Minimum Virtual Machine Resource Configurations
The ISR virtual hosts have the following default VM configurations:
Configuration Type RSS Index Dashboard FACE API
VM Version 8 8 8 8
CPU 4 vCPU 4 vCPU 1 vCPU 1 vCPU
Memory 16GB 8GB 2GB 2GB
Disk Provisioning Type Thin Thin Thin Thin
Disk Provisioned Size 256GB* 256GB* 12GB 12GB
Network Adapter 1 Admin Admin Admin Admin
Network Adapter 2 Local Local Local Local
Network Adapter 3 Voice Voice Voice Voice
Network Adapter 4 Data Data Data Data
WARNING:
The values in the table above reflect the minimum resources required to run the ISR components in a lab/trial environment. For information on your ISR production deployment sizing needs, contact your Oracle representative.
Networking Considerations
The ISR expects four separate network interfaces for the following functions:
Network Expected Use
Admin Management Interface, used for accessing consoles and SNMP traffic
Local (169.254.1.x) Used for internal communications between the various ISR components
Voice SIP and Media traffic
Data Recording Archival and all FACE API traffic
The Interactive Session Recorder Security Guide covers the ISR networking considerations in depth. Oracle recommends reviewing that document before proceeding with the installation.
