The admusr can use sudo to run syscheck from the command line. This method can be used whether an application is installed or whether the GUI is available.
Log in to the MPS as the admusr:
Login: admusr
Password: <Enter admusr password>
Run syscheck with any command line arguments.
$ sudo syscheck
For help on command syntax, use the -h option.$ syscheck
