Index Virtual Machine
Q. What version of MySQL Server is installed with the CIS?
A. The MySQL Server version is MySQL Enterprise Commercial (Advanced) Edition Version 5.7.11.
Q. How do I view the logs in MySQL Server?
A. MySQL Server's log file can be found in the directory /var/lib/mysql.log. The main log file is named <host_name>.err. The error log can be found in the directory /var/lib/mysql/index.err.
If configured to do so, slow query logs can be found in the directory /var/lib/mysql/index-slow.log.
All ISR-related errors are found in the respective component logs.Q. How do I log slow queries in MySQL Server?
A. To start logging slow queries without restarting mysql server, execute the following:
- At MySQL command prompt, enter set global slow_query_log=1.
- Enter set global long_query_time=1 (or whatever you want for query seconds).
- To verify the settings for these commands, use the following show variables: %slow% %length% By default, the slow query logs are stored in the directory /var/lib/mysql/index-slow.log.
Q. How do I find the data files in MySQL Server?
A. Data files for the 'ipcr_db' database are found in the directory /var/lib/mysql/ipcr_db/.
