Specifying Blacklist
The Blacklist contains phone numbers, IP addresses, and hostnames which have been verified in fraudulent activity.
Using the Configuration menu option, you can:
- Enable and disable the Blacklist feature for specific data types.
- Configure the Expiry Timer Value. For more information, see Configuring the Expiry Timer
The Blacklist information provided by Oracle is in the international format. You can append a prefix to international numbers or provide a regular expression to transform the number.
The Global Blacklist is read-only and can be uploaded using the Update menu. You can also add and remove individual entries in the Custom Blacklist area.
