascVal as Integer userchar = "Z" ascVal = Asc(userchar) End Sub
Get Arctangent Method
The Get Arctangent method returns the angle in radians of the arctangent of a number that you specify. It assumes the value in the number argument is the ratio of two sides of a right triangle: the side opposite the angle to find and the side adjacent to the angle. It returns a single-precision value for a ratio expressed as an integer, a currency, or a single-precision numeric expression. The return value is a double-precision value for any of the following numeric expressions:
Long
Variant
Double-precision
You can multiply a value by (180/PI) to convert radians to degrees. The value of PI is approximately 3.14159.
Format
Atn(number)
This method uses the same arguments as the Get Absolute Value method. For more information, see Get Absolute Value Method.
Example
The following example finds the roof angle necessary for a house that includes an attic ceiling height of 8 feet at the roof peak and a 16 foot span from the outside wall to the center of the house. The Get Arctangent method returns the angle in radians. It multiplies this value by 180/PI to convert it to degrees:
Sub Button_Click Dim height As Single, span As Single, angle As Single Dim PI As Single PI = 3.14159 height = 8 span = 16 angle = Atn(height/span) * (180/PI) End Sub
Get Cosine Method
The Get Cosine method returns the cosine of an angle. The angle can be positive or negative. The return value is between negative 1 and 1. To convert degrees to radians, this method multiples the return value by (PI/180). The value of PI is approximately 3.14159.
Format
Cos(number)
number |
An angle in radians. |
Example
The following example finds the length of a roof, given the roof pitch, and the distance of the house from the house center to the outside wall of the house:
Sub Button_Click
Dim bwidth As Single, roof As Single, pitch As Single
Dim msgtext
Const PI = 3.14159
Const conversion = PI/180
pitch = 35
pitch = Cos(pitch * conversion)
bwidth = 75
roof = bwidth/pitch
msgtext = "The length of the roof is " & _
Format(roof, "##.##") & " feet."
End Sub
Get Hexadecimal Method
The Get Hexadecimal Method returns the hexadecimal representation of the value in the number argument. It returns this value in a string. If the value in the number argument:
Is an integer. The return string contains up to four hexadecimal digits.
Is not an integer. This method converts the value to a long integer, and the string can contain up to eight hexadecimal digits.
You precede the hexadecimal value with the following characters to express a hexadecimal number:
&H
For example, &H10 equals decimal 16 in hexadecimal notation.
Format
Hex[$](number)
Example
The following example returns the hex value for a number that the user enters:
Sub Button_Click Dim usernum as Integer Dim hexvalue as String usernum = 23 hexvalue = Hex(usernum) End Sub
Get Integer Method
The Get Integer method returns the integer part of a number:
For a positive number, it removes the fractional part of the expression and returns the integer part only.
For a negative number, it returns the largest integer that is less than or equal to the expression. For example:
Int (6.2) returns 6.
Int(-6.2) returns negative 7.
Format
Int(number)
Similarities Between the Get Integer Method and the Get Rounded Integer Method
The Get Integer method performs the same work as the Get Rounded Integer method except it handles negative numbers differently. For example:
Int(-8.347) = -9
Fix(-8.347) = -8
For more information, see Get Rounded Integer Method.
How The Get Integer Method Handles Variant Types
The return type matches the type of the numeric expression. This includes a variant expression that returns the same variant type as the input value except for the following items:
The string variant type returns as the double variant type.
An empty variant type returns as a long variant type.
Example
The following example uses the Get Integer method to create random numbers in the range of ASCII values for lowercase a through z. This ASCII range is 97 through 122. It converts the values to letters and displays them as a string:
Sub Button_Click
Dim x As Integer, y As Integer
Dim str1 As String, letter As String
Dim randomvalue As Double
Dim upper As Integer, lower As Integer
upper = Asc("z")
lower = Asc("a")
newline = Chr(10)
Randomize
For x = 1 to 26
For y = 1 to 1500
Next y
Next x
msgtext = "The string is:" & newline
msgtext = msgtext & str1
End Sub
The Get Rounded Integer method removes the fractional part of a number. It returns the integer part of a number. For positive and negative numbers, it removes the fractional part of the expression and returns the integer part only. For example:
Fix (6.2) returns 6.
Fix (-6.2) returns negative 6.
For more information, see Get Integer Method.
Format
Fix(number)
The data type of the return value matches the data type of the numeric expression. This includes variant expressions unless the numeric expression is one of the following:
A string variant type that evaluates to a number. In this situation, the data type of the return value is a double variant type.
An empty variant type. In this situation, the data type of the return value is a long variant type.
Example
The following example returns the integer portion of a number that the user enters:
Sub Button_Click Dim usernum Dim intvalue usernum = 77.54 intvalue = Fix(usernum) End Sub
Get Logarithm Method
The Get Logarithm method returns the natural logarithm of a number. For information on how this method handles the data type, see How Some Math Methods Handle the Data Type.
Format
Log(number)
Example
The following example uses the Get Logarithm method to determine which of the following numbers is larger:
999^1000 (999 to the 1000th power)
1000^999 (1000 to the 999th power):
Sub Button_Click Dim x Dim y x = 999 y = 1000 a = y * (Log(x)) b = x * (Log(y)) If a>b then "999^1000 is greater than 1000^999" Else "1000^999 is greater than 999^1000" End If End Sub
You cannot use the exponent (^) operator for very large numbers, such as 999^1000.
Get Octal Method
The Get Octal method converts a number to an octal (base 8) number. It returns the octal representation of a number as a string. The following data type of the integer determines the octal digits that the string can contain:
Is an integer data type. The string can contain up to six octal digits.
Is not an integer data type. This method converts the expression to a long data type. The string can contain up to 11 octal digits.
To represent an octal number, you precede the octal value with the following code:
&O
For example, the following code equals decimal 8 in octal notation:
&O10
Format
Oct[$](number)
Example
The following example prints the octal values for the numbers 1 through 15:
Sub Button_Click Dim x As Integer, y As Integer Dim msgtext As String Dim nofspaces As Integer msgtext = "Octal numbers from 1 to 15:" & Chr(10) For x = 1 to 15 nofspaces = 10 y = Oct(x) If Len(x) = 2 then nofspaces = nofspaces - 2 End If msgtext = msgtext & Chr(10) & x & Space(nofspaces) & y Next x End Sub
Get Number Sign Method
The Get Number Sign method returns a value that identifies the sign of a number. It returns a different value depending on the following value of the number:
Number is less than zero. It returns negative 1.
Number is equal to zero. It returns 0.
Number is greater than zero. It returns 1.
Format
Sgn(number)
Example
The following example examines the value of the profit variable. If this value is a negative number, then it displays 0 for profit:
Sub Button_Click Dim profit as Single Dim expenses Dim sales expenses = 100000 sales = 200000 profit = Val(sales)-Val(expenses) If Sgn(profit) = 1 then ‘Yeah! We turned a profit! ElseIf Sgn(profit) = 0 then ‘Okay. We broke even. Else ‘Uh, oh. We lost money. End If End Sub
Get Random Number Method
The Get Random Number method returns a single-precision, pseudo-random number between 0 and 1 depending on the following value that you specify in the number argument:
Less than zero. Uses the number you specify as the seed for a pseudo-random number. It creates this number every time the Get Random Number method runs.
Equal to zero. Uses the number most recently created.
Greater than zero or no value. Creates a sequence of pseudo-random numbers. Each run of the Get Random Number method uses the next number in the sequence. It creates the same sequence of random numbers when it runs unless the Randomize method resets the random number generator.
Because this method always uses the same algorithm and the same seed value to create a number, it creates a pseudo-random number rather than a true random number. The number it creates appears to be random unless it runs a very large number of iterations, at which point a pattern of numbers might emerge. For practical purposes, you can consider this pseudo-random number to fulfill the requirements you might have to create a random number.
Format
Rnd[(number)]
number |
A numeric expression that describes how to create the random number. |
Example
For an example, see Randomize Method.
Get Sine Method
The Get Sine method returns the sine of an angle specified in radians. The return value is between -1 and 1. You specify the angle in radians as a positive or negative number. To convert degrees to radians, this method multiplies degrees by (PI/180). The value of PI is 3.14159.
Format
Sin(number)
number |
A numeric expression that contains a number that represents the size of an angle in radians. |
Example
The following example finds the height of a building, given the length of the roof and the roof pitch:
Sub Button_Click Dim height, rooflength, pitch, msgtext As String Const PI = 3.14159 Const conversion = PI/180 pitch = 35 pitch = pitch * conversion rooflength = 75 height = Sin(pitch) * rooflength msgtext = "The height of the building is " msgtext = msgtext & Format(height, "##.##") & " feet." End Sub
Get Square Root Method
The Get Square Root method returns the square root of a number. For information on how this method handles the data type, see How Some Math Methods Handle the Data Type.
Format
Sqr(number)
number |
An expression that contains the number whose square root is to be found. |
Example
For an example that calculates the square root of 2 as a double-precision floating-point value and displays it in scientific notation, see Set String Format Method.
Get Tangent Method
The Get Tangent method returns the tangent of an angle in radians. You specify the value in the number argument in radians. This value can be positive or negative. To convert degrees to radians, this method multiplies degrees by PI/180. The value of PI is 3.14159.
Format
Tan(number)
number |
A numeric expression that contains the number of radians in the angle whose tangent this method returns. |
Example
The following example finds the height of the exterior wall of a building, given the roof pitch and the length of the building:
Sub Button_Click Dim bldglen, wallht Dim pitch Dim msgtext Const PI = 3.14159 Const conversion = PI/180 On Error Resume Next pitch = 35 pitch = pitch * conversion bldglen = 150 wallht = Tan(pitch) * (bldglen/2) End Sub
Randomize Method
The Randomize method creates a starting value for the random number generator. It does not return a value. If you do not specify a value for the number argument, then it uses the Get Seconds method to reset the random number generator.
Format
Randomize [number]
number |
An integer value that is in the range of negative 32768 through 32767. |
Example
The following example uses the Randomize method and the Get Random Number method to create a random string of characters. The second For Next loop slows down processing in the first For Next loop so that the Timer method can seed the Randomize method with a new value each time the loop runs:
Sub Button_Click
Dim str1 As String, str2 As String
Dim letter As String
Dim randomvalue
Dim upper, lower
Dim msgtext
upper = Asc("z")
lower = Asc("a")
newline = Chr(10)
Randomize
For x = 1 to 26
For y = 1 to 1500
Next y
Next x
msgtext = str1
End Sub
Date and Time Methods
This topic describes date and time methods. It includes the following topics:
Convert Number to Date Method
The Convert Number to Date method converts an expression to the data type variant of type date. Note the following:
It returns a date variable type that represents a date from January 1, 100, through December 31, 9999. A value of 2 represents January 1, 1900.
It represents a time as fractional days.
It accepts string and numeric values.
It converts the time portion of a date expression in the following situations:
If you include a time portion as part of the expression.
If the time expression is the only argument.
To compare dates, you must make sure that you format these dates consistently with each other. You can use this method to convert both expressions before Siebel VB compares them.
For ways to display the desired result of a date conversion, see Set String Format Method.
Format
CVDate(expression)
expression |
Any expression that Siebel VB can evaluate to a number. |
How the Operating System Affects the Date Format
The date format depends on the format that the operating system uses. For example, if the operating system uses the mm/dd/yyyy format, then the input argument must use the mm/dd/yyyy format or the mm-dd-yyyy format. If you use an integer value, then to calculate this date Siebel eScript adds this integer as the number of days after the year 1900. In this situation, it returns a date in the mm/dd/yyyy form.
Example
The following example displays the date for one week from a date that the user enters:
Sub Button_Click
Dim str1 as String
Dim nextweek
i:
str1 = "2/5/2001"
answer = IsDate(str1)
If answer = -1 then
str1 = CVDate(str1)
nextweek = DateValue(str1) + 7
msgtext = "One week from the date entered is:
msgtext = msgtext & "Format(nextweek,"dddddd")
Else
Goto i
End If
End Sub
Convert Serial Number to Date Method
The Convert Serial Number to Date method converts a number to a date. It returns a date variable type that represents a date from January 1, 100, through December 31, 9999. For more information, see Variants.
To specify a relative date, you can use a numeric expression for any of the arguments. This expression evaluates to a number of days, months, or years before or after a specific date.
Format
DateSerial(year, month, day)
The following table describes the arguments that you can use with this method. As an option, you can use a numeric expression instead of an integer for each argument.
year |
An integer that identifies a year in the range of 100 through 9999. |
month |
An integer that identifies a month in the range of 1 through 12. |
day |
An integer that identifies a day in the range of 1 through 31. |
Example
The following example finds the day of the week for November 7 in the year 2009:
Sub Button_Click
Dim checkdate As Variant, daynumber As Variant
Dim msgtext As String, checkday as Variant
Const checkyear = 2009
Const checkmonth = 11
checkday = 7
checkdate = DateSerial(checkyear,checkmonth,checkday)
daynumber = Weekday(checkdate)
msgtext = "November 7, 2009 falls on a " & _
Format(daynumber, "dddd")
End Sub
Convert String to Date Method
The Convert String to Date method converts a string to a date. It returns a date variable type that represents a date from January 1, 100, through December 31, 9999, where January 1, 1900, is 2. For more information, see Variants. Note the following:
It accepts multiple string representations for a date.
It uses the international settings of the operating system to resolve a numeric date.
Because this method handles dates and not times, if it receives time information then it modifies this time to 12:00:00 AM, which is midnight of the date value.
Format
DateValue(date)
date |
Any numeric or string expression that can evaluate to a date and time or date value. This value can be of any type, including string. |
If the value that the date argument contains is not in a valid date format, then this method returns a Type Mismatch error.
Using the DateValue Statement With the GetFormattedFieldValue Statement
To avoid a locale conflict, it is recommended that you do not use the DateValue statement together with the GetFormattedFieldValue statement. Note the following:
The GetFormattedFieldValue statement formats a date according to the locale setting of the object manager.
The DateValue statement expects a date string in a format according to the locale setting of the operating system.
A Siebel Server can run multiple object managers with different language settings. For example, ENU, DEU, or FRA. However, the server operating system can only have one value selected for Regional Options, such as English (United States).
In this example, if a client connects to a DEU object manager on a Siebel Server where the Regional Options parameter is set to English (United States), then the GetFormattedFieldValue statement returns a string that contains a date that it formats for DEU, but the DateValue statement expects a string formatted for ENU. This situation results in the following error in Siebel VB:
Illegal Function Call
Example
The following example displays the date for one week from the date that the user enters:
Sub Button_Click
Dim str1 As String, answer As Integer, msgtext As String
Dim nextweek
i:
str1 = "12/22/2000"
If answer = -1 then
str1 = CVDate(str1)
msgtext = "One week from your date is: "
msgtext = msgtxt & Format(nextweek,"dddddd")
Else
msgtext = "Invalid date or format. Try again."
Goto i
End If
End Sub
Convert String to Time Method
The Convert String to Time method converts a string to time. It returns a variant of date variable type that represents a time in one of the following ranges:
The time 0:00:00 through 23:59:59
The time 12:00:00 A.M. through 11:59:59 P.M.
Format
TimeValue(time)
time |
Any numeric or string expression that can evaluate to a date and time or time value. |
Example
The following example writes a variable to a file according to a comparison of the last saved time and the current time. It dimensions the variables that it uses for the Convert String to Time method as double. It does this to make sure the calculations work correctly according to their values:
Sub Button_Click
Dim tempfile As String
Dim ftime As Variant
Dim filetime as Double
Dim curtime as Double
Dim minutes as Double
Dim acctno(100) as Integer
Dim x, I
tempfile = "C:\TEMP001"
Open tempfile For Output As 1
ftime = FileDateTime(tempfile)
filetime = TimeValue(ftime)
minutes = TimeValue("00:02:00")
x = 1
I = 1
acctno(x) = 0
Do
curtime = TimeValue(Time)
acctno(x) = 46
If acctno(x) = 99 then
For I = I to x-1
Write #1, acctno(I)
Next I
Exit Do
ElseIf filetime + minutes< = curtime then
For I = I to x
Write #1, acctno(I)
Next I
End If
x = x + 1
Loop
Close #1
x = 1
msgtext = "You entered:" & Chr(10)
Open tempfile for Input as #1
Do While Eof(1) <> -1
Input #1, acctno(x)
msgtext = msgtext & Chr(10) & acctno(x)
x = x + 1
Loop
Close #1
Kill "C:\TEMP001"
End Sub
Extract Day From Date-Time Value Method
The Extract Day From Date-Time Value method returns the day component of a date and time value. The return value is an integer variable type in the range of 1 through 31. If the return value is null, then it returns a null variable type. For more information, see Variants.
Format
Day(date)
The argument that this method uses is the same as the argument that the Convert String to Date method uses. For more information, see Convert String to Date Method.
Example
The following example finds the month in the range of 1 through 12 and the day in the range of 1 through 31 for this Thursday:
Sub Button_Click
Dim x As Integer, Today As Variant, msgtext As String
Today = DateValue(Now)
Let x = 0
Do While Weekday(Today + x) <> 5
x = x + 1
Loop
msgtext = "This Thursday is: " & Month(Today + x) & "/" & _
Day(Today + x)
End Sub
Extract Hour From Date-Time Value Method
The Extract Hour From Date-Time Value method returns the hour component of a date and time value. The return value is an integer variable type in the range of 0 through 23. Note the following:
If the return value is null, then this method returns a null variable type. For more information, see Variants.
The value in the time argument can be of any type, including string.
The value in the time argument is a double-precision value:
The numbers to the left of the decimal point denote the date.
The decimal value denotes the time from 0 to 0.99999.
You can use the Convert String to Time method to get the correct value for a specific time.
Format
Hour(time)
The argument that this method uses is the same as the argument that the Convert String to Time method uses. For more information, see Convert String to Time Method.
If the value that the minute argument contains does not evaluate to a date and time or to a time value, then this method returns 0 (zero). For example:
The value 13:26 or the 1:45:12 PM returns a valid result.
The value 1326 returns a 0.
Extract Minute From Date-Time Value Method
The Extract Minute From Date-Time Value method returns the minute component of a date and time value. The return value is an integer variable type in the range of 0 through 59. If the return value is null, then this method returns a null variable type. For more information, see Variants.
Format
Minute(time)
If the value that the time argument contains does not evaluate to a date and time or to a time value, then this method returns 0 (zero). For example:
The value 13:26 or the value 1:45:12 PM returns a valid results.
Example
The following example gets the hour, minute, and second of the last modification date and time of a file:
Sub Button_Click
Dim ftime
Dim hr, min
Dim sec
i: msgtext = "Enter a filename:"
filename = "d:\temp\trace.txt"
If filename = "" then
Exit Sub
End If
ftime = FileDateTime(filename)
If Err <> 0 then
Goto i:
End If
hr = Hour(ftime)
min = Minute(ftime)
sec = Second(ftime)
End Sub
Extract Month From Date-Time Value Method
The Extract Month From Date-Time Value method returns the month component of a date and time value. The return value is an integer variable type in the range of 1 through 12. If the return value is null, then this method returns a null variable type. For more information, see Variants.
Format
Month(date)
If the value in the date argument does not evaluate to a date and time or to a time value, then this method returns 0 (zero). For example:
The value 11/20 or the value 11-20-2001 returns a valid results.
The value 1120 returns a 0.
Example
Sub Button_Click
Dim msgtext
Let x = 0
x = x + 1
Loop
msgtext = "This Thursday is: " & Month(Today + x) &"/" _
& Day(Today + x)
End Sub
Extract Second From Date-Time Value Method
The Extract Second From Date-Time Value method returns the seconds component of a date and time value. The return value is an integer variable type in the range of 0 through 59. If the return value is null, then this method returns a null variable type. For more information, see Variants.
Format
Second(time)
If the value in the time argument does not evaluate to a date and time or to a time value, then this method returns 0 (zero). For example:
The value 13:26:39 or the value 1:45:12 PM returns a valid results.
Example
For an example, see Extract Minute From Date-Time Value Method.
Extract Weekday From Date-Time Value Method
The Extract Weekday From Date-Time Value method returns the day of the week of a date and time value. It returns this value as an integer in the range of 1 through 7, where 1 is Sunday and 7 is Saturday.
It accepts any expression, including strings, and attempts to convert the input value to a date value.
The return value is an integer variable type. If the return value is null, then this method returns a null variable type. For more information, see Variants.
Format
Weekday(date)
Example
The following example determines the day of the week when November 7 occurs in the year 2009:
Sub Button_Click Dim checkdate Dim daynumber Dim msgtext Dim checkday as Variant Const checkyear = 2009 Const checkmonth = 11 Let checkday = 7 checkdate = DateSerial(checkyear,checkmonth,checkday) daynumber = Weekday(checkdate) msgtext = "November 7, 2009 falls on a " & _ Format(daynumber, "dddd") End Sub
Extract Year From Date-Time Value Method
The Extract Year From Date-Time Value method returns the year component of a date and time value. It returns this value as an integer in the range of 100 through 9999. It accepts any type of date, including strings, and attempts to convert the input value to a date value.
Format
Year(date)
Example
The following example returns the year for today:
Sub Button_Click Dim nowyear nowyear = Year(Now) End Sub
Get Current Date Method
The Get Current Date method returns a ten character string that includes the current date as determined by the computer clock.
Format
Date[$]
This method does not include arguments.
Example
The following example displays the date for one week from the current computer date:
Sub Button_Click Dim nextweek nextweek = CVar(Date) + 7 End Sub
Get Current Date and Time Method
The Get Current Date and Time method returns the current date and time as a date variable type according to the setting of the computer date and time. For more information, see Variants.
You can use the Set String Format method to specify the format that Siebel CRM uses to display the date and time.
Format
Now()
Example
The following example finds the month in the range of 1 through 12 and the day in the range of 1 through 31 for this Thursday. For another example, see Set String Format Method:
Sub Button_Click Dim x As Integer, today As Variant Dim msgtext As String Today = DateValue(Now) Let x = 0 Do While Weekday(Today + x) <> 5 x = x + 1 Loop msgtext = "This Thursday is: " & Month(Today + x) & "/" & _ Day(Today + x) End Sub
Get Current Time Method
This method returns a string that contains the current time. It returns an eight character string of the following format:
hh:mm:ss
where:
hh is the hour
mm is the minute
ss is the second
The hour uses a 24 hour clock in the range of 0 through 23.
Format
Time[$]
Example
The following example writes data to a file if it has not been saved in the last two minutes:
Sub Button_Click Dim tempfile Dim filetime, curtime Dim msgtext Dim acctno(100) as Single Dim x, I tempfile = "c:\temp001" Open tempfile For Output As #1 filetime = FileDateTime(tempfile) x = 1 I = 1 acctno(x) = 0 Do curtime = Time acctno(x) = 44 If acctno(x) = 99 then For I = 1 to x -1 Write #1, acctno(I) Next I Exit Do ElseIf (Minute(filetime) + 2)< = Minute(curtime) then For I = I to x Write #1, acctno(I) Next I End If x = x + 1 Loop Close #1 x = 1 msgtext = "Contents of c:\temp001 is:" & Chr(10) Open tempfile for Input as #1 Do While Eof(1) <> -1 Input #1, acctno(x) msgtext = msgtext & Chr(10) & acctno(x) x = x + 1 Loop Close #1 Kill "c:\temp001" End Sub
Get Current Seconds Method
The Get Current Seconds method returns the number of seconds that have elapsed since midnight. You can use the Get Current Seconds method and the Randomize statement to seed the random number generator. For more information, see Randomize Method.
Format
Timer
Example
The following example uses the Get Current Seconds method to find Megabucks numbers:
Sub Button_Click Dim msgtext As String Dim value(9) As Single Dim nextvalue As Integer Dim x As Integer Dim y As Integer
msgtext = "Your Megabucks numbers are: " For x = 1 to 8 Do value(x) = Timer value(x) = value(x) * 100 value(x) = Str(value(x)) value(x) = Val(Right(value(x),2)) Loop Until value(x)>1 and value(x)<36 For y = 1 to 1500 Next y Next x
For y = 1 to 8 For x = 1 to 8 If y <> x then If value(y) = value(x) then value(x) = value(x) + 1 End If End If Next x Next y For x = 1 to 8 msgtext = msgtext & value(x) & " " Next x End Sub
Get Serial Time Method
The Get Serial Time method returns a time as a variant of type 7 (date and time) for a specific hour, minute, and second.
To specify a relative time for each argument, you can use a numeric expression that identifies the number of hours, minutes, or seconds before or after a specific time.
Format
TimeSerial(hour, minute, second)
hour |
A numeric expression that contains a value in the range of 0 through 23 that identifies an hour. |
minute |
A numeric expression that contains a value in the range of 0 through 59 that identifies a minute. |
second |
A numeric expression that contains a value in the range of 0 through 59 that identifies a second. |
Example
The following example displays the current time:
Sub Button_Click Dim y As Variant Dim msgtext As String Dim nowhr As Integer Dim nowmin As Integer Dim nowsec As Integer nowhr = Hour(Now) nowmin = Minute(Now) nowsec = Second(Now) y = TimeSerial(nowhr,nowmin,nowsec) msgtext = "The time is: " & y End Sub
Set Date Method
The Set Date method sets the computer date. It does not return a value. Note the following:
If you do not include the dollar sign ($), then the expression can be a string that contains a valid date, a date variable type, or a string variable type. For more information, see Variants.
If the expression argument is not already a date variable type, then it attempts to convert this value to a valid date from January 1, 1980, through December 31, 2099.
To identify the day, month, and year if a string contains three numbers that are separated by valid date separators, it uses the Short Date format in the International section of Microsoft Windows Control Panel. It recognizes month names in full or abbreviated form.
Format
Date[$] = expression
expression |
A string in one of the following forms:
The following table describes the value you must specify for each item in the expression.
| Value | Value You Must Specify |
mm |
A month expressed as a two-digit number in the range of 01 through 12. |
dd |
A day expressed as a two-digit number in the range of 01 through 31. |
yy |
A year expressed as a two-digit number in the range of 00 through 99. |
yyyy |
A year expressed as a four-digit number in the range of 1980 through 2099. |
Example
The following example modifies the computer date to a date that the user enters:
Sub Button_Click
Dim userdate
Dim answer
i:
userdate = "2/5/2001"
If userdate = "" then
Exit Sub
End If
answer = IsDate(userdate)
If answer = -1 then
Date = userdate
Else
Goto i
End If
End Sub
Set Time Method
The Set Time method sets the computer time. It does not return a value.
If the value in the expression argument is not already a date variable type, then this method attempts to convert it to a valid time. It recognizes the time separator characters defined in the International section of the Microsoft Windows Control Panel. For more information, see Variants.
Format
Time[$] = expression
expression |
An expression that evaluates to a valid time. |
Usage of the Dollar Sign
If you include the dollar sign ($), then the following items apply:
The value in the expression argument must evaluate to a string that uses one of the following forms:
hh. Sets the time to hh hours, 0 minutes, and 0 seconds.
hh:mm. Sets the time to hh hours, mm minutes, and 0 seconds.
hh:mm:ss. Sets the time to hh hours, mm minutes, and ss seconds.
It uses a 24 hour clock. For example, 6:00 P.M. is 18:00:00.
If you do not include the dollar sign ($), then the following items apply:
The expression argument can include a string that contains a valid date, or a date variable type of 8 (string).
It accepts 12 hour and 24 hour clocks.
Example
The following example modifies the time of the computer clock:
Sub Button_Click
Dim newtime As String
Dim answer As String
i:
newtime = "5:30"
answer = PM
If answer = "PM" or answer = "pm" then
newtime = newtime &"PM"
End If
Time = newtime
If Err <> 0 then
Err = 0
Goto i
End If
End Sub
ODBC Methods
This topic describes methods that you can use with ODBC (Open Database Connectivity). It includes the following topics:
Overview of ODBC Methods
ODBC methods in Siebel VB only support non-Unicode databases.
You must not use some methods to query a Siebel database. Instead, use the Siebel Object Interfaces to query data in a Siebel database. Use an ODBC method only to query non-Siebel data.
ODBC Close Connection Method
The ODBC Close Connection method is a Siebel VB method that disconnects from an ODBC data source connection that the ODBC Open method established. It returns a variant that includes one of the following values:
0. Successful disconnect.
-1. Connection is not valid.
If you call the ODBC Close Connection method with an argument that is not valid, then it replies with the undocumented return code of -2 (negative two), which indicates a data source connection that is not valid. The following items are examples of arguments that are not valid:
An SQLClose(0) argument
A variable argument that does not contain an initial value
Format
SQLClose(connection)
connection |
A named argument that the ODBC Open method returns. It must be a long integer. For information about named arguments, see Comments and Call Subroutine Method. |
Example
The following example opens the data source named SblTest, gets the names in the ODBC data sources, and then closes the connection:
Sub Button_Click
' Declarations
Dim outputStr As String
Dim connection As Long
Dim prompt As Integer
Dim datasources(1 To 50) As Variant
Dim retcode As Variant
prompt = 5
' Open the data source "SblTest"
connection = SQLOpen("DSN = SblTest", outputStr, prompt: = 4)
action1 = 1 ' Get the names of the ODBC data sources
retcode = SQLGetSchema(connection: = connection,action: _
= 1,qualifier: = qualifier, ref: = datasources())
' Close the data source connection
retcode = SQLClose(connection)
End Sub
ODBC Get Errors Method
The ODBC Get Errors method is a Siebel VB method that gets detailed information about errors that occur during an ODBC method call. It returns errors for the last ODBC method and the last connection.
Format
SQLError(destination())
destination |
A two-dimensional array of type variant, where each row contains one error. |
Usage
The ODBC Get Errors method returns detailed information for each detected error to the caller in the destination array. It fills each row of the destination array with information for one error. The following table describes how it fills elements of each row with data.
| Element | Description |
1 |
A character string that identifies the ODBC error class and subclass. The ODBC Get Errors method might return information for more than one error in the destination array. A 0 (zero) in the first element of a row identifies the end of error information in the destination array. |
2 |
A numeric value that identifies the native error code of the data source. |
3 |
A text message that describes the error. |
If no errors from a previous ODBC method call are present, then it returns a 0 (zero) in the array at the first element of the first row. If the array is not two dimensional or if it does not provide for the return of the preceding three elements, then it returns an error message in the array at the first element of the first row.
Example
The following example forces an error as a way to test the ODBC Get Errors method:
Sub Button_Click ' Declarations Dim connection As long Dim prompt as integer Dim retcode as long Dim errors(1 To 10, 1 To 3) as Variant
connection = SQLOpen("DSN = SVBTESTW;UID=DBA;PWD=SQL"
,outputStr, prompt: = 3)
' force an error to test SQLError choose a nonexistent table retcode = SQLExecQuery(connection: = connection, query: = "select * from notable ")
' Retrieve the detailed error message information into the
' errors array
SQLError destination: = errors
errCounter = 1
while errors(errCounter,1) <>0
errCounter = errCounter + 1
wend
end sub
ODBC Get Query Results Method
The ODBC Get Query Results method is a Siebel VB method that gets the results of a pending query. It returns a variant that contains one of the following values:
The number of rows in the result set or the maxRows requested. Indicates success .
-1. Unable to get results, or no results pending .
0. The query did not find any data.
It uses a default value of 0 for any argument that you do not include. This is true for all arguments except for the fetchFirst argument.
Format
SQLRetrieve(connection, destination()[, maxColumns][, maxRows] [, columnNames][, rowNumbers][, fetchFirst])
connection |
The long integer that the ODBC Open Connection method returns. |
destination |
A two-dimensional array of type variant. The first index of the array cannot exceed 100. |
maxColumns |
The number of columns that this method gets in the request. If this number specifies fewer columns than the result contains, then it discards the rightmost result columns until the result fits the size that you specify. |
maxRows |
The number of rows that this method gets in the request. |
columnNames |
An integer. If the columnNames argument is not zero, then this method does the following work:
rowNumbers |
An integer. If the rowNumbers argument is not zero, then that this method returns the row names as the first column of the array that you identify in the ref argument. It clears the user array before it gets the results. |
fetchFirst |
A positive integer that causes the result set that this method repositions to the first row of the database. If the value in the fetchFirst argument is not zero, then it repositions to the first row. If the database does not support repositioning, then it returns a -1 (negative one) error is returned. |
Usage
If you do not include the maxColumns argument or the maxRows argument, then the ODBC Get Query Results method does the following:
To determine the maximum number of columns and rows to get, it uses the size of the array that you specify in the destination argument.
Attempts to return the entire result set.
To get extra rows, you can set the fetchFirst argument to 0 and use the ODBC Get Query Results method again.
Using the ODBC Get Query Results Multiple Times
In some situations, you can use the ODBC Get Query Results method multiple times until the return value is 0. For example, if the result set includes one of the following items:
More rows than the array can contain
More rows than the value specified in the maxRows argument
Example
The following example gets information from a data source:
Dim destination(1 To 50, 1 To 125) As Variant
Dim retcode As long
' open the connection
connection = SQLOpen("DSN = SblTest",outputStr,prompt: = 3)
' Run the query
query = "select * from customer"
retcode = SQLExecQuery(connection,query)
' retrieve the first 50 rows with the first 6 columns of ' each row into the array destination, omit row numbers and ' put column names in the first row of the array
retcode = SQLRetrieve(connection: = connection, _
destination: = destination, columnNames: = 1, _
rowNumbers: = 0, maxRows: = 50, maxColumns: = 6, _
fetchFirst: = 0)
' Get the next 50 rows of from the result set
rowNumbers: = 0, maxRows: = 50, maxColumns: = 6)
' Close the connection
End Sub
ODBC Get Schema Method
The ODBC Get Schema method is a Siebel VB method that returns the following information:
Data sources available
Current user ID
Names of tables names
Types of table columns
Other data source and database information
Format
SQLGetSchema connection, action, qualifier, ref()
connection |
A long integer that the ODBC Open method returns. |
action |
An integer that specifies what information to return. Some database products and some ODBC drivers might not support every action. |
qualifier |
A string. |
ref |
An array of type variant that stores the results. It must be an array even if it includes only one dimension with one element. You must make sure the destination array is properly dimensioned to support the action. If you do not do this, then this method returns an error. |
Values You Can Use In the Action Argument
ODBC Get Schema Method describes the values you can use in the action argument. If the ODBC Get Schema method cannot find the requested information or if the connection is not valid, then it returns a -1 (negative one).
| Value | Description |
1 |
Get a list of available data sources. The dimension of ref() is 1. |
2 |
Get a list of databases on the current connection. Siebel VB does not support this value. |
3 |
Get a list of owners in a database on the current connection. Siebel VB does not support this value. |
4 |
Get a list of tables on the specified connection. It returns every table. You cannot use the qualifier argument with value 4. |
5 |
Get a list of columns in the table that the qualifier argument and the ref argument specifies. This table must include two dimensions. This method returns the column name and the ODBC data type. |
6 |
Get the user ID of the current connection user. |
7 |
Get the name of the current database. |
8 |
Get the name of the data source of the current connection. |
9 |
Get the name of the RDBMS that the data source uses. For example, DB2. |
10 |
Get the server name of the data source. |
11 |
Get the terminology that the data source uses to reference owners. |
12 |
Get the terminology that the data source uses to reference a table. |
13 |
Get the terminology that the data source uses to reference a qualifier. |
14 |
Get the terminology that the data source uses to reference a procedure. |
Example
Sub Button_Click
'Declarations
prompt = 5
'Open the data source "SblTest"
connection = SQLOpen("DSN=SblTest; UID=SADMIN; PWD=SADMIN",
outputStr,prompt:=4)
retcode = SQLGetSchema(connection:= connection,action:= 1,qualifier:=
qualifier, ref:= datasources())
'Close the data source connection
End Sub
ODBC Open Connection Method
The ODBC Open Connection method is a Siebel VB method that establishes a connection to an ODBC data source. It returns a long integer that identifies a unique connection ID that you can use with other ODBC methods. If you include the outputString argument, then it returns the completed connection string in the outputString argument.
If it cannot establish a connection, then it returns an ODBC error with a negative numeric value. You can test for this value. For more information, see ODBC Get Errors Method.
Format
SQLOpen(connectString, [outputString][, prompt])
connectString |
A string or string variable that includes the following information:
The connectString argument typically uses the following format: “DSN=dataSourceName;UID=loginID;PWD=password" However, it must use the format that the ODBC driver requires. Some parts of this string might not be required. For more information on the string you use to access a Siebel application, see Siebel Technical Note #206 on My Oracle Support. |
outputString |
A string variable that holds the completed connection string. |
prompt |
One of the following integers that specifies when to display the driver dialog box:
If you do not include the prompt argument, then Siebel VB uses value 2. |
Example
Sub Button_Click
Dim action As Integer
Dim qualifier As String
prompt = 4
Set ret = TheApplication.NewPropertySet()
' Open the datasource "SblTest" with a user name of sa, _
password of sa
connection = _
SQLOpen("DSN=SblTest;UID=sa;PWD=sa",outputStr,prompt:=4)
action = 1 ' Get the names of the ODBC data sources
retcode = SQLGetSchema(connection:=connection, _
action:=1, _
qualifier:=qualifier, _
ref:=datasources())
’ Close the data source connection
End Sub
ODBC Run Query Method
The ODBC Run Query method is a Siebel VB method that runs an SQL statement on a connection that the ODBC Open method establishes. It returns the number of columns in the result set for SQL SELECT statements as a variant. The value that it returns depends which of the following statements you use:
You use the SELECT statement with UPDATE, INSERT, or DELETE. It returns the number of rows that the statement affected.
You use any other SQL statement. It returns 0.
If it cannot run the query on the data source, or if the connection is not valid, then it returns a negative error code.
If there are any pending results on the connection, then it replaces the pending results with the new results.
Format
SQLExecQuery(connection, query)
connection |
query |
A string that contains a valid SQL statement. |
Example
The following example performs a query on the data source:
Sub Button_Click
' Declarations
Dim retcode As long
' Run the query query = "select * from customer" retcode = SQLExecQuery(connection,query) ' retrieve the first 50 rows with the first 6 columns of ' each row into the array destination, omit row numbers and ' put column names in the first row of the array
destination: = destination, columnNames: = 1,rowNumbers: _
= 0,maxRows: = 50, maxColumns: = 6,fetchFirst: = 0)
= 0,maxRows: = 50, maxColumns: = 6)
End Sub
ODBC Run Query and Get Results Method
The ODBC Run Query And Get Results method is a Siebel VB method that opens a connection to a data source, runs an SQL statement, returns the result, and then closes the connection. It returns a variant that includes one of the following values:
Positive number. The request is successful. The number identifies the number of results that this method returned or the number of rows affected. Other SQL statements return 0.
Negative error code. An error occurred. It cannot complete the connection, the query is not valid, or another error condition occurred.
Format
SQLRequest(connectString, query, outputString[, prompt][, columnNames], ref())
connectString |
A string or string variable that specifies the data source. For more information on the connect string, see ODBC Open Connection Method. |
query |
An SQL query statement that this method runs. |
outputString |
prompt |
An integer that specifies when to display the driver dialog box. For more information about using the prompt argument, see ODBC Open Connection Method. |
columnNames |
An integer. If columnNames is not zero, then it returns column names in the first row of the array that the ref argument identifies. If you do not include the columnNames argument, then the default value is 0. |
ref |
An array of type variant that holds the results of the action you request. It must be an array even if it includes only one dimension with one element. |
Example
The following example uses the ODBC Run Query And Get Results method:
Function WebApplet_PreInvokeMethod (MethodName As String) As Integer If MethodName = "queryExtSys" Then
' The following opens the datasource SVBTESTW and
' runs the query specified by query and returns the
' results in destination.
Dim errors(1 To 10, 1 To 3) As Variant
Dim retCode As Integer
' In the event of a connection error, do not display a
' dialog box, return an error
prompt = 4
' SQL Statement to submit. In this example we'll perform a
' simple select
query = "SELECT * FROM authors"
' Invoke the SQLRequest function to submit the SQL, run the
' query and return a result set.
retCode = SQLRequest("DSN=SVBTESTW;UID=sa;PWD=sa", _
query, outputStr, prompt, 0, destination())
' If retCode < 0, an error has occurred. Retrieve the first
’ error returned in the array and display to the user.
If retCode < 0 Then
SQLError destination := errors
errCounter = 1
While errors(errCounter,1) <> 0
TheApplication.RaiseErrorText "Error " & _
" ODBC error: " & destination(errCounter,1) & _
" Numeric code = " & destination(errCounter,2) & _
" Error Text = " & destination(errCounter,3)
Wend
Else
' do some processing of the results
End If
WebApplet_PreInvokeMethod = CancelOperation
Else
WebApplet_PreInvokeMethod = ContinueOperation
End If
End Function
ODBC Save Results to File Method
This Siebel VB method gets the results of a query and stores them in a file. It returns one of the following values:
Successful. It returns a variant that contains the number of rows that exist in the result set.
Not successful. It returns -1 (negative one).
The arguments must be named arguments. For information about named arguments, see Comments and Call Subroutine Method.
Format
SQLRetrieveToFile(connection, destination[, columnNames][, columnDelimiter])
connection |
destination |
A string or string variable that contains the file name and path to this file. This method stores the results in this file. |
columnNames |
This argument can include one of the following values:
The default value is 0. |
columnDelimiter |
The string this method uses to separate each field in a row. If you do not include the columnDelimiter argument, then it uses a tab character to separate each field. |
Example
The following example opens a connection to a data source and saves information to a file:
Sub Button_Click 'Declarations
Dim connection As Long Dim destination(1 To 50, 1 To 125) As Variant Dim retcode As long
'open the connection
' Run the query
query = "select * from customer" retcode = SQLExecQuery(connection,query) 'Place the results of the previous query in the file 'named by filename and put the column names in the file 'as the first row. 'The field delimiter is %
filename = "c:\myfile.txt"
columnDelimiter = "%"
retcode = SQLRetrieveToFile(connection: = connection, _
destination: = filename, columnNames: = 1, _
columnDelimiter: = columnDelimiter)
End Sub
Object Querying Methods
This topic describes object querying methods. It includes the following topics:
Compare Object Expressions Operator
The Compare Object Expressions operator compares two object expressions. It returns one of the following values:
-1 (negative one). The object expressions reference the same object.
0 (zero). The object expressions do not reference the same object.
You can use this method to determine if an object variable is set to Nothing. For more information, see Remove Object Method.
Format
objectExpression Is objectExpression
objectExpression |
Any valid object expression. |
Example
For examples of using the Compare Object Expressions operator, see Date and Time Methods and Get COM Object Method.
Is Expression a Date Method
The Is Expression a Date method determines if an expression evaluates to a date that Siebel VB allows. It returns one of the following values:
-1 (negative one). The expression is a date variable type or a string that Siebel VB can interpret as a date.
0 (zero). The expression is not a date variable type or a string that Siebel VB can interpret as a date.
Format
IsDate(expression)
expression |
Any valid expression. |
Example
The following example adds a number to the current date value and determines if it is still a valid date. In this example, a valid date is in the range of January 1, 100, through December 31, 9999:
Sub Button_Click
Dim curdatevalue
Dim yrs
Dim msgtext
curdatevalue = DateValue(Date$)
yrs = 20
yrs = yrs * 365
curdatevalue = curdatevalue + yrs
If IsDate(curdatevalue) = -1 then
msgtext = Format(CVDate(curdatevalue))
Else
"The date is not valid."
End If
End Sub
Is Object Of Class Method
The Is Object Of Class method determines if an object is of a given class. It returns one of the following values:
-1 (negative one). The object is of the type that the className argument specifies.
0 (zero). The object is not of the type that the className argument specifies.
You can use this method only in an If statement.
Format
If Typeof objectVariable Is className Then...
You must use this format. You cannot combine this method with a Boolean operator.
objectVariable |
The object to be examined. |
className |
The class that Siebel CRM uses to compare the object. |
You use the following format to determine if an object does not belong to a class:
If Typeof objectVariable Is className Then [Perform some action.] Else [Perform some action.] End If
Is Optional Argument Missing Method
The Is Optional Argument Missing method determines if an optional argument for a procedure is missing. It returns one of the following values:
-1 (negative one). An optional argument is missing.
0 (zero). An optional argument is not missing.
Format
IsMissing(argname)
argname |
An optional argument for a subroutine, function, Siebel VB statement, or Siebel VB method. |
Example
The following example prints a list of uppercase characters. The user determines the quantity printed. If the user must print every character, then this example calls the myfunc function without any argument. The function uses the Is Optional Argument Missing method to determine to print every uppercase character or to print only the quantity that the user specifies:
Function myfunc(Optional arg1)
If IsMissing(arg1) = -1 then
arg1 = 26
End If
msgtext = "The letters are: " & Chr$(10)
For x = 1 to arg1
msgtext = msgtext & Chr$(x + 64) & Chr$(10)
Next x
End Function
Sub Button_Click
Dim arg1
arg1 = 0
If arg1 = 0 then
myfunc()
Else
myfunc(arg1)
End If
End Sub
Is Variable Null Method
The Is Variable Null method determines if a variant variable contains a Null value. It returns one of the following values:
-1 (negative one). The expression contains a Null value.
0 (zero). The expression does not contain a Null value.
A null variant does not contain data. It only identifies a result that is not valid or that is ambiguous. Null is not the same as Empty, which indicates that a variant is not yet set.
Format
IsNull(expression)
expression |
Any expression that contains a variable of data type variant. |
Example
The following example asks for ten test score values and calculates the average. If any score is negative, then it sets the value to Null. This example uses the Is Variable Null method to reduce the total count of 10 scores to only the scores that contain a positive value before it calculates the average:
Sub Button_Click
Dim arrayvar(10)
Dim count as Integer
Dim total as Integer
Dim x as Integer
Dim tscore as Single
count = 10
total = 0
For x = 1 to count
tscore = 88
If tscore<0 then
arrayvar(x) = Null
Else
arrayvar(x) = tscore
total = total + arrayvar(x)
End If
Next x
Do While x <> 0
x = x - 1
If IsNull(arrayvar(x)) = -1 then
count = count-1
End If
Loop
msgtext = "The average (excluding negative values) is: "
msgtext = msgtext & Chr(10) & Format(total/count, "##.##")
End Sub
Is Variable Numeric Method
The Is Variable Numeric method determines if the value of a variable is numeric. It returns one of the following values:
-1 (negative one). The expression is a Numeric data type or is a string that Siebel VB can interpret as a number.
0 (zero). The expression is not a Numeric data type or is not a string that Siebel VB can interpret as a number.
If numeric input is required, then you can use the Is Variable Numeric method to determine if the value that the user provides is a valid number before converting the input to a numeric data type.
Format
IsNumeric(expression)
expression |
Related Topics
Is Variable Set Method
The Is Variable Set method determines if a variable of data type variant is set. To indicate that it contains no data, every new variant defaults to an Empty type. This method returns one of the following values:
-1 (negative one). The variant is set.
0 (zero). The variant is not set.
If you use an empty variant in a numeric expression or in a null string ("") in a string expression, then Siebel VB converts this empty variant to zero. For more information, see Variants.
Format
IsEmpty(expression)
| Argument | Description |
expression |
Any expression that identifies a variable of data type variant. |
Example
The following example prompts the user for a series of test scores. It uses the Is Variable Set method to determine if Siebel CRM reached the maximum allowable limit. This method determines when to exit the Do Loop:
Sub Button_Click
Dim arrayvar(10)
Dim x as Integer
x = 1
Do
tscore = 88
x = x + 1
Loop Until IsEmpty(arrayvar(10)) <> -1
total = x-1
msgtext = "You entered: " & Chr(10)
For x = 1 to total
msgtext = msgtext & Chr(10) & arrayvar(x)
Next x
End Sub
Financial Methods
This topic describes financial methods. It includes the following topics:
Overview of Financial Methods
This topic includes an overview of financial methods.
Arguments You Can Use with Financial Methods
The following table describes arguments that you can use with financial methods. The topic for each method lists the arguments you can use with that method.
due |
An integer that specifies when payments are due. You can use one of the following values:
fv |
The future value of one of the following:
guess |
An estimate of the rate returned. This value is typically in the range of 0.1 (10 percent) through 0.15 (15 percent). |
nper |
The total number of payment periods. |
per |
The payment period, in the range of 1 through the value that the nper argument contains. |
period |
The specific payment period, in the range 1 through the value that the nper argument contains. |
pmt |
The constant periodic payment for each period. |
pv |
The present value or the initial lump sum of one of the following:
rate |
The interest rate for each period. For more information, see How Some Financial Methods Use the Rate Argument. |
valuearray |
An array that contains cash flow values. This argument must include at least one each of the following items:
You must represent payments and receipts in the exact sequence that the method must use to calculate them. The value that the method returns varies according to the modification that occurs in the sequence of cash flows. |
Some financial methods assume that the value that the rate argument includes is constant over the life of the annuity.
For example, if payments are on a monthly schedule, and if the annual percentage rate on the annuity or loan is 9%, then the rate is 0.0075 (.0075 equals .09 divided by 12).
Calculate Future Value Method
The Calculate Future Value method calculates, and then returns a number that identifies the future value of an investment, such as an annuity or a loan.
Format
FV(rate, nper, pmt, pv, due)
For more information, see Arguments You Can Use with Financial Methods.
Example
The following example calculates the future value of an annuity, according to terms that the user specifies:
Sub Button_Click Dim aprate, periods Dim payment, annuitypv Dim due, futurevalue Dim msgtext annuitypv = 100000 aprate = 6.75 If aprate >1 then aprate = aprate/100 End If periods = 60 payment = 10000 ' Assume payments are made at end of month due = 0 futurevalue = FV(aprate/12,periods,-payment,-annuitypv,due) msgtext = "The future value is: " & Format(futurevalue, "Currency") End Sub
Calculate Interest Method
The Calculate Interest method calculates, and then returns the interest portion of a payment for a given period of an annuity.
Format
IPmt(rate, period, nper, pv, fv, due)
Example
The following example calculates the interest portion of a loan payment amount for payments made in the last month of the first year. The loan is for $25,000 to be paid back over 5 years at 9.5% interest:
Sub Button_Click Dim aprate, periods Dim payperiod Dim loanpv, due Dim loanfv, intpaid Dim msgtext aprate = .095 payperiod = 12 periods = 120 loanpv = 25000 loanfv = 0 ' Assume payments are made at end of month due = 0 intpaid = IPmt(aprate/12,payperiod,periods, _ loanpv,loanfv,due) msgtext = "For a loan of $25,000 @ 9.5% for 10 years," _ & Chr(10) msgtext = msgtext + "the interest paid in month 12 is: "_ & Format(intpaid, "Currency") End Sub
Calculate Interest Rate Method
The Calculate Interest Rate method calculates, and then returns the interest rate for each period for an annuity or a loan. This method is iterative. It improves a guess over multiple iterations until the result is within 0.00001 percent. If it does not converge to a result in 20 iterations, then it displays a failure message.
Format
Rate(nper, pmt, pv, fv, due, guess)
Example
The following example calculates the interest rate on a 10 year, $25,000 annuity that pays $100 for each month:
Sub Button_Click Dim aprate Dim periods Dim payment, annuitypv Dim annuityfv, due Dim guess Dim msgtext as String periods = 120 payment = 100 annuitypv = 0 annuityfv = 25000 guess = .1 ' Assume payments are made at end of month due = 0 aprate = Rate(periods,-payment,annuitypv,annuityfv, _ due, guess) aprate = (aprate * 12) msgtext = "The percentage rate for a 10-year $25,000 _ annuity" msgtext = msgtext & "that pays $100/month has " msgtext = msgtext & "a rate of: " & Format(aprate, _ "Percent") End Sub
Calculate Internal Rate of Return Method
The Calculate Internal Rate of Return method calculates, and then returns the internal rate of return for a stream of periodic cash flows. This method is iterative. It improves a guess over multiple iterations until the result is within 0.00001 percent. If it does not converge to a result in 20 iterations, then it displays a failure message.
Format
IRR(valuearray( ), guess)
Example
The following example calculates an internal rate of return for a series of income and cost business transactions. It expresses this rate of return as an interest rate percentage. If the first value entered is a positive amount, then the IRR statement creates an Illegal Function Call error:
Sub Button_Click Dim cashflows() as Double Dim guess, count as Integer Dim i as Integer Dim intnl as Single Dim msgtext as String guess = .15 count = 2 ReDim cashflows(count + 1) For i = 0 to count-1 cashflows(i) = 3000 Next i intnl = IRR(cashflows(),guess) msgtext = "The IRR for your cash flow amounts is: " msgtext = msgtext & Format(intnl, "Percent") End Sub
Calculate Net Present Value Method
The Calculate Net Present Value method calculates, and then returns the net present value of an investment according to a stream of periodic cash flows and a constant interest rate. This method does the following:
Returns the net present value in the valuearray argument according to the value that the rate argument contains.
Uses future cash flows as the basis for the net present value calculation. If the first cash flow occurs at the beginning of the first period, then you must add this cash flow value to the result that this method returns. You must not include this value in the valuearray argument.
The value that the rate argument contains is the decimal equivalent of the discount rate. For example, if the discount rate is 12%, then the rate is 0.12.
Format
NPV(rate, valuearray( ))
The rate argument for this method describes the discount rate for each period. For a description of the valuearray argument, see Arguments You Can Use with Financial Methods.
Calculate Payment Method
The Calculate Payment method calculates, and then returns a constant periodic payment amount for an annuity or a loan.
Format
Pmt(rate, nper, pv, fv, due)
Example
The following example calculates the monthly payment for a given loan:
Sub Button_Click Dim aprate, totalpay Dim loanpv, loanfv Dim due, monthlypay Dim yearlypay, msgtext loanpv = 25000 aprate = 7.25 If aprate >1 then aprate = aprate/100 End If totalpay = 60 loanfv = 0 'Assume payments are made at end of month due = 0 monthlypay = Pmt(aprate/12,totalpay,-loanpv,loanfv,due) msgtext = "The monthly payment is: " Format(monthlypay, "Currency") End Sub
Calculate Principal Method
The Calculate Principal method calculates, and then returns the principal portion of the payment for a given period of an annuity.
Format
PPmt(rate, per, nper, pv, fv, due)
Example
The following example calculates the principal portion of a loan payment amount for payments made in the last month of the first year. The loan is for $25,000 to be paid back over 5 years at 9.5% interest:
Sub Button_Click Dim aprate, periods Dim payperiod Dim loanpv, due Dim loanfv, principal Dim msgtext aprate = 9.5/100 payperiod = 12 periods = 120 loanpv = 25000 loanfv = 0 ' Assume payments are made at end of month due = 0 principal = PPmt(aprate/12,payperiod,periods, _ -loanpv,loanfv,due) msgtext = "Given a loan of $25,000 @ 9.5% for 10 years," msgtext = msgtext & Chr(10) & "the principal paid in month 12 is: " End Sub
Calculate Present Value Method
The Calculate Present Value method calculates, and then returns the present value of a constant periodic stream of cash flows as in an annuity or a loan.
Format
PV(rate, nper, pmt, fv, due)
Example
The following example calculates the present value of a 10 year, $25,000 annuity that pays $1,000 for each year at 9.5%:
Sub Button_Click Dim aprate As Integer, periods As Integer Dim payment As Double, annuityfv As Double Dim due As Integer, presentvalue As Double Dim msgtext aprate = 9.5 periods = 120 payment = 1000 annuityfv = 25000 ' Assume payments are made at end of month due = 0 presentvalue = PV(aprate/12,periods,-payment, annuityfv,due) msgtext = "The present value for a 10-year $25,000 annuity @ 9.5%" msgtext = msgtext & " with a periodic payment of $1,000 is: " msgtext = msgtext & Format(presentvalue, "Currency") End Sub
Conversion Methods
This topic describes conversion methods. It includes the following topics:
Argument That You Can Use with Conversion Methods
The following table describes the arguments that you can use with conversion methods.
expression |
Any expression that evaluates to a number. |
Convert Expression to Currency Method
The Convert Expression to Currency method converts the value that the expression argument contains to a currency. It returns this currency. Note the following:
A number that does not fit in the currency data type causes an Overflow error.
A string that cannot convert to a currency causes a Type Mismatch error.
A variant that contains a null result causes an Illegal Use of Null error.
For more information, see Overview of Data Types.
Format
CCur(expression)
For information about the arguments that you can use with this method, see Argument That You Can Use with Conversion Methods.
Example
The following example converts a yearly payment on a loan to a currency value with four decimal places. A subsequent Format statement formats the value to two decimal places before displaying it in a message box:
Sub Button_Click Dim aprate, totalpay, loanpv Dim loanfv, due, monthlypay Dim yearlypay, msgtext loanpv = 5000 aprate = 6.9 If aprate >1 then aprate = aprate/100 End If aprate = aprate/12 totalpay = 360 loanfv = 0 Rem Assume payments are made at end of month due = 0 monthlypay = Pmt(aprate,totalpay,-loanpv,loanfv,due) yearlypay = CCur(monthlypay * 12) msgtext = "The yearly payment is: " _ ;Format(yearlypay, "Currency") End Sub
Convert Expression to Double-Precision Method
The Convert Expression to Double-Precision method converts the value that the expression argument contains to a double-precision number. It returns this number. Note the following:
A string that cannot convert to a double-precision floating point number causes a Type Mismatch error.
For more information, see Numeric Data Types That Siebel VB Uses.
Format
CDbl(expression)
Example
The following example calculates the square root of 2 as a double-precision, floating-point value and displays it in scientific notation:
Sub Button_Click Dim value Dim msgtext value = CDbl(Sqr(2)) msgtext = "The square root of 2 is: " & Value End Sub
Convert Expression to Integer Method
The Convert Expression to Integer method converts the value that the expression argument contains to an integer and rounds the result. It returns this result. Note the following:
After rounding, the result must reside in the range of negative 32767 to 32767. If it is not, then an error occurs.
A string that cannot convert to an integer causes a Type Mismatch error.
Format
CInt(expression)
Example
The following example calculates the average of ten golf scores:
Sub Button_Click Dim score As Integer Dim x, sum Dim msgtext Let sum = 0 For x = 1 to 10 score = 7- sum = sum + score Next x msgtext = "Your average is: " & _ Format(CInt(sum/ (x - 1)), "General Number") End Sub
Convert Expression to Long Method
The Convert Expression to Long method converts the value that the expression argument contains to a long number. It returns this number. Note the following:
A string that cannot convert to a long number causes a Type Mismatch error.
Format
CLng(expression)
Example
The following example divides the national debt of the United States by the number of people who live in this country to find the amount of money each person must pay to retire this debt. It converts this number to a long integer, and then formats it as currency:
Sub Button_Click Dim debt As Single Dim msgtext Const Populace = 311000000 debt = 14000000000000 msgtext = "The $/citizen is: " & _ Format(CLng(Debt/ Populace), "Currency") End Sub
Convert Expression to Single-Precision Method
The Convert Expression to Single-Precision method converts the value that the expression argument contains to a single-precision, floating-point number. It returns this number. Note the following:
After rounding, the result must reside in the range that the single-precision data type allows. If it is not, then an error occurs.
A string that cannot convert to a single-precision number causes a Type Mismatch error.
Format
CSng(expression)
Example
The following example calculates the factorial of a number. For more information, see Exponential Method:
Sub Button_Click Dim number as Integer Dim factorial as Double Dim msgtext As String number = 25 If number <= 0 then Exit Sub End If
factorial = 1 For x = number to 2 step -1 factorial = factorial * x Next x 'If number <= 35, then its factorial is small enough to ' be stored as a single-precision number If number< 35 then factorial = CSng(factorial) End If msgtext = "The factorial of " & number & " is " & factorial End Sub
Convert Expression to String Method
The Convert Expression to String method converts an expression to a string. It returns one of the values described in the following table depending on the data type of the expression.
| Data Type of Expression | Return Value |
Date |
A string that contains a date. |
Empty |
A zero-length string (""). |
Error |
A string that contains the following information: Error error number |
Null |
A run-time error. |
Other Numeric |
A string that contains the number. |
Format
CStr(expression)
Example
The following example uses the Convert Expression to String method to operate on a string that the user enters as a number:
Sub Button_Click Dim var1, msgtext as String, code as Integer var1 = 77
msgtext = Cstr(var1) msgtext = Left(var1,1) code = Asc(msgtext)
msgtext = "The first digit you entered was," & msgtext msgtext = msgtext & ". Its ANSI code is " & code & "." End Sub
Convert Expression to Variant Method
The Convert Expression to Variant method converts an expression to a variant. It returns this variant. It accepts any type of expression. It creates the same result that assigning the expression to a variant variable creates.
Format
CVar(expression)
Example
The following example converts a single variable to a variant variable:
Sub Button_Click Dim singleAnswer as Single Dim variantAnswer as Variant singleAnswer = 100.5 variantAnswer = CVar(singleAnswer ) end Sub
COM Methods
This topic describes COM methods. It includes the following topics:
Assign COM Object Statement
The Assign COM Object statement assigns a COM object, such as an application, to a variable. In Siebel Tools, you can use it to create an instance of a Siebel object. It does not return a value. The Assign COM Object statement differs from the Let statement. The Let statement assigns an expression to a Siebel VB variable. For example:
Set o1 = o2. Sets the object reference.
Let o1 = o2 . Sets the value of the default member.
Format
Set variableName = objectExpression
variableName |
An object variable or variant variable. |
objectExpression |
An expression that evaluates to an object. This object is typically one of the following items:
Including the Set Keyword When You Assign an Object Variable
If you do not include the Set keyword when you assign an object variable, then Siebel VB attempts to copy the default member of one object to the default member of another object. This situation typically results in the following run-time error:
' Incorrect code - tries to copy default member!
COMObject = GetObject("","spoly.cpoly")
The following example uses the Assign COM Object statement:
Dim COMObject As Object
Set COMObject = CreateObject("spoly.cpoly")
COMObject.reset
The following example creates an Opportunity business component outside the context of the user interface. The code prevents the user from deleting an account if there are opportunities associated with it. For more information about the Siebel VB methods and objects that this example uses, see Siebel Object Interfaces Reference:
Function BusComp_PreDeleteRecord As Integer
Dim iReturn as integer
Dim oBC as BusComp
Dim oBO as BusObject
Dim sAcctRowId as string
iReturn = ContinueOperation
sAcctRowId = me.GetFieldValue("Id")
set oBO = theApplication.GetBusObject("Opportunity")
set oBC = oBO.GetBusComp("Opportunity")
With oBC
.SetViewMode AllView
.ActivateField "Account Id"
.ClearToQuery
.SetSearchSpec "Account Id", sAcctRowId
.ExecuteQuery ForwardOnly
if (.FirstRecord) = 1 then
‘Opportunities exist for the Account - Delete is not allowed
iReturn = CancelOperation
end if
End With
BusComp_PreDeleteRecord = iReturn
Set oBC = Nothing
Set oBO = Nothing
End Function
COM Object Class
The COM Object class provides access to a COM object. It does not return a value. To create a new object, you use the Dim statement to dimension a variable, and then set the variable to the return value of CreateObject or GetObject. For example:
Dim COM As Object
Set COM = CreateObject("spoly.cpoly")
You can use one of the following formats to reference a method or property of the new object:
objectvar.property objectvar.method
For example:
COM.reset
Format
Dim variableName As Object
variableName |
The name of the object variable to declare. |
Example
The following example uses the BusComp object class to declare the variables that Siebel VB uses to access the Account Contacts view in a Siebel application:
Sub Button1_Click Dim i as integer Dim icount as integer Dim oBC as BusComp
' BusObject returns the business object associated with a ' control or applet. ' GetBusComp returns a reference to a Siebel ' business component that is in the UI context
set oBC = me.BusObject.GetBusComp("Contact")
i = oBC.FirstRecord ' returns 0 if fails, 1 if succeeds
if i <> 1 then
TheRaiseErrorText "Error accessing contact records for the account."
else
icount = 0
' NextRecord returns 1 if it successfully
' moved to the next record in the BC
While i = 1
icount = icount + 1
i = oBC.NextRecord ' returns 1 if successful
wend
oBC.FirstRecord
end if
End Sub
Create COM Object Method
The Create COM Object method creates a new COM object. It does not return a value.
Format
CreateObject(application.objectname)
The following table describes the arguments that you can use with this method.
application |
The name of the application. |
objectname |
The name of the object that this method uses. |
Usage
To create an object, you use the Dim statement to declare an object variable, and then set the variable equal to the new object. For example:
Dim excelObj As Object
Set excelObj = CreateObject("Excel.Application")
You can use one of the following formats to reference a method or property of the object:
For example:
Dim cellVal as String cellVal = excelObj.ActiveSheet.Cells(1,1).Value
You cannot display a modal or nonmodal form from a server application. A DLL that this method instantiates must be thread-safe.
To identify correct application and object names, see the documentation for your Web Client Automation Server application.
If a method passes the wrong number, order, or type of arguments to a COM object when it calls a COM object, then a 440 error message might occur.
Example 1
The following example uses the Create COM Object method to create a Microsoft Excel worksheet. It then edits and saves this worksheet:
Sub BtnExcel_Click
Dim oWorkSheet As Object
Dim sfileName As String
Set oWorkSheet = CreateObject("Excel.Sheet")
If oWorkSheet Is Nothing then
Exit Sub
End If
' Make Excel visible through the Application object. oWorkSheet.Application.Visible = 1 ' Place some text in the first cell of the sheet oWorkSheet.ActiveSheet.Cells(1,1).Value = "Column A, Row 1" ' Save the sheet sfileName = "C:\demo.xls" oWorkSheet.SaveAs (fileName) ' Close Excel with the Quit method on the Application object oWorkSheet.Application.Quit ' Clear the object from memory Set oWorkSheet = Nothing End Sub
The following example uses the Create COM Object method to create a Microsoft Word document. It then edits and saves this document:
Sub BtnWrd_Click
Dim oWord As Object
Dim fileName As String
fileName = "C:\demo.doc"
Set oWord = CreateObject("Word.Application")
' Create a new document
oWord.Documents.Add
If oWord Is Nothing then
Exit Sub
End If
' Make Word visible through the Application object
oWord.Application.Visible = 1
' Add some text
oWord.Selection.TypeText "This is a demo."
' Save the document
oWord.ActiveDocument.SaveAs (fileName)
' Close Word with the Quit method on the Application object
oWord.Quit
Set oWord = Nothing
End Sub
The Get COM Object method returns the COM object that the pathname argument or the class argument identifies. To assign a variable to an object for use in a Visual Basic procedure, you dimension a variable as an object, and then use the Get COM Object method with the Assign COM Object statement.
The examples in this topic reference the SiebelAppServer object, which you define as an object type in your external Visual Basic environment.
Format A
GetObject(pathname)
GetObject(pathname, class)
GetObject(, class)
pathname |
The full path and file name for the object to get. |
class |
A string that contains the class of the object. |
Usage for Format A
You can use format A to access a COM object that is stored in a file. For example, the following code dimensions a variable as an object and assigns the payables.xls object to this variable. The Payables.xls file is located in the My Documents directory:
Dim oFileObject As Object
Set oFileObject = GetObject("C:\My Documents\payables.xls")
If the Siebel application supports accessing component objects in the file, then you can append an exclamation point and a component object name to the file name. For example:
Dim oComponentObject As Object
Set oComponentObject = _
GetObject("C:\My Documents\payables.xls!R1C1: R13C9")
You can use format B to access a COM object of a particular class that is stored in a file. The class argument uses the following format:
appName.objectType
where:
appName is the name of the application that provides the object
objectType is the type or class of the object
For example:
Dim oClassObject As Object
Set oClassObject = GetObject("C:\My _
Documents\payables.xls", "Excel.Sheet")
You can use format C to access the active COM object of a particular class. For example:
Dim oApplication As _ SiebelHTMLApplication Set oApplication = _ GetObject(,"SiebelHTML.SiebelHTMLApplication.1")
If you use format C with a null string ("") in the pathname argument, then Siebel VB returns a new object instance of the class that you specify in the class argument. The preceding example gets an open instance of the Siebel application. The following example instantiates the Siebel application in memory, independent of the user interface:
GetObject("","SiebelHTML.SiebelHTMLApplication.1")
The following example opens an Excel worksheet and places the contents of the Name field of the active business component in this worksheet. The worksheet file must already exist:
Sub Button1_Click
Dim ExcelSheet As Object
Set ExcelSheet = GetObject("C:\demo\test.xls")
'Make Excel visible through the Application object. ExcelSheet.Application.Visible = 1
'Place some text in the first cell of the sheet.
ExcelSheet.ActiveSheet.Cells(1, 1).Value = _
theApplication.ActiveBusComp.GetFieldValue("Name")
'Save the sheet.
ExcelSheet.Save
'Close Excel with the Quit method on the Application object.
+ExcelSheet.Application.Quit
End Sub
Initialize COM Object Method
The Initialize COM Object method allocates and initializes a new COM object. It does not return a value.
In the Declare Variable statement, the New argument instructs Siebel VB to allocate and set a new COM object the first time it encounters the object that the objectVar argument identifies. If the code does not reference this object, then it does not allocate a new object.
The Initialize COM Object method does not create a COM object until the first time Siebel eScript uses this object. If Siebel eScript never uses this object, then this method does not create the object. The Create COM Object method creates the object as soon as you call this method. For more information, see Create COM Object Method.
If the objectVar argument contains Nothing, and if you declare an object variable, and if you reference this object again, then New allocates a second object. For more information, see Remove Object Method.
Format
Set objectVar = New className Dim objectVar As New className
objectVar |
The COM object to allocate and initialize. |
className |
The class to assign to the object. |
Error Handling Methods
This topic describes error handling methods. It includes the following topics:
Get Error Code Method
The Get Error Code method returns the error code of the last Visual Basic error handled. You can use the Err statement or the Error statement to set the value for this method.
You cannot use the Get Error Code method to view a Siebel VB error. Instead, you use the appropriate method for the COM or ActiveX Siebel interface that you are using. For more information, see Siebel Object Interfaces Reference.
For more information, see Error Code and Error Text for Siebel VB Errors.
Format
Err
Example
For examples, see Get Error Code Line Method and Get Error Message Method.
The Get Error Code Line method returns a number that identifies the code line where an error occurred. If you use a Resume statement or an On Error statement after you use this method, then this method sets the return value to 0. To maintain the value of the line number, you must assign it to a variable. You can use the Error statement to set this return value.
Format
Erl
Example
The following example uses the Err statement to print the error number and the Erl statement to print the line number if an error occurs during an attempt to open a file. Siebel VB assigns line numbers, starting with 1. In this example the Sub Button_Click statement is line 1:
Sub Button_Click Dim msgtext, userfile On Error GoTo Debugger msgtext = "Enter the filename to use:" userfile = "c:\temp\trace.txt" Open userfile For Input As #1 ' ....etc.... Close #1 done: Exit Sub Debugger: msgtext = "Error number " & Err & " occurred at line: " & Erl Resume done End Sub
The Get Error Message method returns the error message that corresponds to an error code. If it does not find an error message that matches the error code, then it returns a null string (""). For more information, see Error Code and Error Text for Siebel VB Errors.
Format
Error[$] [(errornumber)]
For information about the dollar sign, see Usage of the Dollar Sign.
errornumber |
An integer in the range of 1 through 32,767 that identifies an error code. If you do not include this argument, then Siebel VB returns the error message of the run-time error that occurred most recently. |
Example
The following example uses the Err statement to print the error number and the text of the error. If an error occurs during an attempt to open a file, then it uses the Error$ statement:
Sub Button_Click
' ....etc....
Close #1
done:
Exit Sub
Debugger:
msgtext = "Error " & Err & ": " & Error$
Resume done
End Sub
On Error Method
The On Error method identifies the location of code that handles an error. It does not return a value. You can also use it to disable code that handles the error. If you do not use the On Error method, and if a run-time error occurs, then Siebel VB stops running code.
Format
On Error {GoTo label | Resume Next | GoTo 0}
The following table describes that parts of an On Error statement. You can include only one of these parts.
| Part | Description |
GoTo label |
Identifies the code that handles the error that starts at the label argument. If this label does not reside in the same procedure as the On Error statement, then Siebel VB creates an error message. |
Resume Next |
Identifies the code to run after handling the error. It typically identifies the code that occurs immediately after the statement that caused the error. You can use the Err statement to get the error code of the run-time error at this point in the error handling. |
GoTo 0 |
Disables any error handler that is enabled. |
Usage
Note the following:
If an On Error GoTo label statement references an error handler, then that error handler is enabled.
If an error handler is enabled, and if a run-time error occurs, then Siebel VB gives control to the code that includes this error handler. The error handler remains active from the time the run-time error is handled until code flow encounters a Resume statement in the error handler.
If another error occurs while the error handler is active, then Siebel VB searches for the error handler in the procedure that called the current procedure:
If it find this error handler, then it stops the current procedure and activates the error handler in the calling procedure.
If it does not find this error handler, then it searches for a handler that resides in the procedure that called the calling procedure, and so on.
Because Siebel VB searches in the caller for an error handler, it ignores any On Error statements that exist in the original error handler.
Running an End Sub or End Method statement while an error handler is active creates a No Resume error. You can use the Exit Sub or Exit Method statement to end the error condition and exit the current procedure.
Example
The following example prompts the user for a drive and directory name. It uses the On Error method to handle an entry that is not valid:
Sub Button_Click
Dim userdrive, userdir, msgtext
in1:
userdrive = "c:"
On Error Resume Next
ChDrive userdrive
If Err = 68 then
Goto in1
End If
in2:
On Error Goto Errhdlr1
userdir = "temp"
ChDir userdrive & userdir
userdir
Exit Sub
Errhdlr1:
Select Case Err
Case 75
msgtext = "Path is invalid."
Case 76
msgtext = "Path not found."
Case 70
msgtext = "Permission denied."
Case Else
msgtext = "Error " & Err & ": " & Error$ & "occurred."
End Select
Resume in2
End Sub
Resume Statement
The Resume statement stops the code that handles an error, and then passes control to the statement that immediately follows the statement where the error occurred. It does not return a value.
If you use Resume [0], then control passes to the statement where the error occurred.
The location of the error handler that handles the error determines where code resumes:
If the error is located in the same procedure as the error handler, then code flows to the statement that caused the error.
If the error is not located in the same procedure as the error handler, then code flows to the statement that last called the procedure that contains the error handler.
Format A
Resume Next
Resume label
Resume [0]
label |
The label that identifies the code line to go to after handling an error. |
Set Error Code Method
The Set Error Code method sets a run-time error code. It does not return a value. You can use it to send error information between procedures.
Format
Err = errornumber
errornumber |
An integer in the range of 1 through 32,767 that identifies an error code, or a 0 if no error occurs. |
Example
The following example creates an error code of 10000 and displays an error message if the user does not enter a customer name in reply to a prompt. It uses the Err statement to clear any previous error codes before it runs the loop for the first time. It also clears the error to allow the user to try again:
Sub Button_Click
Dim custname as String
Do
Err = 0
custname = "Acme Inc."
If custname = "" then
Error 10000
Else
Exit Do
End If
Select Case Err
Case 10000
TheApplication.RaiseErrorText "You must enter a customer name."
Case Else
TheApplication.RaiseErrorText "Undetermined error. Try again."
End Select
Loop Until custname <> ""
TheApplication.RaiseErrorText "The name is: " & custname
End Sub
For another example, see the following.
Simulate Error Method
The Simulate Error method simulates the occurrence of an error. Note the following:
If an Error statement runs, and if code to handle the error does not exist, then Siebel VB creates an error message and stops code from running.
If an Error statement specifies an error code that Siebel VB does not use, then it displays the following error message:
User-defined error
Format
Error errornumber
errornumber |
An integer in the range of 1 through 32,767 that identifies an error code. If Siebel VB already uses an error number that the errornumber argument identifies, then the Error statement simulates an occurrence of that error. |
Using a Custom Error Code
A custom error code must use a value that is greater than any value that Siebel VB uses for a predefined error code. To avoid using a predefined error code, it is recommended that the value you use for a custom error code start with 32,767. For subsequent custom error codes, you can work down from 32,767.
Do not use any error code in the range of 4000 through 4999. These are predefined codes for Siebel VB methods. For more information, see Siebel Object Interfaces Reference.
