Installing the ISR Components
This section describes how to install the
ISR components, including the Index, Dashboard, and RSS.
During the installation process, you will be asked to provide and/or verify the users, passwords, and interfaces you created during the Oracle Linux installation.Installing the ISR Index
This section
ISR Index.
The ISR requires installations of both MySQL Server and the MySQL client application, which are included in the Index RPM. The ISR includes MySQL Enterprise Commercial (Advanced) Edition Version 5.7.11. For more information, see Oracle's MySQL Products page to learn more about the MySQL platform.
During the installation process, you will be asked to provide and/or verify the users, passwords, and interfaces you created during the Oracle Linux installation, including:- OS root passwords of all ISR component hosts
- MySQL root password in the case of an existing MySQL deployment (otherwise the temporary password is replaced during initial configuration)
- An understanding of how to map your four network interfaces to ISR's 'Admin', 'Local', 'VoIP', and 'Data'.
To install the ISR Index:
Installing the ISR RSS
This section
ISR RSS.
During the installation process, you will be asked to provide and/or verify the users, passwords, and interfaces you created during the Oracle Linux installation.To install the ISR RSS:
Installing the ISR Dashboard
This section
ISR Dashboard.
During the installation process, you will be asked to provide and/or verify the users, passwords, and interfaces you created during the Oracle Linux installation.To install the ISR Dashboard:
Configuring Recording Capacity
Recording capacity
is configured via the
ISR Dashboard. Navigate
to
Admin,
Sites,
RSS
to add any RSS hosts, configure their
VoIP IP,
Admin IP, and
Data IP, and set the Recorder capacity in the
Advanced Configurations - Session Capacity field.
The Sessions Capacity value is the number of concurrent sessions allowed for this RSS host. This number must comply with your Oracle contract. For more information regarding your ISR software contract, contact your Oracle representative.
