PreviousNextJavaScript must be enabled to correctly display this content
Configuring your vSphere ESXi Host
After installing your vSphere Client, you must configure the vSphere ESXi host’s network time server. Use the procedures in this section to configure the network time server of your ESXi host.
Assigning Network Time
Server
To assign a network time server:
Open the vSphere
Client and enter your username and password to login.
In the vSphere
Client window, click the
Configuration tab.
In the left column,
under the Software category, click on
Time
Configuration.
In the upper right
corner of the window, click on
Properties. The
following window displays.
Click on
Options. The
In the left column,
click on
NTP
Settnigs.
Click
Add. The following
window displays.
Add each of the
following in the
Address text box,
clicking
OK after each entry:
0.pool.ntp.org
1.pool.ntp.org
2.pool.ntp.org
The entries display in the NTP Servers box.
In the left column,
click on
General. The
Click
Restart.
It
is important that your ISR component hosts are assigned the same timezone,
except the Index host, which must be set to UTC.
You must now configure your local network using the
procedures in Configuring the Local Network.
